    147 Posts 11 Posters 65.4k Views
      我所有U盘都是一样的
      那要什么样的U盘才行
        @jugg 你升级下最新的loader,再试下上下两个U3有没有改善。我们测试用闪迪/金士顿 U3 U盘,也试过部分移动硬盘,可以识别加载
          最新的uboot在哪里?
          需要自己重新编译?
            最新的uboot在哪里?
            需要自己重新编译?
            百度网盘或Onedrive
              没有啊
                @jugg 0411那个就是了
                  没法更新loader
                  电脑上用RKdev工具 也识别不到设备
                  我也不知道你们是怎么做的 到底需要什么样的U盘
                    https://wiki.cool-pi.com/en/home/quick_start
                    参考loader更新方法
                    U盘你格式化一次,拷贝uboot.img到U盘
                      更新了loader
                      ab8cd4ce-4cfe-451f-b009-cf76a252110b-lQDPJxeIVzHuKzjNA7zNBPyw9wCLfw9939cEvtjmk0B9AA_1276_956.jpg
                      卡在这里不动了 过一会儿就黑屏了
                        @jugg extlinux.conf把参数改为ttyS0,115200n8,用串口观察过程
                          DDR V1.09 a930779e06 typ 22/11/21-17:50:56
                          CH2 RX Vref:29.7%, TX Vref:21.8%,21.8%
                          CH3 RX Vref:29.7%, TX Vref:21.8%,21.8%
                          INFO:    Preloader serial: 2
                          NOTICE:  BL31: v2.3():v2.3-557-g9609b9c19:derrick.huang
                          NOTICE:  BL31: Built : 14:29:57, Mar  8 2023
                          INFO:    spec: 0x13
                          INFO:    ext 32k is not valid
                          INFO:    ddr: stride-en 4CH
                          INFO:    SPSR = 0x3c9
                          COOLPI LOADER BY YANYI(Jun 06 2023)
                          FAT: Misaligned buffer address (00000000ebc9e610)
                          scanning bus usb@fc880000 for devices...
                          CH3 RX Vref:30.7%, TX Vref:22.8%,21.8%
                          INFO:    spec: 0x13
                          INFO:    SPSR = 0x3c9
                          284 bytes read in 35 ms (7.8 KiB/s)
                          8913121 bytes read in 886 ms (9.6 MiB/s)
                          37706240 bytes read in 3595 ms (10 MiB/s)
                          append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n8 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:96:39:8b:af:40:ae
                             Loading Ramdisk to eb153000, end eb9d30e1 ... OK
                             Loading Device Tree to 00000000eb12d000, end 00000000eb152a0d ... OK
                          FAT: Misaligned buffer address (00000000ebcaf6f0)
                          [   12.746995] rk-pcie fe190000.pcie: IRQ msi not found
                          [   12.747011] rk-pcie fe190000.pcie: Missing *config* reg space
                          [   12.747100] rk-pcie fe190000.pcie: Missing *config* reg space
                          [   12.747128] rk-pcie fe190000.pcie: invalid resource
                          [   12.750030] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                          [   12.751179] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                          [   12.751183] rkvdec2_init:1010: No niu aclk reset resource define
                          [   12.751187] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                          [   12.751190] rkvdec2_init:1013: No niu hclk reset resource define
                          [   12.751707] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                          [   12.751711] rkvdec2_init:1010: No niu aclk reset resource define
                          [   12.751714] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                          [   12.751717] rkvdec2_init:1013: No niu hclk reset resource define
                          [   12.753419] mpp_iommu_probe:434: failed to get device node
                          [   12.753424] mpp_av1dec av1d-master: failed to attach iommu
                          [   12.983271] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any match mode
                          [   12.991632] rockchip-drm display-subsystem: failed to show kernel logo
                          [   13.109833] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
                          [   13.110084] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
                          [   13.372226] rk806 spi2.0: no sleep-setting state
                          [   13.376844] rk806 spi2.0: no reset-setting pinctrl state
                          [   13.382148] rk806 spi2.0: no dvs-setting pinctrl state
                          [   13.595213] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                          [   13.602569] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                          [   13.609918] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                          [   13.617266] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                          [   13.624613] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                          [   13.631823] tinker-mcu: send_cmds: send command failed
                          [   13.636952] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
                          [   14.207396] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
                          [   14.226018] : terminal subdev does not exist
                          [   14.230290] : terminal subdev does not exist
                          [   14.234552] : terminal subdev does not exist
                          [   14.238815] : terminal subdev does not exist
                          [   14.243078] : get_remote_sensor: video pad[0] is null
                          [   14.248121] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                          [   14.255330] : get_remote_sensor: video pad[0] is null
                          [   14.260373] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                          [   14.267584] : get_remote_sensor: video pad[0] is null
                          [   14.272629] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                          [   14.279839] : get_remote_sensor: video pad[0] is null
                          [   14.284881] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                          [   14.293240] rockchip-mipi-csi2: Async registered subdev
                          [   14.362227] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                          [   14.373046] debugfs: File 'Capture' in directory 'dapm' already present!
