    81 Posts 14 Posters 34.3k Views
      mainbord @mainbord
      I boot from ubuntu 24.04 hdmi and usb 2.0 works. Usbc wi-fi and lcd do not work. This image not for laptop. Latest kernel source not for laptop too.
        Use the following command to generate a deb file and then install it.
        ./build-kernel.sh arm64
        M P 2 Replies Last reply Reply Quote 0
          @george said in Cool Pi Cm5-Laptop Linux Quick Start Guide:
          It was hard. Now it works but without wi-fi and sound
          How to install mainline kernel 6.18?
          • P
            petersen77 @george
            @george Can't finish the job. Btrfs module keeps sending an error when building the modules. The script doesn't finish.
              mainbord @petersen77
              Tyied it
              https://github.com/armbian/build/pull/8275
              from usb and from nand it does not boot.
                Momo 0 @mainbord
                @mainbord same here, sadly Armbian isnt booting or else i would already be using it instead of the supplied distros
                  The official default configuration of ARMBIN's loadaddr and optee conflicts and needs to be modified to 0x200000
                    @george is this true even for the community made Genbook build?
                      mainbord @Momo 0
                      I did it
                      change address 0x200000
                      build
                      burn it to emmc
                      profit
                      Linux coolpi-genbook 6.18.0-edge-rockchip64 #1 SMP PREEMPT Mon Dec 1 01:42:10 MSK 2025 aarch64 aarch64 aarch64 GNU/Linux
                      wireless works
                      no sound
                      No usb-c
                        Momo 0 @mainbord
                        @mainbord too bad about the usbc and the sound, can i ask how you went about it? im not to deep into armbian.
                          TYPEC is only related to DTS, and the main issue with the sound card is Tinymix configuration.
                          M M 3 Replies Last reply Reply Quote 0
                            @georgecould you elaborate on how to build and change the Kernel from the current github repository?
                              git checkout 6.1.75
                              The deb file will be generated in the higher-level directory of the code and copied to the machine for installation.
                                Armbian use this file from linux kernel
                                https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/rockchip/rk3588-coolpi-cm5-genbook.dts
                                George use this
                                https://github.com/coolpi-george/coolpi-kernel/blob/linux-6.1-stan-rkr5.1/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-notebook-v20.dts
                                I found instruction how to build my own dts
                                https://docs.armbian.com/User-Guide_Armbian_overlays/
                                But i can't build even the linux kernel dts file
                                sudo armbian-add-overlay rk3588-coolpi-cm5-genbook.dts
                                  @george on git checkout i get the error pathspec did not match any files known to git
                                  compiling leads to error cannot stat arch/arm/amr64/boot/image
                                    jask @Momo 0
                                    @Momo-0 I just met this problem, and it was caused by previous job not finishing. https://lkml.org/lkml/2024/1/8/549, I met this problem, and swapped argument, then it compiles
                                      @george can we please get a precompiled image to install that has exfat and wireguard and filesytem encryption modules built in? is there a reason the provided images dont contain these features?
                                        @george which github repo is that?
                                          nobody here anymore?
                                            mainbord @Momo 0
                                            I compile armbian with mainline kernel linux 7.1.5 full work, patch
                                            coolpi-genbook_7.1.5_full.patch
                                            get source code
                                            https://github.com/armbian/build.git
                                            apply git patch build it and burn it
                                            ./compile.sh build BOARD=coolpi-genbook BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='browsers chat desktop_tools editors email internet multimedia office programming remote_desktop' DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base DOWNLOAD_MIRROR=bfsu EXPERT=yes EXTRAWIFI=no KERNEL_CONFIGURE=no RELEASE=resolute BUILD_IN_DOCKER=yes
                                            You can download it here
                                            https://drive.google.com/file/d/1EkmzfyRZYfToua_4tHBk718ho_2Q-fsU/view?usp=sharing
                                            • 4 / 5
