    CM5如何安装网卡驱动?
    39 Posts 5 Posters 10.9k Views
      大法师 @Jachyn
      @Jachyn said in CM5如何安装网卡驱动?:
      @大法师 更新源码目录链接显示如下错误
      ln: /lib/modules/5.10.110/build/kernel: cannot overwrite directory
      ln: /lib/modules/5.10.110/source/kernel: cannot overwrite directory
      sudo unlink /lib/modules/5.10.110/build
      sudo unlink /lib/modules/5.10.110/source
      然后再操作。编译可能有错误,你先排查下
        Jachyn @大法师
        @大法师 编译内核使用命令make Image -j4,然后编译模块make modules -j4,并没有报错,内核 make modules_install 也是成功的
        当前日志显示
        coolpi@coolpi:~/Downloads/mlnx-en-23.04-0.5.3.3-ubuntu22.04-aarch64$ sudo ./install --force-dkms
        Logs dir: /tmp/mlnx-en.6425.logs
        General log file: /tmp/mlnx-en.6425.logs/general.log
        ofed-scripts
        mlnx-tools
        mlnx-en-utils
        mlnx-en-dkms
        mstflint
        Checking SW Requirements...
        Removing old packages...
        Installing new packages
        Installing mlnx-en-utils-23.04...
        Installing mlnx-en-dkms-23.04...
        Installing mstflint-4.16.1...
        (Reading database ... 196397 files and directories currently installed.)
        Preparing to unpack .../mlnx-fw-updater_23.04-0.5.3.3_arm64.deb ...
        Unpacking mlnx-fw-updater (23.04-0.5.3.3) ...
        Setting up mlnx-fw-updater (23.04-0.5.3.3) ...
        Initializing...
        Device #1:
          Device Type:      ConnectX4LX
             FW             14.22.1002     14.32.1010
             PXE            3.5.0403       3.6.0502
             UEFI           14.15.0019     14.25.0017
          Status:           Update required
        Found 1 device(s) requiring firmware update...
        Device #1: Updating FW ...
        Done
        Restart needed for updates to take effect.
        Log File: /tmp/C3m3Iz3_P3
        Real log file: /tmp/mlnx-en.6425.logs/fw_update.log
        Device (0001:11:00.0):
        	PCI Link Speed: 2.5GT/s
        Device (0001:11:00.1):
        To load the new driver, run:
        /etc/init.d/mlnx-en.d restart
          大法师 @Jachyn
          @Jachyn 好
            Jachyn @大法师
            coolpi@coolpi:~/Desktop$ /etc/init.d/mlnx-en.d restart
              大法师 @Jachyn
              @Jachyn 加 sudo 执行试下
                Jachyn @大法师
                  Jachyn @大法师
                  coolpi@coolpi:~/Downloads/mlnx-en-5.9-0.5.6.0-ubuntu22.04-aarch64$ sudo ./install --add-kernel-support
                  Note: This program will create mlnx-en TGZ for ubuntu22.04 under /tmp/mlnx-en-5.9-0.5.6.0-5.10.110 directory.
                  See log file /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs/mlnx_ofed_iso.109096.log
                  ERROR: Failed executing "MLNX_EN_SRC-5.9-0.5.6.0/install.pl --tmpdir /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs --eth-only --kernel 5.10.110 --kernel-sources /lib/modules/5.10.110/build --builddir /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096 --without-dkms --without-debug-symbols --build-only --distro ubuntu22.04"
                  ERROR: See /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs/mlnx_ofed_iso.109096.log
                  Failed to build mlnx-en for 5.10.110
                  是不是这系统就不支持这个驱动呢
                    jack_admin @Jachyn
                    执行这个之后,系统日志输出(dmesg)分析下错误原因。
                      Jake @george
                        Jake @Jake
                        我是不是需要去内核修改一些相关的配置?
                          jack_admin @Jake
                          @Jake 有什么问题?网口节点出来了没
                            Jake @jack_admin
                              Jachyn @jack_admin
                              CMD: mlxup -u --log-on-update --ssl-certificate /tmp/SGKRmQP1We/mlxfwmanager_sriov_dis_aarch64_4115-dir/ca-bundle.crt --current-dir /opt/mellanox/mlnx-fw-updater/  -L /tmp/Nr5DC9bSSF -y -d 0001:11:00.0
                              Device #1:
                               Part Number:      --
                               Description:
                               PSID:
                               Base MAC:         N/A
                                  FW             --
                               Status:           Failed to open device
                              -E- Failed to query 0001:11:00.0 device, error : No such file or directory. MFE_ICMD_NOT_SUPPORTED
                              EXIT_STATUS: 0
                              安装网卡驱动后 显示如上的日志
                                Jachyn @Jachyn
                                coolpi@coolpi:~/Downloads/mlnx-en-5.8-1.0.1.1-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                                [sudo] password for coolpi:
                                Logs dir: /tmp/mlnx-en.738979.logs
                                General log file: /tmp/mlnx-en.738979.logs/general.log
                                ofed-scripts
                                mlnx-tools
                                mlnx-en-utils
                                mlnx-en-dkms
                                mstflint
                                Installing ofed-scripts-5.8...
