    Coolpi 4b Ubuntu20.04 原生系统
    41 Posts 10 Posters 12.4k Views
      myhexb @george
      @george 完全启动不起来 可以打印日志吗 该怎么打印 反复显示 cool pi
        myhexb @大法师
        @大法师 用的官方文件百度网盘ubuntu文件夹里的 20.04桌面版 3.52g的那个
          myhexb @大法师
          @大法师 闪迪的卡就像没插卡一样,反复显示 coolpi 京东卡可以进去 但特别卡,而且非正常关机后大概率也会进不去系统,不过一般会卡到 - 界面。需要重新刷机才行
            myhexb @george
            @george 嫊-oZp@fde50000 disconnected
            hdmi@fde80000 disconnected
            mmc1 is current device
            Scanning mmc 1:1...
            287 bytes read in 8 ms (34.2 KiB/s)
            1: Ubuntu coolpi
            8775086 bytes read in 709 ms (11.8 MiB/s)
            37294592 bytes read in 2992 ms (11.9 MiB/s)
            append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n81 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:52:84:fe:01:16:93
            141784 bytes read in 18 ms (7.5 MiB/s)
            Flattened Device Tree blob at 0x0a100000
            Loading Device Tree to 00000000eb150000, end 00000000eb1759d7 ... OK
            [ 8.386768] rk-pcie fe190000.pcie: IRQ msi not found
            [ 8.386784] rk-pcie fe190000.pcie: Missing config reg space
            [ 8.386875] rk-pcie fe190000.pcie: Missing config reg space
            [ 8.386902] rk-pcie fe190000.pcie: invalid resource
            [ 8.389687] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
            [ 8.390791] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
            [ 8.390796] rkvdec2_init:1010: No niu aclk reset resource define
            [ 8.390799] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
            [ 8.390802] rkvdec2_init:1013: No niu hclk reset resource define
            [ 8.391320] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
            [ 8.391324] rkvdec2_init:1010: No niu aclk reset resource define
            [ 8.391327] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
            [ 8.391330] rkvdec2_init:1013: No niu hclk reset resource define
            [ 8.393004] mpp_iommu_probe:434: failed to get device node
            [ 8.393008] mpp_av1dec av1d-master: failed to attach iommu
            [ 8.517456] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
            [ 8.525303] rockchip-drm display-subsystem: failed to show kernel logo
            [ 8.704582] rk806 spi2.0: no sleep-setting state
            [ 8.709201] rk806 spi2.0: no reset-setting pinctrl state
            [ 8.714503] rk806 spi2.0: no dvs-setting pinctrl state
            [ 8.926386] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
            [ 8.933738] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
            [ 8.941087] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
            [ 8.948434] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
            [ 8.955782] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
            [ 8.962994] tinker-mcu: send_cmds: send command failed
            [ 8.968123] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
            [ 9.539506] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
            [ 9.620266] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
            [ 9.630200] debugfs: File 'Capture' in directory 'dapm' already present!
            [ 9.652203] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
            [ 9.851268] ov5647 8-0036: Unsupported clock frequency: 24000000
            [ 9.991259] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
            [ 9.998472] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
            [ 10.005768] debugfs: File 'HPCP L' in directory 'dapm' already present!
            [ 10.012367] debugfs: File 'HPCP R' in directory 'dapm' already present!
            [ 10.018969] debugfs: File 'HPVOL L' in directory 'dapm' already present!
            [ 10.025654] debugfs: File 'HPVOL R' in directory 'dapm' already present!
            [ 10.034611] rockchip_headset rk-headset: Can not read property headset_gpio
            [ 10.042867] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
            [ 10.051384] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
            [ 10.059894] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
            [ 10.072022] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
            [ 10.100903] RKNPU fdab0000.npu: failed to find power_model node
            [ 10.106814] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
            [ 10.113414] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
            Gave up waiting for root file system device. Common problems:
            • Boot args (cat /proc/cmdline)
              • Check rootdelay= (did the system wait long enough?)
            • Missing modules (cat /proc/modules; ls /dev)
              ALERT! LABEL=writable does not exist. Dropping to a shell!
            BusyBox v1.30.1 (Ubuntu 1:1.30.1-7ubuntu3) built-in shell (ash)
            Enter 'help' for a list of built-in commands.
