      更新了loader
      ab8cd4ce-4cfe-451f-b009-cf76a252110b-lQDPJxeIVzHuKzjNA7zNBPyw9wCLfw9939cEvtjmk0B9AA_1276_956.jpg
      卡在这里不动了 过一会儿就黑屏了
        @jugg extlinux.conf把参数改为ttyS0,115200n8,用串口观察过程
          DDR V1.09 a930779e06 typ 22/11/21-17:50:56
          CH2 RX Vref:29.7%, TX Vref:21.8%,21.8%
          CH3 RX Vref:29.7%, TX Vref:21.8%,21.8%
          INFO:    Preloader serial: 2
          NOTICE:  BL31: v2.3():v2.3-557-g9609b9c19:derrick.huang
          NOTICE:  BL31: Built : 14:29:57, Mar  8 2023
          INFO:    spec: 0x13
          INFO:    ext 32k is not valid
          INFO:    ddr: stride-en 4CH
          INFO:    SPSR = 0x3c9
          COOLPI LOADER BY YANYI(Jun 06 2023)
          FAT: Misaligned buffer address (00000000ebc9e610)
          scanning bus usb@fc880000 for devices...
          CH3 RX Vref:30.7%, TX Vref:22.8%,21.8%
          INFO:    spec: 0x13
          INFO:    SPSR = 0x3c9
          284 bytes read in 35 ms (7.8 KiB/s)
          8913121 bytes read in 886 ms (9.6 MiB/s)
          37706240 bytes read in 3595 ms (10 MiB/s)
          append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n8 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:96:39:8b:af:40:ae
             Loading Ramdisk to eb153000, end eb9d30e1 ... OK
             Loading Device Tree to 00000000eb12d000, end 00000000eb152a0d ... OK
          FAT: Misaligned buffer address (00000000ebcaf6f0)
          [   12.746995] rk-pcie fe190000.pcie: IRQ msi not found
          [   12.747011] rk-pcie fe190000.pcie: Missing *config* reg space
          [   12.747100] rk-pcie fe190000.pcie: Missing *config* reg space
          [   12.747128] rk-pcie fe190000.pcie: invalid resource
          [   12.750030] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
          [   12.751179] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
          [   12.751183] rkvdec2_init:1010: No niu aclk reset resource define
          [   12.751187] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
          [   12.751190] rkvdec2_init:1013: No niu hclk reset resource define
          [   12.751707] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
          [   12.751711] rkvdec2_init:1010: No niu aclk reset resource define
          [   12.751714] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
          [   12.751717] rkvdec2_init:1013: No niu hclk reset resource define
          [   12.753419] mpp_iommu_probe:434: failed to get device node
          [   12.753424] mpp_av1dec av1d-master: failed to attach iommu
          [   12.983271] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any match mode
          [   12.991632] rockchip-drm display-subsystem: failed to show kernel logo
          [   13.109833] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
          [   13.110084] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
          [   13.372226] rk806 spi2.0: no sleep-setting state
          [   13.376844] rk806 spi2.0: no reset-setting pinctrl state
          [   13.382148] rk806 spi2.0: no dvs-setting pinctrl state
          [   13.595213] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
          [   13.602569] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
          [   13.609918] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
          [   13.617266] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
          [   13.624613] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
          [   13.631823] tinker-mcu: send_cmds: send command failed
          [   13.636952] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
          [   14.207396] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
          [   14.226018] : terminal subdev does not exist
          [   14.230290] : terminal subdev does not exist
          [   14.234552] : terminal subdev does not exist
          [   14.238815] : terminal subdev does not exist
          [   14.243078] : get_remote_sensor: video pad[0] is null
          [   14.248121] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
          [   14.255330] : get_remote_sensor: video pad[0] is null
          [   14.260373] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
          [   14.267584] : get_remote_sensor: video pad[0] is null
          [   14.272629] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
          [   14.279839] : get_remote_sensor: video pad[0] is null
          [   14.284881] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
          [   14.293240] rockchip-mipi-csi2: Async registered subdev
          [   14.362227] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
          [   14.373046] debugfs: File 'Capture' in directory 'dapm' already present!
