    CM5如何安装网卡驱动?
    39 Posts 5 Posters 10.9k Views
      大法师 @jack_admin
      @jack_admin https://network.nvidia.com/products/ethernet-drivers/linux/mlnx_en/
      The NVIDIA ConnectX adapter family can run Ethernet traffic simultaneously on two ports
      Single software stack that operates across all available NVIDIA Ethernet devices and configurations such as mem-free, up to 400Gb/s, and PCI Express modes 3.0, 4.0 and 5.0
      Support for HPC applications for scientific research and AI
      Support for data center applications such as Oracle 11g/10g RAC, IBM DB2, Financial services applications such as IBM WebSphere LLM, Red Hat MRG, NYSE Data Fabric
        大法师 @Jachyn
        @Jachyn said in CM5如何安装网卡驱动?:
        @大法师 大师 内核已经编译了 编译之后进行安装 又报如下的错
        更新内核源码编译目录链接(假定源码目录在/home/coolpi/kernel)
        sudo ln -sf /home/coolpi/kernel /lib/modules/5.10.110/build
        sudo ln -sf /home/coolpi/kernel /lib/modules/5.10.110/source
        MLNX_EN_SRC-debian-23.04-1.1.3.0.tgz
        MLNX_EN_SRC-debian-5.8-3.0.7.0.tgz
        解压网卡驱动源码,编译
        coolpi@coolpi:~/MLNX_EN_SRC-23.04-1.1.3.0$ sudo ./install.pl
        Logs dir: /tmp/OFED.80654.logs
        General log file: /tmp/OFED.80654.logs/general.log
        ofed-scripts
        mlnx-tools
        mlnx-ofed-kernel-utils
        mlnx-ofed-kernel-modules
        Checking SW Requirements...
        swig  make python3 chrpath gcc quilt debhelper dh-python python3-distutils
        Removing old packages
        Building packages
        Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/MLNX_EN_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ofed-scripts_23.04-OFED.23.04.1.1.3_arm64.deb'
        Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/MLNX_EN_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-tools_23.04-0.2304053_arm64.deb'
        -W- --with-mlx5-ipsec is enabled
          Jachyn @大法师
          @大法师 更新源码目录链接显示如下错误
          ln: /lib/modules/5.10.110/build/kernel: cannot overwrite directory
          ln: /lib/modules/5.10.110/source/kernel: cannot overwrite directory
            大法师 @Jachyn
            @大法师 更新源码目录链接显示如下错误
            sudo unlink /lib/modules/5.10.110/build
            sudo unlink /lib/modules/5.10.110/source
            然后再操作。编译可能有错误,你先排查下
              Jachyn @大法师
              @大法师 编译内核使用命令make Image -j4,然后编译模块make modules -j4,并没有报错,内核 make modules_install 也是成功的
              当前日志显示
              coolpi@coolpi:~/Downloads/mlnx-en-23.04-0.5.3.3-ubuntu22.04-aarch64$ sudo ./install --force-dkms
              Logs dir: /tmp/mlnx-en.6425.logs
              General log file: /tmp/mlnx-en.6425.logs/general.log
              ofed-scripts
              mlnx-tools
              mlnx-en-utils
              mlnx-en-dkms
              mstflint
              Removing old packages...
              Installing new packages
              Installing mlnx-en-utils-23.04...
              Installing mlnx-en-dkms-23.04...
              Installing mstflint-4.16.1...
              (Reading database ... 196397 files and directories currently installed.)
              Preparing to unpack .../mlnx-fw-updater_23.04-0.5.3.3_arm64.deb ...
              Unpacking mlnx-fw-updater (23.04-0.5.3.3) ...
              Setting up mlnx-fw-updater (23.04-0.5.3.3) ...
              Initializing...
              Device #1:
                Device Type:      ConnectX4LX
                   FW             14.22.1002     14.32.1010
                   PXE            3.5.0403       3.6.0502
                   UEFI           14.15.0019     14.25.0017
                Status:           Update required
              Found 1 device(s) requiring firmware update...