            (initramfs)
              myhexb @george
              @george DDR V1.09 a930779e06 typ 22/11/21-17:50:56
              channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 D镈DR V1.09 a930779e06 typ 22/11/21-17:50:56
              CH0 RX Vref:29.7%, TX Vref:21.8%,21.8%
              CH1 RX Vref:30.7%, TX Vref:21.8%,22.8%
              CH2 RX Vref:30.7%, TX Vref:20.8%,20.8%
              CH3 RX Vref:29.7%, TX Vref:22.8%,22.8%
              INFO: Preloader serial: 2
              NOTICE: BL31: v2.3():v2.3-481-g17b41886e:derrick.huang
              NOTICE: BL31: Built : 16:20:07, Dec 7 2022
              INFO: spec: 0x13
              INFO: ext 32k is not valid
              INFO: ddr: stride-en 4CH
              INFO: BL31: Initialising Exception Handling Framework
              INFO: BL31: Initializing BL32
              INFO: hdmirx_handler: dma not on, ret
              I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022骞?09鏈?20鏃?鏄熸湡浜?09:41:09 CST aarch64
              INFO: SPSR = 0x3c9
              DRAM: 8 GiB
              Card did not respond to voltage select!
              mmc_init: -95, time 17
              Loading order: usb - tf - emmc
              bank id invalid
              request for 141 failed:-22
              bank id invalid
              resetting USB...
              ** Bad device usb 0 **
              mmc_init: -95, time 16
              ** Bad device mmc 0 **
              CH3 RX Vref:30.7%, TX Vref:22.8%,22.8%
              INFO: spec: 0x13
              INFO: ext 32k is valid
              INFO: SPSR = 0x3c9
              DRAM: 8 GiB
              bank id invalid
              bank id invalid
              resetting USB...
              这个是完全启动 不起来的日志
                george @myhexb
                @myhexb 这个是镜像没有制作成功。如果有读卡器可以先格式化一次卡,然后再制作,闪迪的卡我一直在用,没有什么问题。
                  myhexb @george
                  @george 第一张闪迪卡各种方式格式化 试了4 5次了 ,第二张也试了一次 还是不行
                    george @myhexb
                    @myhexb 可以换个镜像再测试。从log看的情况就是卡没有识别到或者rootfs没有成功挂载。
                      myhexb @george
                      @george 换22.04 也还是一样的情况
                        大法师 @myhexb
                        @myhexb 用读卡器连接,插在USB3下层端口,启动试试
                          myhexb @大法师
                          @大法师 试了 usb插 硬盘盒子和 读卡器 还是只有京东卡可以启动,闪迪卡可以找到卡 但不能启动 ,重做和换镜像文件都没成功,0 2 1 3 6 8 7 9 trsv ln0 mon rx cdr lock timeout
                          Device 0: Vendor: Generic Rev: 1532 Prod: STORAGE DEVICE
                          Capacity: 60906.0 MB = 59.4 GB (124735488 x 512)
                            myhexb @大法师
                            @大法师 硬盘盒子干脆就找不到usb设备 ,
                              大法师 @myhexb
                              @myhexb said in Coolpi 4b Ubuntu20.04 原生系统:
                              硬盘盒需要更新loader,且需要注意适配器供电功率
                              https://www.cool-pi.com/topic/170/coolpi-4b-loading-from-usb-ssd
                                大法师 @myhexb
                                能找到卡,不能启动,可能与分区表有关,请参考
                                https://www.cool-pi.com/topic/168/如果制作的启动盘无法加载/3
                                  myhexb @大法师
                                  找不到设备,数据线也换了两根了 就是读不到,设备管理器也看不到有设备
                                    jack_admin @myhexb
                                    @myhexb usb线插上面那个蓝色USB端口。另外驱动安装后,重启系统试试
                                      myhexb @jack_admin
                                      @jack_admin 都试了 , 重启 换线 换口 短接MASKROM和地 重装驱动
                                        jack_admin @myhexb
                                        @myhexb
                                        有些usb数据线是只供电的,不带数据信号。请确认一下
                                          myhexb @jack_admin
                                          @jack_admin 试了两根 万用表测4个触点通断也没问题,
                                            george @myhexb
                                            @myhexb 联系一下代理商,申请售后。
                                            • 2 / 3