                                Installing mlnx-tools-5.2.0...
                                Installing mlnx-en-utils-5.8...
                                Installing mlnx-en-dkms-5.8...
                                (Reading database ... 199866 files and directories currently installed.)
                                Preparing to unpack .../mlnx-fw-updater_5.8-1.0.1.1_arm64.deb ...
                                Unpacking mlnx-fw-updater (5.8-1.0.1.1) ...
                                Setting up mlnx-fw-updater (5.8-1.0.1.1) ...
                                Initializing...
                                Device #1:
                                     FW             14.32.1010     14.32.1010
                                     PXE            3.6.0502       3.6.0502
                                     UEFI           14.25.0017     14.25.0017
                                  Status:           Up to date
                                Log File: /tmp/DR3i76jLzy
                                Real log file: /tmp/mlnx-en.738979.logs/fw_update.log
                                coolpi@coolpi:~/Downloads/mlnx-en-5.8-1.0.1.1-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                                  Jachyn @Jachyn
                                  coolpi@coolpi:~/Downloads/mlnx-en-5.8-2.0.3.0-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                                  Logs dir: /tmp/mlnx-en.3438.logs
                                  General log file: /tmp/mlnx-en.3438.logs/general.log
                                  ofed-scripts
                                  mlnx-tools
                                  mlnx-en-utils
                                  mlnx-en-dkms
                                  mstflint
                                  Preparing to unpack .../mlnx-fw-updater_5.8-2.0.3.0_arm64.deb ...
                                  Unpacking mlnx-fw-updater (5.8-2.0.3.0) ...
                                  Setting up mlnx-fw-updater (5.8-2.0.3.0) ...
                                  Initializing...
                                  Device #1:
                                    Status:           Up to date
                                  Log File: /tmp/05iafkfb8h
                                  Real log file: /tmp/mlnx-en.3438.logs/fw_update.log
                                  	PCI Link Speed: 8GT/s
                                  coolpi@coolpi:~/Downloads/mlnx-en-5.8-2.0.3.0-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                                    Jachyn @Jachyn
                                    coolpi@coolpi:~/Downloads/mlnx-en-5.6-2.0.9.0-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                                    Logs dir: /tmp/mlnx-en.514532.logs
                                    General log file: /tmp/mlnx-en.514532.logs/general.log
                                    ofed-scripts
                                    mlnx-tools
                                    mlnx-en-utils
                                    mlnx-en-dkms
                                    mstflint
                                    Installing ofed-scripts-5.6...
                                    Installing mlnx-en-utils-5.6...
                                    Installing mlnx-en-dkms-5.6...
                                    (Reading database ... 199769 files and directories currently installed.)
                                    Preparing to unpack .../mlnx-fw-updater_5.6-2.0.9.0_arm64.deb ...
                                    Unpacking mlnx-fw-updater (5.6-2.0.9.0) ...
                                    Setting up mlnx-fw-updater (5.6-2.0.9.0) ...
                                    Initializing...
                                    Device #1:
                                      Status:           Up to date
                                    Log File: /tmp/07OcqgbJK0
                                    Real log file: /tmp/mlnx-en.514532.logs/fw_update.log
                                    coolpi@coolpi:~/Downloads/mlnx-en-5.6-2.0.9.0-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                                      Jachyn @Jachyn
                                      coolpi@coolpi:~/Downloads/mlnx-en-5.7-1.0.2.0-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                                      Logs dir: /tmp/mlnx-en.759187.logs
                                      General log file: /tmp/mlnx-en.759187.logs/general.log
                                      ofed-scripts
                                      mlnx-tools
                                      mlnx-en-utils
                                      mlnx-en-dkms
                                      mstflint
                                      Installing ofed-scripts-5.7...
                                      Installing mlnx-en-utils-5.7...
                                      Installing mlnx-en-dkms-5.7...
                                      (Reading database ... 199851 files and directories currently installed.)
                                      Preparing to unpack .../mlnx-fw-updater_5.7-1.0.2.0_arm64.deb ...
