    CM5如何安装网卡驱动?
    39 Posts 5 Posters 11.3k Views
      Jachyn @george
      目前的错误提示如上图所示,问一下怎么把内核的头文件编译生成deb包呢?🤔
        大法师 @Jachyn
        @Jachyn 我们提供的内核源码,你下载一份,先编译一次。
          Jachyn
          @大法师 大师 内核已经编译了 编译之后进行安装 又报如下的错
          J 大法师大 2 Replies Last reply Reply Quote 0
            jack_admin @Jachyn
            @Jachyn 你用的网卡驱动源码提供一个链接
              大法师 @jack_admin
              @jack_admin https://network.nvidia.com/products/ethernet-drivers/linux/mlnx_en/
              The NVIDIA ConnectX adapter family can run Ethernet traffic simultaneously on two ports
              Single software stack that operates across all available NVIDIA Ethernet devices and configurations such as mem-free, up to 400Gb/s, and PCI Express modes 3.0, 4.0 and 5.0
              Support for HPC applications for scientific research and AI
              Support for data center applications such as Oracle 11g/10g RAC, IBM DB2, Financial services applications such as IBM WebSphere LLM, Red Hat MRG, NYSE Data Fabric
                大法师 @Jachyn
                @Jachyn said in CM5如何安装网卡驱动?:
                更新内核源码编译目录链接(假定源码目录在/home/coolpi/kernel)
                sudo ln -sf /home/coolpi/kernel /lib/modules/5.10.110/build
                sudo ln -sf /home/coolpi/kernel /lib/modules/5.10.110/source
                MLNX_EN_SRC-debian-23.04-1.1.3.0.tgz
                MLNX_EN_SRC-debian-5.8-3.0.7.0.tgz
                解压网卡驱动源码,编译
                coolpi@coolpi:~/MLNX_EN_SRC-23.04-1.1.3.0$ sudo ./install.pl
                Logs dir: /tmp/OFED.80654.logs
                General log file: /tmp/OFED.80654.logs/general.log
                ofed-scripts
                mlnx-tools
                mlnx-ofed-kernel-utils
                mlnx-ofed-kernel-modules
                Checking SW Requirements...
                swig  make python3 chrpath gcc quilt debhelper dh-python python3-distutils
                Removing old packages
                Building packages
                Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/MLNX_EN_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ofed-scripts_23.04-OFED.23.04.1.1.3_arm64.deb'
                Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/MLNX_EN_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-tools_23.04-0.2304053_arm64.deb'
                -W- --with-mlx5-ipsec is enabled
                  Jachyn @大法师
                  @大法师 更新源码目录链接显示如下错误
                  ln: /lib/modules/5.10.110/build/kernel: cannot overwrite directory
                  ln: /lib/modules/5.10.110/source/kernel: cannot overwrite directory
                    大法师 @Jachyn
                    @大法师 更新源码目录链接显示如下错误
                    sudo unlink /lib/modules/5.10.110/build
                    sudo unlink /lib/modules/5.10.110/source
                    然后再操作。编译可能有错误,你先排查下
                      Jachyn @大法师
                      @大法师 编译内核使用命令make Image -j4,然后编译模块make modules -j4,并没有报错,内核 make modules_install 也是成功的
                      当前日志显示
                      coolpi@coolpi:~/Downloads/mlnx-en-23.04-0.5.3.3-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                      Logs dir: /tmp/mlnx-en.6425.logs
                      General log file: /tmp/mlnx-en.6425.logs/general.log
                      ofed-scripts
                      mlnx-tools
                      mlnx-en-utils
                      mlnx-en-dkms
                      mstflint
                      Removing old packages...
                      Installing new packages
                      Installing mlnx-en-utils-23.04...
                      Installing mlnx-en-dkms-23.04...
                      Installing mstflint-4.16.1...
                      (Reading database ... 196397 files and directories currently installed.)
                      Preparing to unpack .../mlnx-fw-updater_23.04-0.5.3.3_arm64.deb ...
                      Unpacking mlnx-fw-updater (23.04-0.5.3.3) ...
                      Setting up mlnx-fw-updater (23.04-0.5.3.3) ...
                      Initializing...
                      Device #1:
                        Device Type:      ConnectX4LX
                           FW             14.22.1002     14.32.1010
                           PXE            3.5.0403       3.6.0502
                           UEFI           14.15.0019     14.25.0017
                        Status:           Update required
                      Found 1 device(s) requiring firmware update...
                      Device #1: Updating FW ...
                      Done
                      Restart needed for updates to take effect.
                      Log File: /tmp/C3m3Iz3_P3
                      Real log file: /tmp/mlnx-en.6425.logs/fw_update.log
                      Device (0001:11:00.0):
                      	PCI Link Speed: 2.5GT/s
                      Device (0001:11:00.1):
                      To load the new driver, run:
                      /etc/init.d/mlnx-en.d restart
                        大法师 @Jachyn
                        @Jachyn 好
                          Jachyn @大法师
                          coolpi@coolpi:~/Desktop$ /etc/init.d/mlnx-en.d restart
                            大法师 @Jachyn
                            @Jachyn 加 sudo 执行试下
                              Jachyn @大法师
                                Jachyn @大法师
                                coolpi@coolpi:~/Downloads/mlnx-en-5.9-0.5.6.0-ubuntu22.04-aarch64$ sudo ./install --add-kernel-support
                                Note: This program will create mlnx-en TGZ for ubuntu22.04 under /tmp/mlnx-en-5.9-0.5.6.0-5.10.110 directory.
                                See log file /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs/mlnx_ofed_iso.109096.log
                                ERROR: Failed executing "MLNX_EN_SRC-5.9-0.5.6.0/install.pl --tmpdir /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs --eth-only --kernel 5.10.110 --kernel-sources /lib/modules/5.10.110/build --builddir /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096 --without-dkms --without-debug-symbols --build-only --distro ubuntu22.04"
                                ERROR: See /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs/mlnx_ofed_iso.109096.log
                                Failed to build mlnx-en for 5.10.110
                                是不是这系统就不支持这个驱动呢
                                  jack_admin @Jachyn
                                  执行这个之后,系统日志输出(dmesg)分析下错误原因。
                                    Jake @george
                                      Jake @Jake
                                      我是不是需要去内核修改一些相关的配置?
                                        jack_admin @Jake
                                        @Jake 有什么问题?网口节点出来了没
                                          Jake @jack_admin
                                            Jachyn @jack_admin
                                            CMD: mlxup -u --log-on-update --ssl-certificate /tmp/SGKRmQP1We/mlxfwmanager_sriov_dis_aarch64_4115-dir/ca-bundle.crt --current-dir /opt/mellanox/mlnx-fw-updater/  -L /tmp/Nr5DC9bSSF -y -d 0001:11:00.0
                                            Device #1:
                                             Part Number:      --
                                             Description:
                                             PSID:
                                             Base MAC:         N/A
                                                FW             --
                                             Status:           Failed to open device
                                            -E- Failed to query 0001:11:00.0 device, error : No such file or directory. MFE_ICMD_NOT_SUPPORTED
                                            EXIT_STATUS: 0
                                            安装网卡驱动后 显示如上的日志