          [   14.395725] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
          [   14.729254] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
          [   14.736468] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
          [   14.743765] debugfs: File 'HPCP L' in directory 'dapm' already present!
          [   14.750365] debugfs: File 'HPCP R' in directory 'dapm' already present!
          [   14.756967] debugfs: File 'HPVOL L' in directory 'dapm' already present!
          [   14.763653] debugfs: File 'HPVOL R' in directory 'dapm' already present!
          [   14.771803] ov5648 8-0036: could not get default pinstate
          [   14.777196] ov5648 8-0036: could not get sleep pinstate
          [   14.785078] ov5648 8-0036: Unexpected sensor id(000000), ret(-5)
          [   14.792138] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
          [   14.801266] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
          [   14.810380] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
          [   14.818204] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
          [   14.818440] rockchip_headset rk-headset: Can not read property headset_gpio
          [   14.827318] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
          [   14.843348] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
          [   14.851869] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
          [   14.860378] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
          [   14.872438] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
          [   14.902618] RKNPU fdab0000.npu: failed to find power_model node
          [   14.908529] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
          [   14.908530] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
          AT2Y1B
          wait for external disk device.
          Generic
          20+0 records in
          20+0 records out
          20971520 bytes (21 MB, 20 MiB) copied, 0.188153 s, 111 MB/s
          won't be recoverable.
             (e.g., DOS FDISK, OS/2 FDISK)
             p   primary partition (1-4)
             e   extended
             e   extended
          mkfs.fat 4.2 (2021-01-31)
          total 205M
          mke2fs 1.46.5 (30-Dec-2021)
          Discarding device blocks: [   41.269135] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
          [   41.276429] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
          [   42.604779] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
          [   42.612045] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
          Filesystem UUID: eb878b89-7651-4f9c-8eb8-e6e819f2f447
          	4096000
          Allocating group tables: done
          Writing inode tables: done
          e2fsck 1.46.5 (30-Dec-2021)
            @jugg 把备份的镜像文件压缩包发给我试试
              是不是跟要刷机的板子的原来的系统有关 而不是备份的镜像
              这是安装盘的压缩包 install里面就是备份盘备份出来的镜像 还原不了到另外一块板子里面
              链接:https://pan.baidu.com/s/1qw-WQMRiGHzMaGcCRLAtMA?pwd=6qap
              提取码:6qap
                怎么样?
                  正常安装
                  [   11.122038] rk-pcie fe190000.pcie: IRQ msi not found
                  [   11.122053] rk-pcie fe190000.pcie: Missing *config* reg space
                  [   11.122142] rk-pcie fe190000.pcie: Missing *config* reg space
                  [   11.122169] rk-pcie fe190000.pcie: invalid resource
                  [   11.125068] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                  [   11.126208] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                  [   11.126214] rkvdec2_init:1010: No niu aclk reset resource define
                  [   11.126218] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                  [   11.126220] rkvdec2_init:1013: No niu hclk reset resource define
                  [   11.126737] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                  [   11.126740] rkvdec2_init:1010: No niu aclk reset resource define
                  [   11.126744] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                  [   11.126747] rkvdec2_init:1013: No niu hclk reset resource define
                  [   11.128444] mpp_iommu_probe:434: failed to get device node
                  [   11.128448] mpp_av1dec av1d-master: failed to attach iommu
                  [   11.666758] rk806 spi2.0: no sleep-setting state
                  [   11.671377] rk806 spi2.0: no reset-setting pinctrl state
                  [   11.676680] rk806 spi2.0: no dvs-setting pinctrl state
                  [   11.889706] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                  [   11.897062] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                  [   11.904409] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                  [   11.911758] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                  [   11.919105] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                  [   11.926316] tinker-mcu: send_cmds: send command failed
                  [   11.931446] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
                  [   12.501950] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
                  [   12.520585] : terminal subdev does not exist
                  [   12.524858] : terminal subdev does not exist
                  [   12.529120] : terminal subdev does not exist
                  [   12.533383] : terminal subdev does not exist
                  [   12.537647] : get_remote_sensor: video pad[0] is null
                  [   12.542691] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                  [   12.549901] : get_remote_sensor: video pad[0] is null
                  [   12.554943] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                  [   12.562160] : get_remote_sensor: video pad[0] is null
                  [   12.567204] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                  [   12.574416] : get_remote_sensor: video pad[0] is null
                  [   12.579458] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                  [   12.587879] rockchip-mipi-csi2: Async registered subdev
                  [   12.657092] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                  [   12.667892] debugfs: File 'Capture' in directory 'dapm' already present!
