    81 Posts 14 Posters 33.8k Views
    • P
      petersen77 @george
      @george Can't finish the job. Btrfs module keeps sending an error when building the modules. The script doesn't finish.
        mainbord @petersen77
        Tyied it
        https://github.com/armbian/build/pull/8275
        from usb and from nand it does not boot.
          Momo 0 @mainbord
          @mainbord same here, sadly Armbian isnt booting or else i would already be using it instead of the supplied distros
            The official default configuration of ARMBIN's loadaddr and optee conflicts and needs to be modified to 0x200000
              @george is this true even for the community made Genbook build?
                mainbord @Momo 0
                I did it
                change address 0x200000
                build
                burn it to emmc
                profit
                Linux coolpi-genbook 6.18.0-edge-rockchip64 #1 SMP PREEMPT Mon Dec 1 01:42:10 MSK 2025 aarch64 aarch64 aarch64 GNU/Linux
                wireless works
                no sound
                No usb-c
                  Momo 0 @mainbord
                  @mainbord too bad about the usbc and the sound, can i ask how you went about it? im not to deep into armbian.
                    TYPEC is only related to DTS, and the main issue with the sound card is Tinymix configuration.
                    M M 3 Replies Last reply Reply Quote 0
                      @georgecould you elaborate on how to build and change the Kernel from the current github repository?
                        git checkout 6.1.75
                        ./build-kernel.sh arm64
                        The deb file will be generated in the higher-level directory of the code and copied to the machine for installation.
                          Armbian use this file from linux kernel
                          https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/rockchip/rk3588-coolpi-cm5-genbook.dts
                          George use this
                          https://github.com/coolpi-george/coolpi-kernel/blob/linux-6.1-stan-rkr5.1/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-notebook-v20.dts
                          I found instruction how to build my own dts
                          https://docs.armbian.com/User-Guide_Armbian_overlays/
                          But i can't build even the linux kernel dts file
                          sudo armbian-add-overlay rk3588-coolpi-cm5-genbook.dts
                            @george on git checkout i get the error pathspec did not match any files known to git
                            compiling leads to error cannot stat arch/arm/amr64/boot/image
                              jask @Momo 0
                              @Momo-0 I just met this problem, and it was caused by previous job not finishing. https://lkml.org/lkml/2024/1/8/549, I met this problem, and swapped argument, then it compiles
                                @george can we please get a precompiled image to install that has exfat and wireguard and filesytem encryption modules built in? is there a reason the provided images dont contain these features?
                                  @george which github repo is that?
                                    nobody here anymore?
                                      mainbord @Momo 0
                                      I compile armbian with mainline kernel linux 7.1.5 full work, patch
                                      coolpi-genbook_7.1.5_full.patch
                                      get source code
                                      https://github.com/armbian/build.git
                                      apply git patch build it and burn it
                                      ./compile.sh build BOARD=coolpi-genbook BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='browsers chat desktop_tools editors email internet multimedia office programming remote_desktop' DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base DOWNLOAD_MIRROR=bfsu EXPERT=yes EXTRAWIFI=no KERNEL_CONFIGURE=no RELEASE=resolute BUILD_IN_DOCKER=yes
                                      You can download it here
                                      https://drive.google.com/file/d/1EkmzfyRZYfToua_4tHBk718ho_2Q-fsU/view?usp=sharing
                                        Momo 0 @mainbord
                                        @mainbord thats really cool, im definetly gonna try this, thanks, is the laptop fully funktional like that? usbs charging and all?
                                          mainbord @Momo 0
                                          I tested sound, microphone, wi-fi, usb-c charging, hdmi, usb mouse and usb ethernet with usb-c, touchpad, LCD, LEDs, turn off functionality, mesa acceleration, 3d aceleration, 4k playback.
                                          Games: 0.A.d., xonotic, Superttux kart, quake, Fheroes and other.
                                          It's all works.
                                          And here is full version with verndor 6.1.115 kernel
                                          https://forum.cool-pi.com/topic/1293/armbian-ubuntu-fully-works-from-source-code
                                          But i think mainline kernel is more interesting;
                                            Momo 0 @mainbord
                                            @mainbord i tested your version with the edge kernel and i found that the laptop doesnt turn off the display when the lid is closed, and after enabling suspend it doesnt seem to work, laptop doesnt come back from sleep, does that track with what youve seen?
                                            • 4 / 5
