    147 Posts 11 Posters 69.5k Views
      怎么样?
        正常安装
        [   11.122038] rk-pcie fe190000.pcie: IRQ msi not found
        [   11.122053] rk-pcie fe190000.pcie: Missing *config* reg space
        [   11.122142] rk-pcie fe190000.pcie: Missing *config* reg space
        [   11.122169] rk-pcie fe190000.pcie: invalid resource
        [   11.125068] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
        [   11.126208] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
        [   11.126214] rkvdec2_init:1010: No niu aclk reset resource define
        [   11.126218] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
        [   11.126220] rkvdec2_init:1013: No niu hclk reset resource define
        [   11.126737] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
        [   11.126740] rkvdec2_init:1010: No niu aclk reset resource define
        [   11.126744] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
        [   11.126747] rkvdec2_init:1013: No niu hclk reset resource define
        [   11.128444] mpp_iommu_probe:434: failed to get device node
        [   11.128448] mpp_av1dec av1d-master: failed to attach iommu
        [   11.666758] rk806 spi2.0: no sleep-setting state
        [   11.671377] rk806 spi2.0: no reset-setting pinctrl state
        [   11.676680] rk806 spi2.0: no dvs-setting pinctrl state
        [   11.889706] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
        [   11.897062] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
        [   11.904409] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
        [   11.911758] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
        [   11.919105] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
        [   11.926316] tinker-mcu: send_cmds: send command failed
        [   11.931446] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
        [   12.501950] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
        [   12.520585] : terminal subdev does not exist
        [   12.524858] : terminal subdev does not exist
        [   12.529120] : terminal subdev does not exist
        [   12.533383] : terminal subdev does not exist
        [   12.537647] : get_remote_sensor: video pad[0] is null
        [   12.542691] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
        [   12.549901] : get_remote_sensor: video pad[0] is null
        [   12.554943] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
        [   12.562160] : get_remote_sensor: video pad[0] is null
        [   12.567204] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
        [   12.574416] : get_remote_sensor: video pad[0] is null
        [   12.579458] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
        [   12.587879] rockchip-mipi-csi2: Async registered subdev
        [   12.657092] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
        [   12.667892] debugfs: File 'Capture' in directory 'dapm' already present!
        [   12.690795] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
        [   13.023688] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
        [   13.030902] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
        [   13.038198] debugfs: File 'HPCP L' in directory 'dapm' already present!
        [   13.044797] debugfs: File 'HPCP R' in directory 'dapm' already present!
        [   13.051402] debugfs: File 'HPVOL L' in directory 'dapm' already present!
        [   13.058088] debugfs: File 'HPVOL R' in directory 'dapm' already present!
        [   13.066273] ov5648 8-0036: could not get default pinstate
        [   13.071667] ov5648 8-0036: could not get sleep pinstate
        [   13.079716] ov5648 8-0036: Unexpected sensor id(000000), ret(-5)
        [   13.086769] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
        [   13.095900] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
        [   13.105015] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
        [   13.112896] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
        [   13.113084] rockchip_headset rk-headset: Can not read property headset_gpio
        [   13.122014] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
        [   13.137989] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
        [   13.146511] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
        [   13.155020] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
        [   13.167187] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
        [   13.198264] RKNPU fdab0000.npu: failed to find power_model node
        [   13.204174] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
        [   13.210775] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
        AT2Y1B
        Kingston
        20+0 records in
        20+0 records out
        20971520 bytes (21 MB, 20 MiB) copied, 0.186213 s, 113 MB/s
        won't be recoverable.
           (e.g., DOS FDISK, OS/2 FDISK)
           p   primary partition (1-4)
           e   extended
           e   extended
        mkfs.fat 4.2 (2021-01-31)
        total 205M
        mke2fs 1.46.5 (30-Dec-2021)
        Filesystem UUID: e42c8656-d1a3-40b1-85a8-2ddce3913d78
                4096000
        Allocating group tables: done
        Writing inode tables: done
        e2fsck 1.46.5 (30-Dec-2021)
         1.6GiB 0:00:54 [29.8MiB/s] [================================> ] 99%
        Complete install... please remove udisk for next booting
        auto poweroff system later when you plugout udisk...
        udisk have been removed.Now poweroff system...
        [  136.856307] reboot: Power down
          要换U盘?
            我也是这样刷的
            安装盘里面就只有压缩包里面的内容
            怎么就不行呢
            u盘也识别到了啊
              @jugg 你的u盘感觉质量如何
                我觉得质量没问题
                  你可以多刷几次 是不是每次都能刷成功
                    系统刷不了 就没法批量了
                      @jugg 有没有试过品牌U盘。这个方法我一直在用
                        你可以多刷几次 是不是每次都能刷成功
                        刷机方法没有问题,试了多次都能刷成功。
                          换了个金士顿的U盘作为安装盘 加载完logo就重启 反复重启
                          我已经没办法了
                            到底是接U3的上面口还是下面口
                            为什么我接U3上面口 没反应 接下面口才有反应
                              这是换了金士顿U盘的
                              还是卡在那里
                              VP0 set crtc_clock to 1485KHz
                              scanning bus usb@fc000000 for devices... cannot reset port 1!?