                          [   14.395725] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                          [   14.729254] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                          [   14.736468] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                          [   14.743765] debugfs: File 'HPCP L' in directory 'dapm' already present!
                          [   14.750365] debugfs: File 'HPCP R' in directory 'dapm' already present!
                          [   14.756967] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                          [   14.763653] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                          [   14.771803] ov5648 8-0036: could not get default pinstate
                          [   14.777196] ov5648 8-0036: could not get sleep pinstate
                          [   14.785078] ov5648 8-0036: Unexpected sensor id(000000), ret(-5)
                          [   14.792138] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                          [   14.801266] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                          [   14.810380] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                          [   14.818204] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                          [   14.818440] rockchip_headset rk-headset: Can not read property headset_gpio
                          [   14.827318] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                          [   14.843348] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                          [   14.851869] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                          [   14.860378] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                          [   14.872438] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                          [   14.902618] RKNPU fdab0000.npu: failed to find power_model node
                          [   14.908529] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                          [   14.908530] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                          AT2Y1B
                          wait for external disk device.
                          Generic
                          20+0 records in
                          20+0 records out
                          20971520 bytes (21 MB, 20 MiB) copied, 0.188153 s, 111 MB/s
                          won't be recoverable.
                             (e.g., DOS FDISK, OS/2 FDISK)
                             p   primary partition (1-4)
                             e   extended
                             e   extended
                          mkfs.fat 4.2 (2021-01-31)
                          total 205M
                          mke2fs 1.46.5 (30-Dec-2021)
                          Discarding device blocks: [   41.269135] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
                          [   41.276429] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
                          [   42.604779] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
                          [   42.612045] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
                          Filesystem UUID: eb878b89-7651-4f9c-8eb8-e6e819f2f447
                          	4096000
                          Allocating group tables: done
                          Writing inode tables: done
                          e2fsck 1.46.5 (30-Dec-2021)
                            @jugg 把备份的镜像文件压缩包发给我试试
                              是不是跟要刷机的板子的原来的系统有关 而不是备份的镜像
                              这是安装盘的压缩包 install里面就是备份盘备份出来的镜像 还原不了到另外一块板子里面
                              链接:https://pan.baidu.com/s/1qw-WQMRiGHzMaGcCRLAtMA?pwd=6qap
                              提取码:6qap
                                怎么样?
