    81 Posts 14 Posters 32.1k Views
      george @guyii
      @guyii
      Firstly, create a system image to a USB drive or a portable hard drive using the etcher. Then, insert the computer and start it up. The machine will first start from the USB drive. After entering the system, format the EMMC using the following command to enter UMS mode again.
      sudo mkfs.ext4 /dev/mmcblk0
      • M mainbord referenced this topic on
        anernest
        I received the V20 mainboard and installed it. I followed these instructions including pulling, compiling and installing the latest kernel source, and the system boots fine, however it does not recognize the NVMe card.
          anernest @anernest
          @george would you mind taking a look at this issue. I have not been able to find the instructions specific to the V20 board upgrade, so I may have missed something. I've pulled the notebook apart again and reseated the NVMe stick. I installed Ubuntu 24.04, but maybe I should have used 22.04?
            anernest @anernest
            @george Never mind. It just started working. No clue why, but I'll monitor it and let you know if it starts to get flaky.
              berkaroad
              @george 一开始 进入 UMS模式,用另一台电脑用 balenaEtcher 刷最新的Ubuntu镜像,中途另一台电脑故障死机,刷机失败。
              之后coolpi笔记本无法进入UMS模式,用64GB USB2.0的sandisk U盘刷了最新的Ubuntu镜像后,插上coolpi笔记本后开机,能看到Ubuntu启动logo,之后就是一直黑屏状态,也无法用 Ctrl + Alt + F1(到F12) 切换到控制台模式。U盘刷Ubuntu的内核5.10版本的那个,也是最终黑屏状态。这个如何恢复?
              制作启动U盘的,是用linux 的 dd命令写入img镜像文件的
              B 大法师大 2 Replies Last reply Reply Quote 0
                berkaroad @berkaroad
                  大法师 @berkaroad
                  @berkaroad 你把u盘镜像插电脑重新修改下分区label,再将extlinux.conf参数匹配上
                    berkaroad @大法师
                    @大法师 谢谢提醒,搞定了!
                    u盘的两个分区的label都改了下,extlinux下的配置文件改为第二分区的label;修改fstab文件,挂载的boot分区改为按label查找的第一分区的label。
                    • M mtiqbal referenced this topic on
                      rtmtree
                      @george Can the kernel from https://github.com/yanyitech/coolpi-kernel work with Armbian image?
                      I installed Armbian image (from Onedrive) on my Notebook-v20 and got kernel 5.10.
                      So I tried to upgrade the kernel. but there is no dir /boot/firmware to copy to.
                      and when I created /boot/firmware dir and copy /out/ to it.
                      thank in advance.
                        767691701
                        1. cm5-notebook
                        2. cm5-notebook-v20
                          怎么判断笔记本是不是v20啊,
                          百度网盘镜像下载哪个啊
                          i was trying to build the kernel, but after following the instructions i only get a blinking cursor on reboot.
                            Usually caused by incorrect recognition of file system partitions, pay attention to checking the cmdline.
                            • P
                              petersen77
                              Hello everybody,
                              I can't download any images. Do you have any recent links?
                              BR
                              Peter
                                george @petersen77
                                @petersen77
                                • As shown in the figure below, download the system image of Microsoft Cloud Drive
                                P 1 Reply Last reply Reply Quote 0
                                • P
                                  petersen77 @george
                                  Thanks. It seems that in Ubuntu (24.04) there's no exfat support compiled. How to modify the script or the settings to get it compiled?
                                  Thanks in advance
                                  BR
                                  Peter
                                    george @petersen77
                                    @petersen77
                                    Modify the config file as shown in the following figure, then recompile and replace the kernel.
                                    diff --git a/arch/arm64/configs/coolpi_linux_defconfig b/arch/arm64/configs/coolpi_linux_defconfig
                                    index 76e84eb3e9b7..45cd2e0d149b 100755
                                    --- a/arch/arm64/configs/coolpi_linux_defconfig
                                    +++ b/arch/arm64/configs/coolpi_linux_defconfig
                                    @@ -1044,6 +1044,7 @@ CONFIG_ZISOFS=y
                                     CONFIG_VFAT_FS=y
                                     CONFIG_FAT_DEFAULT_CODEPAGE=936
                                     CONFIG_FAT_DEFAULT_IOCHARSET="utf8"
                                    +CONFIG_EXFAT_FS=y
                                     CONFIG_NTFS_FS=y
                                     CONFIG_TMPFS=y
                                     CONFIG_TMPFS_POSIX_ACL=y
                                    P M 3 Replies Last reply Reply Quote 0
                                    • P
                                      petersen77 @george
                                      Nice. Thanks
                                        @george any reason this isn't already built in into the published images?
                                          The mirror in May will include this modification.
                                            @george any chance you could include the wireguard kernel modules too in these images?
                                            • 2 / 5