              Device #1: Updating FW ...
              Done
              Restart needed for updates to take effect.
              Log File: /tmp/C3m3Iz3_P3
              Real log file: /tmp/mlnx-en.6425.logs/fw_update.log
              Device (0001:11:00.0):
              	PCI Link Speed: 2.5GT/s
              Device (0001:11:00.1):
              To load the new driver, run:
              /etc/init.d/mlnx-en.d restart
                大法师 @Jachyn
                @Jachyn 好
                  Jachyn @大法师
                  coolpi@coolpi:~/Desktop$ /etc/init.d/mlnx-en.d restart
                    大法师 @Jachyn
                    @Jachyn 加 sudo 执行试下
                      Jachyn @大法师
                        Jachyn @大法师
                        coolpi@coolpi:~/Downloads/mlnx-en-5.9-0.5.6.0-ubuntu22.04-aarch64$ sudo ./install --add-kernel-support
                        Note: This program will create mlnx-en TGZ for ubuntu22.04 under /tmp/mlnx-en-5.9-0.5.6.0-5.10.110 directory.
                        See log file /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs/mlnx_ofed_iso.109096.log
                        ERROR: Failed executing "MLNX_EN_SRC-5.9-0.5.6.0/install.pl --tmpdir /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs --eth-only --kernel 5.10.110 --kernel-sources /lib/modules/5.10.110/build --builddir /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096 --without-dkms --without-debug-symbols --build-only --distro ubuntu22.04"
                        ERROR: See /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs/mlnx_ofed_iso.109096.log
                        Failed to build mlnx-en for 5.10.110
                        是不是这系统就不支持这个驱动呢
                          jack_admin @Jachyn
                          执行这个之后,系统日志输出(dmesg)分析下错误原因。
                            Jake @george
                              Jake @Jake
                              我是不是需要去内核修改一些相关的配置?
                                jack_admin @Jake
                                @Jake 有什么问题?网口节点出来了没
                                  Jake @jack_admin
                                    Jachyn @jack_admin
                                    CMD: mlxup -u --log-on-update --ssl-certificate /tmp/SGKRmQP1We/mlxfwmanager_sriov_dis_aarch64_4115-dir/ca-bundle.crt --current-dir /opt/mellanox/mlnx-fw-updater/  -L /tmp/Nr5DC9bSSF -y -d 0001:11:00.0
                                    Device #1:
                                     Part Number:      --
                                     Description:
                                     PSID:
                                     Base MAC:         N/A
                                        FW             --
                                     Status:           Failed to open device
                                    -E- Failed to query 0001:11:00.0 device, error : No such file or directory. MFE_ICMD_NOT_SUPPORTED
                                    EXIT_STATUS: 0
                                    安装网卡驱动后 显示如上的日志
                                      Jachyn @Jachyn
                                      coolpi@coolpi:~/Downloads/mlnx-en-5.8-1.0.1.1-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                                      [sudo] password for coolpi:
                                      Logs dir: /tmp/mlnx-en.738979.logs
                                      General log file: /tmp/mlnx-en.738979.logs/general.log
                                      ofed-scripts
                                      mlnx-tools
                                      mlnx-en-utils
                                      mlnx-en-dkms
                                      mstflint
                                      Installing ofed-scripts-5.8...
                                      Installing mlnx-tools-5.2.0...
                                      Installing mlnx-en-utils-5.8...
                                      Installing mlnx-en-dkms-5.8...
                                      (Reading database ... 199866 files and directories currently installed.)
                                      Preparing to unpack .../mlnx-fw-updater_5.8-1.0.1.1_arm64.deb ...
                                      Unpacking mlnx-fw-updater (5.8-1.0.1.1) ...
                                      Setting up mlnx-fw-updater (5.8-1.0.1.1) ...
                                      Initializing...
