    147 Posts 11 Posters 63.1k Views
      最新的uboot在哪里?
      需要自己重新编译?
        最新的uboot在哪里?
        需要自己重新编译?
        百度网盘或Onedrive
          没有啊
            @jugg 0411那个就是了
              没法更新loader
              电脑上用RKdev工具 也识别不到设备
              我也不知道你们是怎么做的 到底需要什么样的U盘
                https://wiki.cool-pi.com/en/home/quick_start
                参考loader更新方法
                U盘你格式化一次,拷贝uboot.img到U盘
                  更新了loader
                  ab8cd4ce-4cfe-451f-b009-cf76a252110b-lQDPJxeIVzHuKzjNA7zNBPyw9wCLfw9939cEvtjmk0B9AA_1276_956.jpg
                  卡在这里不动了 过一会儿就黑屏了
                    @jugg extlinux.conf把参数改为ttyS0,115200n8,用串口观察过程
                      DDR V1.09 a930779e06 typ 22/11/21-17:50:56
                      CH2 RX Vref:29.7%, TX Vref:21.8%,21.8%
                      CH3 RX Vref:29.7%, TX Vref:21.8%,21.8%
                      INFO:    Preloader serial: 2
                      NOTICE:  BL31: v2.3():v2.3-557-g9609b9c19:derrick.huang
                      NOTICE:  BL31: Built : 14:29:57, Mar  8 2023
                      INFO:    spec: 0x13
                      INFO:    ext 32k is not valid
                      INFO:    ddr: stride-en 4CH
                      INFO:    SPSR = 0x3c9
                      COOLPI LOADER BY YANYI(Jun 06 2023)
                      FAT: Misaligned buffer address (00000000ebc9e610)
                      scanning bus usb@fc880000 for devices...
                      CH3 RX Vref:30.7%, TX Vref:22.8%,21.8%
                      INFO:    spec: 0x13
                      INFO:    SPSR = 0x3c9
                      284 bytes read in 35 ms (7.8 KiB/s)
                      8913121 bytes read in 886 ms (9.6 MiB/s)
                      37706240 bytes read in 3595 ms (10 MiB/s)
                      append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n8 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:96:39:8b:af:40:ae
                         Loading Ramdisk to eb153000, end eb9d30e1 ... OK
                         Loading Device Tree to 00000000eb12d000, end 00000000eb152a0d ... OK
                      FAT: Misaligned buffer address (00000000ebcaf6f0)
                      [   12.746995] rk-pcie fe190000.pcie: IRQ msi not found
                      [   12.747011] rk-pcie fe190000.pcie: Missing *config* reg space
                      [   12.747100] rk-pcie fe190000.pcie: Missing *config* reg space
                      [   12.747128] rk-pcie fe190000.pcie: invalid resource
                      [   12.750030] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                      [   12.751179] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                      [   12.751183] rkvdec2_init:1010: No niu aclk reset resource define
                      [   12.751187] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                      [   12.751190] rkvdec2_init:1013: No niu hclk reset resource define
                      [   12.751707] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                      [   12.751711] rkvdec2_init:1010: No niu aclk reset resource define
                      [   12.751714] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                      [   12.751717] rkvdec2_init:1013: No niu hclk reset resource define
                      [   12.753419] mpp_iommu_probe:434: failed to get device node
                      [   12.753424] mpp_av1dec av1d-master: failed to attach iommu
                      [   12.983271] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any match mode
                      [   12.991632] rockchip-drm display-subsystem: failed to show kernel logo
                      [   13.109833] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
                      [   13.110084] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
                      [   13.372226] rk806 spi2.0: no sleep-setting state
                      [   13.376844] rk806 spi2.0: no reset-setting pinctrl state
                      [   13.382148] rk806 spi2.0: no dvs-setting pinctrl state
                      [   13.595213] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                      [   13.602569] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                      [   13.609918] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                      [   13.617266] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                      [   13.624613] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                      [   13.631823] tinker-mcu: send_cmds: send command failed
                      [   13.636952] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
                      [   14.207396] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
                      [   14.226018] : terminal subdev does not exist
                      [   14.230290] : terminal subdev does not exist
                      [   14.234552] : terminal subdev does not exist
                      [   14.238815] : terminal subdev does not exist
                      [   14.243078] : get_remote_sensor: video pad[0] is null
                      [   14.248121] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                      [   14.255330] : get_remote_sensor: video pad[0] is null
                      [   14.260373] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                      [   14.267584] : get_remote_sensor: video pad[0] is null
                      [   14.272629] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                      [   14.279839] : get_remote_sensor: video pad[0] is null
                      [   14.284881] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                      [   14.293240] rockchip-mipi-csi2: Async registered subdev
                      [   14.362227] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                      [   14.373046] debugfs: File 'Capture' in directory 'dapm' already present!
                      [   14.395725] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                      [   14.729254] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                      [   14.736468] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                      [   14.743765] debugfs: File 'HPCP L' in directory 'dapm' already present!
                      [   14.750365] debugfs: File 'HPCP R' in directory 'dapm' already present!
                      [   14.756967] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                      [   14.763653] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                      [   14.771803] ov5648 8-0036: could not get default pinstate
                      [   14.777196] ov5648 8-0036: could not get sleep pinstate
                      [   14.785078] ov5648 8-0036: Unexpected sensor id(000000), ret(-5)
                      [   14.792138] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                      [   14.801266] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                      [   14.810380] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                      [   14.818204] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                      [   14.818440] rockchip_headset rk-headset: Can not read property headset_gpio
                      [   14.827318] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                      [   14.843348] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                      [   14.851869] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                      [   14.860378] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                      [   14.872438] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                      [   14.902618] RKNPU fdab0000.npu: failed to find power_model node
                      [   14.908529] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                      [   14.908530] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                      AT2Y1B
                      wait for external disk device.