                                  正常安装
                                  [   11.122038] rk-pcie fe190000.pcie: IRQ msi not found
                                  [   11.122053] rk-pcie fe190000.pcie: Missing *config* reg space
                                  [   11.122142] rk-pcie fe190000.pcie: Missing *config* reg space
                                  [   11.122169] rk-pcie fe190000.pcie: invalid resource
                                  [   11.125068] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                                  [   11.126208] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                                  [   11.126214] rkvdec2_init:1010: No niu aclk reset resource define
                                  [   11.126218] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                                  [   11.126220] rkvdec2_init:1013: No niu hclk reset resource define
                                  [   11.126737] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                                  [   11.126740] rkvdec2_init:1010: No niu aclk reset resource define
                                  [   11.126744] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                                  [   11.126747] rkvdec2_init:1013: No niu hclk reset resource define
                                  [   11.128444] mpp_iommu_probe:434: failed to get device node
                                  [   11.128448] mpp_av1dec av1d-master: failed to attach iommu
                                  [   11.666758] rk806 spi2.0: no sleep-setting state
                                  [   11.671377] rk806 spi2.0: no reset-setting pinctrl state
                                  [   11.676680] rk806 spi2.0: no dvs-setting pinctrl state
                                  [   11.889706] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                                  [   11.897062] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                                  [   11.904409] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                                  [   11.911758] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                                  [   11.919105] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                                  [   11.926316] tinker-mcu: send_cmds: send command failed
                                  [   11.931446] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
                                  [   12.501950] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
                                  [   12.520585] : terminal subdev does not exist
                                  [   12.524858] : terminal subdev does not exist
                                  [   12.529120] : terminal subdev does not exist
                                  [   12.533383] : terminal subdev does not exist
                                  [   12.537647] : get_remote_sensor: video pad[0] is null
                                  [   12.542691] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                                  [   12.549901] : get_remote_sensor: video pad[0] is null
                                  [   12.554943] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                                  [   12.562160] : get_remote_sensor: video pad[0] is null
                                  [   12.567204] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                                  [   12.574416] : get_remote_sensor: video pad[0] is null
                                  [   12.579458] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                                  [   12.587879] rockchip-mipi-csi2: Async registered subdev
                                  [   12.657092] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                                  [   12.667892] debugfs: File 'Capture' in directory 'dapm' already present!
                                  [   12.690795] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                                  [   13.023688] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                                  [   13.030902] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                                  [   13.038198] debugfs: File 'HPCP L' in directory 'dapm' already present!
                                  [   13.044797] debugfs: File 'HPCP R' in directory 'dapm' already present!
                                  [   13.051402] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                                  [   13.058088] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                                  [   13.066273] ov5648 8-0036: could not get default pinstate
                                  [   13.071667] ov5648 8-0036: could not get sleep pinstate
                                  [   13.079716] ov5648 8-0036: Unexpected sensor id(000000), ret(-5)
                                  [   13.086769] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                                  [   13.095900] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                                  [   13.105015] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                                  [   13.112896] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                                  [   13.113084] rockchip_headset rk-headset: Can not read property headset_gpio
                                  [   13.122014] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                                  [   13.137989] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                                  [   13.146511] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                                  [   13.155020] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                                  [   13.167187] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                                  [   13.198264] RKNPU fdab0000.npu: failed to find power_model node
                                  [   13.204174] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                                  [   13.210775] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                                  AT2Y1B
                                  Kingston
                                  20+0 records in
                                  20+0 records out
                                  20971520 bytes (21 MB, 20 MiB) copied, 0.186213 s, 113 MB/s
                                     e   extended
                                     e   extended
                                  total 205M
                                  Filesystem UUID: e42c8656-d1a3-40b1-85a8-2ddce3913d78
                                          4096000
                                   1.6GiB 0:00:54 [29.8MiB/s] [================================> ] 99%
                                  Complete install... please remove udisk for next booting
                                  auto poweroff system later when you plugout udisk...
                                  udisk have been removed.Now poweroff system...
                                  [  136.856307] reboot: Power down
                                    要换U盘?
                                      我也是这样刷的
                                      安装盘里面就只有压缩包里面的内容
                                      怎么就不行呢
                                      u盘也识别到了啊
                                        @jugg 你的u盘感觉质量如何
                                          我觉得质量没问题
                                            你可以多刷几次 是不是每次都能刷成功
                                            • 5 / 8