                              2 USB Device(s) found
                              Device 0: Vendor: Kingston Rev: PMAP Prod: DataTraveler 3.0
                                          Capacity: 29592.0 MB = 28.8 GB (60604416 x 512)
                              284 bytes read in 33 ms (7.8 KiB/s)
                              8913121 bytes read in 422 ms (20.1 MiB/s)
                              37706240 bytes read in 1697 ms (21.2 MiB/s)
                              append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n8 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:7a:46:da:5f:3e:bd
                              141838 bytes read in 38 ms (3.6 MiB/s)
                              [   10.801747] rk-pcie fe190000.pcie: IRQ msi not found
                              [   10.801763] rk-pcie fe190000.pcie: Missing *config* reg space
                              [   10.801855] rk-pcie fe190000.pcie: Missing *config* reg space
                              [   10.801883] rk-pcie fe190000.pcie: invalid resource
                              [   10.804829] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                              [   10.805992] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                              [   10.805997] rkvdec2_init:1010: No niu aclk reset resource define
                              [   10.806001] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                              [   10.806004] rkvdec2_init:1013: No niu hclk reset resource define
                              [   10.806530] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                              [   10.806533] rkvdec2_init:1010: No niu aclk reset resource define
                              [   10.806537] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                              [   10.806539] rkvdec2_init:1013: No niu hclk reset resource define
                              [   10.808288] mpp_iommu_probe:434: failed to get device node
                              [   10.808293] mpp_av1dec av1d-master: failed to attach iommu
                              [   11.341426] rk806 spi2.0: no sleep-setting state
                              [   11.346050] rk806 spi2.0: no reset-setting pinctrl state
                              [   11.351356] rk806 spi2.0: no dvs-setting pinctrl state
                              [   11.567895] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                              [   11.575253] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                              [   11.582602] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                              [   11.589953] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                              [   11.597302] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                              [   11.604512] tinker-mcu: send_cmds: send command failed
                              [   11.609641] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
                              [   12.179893] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
                              [   12.198621] : terminal subdev does not exist
                              [   12.202893] : terminal subdev does not exist
                              [   12.207155] : terminal subdev does not exist
                              [   12.211418] : terminal subdev does not exist
                              [   12.215681] : get_remote_sensor: video pad[0] is null
                              [   12.220725] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                              [   12.227935] : get_remote_sensor: video pad[0] is null
                              [   12.232977] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                              [   12.240190] : get_remote_sensor: video pad[0] is null
                              [   12.245236] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                              [   12.252446] : get_remote_sensor: video pad[0] is null
                              [   12.257489] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                              [   12.265952] rockchip-mipi-csi2: Async registered subdev
                              [   12.335257] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                              [   12.346141] debugfs: File 'Capture' in directory 'dapm' already present!
                              [   12.368803] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                              [   12.705027] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                              [   12.712240] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                              [   12.719536] debugfs: File 'HPCP L' in directory 'dapm' already present!
                              [   12.726135] debugfs: File 'HPCP R' in directory 'dapm' already present!
                              [   12.732737] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                              [   12.739423] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                              [   12.747604] ov5648 8-0036: could not get default pinstate
                              [   12.752995] ov5648 8-0036: could not get sleep pinstate
                              [   12.761463] ov5648 8-0036: Unexpected sensor id(000000), ret(0)
                              [   12.768370] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                              [   12.777492] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                              [   12.786609] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                              [   12.794481] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                              [   12.794638] rockchip_headset rk-headset: Can not read property headset_gpio
                              [   12.803602] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                              [   12.819574] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                              [   12.828095] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                              [   12.836604] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                              [   12.848785] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                              [   12.877861] RKNPU fdab0000.npu: failed to find power_model node
                              [   12.883771] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                              [   12.890371] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                              AT2Y1B
                              Kingston
                              20+0 records in
                              20+0 records out
                              20971520 bytes (21 MB, 20 MiB) copied, 0.187014 s, 112 MB/s
                                 e   extended
                                 e   extended
                              total 205M
                              /dev/mmcblk0p2 contains a ext4 file system labelled 'writable'
                              	last mounted on /root on Thu Jan  1 00:00:03 1970
                              Filesystem UUID: d1493481-5088-470c-87b2-3cc6db991a0c
                              	4096000
                                这个角度看,U3下面一个口。
                                确认你的电源适配器
                                  电源适配器是买的时候里面配的12V2A的
                                      你这接的不是U3上面那个口?
                                      我接的不是对的?
                                        @jugg 你手上有几块板,换个试下。emmc模组看下有没有扣好
                                          不接U盘 系统能正常进去 说明emmc没问题
                                            你这接的不是U3上面那个口?
                                            我接的不是对的?
                                            看文字描述。图片是角度示意
                                            • 5 / 8