                  [   12.690795] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                  [   13.023688] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                  [   13.030902] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                  [   13.038198] debugfs: File 'HPCP L' in directory 'dapm' already present!
                  [   13.044797] debugfs: File 'HPCP R' in directory 'dapm' already present!
                  [   13.051402] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                  [   13.058088] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                  [   13.066273] ov5648 8-0036: could not get default pinstate
                  [   13.071667] ov5648 8-0036: could not get sleep pinstate
                  [   13.079716] ov5648 8-0036: Unexpected sensor id(000000), ret(-5)
                  [   13.086769] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                  [   13.095900] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                  [   13.105015] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                  [   13.112896] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                  [   13.113084] rockchip_headset rk-headset: Can not read property headset_gpio
                  [   13.122014] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                  [   13.137989] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                  [   13.146511] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                  [   13.155020] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                  [   13.167187] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                  [   13.198264] RKNPU fdab0000.npu: failed to find power_model node
                  [   13.204174] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                  [   13.210775] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                  AT2Y1B
                  Kingston
                  20+0 records in
                  20+0 records out
                  20971520 bytes (21 MB, 20 MiB) copied, 0.186213 s, 113 MB/s
                     e   extended
                     e   extended
                  total 205M
                  Filesystem UUID: e42c8656-d1a3-40b1-85a8-2ddce3913d78
                          4096000
                   1.6GiB 0:00:54 [29.8MiB/s] [================================> ] 99%
                  Complete install... please remove udisk for next booting
                  auto poweroff system later when you plugout udisk...
                  udisk have been removed.Now poweroff system...
                  [  136.856307] reboot: Power down
                    要换U盘?
                      我也是这样刷的
                      安装盘里面就只有压缩包里面的内容
                      怎么就不行呢
                      u盘也识别到了啊
                        @jugg 你的u盘感觉质量如何
                          我觉得质量没问题
                            你可以多刷几次 是不是每次都能刷成功
                              系统刷不了 就没法批量了
                                @jugg 有没有试过品牌U盘。这个方法我一直在用
                                  你可以多刷几次 是不是每次都能刷成功
                                  刷机方法没有问题,试了多次都能刷成功。
                                    换了个金士顿的U盘作为安装盘 加载完logo就重启 反复重启
                                    我已经没办法了
                                      到底是接U3的上面口还是下面口
                                      为什么我接U3上面口 没反应 接下面口才有反应
                                        这是换了金士顿U盘的
                                        还是卡在那里
                                        VP0 set crtc_clock to 1485KHz
                                        scanning bus usb@fc000000 for devices... cannot reset port 1!?