                                      Device #1:
                                           FW             14.32.1010     14.32.1010
                                           PXE            3.6.0502       3.6.0502
                                           UEFI           14.25.0017     14.25.0017
                                        Status:           Up to date
                                      Log File: /tmp/DR3i76jLzy
                                      Real log file: /tmp/mlnx-en.738979.logs/fw_update.log
                                      coolpi@coolpi:~/Downloads/mlnx-en-5.8-1.0.1.1-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                                        Jachyn @Jachyn
                                        coolpi@coolpi:~/Downloads/mlnx-en-5.8-2.0.3.0-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                                        Logs dir: /tmp/mlnx-en.3438.logs
                                        General log file: /tmp/mlnx-en.3438.logs/general.log
                                        ofed-scripts
                                        mlnx-tools
                                        mlnx-en-utils
                                        mlnx-en-dkms
                                        mstflint
                                        Preparing to unpack .../mlnx-fw-updater_5.8-2.0.3.0_arm64.deb ...
                                        Unpacking mlnx-fw-updater (5.8-2.0.3.0) ...
                                        Setting up mlnx-fw-updater (5.8-2.0.3.0) ...
                                        Initializing...
                                        Device #1:
                                          Status:           Up to date
                                        Log File: /tmp/05iafkfb8h
                                        Real log file: /tmp/mlnx-en.3438.logs/fw_update.log
                                        	PCI Link Speed: 8GT/s
                                        coolpi@coolpi:~/Downloads/mlnx-en-5.8-2.0.3.0-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                                          Jachyn @Jachyn
                                          coolpi@coolpi:~/Downloads/mlnx-en-5.6-2.0.9.0-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                                          Logs dir: /tmp/mlnx-en.514532.logs
                                          General log file: /tmp/mlnx-en.514532.logs/general.log
                                          ofed-scripts
                                          mlnx-tools
                                          mlnx-en-utils
                                          mlnx-en-dkms
                                          mstflint
                                          Installing ofed-scripts-5.6...
                                          Installing mlnx-en-utils-5.6...
                                          Installing mlnx-en-dkms-5.6...
                                          (Reading database ... 199769 files and directories currently installed.)
                                          Preparing to unpack .../mlnx-fw-updater_5.6-2.0.9.0_arm64.deb ...
                                          Unpacking mlnx-fw-updater (5.6-2.0.9.0) ...
                                          Setting up mlnx-fw-updater (5.6-2.0.9.0) ...
                                          Initializing...
                                          Device #1:
                                            Status:           Up to date
                                          Log File: /tmp/07OcqgbJK0
                                          Real log file: /tmp/mlnx-en.514532.logs/fw_update.log
                                          coolpi@coolpi:~/Downloads/mlnx-en-5.6-2.0.9.0-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                                            Jachyn @Jachyn
                                            coolpi@coolpi:~/Downloads/mlnx-en-5.7-1.0.2.0-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                                            Logs dir: /tmp/mlnx-en.759187.logs
                                            General log file: /tmp/mlnx-en.759187.logs/general.log
                                            ofed-scripts
                                            mlnx-tools
                                            mlnx-en-utils
                                            mlnx-en-dkms
                                            mstflint
                                            Installing ofed-scripts-5.7...
                                            Installing mlnx-en-utils-5.7...
                                            Installing mlnx-en-dkms-5.7...
                                            (Reading database ... 199851 files and directories currently installed.)
                                            Preparing to unpack .../mlnx-fw-updater_5.7-1.0.2.0_arm64.deb ...
                                            Unpacking mlnx-fw-updater (5.7-1.0.2.0) ...
                                            Setting up mlnx-fw-updater (5.7-1.0.2.0) ...
                                            Initializing...
                                            Device #1:
                                              Status:           Up to date
                                            Log File: /tmp/FFuM6_xJPq
                                            Real log file: /tmp/mlnx-en.759187.logs/fw_update.log
                                            coolpi@coolpi:~/Downloads/mlnx-en-5.7-1.0.2.0-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
