    CM5如何安装网卡驱动?
    39 Posts 5 Posters 11.3k Views
      大法师 @Jachyn
      @Jachyn 加 sudo 执行试下
        Jachyn @大法师
          Jachyn @大法师
          coolpi@coolpi:~/Downloads/mlnx-en-5.9-0.5.6.0-ubuntu22.04-aarch64$ sudo ./install --add-kernel-support
          Note: This program will create mlnx-en TGZ for ubuntu22.04 under /tmp/mlnx-en-5.9-0.5.6.0-5.10.110 directory.
          See log file /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs/mlnx_ofed_iso.109096.log
          ERROR: Failed executing "MLNX_EN_SRC-5.9-0.5.6.0/install.pl --tmpdir /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs --eth-only --kernel 5.10.110 --kernel-sources /lib/modules/5.10.110/build --builddir /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096 --without-dkms --without-debug-symbols --build-only --distro ubuntu22.04"
          ERROR: See /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs/mlnx_ofed_iso.109096.log
          Failed to build mlnx-en for 5.10.110
          是不是这系统就不支持这个驱动呢
            jack_admin @Jachyn
            @Jachyn said in CM5如何安装网卡驱动?:
            执行这个之后,系统日志输出(dmesg)分析下错误原因。
              Jake @george
                Jake @Jake
                我是不是需要去内核修改一些相关的配置?
                  jack_admin @Jake
                  @Jake 有什么问题?网口节点出来了没
                    Jake @jack_admin
                      Jachyn @jack_admin
                      CMD: mlxup -u --log-on-update --ssl-certificate /tmp/SGKRmQP1We/mlxfwmanager_sriov_dis_aarch64_4115-dir/ca-bundle.crt --current-dir /opt/mellanox/mlnx-fw-updater/  -L /tmp/Nr5DC9bSSF -y -d 0001:11:00.0
                      Device #1:
                       Device Type:      ConnectX4LX
                       Part Number:      --
                       Description:
                       PSID:
                       Base MAC:         N/A
                          FW             --
                       Status:           Failed to open device
                      -E- Failed to query 0001:11:00.0 device, error : No such file or directory. MFE_ICMD_NOT_SUPPORTED
                      EXIT_STATUS: 0
                      安装网卡驱动后 显示如上的日志
                        Jachyn @Jachyn
                        coolpi@coolpi:~/Downloads/mlnx-en-5.8-1.0.1.1-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                        [sudo] password for coolpi:
                        Logs dir: /tmp/mlnx-en.738979.logs
                        General log file: /tmp/mlnx-en.738979.logs/general.log
                        ofed-scripts
                        mlnx-tools
                        mlnx-en-utils
                        mlnx-en-dkms
                        mstflint
                        Checking SW Requirements...
                        Removing old packages...
                        Installing new packages
                        Installing ofed-scripts-5.8...
                        Installing mlnx-tools-5.2.0...
                        Installing mlnx-en-utils-5.8...
                        Installing mlnx-en-dkms-5.8...
                        Installing mstflint-4.16.1...
                        (Reading database ... 199866 files and directories currently installed.)
                        Preparing to unpack .../mlnx-fw-updater_5.8-1.0.1.1_arm64.deb ...
                        Unpacking mlnx-fw-updater (5.8-1.0.1.1) ...
                        Setting up mlnx-fw-updater (5.8-1.0.1.1) ...
                        Initializing...
                        Device #1:
                             FW             14.32.1010     14.32.1010
                             PXE            3.6.0502       3.6.0502
                             UEFI           14.25.0017     14.25.0017
                          Status:           Up to date
                        Log File: /tmp/DR3i76jLzy
                        Real log file: /tmp/mlnx-en.738979.logs/fw_update.log
                        Device (0001:11:00.0):
                        	PCI Link Speed: 2.5GT/s
                        Device (0001:11:00.1):
                        To load the new driver, run:
                        coolpi@coolpi:~/Downloads/mlnx-en-5.8-1.0.1.1-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                          Jachyn @Jachyn
                          coolpi@coolpi:~/Downloads/mlnx-en-5.8-2.0.3.0-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                          Logs dir: /tmp/mlnx-en.3438.logs
                          General log file: /tmp/mlnx-en.3438.logs/general.log
                          ofed-scripts
                          mlnx-tools
                          mlnx-en-utils
                          mlnx-en-dkms
                          mstflint
                          Preparing to unpack .../mlnx-fw-updater_5.8-2.0.3.0_arm64.deb ...
