      我觉得质量没问题
        你可以多刷几次 是不是每次都能刷成功
          系统刷不了 就没法批量了
            @jugg 有没有试过品牌U盘。这个方法我一直在用
              你可以多刷几次 是不是每次都能刷成功
              刷机方法没有问题,试了多次都能刷成功。
                换了个金士顿的U盘作为安装盘 加载完logo就重启 反复重启
                我已经没办法了
                  到底是接U3的上面口还是下面口
                  为什么我接U3上面口 没反应 接下面口才有反应
                    这是换了金士顿U盘的
                    还是卡在那里
                    VP0 set crtc_clock to 1485KHz
                    scanning bus usb@fc000000 for devices... cannot reset port 1!?
                    2 USB Device(s) found
                    Device 0: Vendor: Kingston Rev: PMAP Prod: DataTraveler 3.0
                                Capacity: 29592.0 MB = 28.8 GB (60604416 x 512)
                    284 bytes read in 33 ms (7.8 KiB/s)
                    8913121 bytes read in 422 ms (20.1 MiB/s)
                    37706240 bytes read in 1697 ms (21.2 MiB/s)
                    append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n8 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:7a:46:da:5f:3e:bd
                    141838 bytes read in 38 ms (3.6 MiB/s)
                    [   10.801747] rk-pcie fe190000.pcie: IRQ msi not found
                    [   10.801763] rk-pcie fe190000.pcie: Missing *config* reg space
                    [   10.801855] rk-pcie fe190000.pcie: Missing *config* reg space
                    [   10.801883] rk-pcie fe190000.pcie: invalid resource
                    [   10.804829] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                    [   10.805992] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                    [   10.805997] rkvdec2_init:1010: No niu aclk reset resource define
                    [   10.806001] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                    [   10.806004] rkvdec2_init:1013: No niu hclk reset resource define
                    [   10.806530] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                    [   10.806533] rkvdec2_init:1010: No niu aclk reset resource define
                    [   10.806537] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                    [   10.806539] rkvdec2_init:1013: No niu hclk reset resource define
                    [   10.808288] mpp_iommu_probe:434: failed to get device node
                    [   10.808293] mpp_av1dec av1d-master: failed to attach iommu
                    [   11.341426] rk806 spi2.0: no sleep-setting state
                    [   11.346050] rk806 spi2.0: no reset-setting pinctrl state
                    [   11.351356] rk806 spi2.0: no dvs-setting pinctrl state
                    [   11.567895] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                    [   11.575253] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                    [   11.582602] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                    [   11.589953] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                    [   11.597302] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                    [   11.604512] tinker-mcu: send_cmds: send command failed
                    [   11.609641] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
                    [   12.179893] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
                    [   12.198621] : terminal subdev does not exist
                    [   12.202893] : terminal subdev does not exist
                    [   12.207155] : terminal subdev does not exist
                    [   12.211418] : terminal subdev does not exist
                    [   12.215681] : get_remote_sensor: video pad[0] is null
                    [   12.220725] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                    [   12.227935] : get_remote_sensor: video pad[0] is null
                    [   12.232977] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                    [   12.240190] : get_remote_sensor: video pad[0] is null
                    [   12.245236] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                    [   12.252446] : get_remote_sensor: video pad[0] is null
                    [   12.257489] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                    [   12.265952] rockchip-mipi-csi2: Async registered subdev
                    [   12.335257] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                    [   12.346141] debugfs: File 'Capture' in directory 'dapm' already present!
                    [   12.368803] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                    [   12.705027] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                    [   12.712240] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                    [   12.719536] debugfs: File 'HPCP L' in directory 'dapm' already present!
                    [   12.726135] debugfs: File 'HPCP R' in directory 'dapm' already present!
                    [   12.732737] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                    [   12.739423] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                    [   12.747604] ov5648 8-0036: could not get default pinstate
                    [   12.752995] ov5648 8-0036: could not get sleep pinstate
                    [   12.761463] ov5648 8-0036: Unexpected sensor id(000000), ret(0)
                    [   12.768370] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                    [   12.777492] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                    [   12.786609] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                    [   12.794481] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                    [   12.794638] rockchip_headset rk-headset: Can not read property headset_gpio
                    [   12.803602] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                    [   12.819574] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                    [   12.828095] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                    [   12.836604] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                    [   12.848785] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                    [   12.877861] RKNPU fdab0000.npu: failed to find power_model node
                    [   12.883771] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                    [   12.890371] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                    AT2Y1B
                    Kingston
                    20+0 records in
                    20+0 records out
                    20971520 bytes (21 MB, 20 MiB) copied, 0.187014 s, 112 MB/s
                    won't be recoverable.
                       (e.g., DOS FDISK, OS/2 FDISK)
                       p   primary partition (1-4)
                       e   extended
                       e   extended
                    mkfs.fat 4.2 (2021-01-31)
                    total 205M
                    mke2fs 1.46.5 (30-Dec-2021)
                    /dev/mmcblk0p2 contains a ext4 file system labelled 'writable'
                    	last mounted on /root on Thu Jan  1 00:00:03 1970
                    Filesystem UUID: d1493481-5088-470c-87b2-3cc6db991a0c
                    	4096000
                    Allocating group tables: done
                    Writing inode tables: done
                    e2fsck 1.46.5 (30-Dec-2021)
                      这个角度看,U3下面一个口。
                      确认你的电源适配器
                        电源适配器是买的时候里面配的12V2A的
                            你这接的不是U3上面那个口?
                            我接的不是对的?
                              @jugg 你手上有几块板,换个试下。emmc模组看下有没有扣好
                                不接U盘 系统能正常进去 说明emmc没问题
                                  你这接的不是U3上面那个口?
                                  我接的不是对的?
                                  看文字描述。图片是角度示意
                                    接下面口 直接进系统
                                      @jugg loader重新刷一个,用Windows rkdevtools工具刷
                                        loader刷了 接U3下面口 还是直接进系统
                                            确认是这个接口,附带串口启动信息
                                            • 6 / 8
