      我也是这样刷的
      安装盘里面就只有压缩包里面的内容
      怎么就不行呢
      u盘也识别到了啊
        @jugg 你的u盘感觉质量如何
          我觉得质量没问题
            你可以多刷几次 是不是每次都能刷成功
              系统刷不了 就没法批量了
                @jugg 有没有试过品牌U盘。这个方法我一直在用
                  你可以多刷几次 是不是每次都能刷成功
                  刷机方法没有问题,试了多次都能刷成功。
                    换了个金士顿的U盘作为安装盘 加载完logo就重启 反复重启
                    我已经没办法了
                      到底是接U3的上面口还是下面口
                      为什么我接U3上面口 没反应 接下面口才有反应
                        这是换了金士顿U盘的
                        还是卡在那里
                        VP0 set crtc_clock to 1485KHz
                        scanning bus usb@fc000000 for devices... cannot reset port 1!?
                        2 USB Device(s) found
                        Device 0: Vendor: Kingston Rev: PMAP Prod: DataTraveler 3.0
                                    Capacity: 29592.0 MB = 28.8 GB (60604416 x 512)
                        284 bytes read in 33 ms (7.8 KiB/s)
                        8913121 bytes read in 422 ms (20.1 MiB/s)
                        37706240 bytes read in 1697 ms (21.2 MiB/s)
                        append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n8 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:7a:46:da:5f:3e:bd
                        141838 bytes read in 38 ms (3.6 MiB/s)
                        [   10.801747] rk-pcie fe190000.pcie: IRQ msi not found
                        [   10.801763] rk-pcie fe190000.pcie: Missing *config* reg space
                        [   10.801855] rk-pcie fe190000.pcie: Missing *config* reg space
                        [   10.801883] rk-pcie fe190000.pcie: invalid resource
                        [   10.804829] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                        [   10.805992] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                        [   10.805997] rkvdec2_init:1010: No niu aclk reset resource define
                        [   10.806001] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                        [   10.806004] rkvdec2_init:1013: No niu hclk reset resource define
                        [   10.806530] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                        [   10.806533] rkvdec2_init:1010: No niu aclk reset resource define
                        [   10.806537] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                        [   10.806539] rkvdec2_init:1013: No niu hclk reset resource define
                        [   10.808288] mpp_iommu_probe:434: failed to get device node
                        [   10.808293] mpp_av1dec av1d-master: failed to attach iommu
                        [   11.341426] rk806 spi2.0: no sleep-setting state
                        [   11.346050] rk806 spi2.0: no reset-setting pinctrl state
                        [   11.351356] rk806 spi2.0: no dvs-setting pinctrl state
                        [   11.567895] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                        [   11.575253] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                        [   11.582602] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                        [   11.589953] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                        [   11.597302] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                        [   11.604512] tinker-mcu: send_cmds: send command failed
                        [   11.609641] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
                        [   12.179893] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
                        [   12.198621] : terminal subdev does not exist
                        [   12.202893] : terminal subdev does not exist
                        [   12.207155] : terminal subdev does not exist
                        [   12.211418] : terminal subdev does not exist
                        [   12.215681] : get_remote_sensor: video pad[0] is null
                        [   12.220725] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                        [   12.227935] : get_remote_sensor: video pad[0] is null
                        [   12.232977] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                        [   12.240190] : get_remote_sensor: video pad[0] is null
                        [   12.245236] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                        [   12.252446] : get_remote_sensor: video pad[0] is null
                        [   12.257489] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                        [   12.265952] rockchip-mipi-csi2: Async registered subdev
                        [   12.335257] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                        [   12.346141] debugfs: File 'Capture' in directory 'dapm' already present!
                        [   12.368803] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                        [   12.705027] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                        [   12.712240] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                        [   12.719536] debugfs: File 'HPCP L' in directory 'dapm' already present!
                        [   12.726135] debugfs: File 'HPCP R' in directory 'dapm' already present!
                        [   12.732737] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                        [   12.739423] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                        [   12.747604] ov5648 8-0036: could not get default pinstate
                        [   12.752995] ov5648 8-0036: could not get sleep pinstate
                        [   12.761463] ov5648 8-0036: Unexpected sensor id(000000), ret(0)
                        [   12.768370] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                        [   12.777492] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                        [   12.786609] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                        [   12.794481] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                        [   12.794638] rockchip_headset rk-headset: Can not read property headset_gpio
                        [   12.803602] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                        [   12.819574] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                        [   12.828095] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                        [   12.836604] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                        [   12.848785] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                        [   12.877861] RKNPU fdab0000.npu: failed to find power_model node
                        [   12.883771] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                        [   12.890371] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                        AT2Y1B
                        Kingston
                        20+0 records in
                        20+0 records out
                        20971520 bytes (21 MB, 20 MiB) copied, 0.187014 s, 112 MB/s
                        won't be recoverable.
                           (e.g., DOS FDISK, OS/2 FDISK)
                           p   primary partition (1-4)
                           e   extended
                           e   extended
                        mkfs.fat 4.2 (2021-01-31)
                        total 205M
                        mke2fs 1.46.5 (30-Dec-2021)
                        /dev/mmcblk0p2 contains a ext4 file system labelled 'writable'
                        	last mounted on /root on Thu Jan  1 00:00:03 1970
                        Filesystem UUID: d1493481-5088-470c-87b2-3cc6db991a0c
                        	4096000
                        Allocating group tables: done
                        Writing inode tables: done
                        e2fsck 1.46.5 (30-Dec-2021)
                          这个角度看,U3下面一个口。
                          确认你的电源适配器
                            电源适配器是买的时候里面配的12V2A的
                                你这接的不是U3上面那个口?
                                我接的不是对的?
                                  @jugg 你手上有几块板,换个试下。emmc模组看下有没有扣好
                                    不接U盘 系统能正常进去 说明emmc没问题
                                      你这接的不是U3上面那个口?
                                      我接的不是对的?
                                      看文字描述。图片是角度示意
                                        接下面口 直接进系统
                                          @jugg loader重新刷一个,用Windows rkdevtools工具刷
                                            loader刷了 接U3下面口 还是直接进系统
                                            • 6 / 8