                          Unpacking mlnx-fw-updater (5.8-2.0.3.0) ...
                          Setting up mlnx-fw-updater (5.8-2.0.3.0) ...
                          Initializing...
                          Device #1:
                            Status:           Up to date
                          Log File: /tmp/05iafkfb8h
                          Real log file: /tmp/mlnx-en.3438.logs/fw_update.log
                          	PCI Link Speed: 8GT/s
                          coolpi@coolpi:~/Downloads/mlnx-en-5.8-2.0.3.0-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                            Jachyn @Jachyn
                            coolpi@coolpi:~/Downloads/mlnx-en-5.6-2.0.9.0-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                            Logs dir: /tmp/mlnx-en.514532.logs
                            General log file: /tmp/mlnx-en.514532.logs/general.log
                            ofed-scripts
                            mlnx-tools
                            mlnx-en-utils
                            mlnx-en-dkms
                            mstflint
                            Installing ofed-scripts-5.6...
                            Installing mlnx-en-utils-5.6...
                            Installing mlnx-en-dkms-5.6...
                            (Reading database ... 199769 files and directories currently installed.)
                            Preparing to unpack .../mlnx-fw-updater_5.6-2.0.9.0_arm64.deb ...
                            Unpacking mlnx-fw-updater (5.6-2.0.9.0) ...
                            Setting up mlnx-fw-updater (5.6-2.0.9.0) ...
                            Initializing...
                            Device #1:
                              Status:           Up to date
                            Log File: /tmp/07OcqgbJK0
                            Real log file: /tmp/mlnx-en.514532.logs/fw_update.log
                            coolpi@coolpi:~/Downloads/mlnx-en-5.6-2.0.9.0-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                              Jachyn @Jachyn
                              coolpi@coolpi:~/Downloads/mlnx-en-5.7-1.0.2.0-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                              Logs dir: /tmp/mlnx-en.759187.logs
                              General log file: /tmp/mlnx-en.759187.logs/general.log
                              ofed-scripts
                              mlnx-tools
                              mlnx-en-utils
                              mlnx-en-dkms
                              mstflint
                              Installing ofed-scripts-5.7...
                              Installing mlnx-en-utils-5.7...
                              Installing mlnx-en-dkms-5.7...
                              (Reading database ... 199851 files and directories currently installed.)
                              Preparing to unpack .../mlnx-fw-updater_5.7-1.0.2.0_arm64.deb ...
                              Unpacking mlnx-fw-updater (5.7-1.0.2.0) ...
                              Setting up mlnx-fw-updater (5.7-1.0.2.0) ...
                              Initializing...
