    81 Posts 14 Posters 33.0k Views
      @george said in Cool Pi Cm5-Laptop Linux Quick Start Guide:
      Use the following command to generate a deb file and then install it.
      It was hard. Now it works but without wi-fi and sound
      How to install mainline kernel 6.18?
      • P
        petersen77 @george
        @george Can't finish the job. Btrfs module keeps sending an error when building the modules. The script doesn't finish.
          mainbord @petersen77
          Tyied it
          https://github.com/armbian/build/pull/8275
          from usb and from nand it does not boot.
            Momo 0 @mainbord
            @mainbord same here, sadly Armbian isnt booting or else i would already be using it instead of the supplied distros
              The official default configuration of ARMBIN's loadaddr and optee conflicts and needs to be modified to 0x200000
                @george is this true even for the community made Genbook build?
                  mainbord @Momo 0
                  I did it
                  change address 0x200000
                  build
                  burn it to emmc
                  profit
                  Linux coolpi-genbook 6.18.0-edge-rockchip64 #1 SMP PREEMPT Mon Dec 1 01:42:10 MSK 2025 aarch64 aarch64 aarch64 GNU/Linux
                  wireless works
                  no sound
                  No usb-c
                    Momo 0 @mainbord
                    @mainbord too bad about the usbc and the sound, can i ask how you went about it? im not to deep into armbian.
                      TYPEC is only related to DTS, and the main issue with the sound card is Tinymix configuration.
                      M M 3 Replies Last reply Reply Quote 0
                        @georgecould you elaborate on how to build and change the Kernel from the current github repository?
                          git checkout 6.1.75
                          ./build-kernel.sh arm64
                          The deb file will be generated in the higher-level directory of the code and copied to the machine for installation.
                            Armbian use this file from linux kernel
                            https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/rockchip/rk3588-coolpi-cm5-genbook.dts
                            George use this
                            https://github.com/coolpi-george/coolpi-kernel/blob/linux-6.1-stan-rkr5.1/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-notebook-v20.dts
                            I found instruction how to build my own dts
                            https://docs.armbian.com/User-Guide_Armbian_overlays/
                            But i can't build even the linux kernel dts file
                            sudo armbian-add-overlay rk3588-coolpi-cm5-genbook.dts
                              @george on git checkout i get the error pathspec did not match any files known to git
                              compiling leads to error cannot stat arch/arm/amr64/boot/image
                                jask @Momo 0
                                @Momo-0 I just met this problem, and it was caused by previous job not finishing. https://lkml.org/lkml/2024/1/8/549, I met this problem, and swapped argument, then it compiles
                                  @george can we please get a precompiled image to install that has exfat and wireguard and filesytem encryption modules built in? is there a reason the provided images dont contain these features?
                                    @george which github repo is that?
                                      nobody here anymore?
                                        mainbord @Momo 0
                                        I compile armbian with mainline kernel linux 7.1.5 full work, patch
                                        coolpi-genbook_7.1.5_full.patch
                                        get source code
                                        https://github.com/armbian/build.git
                                        apply git patch build it and burn it
                                        ./compile.sh build BOARD=coolpi-genbook BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='browsers chat desktop_tools editors email internet multimedia office programming remote_desktop' DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base DOWNLOAD_MIRROR=bfsu EXPERT=yes EXTRAWIFI=no KERNEL_CONFIGURE=no RELEASE=resolute BUILD_IN_DOCKER=yes
                                        You can download it here
                                        https://drive.google.com/file/d/1EkmzfyRZYfToua_4tHBk718ho_2Q-fsU/view?usp=sharing
                                          Momo 0 @mainbord
                                          @mainbord thats really cool, im definetly gonna try this, thanks, is the laptop fully funktional like that? usbs charging and all?
                                            mainbord @Momo 0
                                            I tested sound, microphone, wi-fi, usb-c charging, hdmi, usb mouse and usb ethernet with usb-c, touchpad, LCD, LEDs, turn off functionality, mesa acceleration, 3d aceleration, 4k playback.
                                            Games: 0.A.d., xonotic, Superttux kart, quake, Fheroes and other.
                                            It's all works.
                                            And here is full version with verndor 6.1.115 kernel
                                            https://forum.cool-pi.com/topic/1293/armbian-ubuntu-fully-works-from-source-code
                                            But i think mainline kernel is more interesting;
                                            • 4 / 5
