    81 Posts 14 Posters 34.3k Views
      ngavarta @ngavarta
      @ngavarta just got mine, can’t wait to hands on my new toy 😑
      • P
        petersen77 @george
        EXFAT is still not in the kernel. It also seems that the building process is broken, so I can't implement it. Please check.
        Best regards,
        Peter
          berkaroad @petersen77
          @petersen77
          append this to file arch/arm64/configs/coolpi_linux_defconfig , compile kernel and install to /boot/firmware
          CONFIG_EXFAT_FS=y
          M P 2 Replies Last reply Reply Quote 0
            Momo 0 @berkaroad
            • P
              petersen77 @berkaroad
              @berkaroad The generated files are not complete so WiFi, opengl and many more is not working.
                can we get some updated instructions in general? The repo on the first page doesnt seem to be the current one, and every build i do from the Current one doesnt seem to boot on my laptop.
                P 1 Reply Last reply Reply Quote 0
                • P
                  petersen77 @Momo 0
                  @Momo-0 The same here, I cannot replace the standard kernel with EXFAT support.
                    mainbord @petersen77
                    Hi help me please to find firmware for laptop, I Flashed ubuntu-24.04-preinstalled-desktop-arm64-coolpi-0926.img from google and it does not boot.
                      Momo 0 @mainbord
                      @mainbord for me currently only the Debian image works
                        mainbord @Momo 0
                        @Momo-0 said in Cool Pi Cm5-Laptop Linux Quick Start Guide:
                        Thanks, 11 debian booted. Because this is an old image.
                        P M 2 Replies Last reply Reply Quote 1
                        • P
                          petersen77 @mainbord
                          @mainbord Debian 13 is also working, but no EXFAT support in the kernel, so it's a little bit inconvenient copying files (e.g. my Camera is using EXFAT) or making backups
                            Momo 0 @petersen77
                            @petersen77 i got around this with installing exfat-progs and exfatfuse i think, after installing i needed to create a symlink like this "sudo ln -s /usr/sbin/mount.exfat-fuse /sbin/mount.exfat"
                            https://unix.stackexchange.com/questions/607949/cannot-mount-exfat-even-installed-exfat-fuse-exfat-utils-in-kali-linux
                            but yeah being able to compile the kernel or have this and some other features (vpn, filesystem encryption) in the kernel from the beginning for example would be better
                            • P
                              petersen77 @Momo 0
                              @Momo-0 Thanks, it's working now.
                                mainbord @mainbord
                                I boot from ubuntu 24.04 hdmi and usb 2.0 works. Usbc wi-fi and lcd do not work. This image not for laptop. Latest kernel source not for laptop too.
                                  Use the following command to generate a deb file and then install it.
                                  ./build-kernel.sh arm64
                                    @george said in Cool Pi Cm5-Laptop Linux Quick Start Guide:
                                    It was hard. Now it works but without wi-fi and sound
                                    How to install mainline kernel 6.18?
                                    • P
                                      petersen77 @george
                                      @george Can't finish the job. Btrfs module keeps sending an error when building the modules. The script doesn't finish.
                                        Tyied it
                                        https://github.com/armbian/build/pull/8275
                                        from usb and from nand it does not boot.
                                          Momo 0 @mainbord
                                          @mainbord same here, sadly Armbian isnt booting or else i would already be using it instead of the supplied distros
                                            The official default configuration of ARMBIN's loadaddr and optee conflicts and needs to be modified to 0x200000
                                            • 3 / 5