                              Device #1:
                                Status:           Up to date
                              Log File: /tmp/FFuM6_xJPq
                              Real log file: /tmp/mlnx-en.759187.logs/fw_update.log
                              coolpi@coolpi:~/Downloads/mlnx-en-5.7-1.0.2.0-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                                jack_admin @Jachyn
                                @Jachyn 需要把驱动加载过程,内核打印日志输出看看错误在哪,可以用dmesg命令
                                  Jachyn @Jachyn
                                  root@coolpi:/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0# ./install.pl
                                  Logs dir: /tmp/OFED.127412.logs
                                  General log file: /tmp/OFED.127412.logs/general.log
                                  ofed-scripts
                                  mlnx-tools
                                  mlnx-ofed-kernel-utils
                                  mlnx-ofed-kernel-modules
                                  srp-modules
                                  mlnx-nvme-modules
                                  rdma-core
                                  libibverbs1
                                  ibverbs-utils
                                  ibverbs-providers
                                  libibverbs-dev
                                  libibverbs1-dbg
                                  libibumad3
                                  libibumad-dev
                                  ibacm
                                  librdmacm1
                                  rdmacm-utils
                                  librdmacm-dev
                                  mstflint
                                  libibmad5
                                  libibmad-dev
                                  libibnetdisc5
                                  infiniband-diags
                                  kernel-mft-modules
                                  perftest
                                  ibsim
                                  ibsim-doc
                                  ucx
                                  openmpi
                                  mpitests
                                  knem-modules
                                  srptools
                                  mlnx-ethtool
                                  mlnx-iproute2
                                  rshim
                                  ibarr
                                  build-essential autotools-dev pkg-config  python3-docutils debhelper libstdc++6 pandoc bison dh-autoreconf devscripts libmnl-dev fakeroot libgfortran5 cython3 libnuma-dev libnl-route-3-dev libssl-dev python3-dev libnl-3-dev autoconf quilt libfuse-dev python3-distutils flex libsystemd-dev libselinux1-dev libudev-dev dh-python cmake libpci-dev sudo make libdb-dev libusb-1.0-0-dev libelf-dev libtool valgrind python3 gcc bzip2
                                  Error: One or more packages depends on MLNX_OFED.
                                  Those packages should be removed before uninstalling MLNX_OFED:
                                  licensecheck libarray-intspan-perl
                                  To force uninstallation use '--force' flag.
                                  root@coolpi:/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0# ./install.pl --force
                                  Logs dir: /tmp/OFED.129276.logs
                                  General log file: /tmp/OFED.129276.logs/general.log
                                  ofed-scripts
                                  mlnx-tools
                                  srp-modules
                                  mlnx-nvme-modules
                                  rdma-core
                                  libibverbs1
                                  ibverbs-utils
                                  ibverbs-providers
                                  libibverbs-dev
                                  libibverbs1-dbg
                                  libibumad3
                                  libibumad-dev
                                  ibacm
                                  librdmacm1
                                  rdmacm-utils
                                  librdmacm-dev
                                  mstflint
                                  libibmad5
                                  libibmad-dev
                                  libibnetdisc5
                                  infiniband-diags
                                  kernel-mft-modules
                                  perftest
                                  ibsim
                                  ibsim-doc
                                  ucx
                                  openmpi
                                  mpitests
                                  knem-modules
                                  srptools
                                  mlnx-ethtool
                                  mlnx-iproute2
                                  rshim
                                  ibarr
                                  flex libelf-dev fakeroot autoconf autotools-dev dh-python libtool libfuse-dev sudo debhelper python3-docutils libnl-route-3-dev pandoc bison libselinux1-dev quilt python3 libgfortran5 build-essential valgrind libsystemd-dev libssl-dev cmake libnl-3-dev libudev-dev cython3 python3-distutils libdb-dev libpci-dev python3-dev  devscripts bzip2 libmnl-dev gcc libstdc++6 pkg-config libnuma-dev libusb-1.0-0-dev make dh-autoreconf
                                  Building packages
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ofed-scripts_23.04-OFED.23.04.1.1.3_arm64.deb'
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-tools_23.04-0.2304053_arm64.deb'
                                  Installing mlnx-ofed-kernel-utils-23.04...
                                  Running /usr/bin/dpkg -i --force-confnew --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-ofed-kernel-utils_23.04-OFED.23.04.1.1.3.1.kver.5.10.110_arm64.deb'
                                  Installing mlnx-ofed-kernel-modules-23.04...
                                  Running /usr/bin/dpkg -i --force-confnew --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-ofed-kernel-modules_23.04-OFED.23.04.1.1.3.1.kver.5.10.110_arm64.deb'
                                  Building DEB for srp-modules-23.04 (srp)...