                      Generic
                      20+0 records in
                      20+0 records out
                      20971520 bytes (21 MB, 20 MiB) copied, 0.188153 s, 111 MB/s
                      won't be recoverable.
                         (e.g., DOS FDISK, OS/2 FDISK)
                         p   primary partition (1-4)
                         e   extended
                         e   extended
                      mkfs.fat 4.2 (2021-01-31)
                      total 205M
                      mke2fs 1.46.5 (30-Dec-2021)
                      Discarding device blocks: [   41.269135] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
                      [   41.276429] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
                      [   42.604779] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
                      [   42.612045] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
                      Filesystem UUID: eb878b89-7651-4f9c-8eb8-e6e819f2f447
                      	4096000
                      Allocating group tables: done
                      Writing inode tables: done
                      e2fsck 1.46.5 (30-Dec-2021)
                        @jugg 把备份的镜像文件压缩包发给我试试
                          是不是跟要刷机的板子的原来的系统有关 而不是备份的镜像
                          这是安装盘的压缩包 install里面就是备份盘备份出来的镜像 还原不了到另外一块板子里面
                          链接:https://pan.baidu.com/s/1qw-WQMRiGHzMaGcCRLAtMA?pwd=6qap
                          提取码:6qap
                            怎么样?
                              正常安装
                              [   11.122038] rk-pcie fe190000.pcie: IRQ msi not found
                              [   11.122053] rk-pcie fe190000.pcie: Missing *config* reg space
                              [   11.122142] rk-pcie fe190000.pcie: Missing *config* reg space
                              [   11.122169] rk-pcie fe190000.pcie: invalid resource
                              [   11.125068] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                              [   11.126208] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                              [   11.126214] rkvdec2_init:1010: No niu aclk reset resource define
                              [   11.126218] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                              [   11.126220] rkvdec2_init:1013: No niu hclk reset resource define
                              [   11.126737] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                              [   11.126740] rkvdec2_init:1010: No niu aclk reset resource define
                              [   11.126744] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                              [   11.126747] rkvdec2_init:1013: No niu hclk reset resource define
                              [   11.128444] mpp_iommu_probe:434: failed to get device node
                              [   11.128448] mpp_av1dec av1d-master: failed to attach iommu
                              [   11.666758] rk806 spi2.0: no sleep-setting state
                              [   11.671377] rk806 spi2.0: no reset-setting pinctrl state
                              [   11.676680] rk806 spi2.0: no dvs-setting pinctrl state
                              [   11.889706] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                              [   11.897062] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                              [   11.904409] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                              [   11.911758] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                              [   11.919105] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                              [   11.926316] tinker-mcu: send_cmds: send command failed
                              [   11.931446] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
                              [   12.501950] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
                              [   12.520585] : terminal subdev does not exist
                              [   12.524858] : terminal subdev does not exist
                              [   12.529120] : terminal subdev does not exist
                              [   12.533383] : terminal subdev does not exist
                              [   12.537647] : get_remote_sensor: video pad[0] is null
                              [   12.542691] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                              [   12.549901] : get_remote_sensor: video pad[0] is null
                              [   12.554943] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                              [   12.562160] : get_remote_sensor: video pad[0] is null
                              [   12.567204] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                              [   12.574416] : get_remote_sensor: video pad[0] is null
                              [   12.579458] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                              [   12.587879] rockchip-mipi-csi2: Async registered subdev
                              [   12.657092] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                              [   12.667892] debugfs: File 'Capture' in directory 'dapm' already present!
                              [   12.690795] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                              [   13.023688] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                              [   13.030902] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                              [   13.038198] debugfs: File 'HPCP L' in directory 'dapm' already present!
                              [   13.044797] debugfs: File 'HPCP R' in directory 'dapm' already present!
                              [   13.051402] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                              [   13.058088] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                              [   13.066273] ov5648 8-0036: could not get default pinstate
                              [   13.071667] ov5648 8-0036: could not get sleep pinstate
                              [   13.079716] ov5648 8-0036: Unexpected sensor id(000000), ret(-5)
                              [   13.086769] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                              [   13.095900] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                              [   13.105015] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                              [   13.112896] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                              [   13.113084] rockchip_headset rk-headset: Can not read property headset_gpio
                              [   13.122014] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                              [   13.137989] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                              [   13.146511] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                              [   13.155020] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                              [   13.167187] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                              [   13.198264] RKNPU fdab0000.npu: failed to find power_model node
                              [   13.204174] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                              [   13.210775] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                              AT2Y1B
                              Kingston
                              20+0 records in
                              20+0 records out
                              20971520 bytes (21 MB, 20 MiB) copied, 0.186213 s, 113 MB/s
                                 e   extended
                                 e   extended
                              total 205M
                              Filesystem UUID: e42c8656-d1a3-40b1-85a8-2ddce3913d78
                                      4096000
                               1.6GiB 0:00:54 [29.8MiB/s] [================================> ] 99%
                              Complete install... please remove udisk for next booting
                              auto poweroff system later when you plugout udisk...
                              udisk have been removed.Now poweroff system...
                              [  136.856307] reboot: Power down
                                要换U盘?
                                  我也是这样刷的
                                  安装盘里面就只有压缩包里面的内容
                                  怎么就不行呢
                                  u盘也识别到了啊
                                    @jugg 你的u盘感觉质量如何
                                      我觉得质量没问题
                                        你可以多刷几次 是不是每次都能刷成功
                                          系统刷不了 就没法批量了
                                            @jugg 有没有试过品牌U盘。这个方法我一直在用
                                            • 5 / 8