                                        Device 0: Vendor: Kingston Rev: PMAP Prod: DataTraveler 3.0
                                                    Capacity: 29592.0 MB = 28.8 GB (60604416 x 512)
                                        284 bytes read in 33 ms (7.8 KiB/s)
                                        8913121 bytes read in 422 ms (20.1 MiB/s)
                                        37706240 bytes read in 1697 ms (21.2 MiB/s)
                                        append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n8 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:7a:46:da:5f:3e:bd
                                        141838 bytes read in 38 ms (3.6 MiB/s)
                                        [   10.801747] rk-pcie fe190000.pcie: IRQ msi not found
                                        [   10.801763] rk-pcie fe190000.pcie: Missing *config* reg space
                                        [   10.801855] rk-pcie fe190000.pcie: Missing *config* reg space
                                        [   10.801883] rk-pcie fe190000.pcie: invalid resource
                                        [   10.804829] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                                        [   10.805992] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                                        [   10.805997] rkvdec2_init:1010: No niu aclk reset resource define
                                        [   10.806001] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                                        [   10.806004] rkvdec2_init:1013: No niu hclk reset resource define
                                        [   10.806530] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                                        [   10.806533] rkvdec2_init:1010: No niu aclk reset resource define
                                        [   10.806537] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                                        [   10.806539] rkvdec2_init:1013: No niu hclk reset resource define
                                        [   10.808288] mpp_iommu_probe:434: failed to get device node
                                        [   10.808293] mpp_av1dec av1d-master: failed to attach iommu
                                        [   11.341426] rk806 spi2.0: no sleep-setting state
                                        [   11.346050] rk806 spi2.0: no reset-setting pinctrl state
                                        [   11.351356] rk806 spi2.0: no dvs-setting pinctrl state
                                        [   11.567895] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                                        [   11.575253] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                                        [   11.582602] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                                        [   11.589953] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                                        [   11.597302] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                                        [   11.604512] tinker-mcu: send_cmds: send command failed
                                        [   11.609641] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
                                        [   12.179893] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
                                        [   12.198621] : terminal subdev does not exist
                                        [   12.202893] : terminal subdev does not exist
                                        [   12.207155] : terminal subdev does not exist
                                        [   12.211418] : terminal subdev does not exist
                                        [   12.215681] : get_remote_sensor: video pad[0] is null
                                        [   12.220725] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                                        [   12.227935] : get_remote_sensor: video pad[0] is null
                                        [   12.232977] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                                        [   12.240190] : get_remote_sensor: video pad[0] is null
                                        [   12.245236] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                                        [   12.252446] : get_remote_sensor: video pad[0] is null
                                        [   12.257489] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                                        [   12.265952] rockchip-mipi-csi2: Async registered subdev
                                        [   12.335257] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                                        [   12.346141] debugfs: File 'Capture' in directory 'dapm' already present!
                                        [   12.368803] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                                        [   12.705027] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                                        [   12.712240] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                                        [   12.719536] debugfs: File 'HPCP L' in directory 'dapm' already present!
                                        [   12.726135] debugfs: File 'HPCP R' in directory 'dapm' already present!
                                        [   12.732737] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                                        [   12.739423] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                                        [   12.747604] ov5648 8-0036: could not get default pinstate
                                        [   12.752995] ov5648 8-0036: could not get sleep pinstate
                                        [   12.761463] ov5648 8-0036: Unexpected sensor id(000000), ret(0)
                                        [   12.768370] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                                        [   12.777492] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                                        [   12.786609] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                                        [   12.794481] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                                        [   12.794638] rockchip_headset rk-headset: Can not read property headset_gpio
                                        [   12.803602] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                                        [   12.819574] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                                        [   12.828095] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                                        [   12.836604] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                                        [   12.848785] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                                        [   12.877861] RKNPU fdab0000.npu: failed to find power_model node
                                        [   12.883771] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                                        [   12.890371] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                                        AT2Y1B
                                        Kingston
                                        20+0 records in
                                        20+0 records out
                                        20971520 bytes (21 MB, 20 MiB) copied, 0.187014 s, 112 MB/s
                                           e   extended
                                           e   extended
                                        total 205M
                                        /dev/mmcblk0p2 contains a ext4 file system labelled 'writable'
                                        	last mounted on /root on Thu Jan  1 00:00:03 1970
                                        Filesystem UUID: d1493481-5088-470c-87b2-3cc6db991a0c
                                        	4096000
                                          这个角度看,U3下面一个口。
                                          确认你的电源适配器
                                            电源适配器是买的时候里面配的12V2A的
                                            • 5 / 8