                                  Installing srp-modules-23.04...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/srp-modules_23.04-OFED.23.04.0.5.3.1.kver.5.10.110_arm64.deb'
                                  Building DEB for mlnx-nvme-modules-23.04 (mlnx-nvme)...
                                  Installing mlnx-nvme-modules-23.04...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-nvme-modules_23.04-OFED.23.04.0.5.3.1.kver.5.10.110_arm64.deb'
                                  Building DEB for rdma-core-2304mlnx44 (rdma-core)...
                                  Installing rdma-core-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/rdma-core_2304mlnx44-1.2304113_arm64.deb'
                                  Installing libibverbs1-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibverbs1_2304mlnx44-1.2304113_arm64.deb'
                                  Installing ibverbs-utils-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibverbs-utils_2304mlnx44-1.2304113_arm64.deb'
                                  Installing ibverbs-providers-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibverbs-providers_2304mlnx44-1.2304113_arm64.deb'
                                  Installing libibverbs-dev-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibverbs-dev_2304mlnx44-1.2304113_arm64.deb'
                                  Installing libibverbs1-dbg-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibverbs1-dbg_2304mlnx44-1.2304113_arm64.deb'
                                  Installing libibumad3-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibumad3_2304mlnx44-1.2304113_arm64.deb'
                                  Installing libibumad-dev-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibumad-dev_2304mlnx44-1.2304113_arm64.deb'
                                  Installing ibacm-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibacm_2304mlnx44-1.2304113_arm64.deb'
                                  Installing librdmacm1-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/librdmacm1_2304mlnx44-1.2304113_arm64.deb'
                                  Installing rdmacm-utils-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/rdmacm-utils_2304mlnx44-1.2304113_arm64.deb'
                                  Installing librdmacm-dev-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/librdmacm-dev_2304mlnx44-1.2304113_arm64.deb'
                                  Building DEB for mstflint-4.16.1 (mstflint)...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mstflint_4.16.1-2.2304053_arm64.deb'
                                  Installing libibmad5-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibmad5_2304mlnx44-1.2304113_arm64.deb'
                                  Installing libibmad-dev-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibmad-dev_2304mlnx44-1.2304113_arm64.deb'
                                  Installing libibnetdisc5-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibnetdisc5_2304mlnx44-1.2304113_arm64.deb'
                                  Installing infiniband-diags-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/infiniband-diags_2304mlnx44-1.2304113_arm64.deb'
                                  Building DEB for kernel-mft-modules-4.24.0 (kernel-mft)...
                                  Installing kernel-mft-modules-4.24.0...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/kernel-mft-modules_4.24.0-72.kver.5.10.110_all.deb'
                                  Building DEB for perftest-23.04.0 (perftest)...
                                  Installing perftest-23.04.0...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/perftest_23.04.0-0.23.g63e250f.2304053_arm64.deb'
                                  Building DEB for ibsim-0.12 (ibsim)...
                                  Installing ibsim-0.12...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibsim_0.12-1.2304053_arm64.deb'
                                  Installing ibsim-doc-0.12...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibsim-doc_0.12-1.2304053_all.deb'
                                  Building DEB for ucx-1.15.0 (ucx)...
                                  Installing ucx-1.15.0...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ucx_1.15.0-1.2304053_arm64.deb'
                                  Building DEB for openmpi-4.1.5rc2 (openmpi)...
                                  Running  mellanox_autodetect='yes' /usr/bin/dpkg-buildpackage -us -uc
                                  Installing openmpi-4.1.5rc2...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/openmpi_4.1.5rc2-1.2304053_all.deb'
                                  Building DEB for mpitests-3.2.20 (mpitests)...
                                  Installing mpitests-3.2.20...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mpitests_3.2.20-de56b6b.2304053_arm64.deb'
                                  Building DEB for knem-modules-1.1.4.90mlnx2 (knem)...
                                  Installing knem-modules-1.1.4.90mlnx2...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/knem-modules_1.1.4.90mlnx2-OFED.23.04.0.5.2.1.kver.5.10.110_arm64.deb'
                                  Installing srptools-2304mlnx44...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/srptools_2304mlnx44-1.2304113_arm64.deb'
                                  Building DEB for mlnx-ethtool-6.0 (mlnx-ethtool)...
                                  Installing mlnx-ethtool-6.0...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-ethtool_6.0-1.2304053_arm64.deb'
                                  Building DEB for mlnx-iproute2-6.2.0 (mlnx-iproute2)...
                                  Installing mlnx-iproute2-6.2.0...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-iproute2_6.2.0-1.2304053_arm64.deb'
                                  Building DEB for rshim-2.0.6 (rshim)...
                                  Installing rshim-2.0.6...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/rshim_2.0.6-19.g0873acd.2304113_arm64.deb'
                                  Building DEB for ibarr-0.1.3 (ibarr)...
                                  Installing ibarr-0.1.3...
                                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibarr_0.1.3-1.2304053_arm64.deb'
                                    Jachyn @jack_admin
                                    [11810.222046] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11936.108867] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11936.108876] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11936.358696] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11936.358704] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11936.611757] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11936.611762] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11936.743419] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11936.743427] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11936.810102] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11936.810110] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11936.826712] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11936.826721] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11936.876678] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11936.876687] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11936.909930] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11936.909938] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11936.927166] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11936.927174] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11936.943234] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11936.943244] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11936.960300] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11936.960307] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11936.974299] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11936.974307] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11936.994271] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11936.994279] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.007777] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.007786] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11937.026685] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11937.026694] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.041018] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.041025] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11937.060333] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11937.060346] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.208100] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.208108] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11937.243441] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11937.243450] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.276830] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.276838] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11937.376144] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11937.376152] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.390939] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.390948] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11937.408707] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11937.408715] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.424696] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.424703] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11937.441800] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11937.441809] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.457559] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.457567] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11937.476665] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11937.476673] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.494117] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.494125] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11937.527350] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11937.527358] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.543463] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.543472] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11937.677395] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11937.677402] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.693754] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.693778] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11937.827447] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11937.827455] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.843330] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.843338] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11937.859775] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11937.859783] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.876886] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.876894] rockchip-vop2 fdd90000.vop: pd0 on
                                    [11937.977322] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [11937.977330] rockchip-vop2 fdd90000.vop: pd0 off
                                    [11937.993229] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [11937.993237] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12026.742752] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [12026.742761] rockchip-vop2 fdd90000.vop: pd0 off
                                    [12028.675768] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [12028.675777] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12038.110980] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [12038.110991] rockchip-vop2 fdd90000.vop: pd0 off
                                    [12042.042122] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [12042.042131] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12059.577168] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [12059.577176] rockchip-vop2 fdd90000.vop: pd0 off
                                    [12097.108956] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [12097.108964] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12112.377853] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [12112.377862] rockchip-vop2 fdd90000.vop: pd0 off
                                    [12113.609157] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [12113.609166] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12113.743643] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [12113.743651] rockchip-vop2 fdd90000.vop: pd0 off
                                    [12115.227092] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [12115.227099] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12115.243558] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [12115.243567] rockchip-vop2 fdd90000.vop: pd0 off
                                    [12123.609235] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [12123.609244] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12138.310541] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [12138.310549] rockchip-vop2 fdd90000.vop: pd0 off
                                    [12138.461714] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [12138.461723] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12177.442599] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [12177.442612] rockchip-vop2 fdd90000.vop: pd0 off
                                    [12177.459270] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [12177.459282] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12214.938648] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [12214.938655] rockchip-vop2 fdd90000.vop: pd0 off
                                    [12214.955385] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [12214.955393] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12307.991337] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [12307.991341] rockchip-vop2 fdd90000.vop: pd0 off
                                    [12310.607684] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [12310.607688] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12430.810610] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [12430.810618] rockchip-vop2 fdd90000.vop: pd0 off
                                    [12449.474330] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [12449.474333] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12827.407348] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 512 (unused: 4608)
                                    [12830.044346] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 512 (unused: 2560)
                                    [12832.345678] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 1024 (unused: 5120)
                                    [12834.277161] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 1024 (unused: 3072)
                                    [12839.567026] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 2048 (unused: 4608)
                                    [12946.121325] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 1536 (unused: 3584)
                                    [12973.576452] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [12973.576460] rockchip-vop2 fdd90000.vop: pd0 off
                                    [12979.624709] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                    [12979.624713] rockchip-vop2 fdd90000.vop: pd0 on
                                    [12991.331086] mlx5_core: version magic '5.10.110 SMP preempt mod_unload aarch64' should be '5.10.110 SMP mod_unload aarch64'
                                    [13019.261815] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                    [13019.261823] rockchip-vop2 fdd90000.vop: pd0 off
                                    dmseg的结果如上
                                      jack_admin @Jachyn
                                      @Jachyn
                                      1. modinfo mlx5相关的ko驱动文件
                                      2. 内核更改配置为抢占模式,编译替换
                                        Jachyn @jack_admin
                                        [ 8935.079458] mlx5_core: Unknown symbol pci_num_vf (err -2)
                                        [ 8935.079472] mlx5_core: Unknown symbol pci_sriov_get_totalvfs (err -2)
                                        [ 8935.079526] mlx5_core: Unknown symbol net_dim (err -2)
                                        [ 8935.079536] mlx5_core: Unknown symbol numa_node (err -2)
                                        [ 8935.079650] mlx5_core: Unknown symbol net_dim_get_rx_moderation (err -2)
                                        [ 8935.079667] mlx5_core: Unknown symbol net_dim_get_def_tx_moderation (err -2)
                                        [ 8935.079679] mlx5_core: Unknown symbol pci_disable_sriov (err -2)
                                        [ 8935.079686] mlx5_core: Unknown symbol net_dim_get_def_rx_moderation (err -2)
                                        [ 8935.079687] mlx5_core: Unknown symbol net_dim_get_tx_moderation (err -2)
                                        [ 8935.079711] mlx5_core: Unknown symbol pci_enable_sriov (err -2)
                                        [ 8935.079715] mlx5_core: Unknown symbol elfcorehdr_addr (err -2)
                                        [ 8935.079725] mlx5_core: Unknown symbol alloc_pages_current (err -2)
                                        这次不报抢占的错误了 但是有这些
                                          Jachyn @Jachyn
                                          @Jachyn
                                          root@coolpi:/home/coolpi/Downloads/mlnx-en-5.9-0.5.6.0-ubuntu22.04-aarch64/mlnx-en-5.9-0.5.6.0-ubuntu22.04-aarch64# ./mlnx_add_kernel_support.sh -m ./
                                          Note: This program will create mlnx-en TGZ for ubuntu22.04 under /tmp directory.
                                          See log file /tmp/mlnx_iso.834968_logs/mlnx_ofed_iso.834968.log
                                          ERROR: Failed executing "MLNX_EN_SRC-5.9-0.5.6.0/install.pl --tmpdir /tmp/mlnx_iso.834968_logs --eth-only --kernel 5.10.110 --kernel-sources /lib/modules/5.10.110/build/ --builddir /tmp/mlnx_iso.834968 --without-dkms --build-only"
                                          ERROR: See /tmp/mlnx_iso.834968_logs/mlnx_ofed_iso.834968.log
                                            jack_admin @Jachyn
                                            @Jachyn 内核配置增加CONFIG_PCI_IOV,还有其他的根据相应的symbol查找。
                                            另外发现内核带有一个版本的驱动,你可以试下配置编译试试
                                            drivers/net/ethernet/mellanox/
                                            ├── Kconfig
                                            ├── Makefile
                                            ├── mlx4
                                            ├── mlx5
                                            ├── mlxfw
                                            └── mlxsw
                                            4 directories, 2 files