                                      Unpacking mlnx-fw-updater (5.7-1.0.2.0) ...
                                      Setting up mlnx-fw-updater (5.7-1.0.2.0) ...
                                      Initializing...
                                      Device #1:
                                        Status:           Up to date
                                      Log File: /tmp/FFuM6_xJPq
                                      Real log file: /tmp/mlnx-en.759187.logs/fw_update.log
                                      coolpi@coolpi:~/Downloads/mlnx-en-5.7-1.0.2.0-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                                        jack_admin @Jachyn
                                        @Jachyn 需要把驱动加载过程,内核打印日志输出看看错误在哪,可以用dmesg命令
                                          Jachyn @Jachyn
                                          root@coolpi:/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0# ./install.pl
                                          Logs dir: /tmp/OFED.127412.logs
                                          General log file: /tmp/OFED.127412.logs/general.log
                                          ofed-scripts
                                          mlnx-tools
                                          mlnx-ofed-kernel-utils
                                          mlnx-ofed-kernel-modules
                                          srp-modules
                                          mlnx-nvme-modules
                                          rdma-core
                                          libibverbs1
                                          ibverbs-utils
                                          ibverbs-providers
                                          libibverbs-dev
                                          libibverbs1-dbg
                                          libibumad3
                                          libibumad-dev
                                          ibacm
                                          librdmacm1
                                          rdmacm-utils
                                          librdmacm-dev
                                          mstflint
                                          libibmad5
                                          libibmad-dev
                                          libibnetdisc5
                                          infiniband-diags
                                          kernel-mft-modules
                                          perftest
                                          ibsim
                                          ibsim-doc
                                          ucx
                                          openmpi
                                          mpitests
                                          knem-modules
                                          srptools
                                          mlnx-ethtool
                                          mlnx-iproute2
                                          rshim
                                          ibarr
                                          build-essential autotools-dev pkg-config  python3-docutils debhelper libstdc++6 pandoc bison dh-autoreconf devscripts libmnl-dev fakeroot libgfortran5 cython3 libnuma-dev libnl-route-3-dev libssl-dev python3-dev libnl-3-dev autoconf quilt libfuse-dev python3-distutils flex libsystemd-dev libselinux1-dev libudev-dev dh-python cmake libpci-dev sudo make libdb-dev libusb-1.0-0-dev libelf-dev libtool valgrind python3 gcc bzip2
                                          Error: One or more packages depends on MLNX_OFED.
                                          Those packages should be removed before uninstalling MLNX_OFED:
                                          licensecheck libarray-intspan-perl
                                          To force uninstallation use '--force' flag.
                                          root@coolpi:/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0# ./install.pl --force
                                          Logs dir: /tmp/OFED.129276.logs
                                          General log file: /tmp/OFED.129276.logs/general.log
                                          ofed-scripts
                                          mlnx-tools
                                          srp-modules
                                          mlnx-nvme-modules
                                          rdma-core
                                          libibverbs1
                                          ibverbs-utils
                                          ibverbs-providers
                                          libibverbs-dev
                                          libibverbs1-dbg
                                          libibumad3
                                          libibumad-dev
                                          ibacm
                                          librdmacm1
                                          rdmacm-utils
                                          librdmacm-dev
                                          mstflint
                                          libibmad5
                                          libibmad-dev
                                          libibnetdisc5
                                          infiniband-diags
                                          kernel-mft-modules
                                          perftest
                                          ibsim
                                          ibsim-doc
                                          ucx
                                          openmpi
                                          mpitests
                                          knem-modules
                                          srptools
                                          mlnx-ethtool
                                          mlnx-iproute2
                                          rshim
                                          ibarr
                                          flex libelf-dev fakeroot autoconf autotools-dev dh-python libtool libfuse-dev sudo debhelper python3-docutils libnl-route-3-dev pandoc bison libselinux1-dev quilt python3 libgfortran5 build-essential valgrind libsystemd-dev libssl-dev cmake libnl-3-dev libudev-dev cython3 python3-distutils libdb-dev libpci-dev python3-dev  devscripts bzip2 libmnl-dev gcc libstdc++6 pkg-config libnuma-dev libusb-1.0-0-dev make dh-autoreconf
                                          Building packages
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ofed-scripts_23.04-OFED.23.04.1.1.3_arm64.deb'
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-tools_23.04-0.2304053_arm64.deb'
                                          Installing mlnx-ofed-kernel-utils-23.04...
                                          Running /usr/bin/dpkg -i --force-confnew --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-ofed-kernel-utils_23.04-OFED.23.04.1.1.3.1.kver.5.10.110_arm64.deb'
                                          Installing mlnx-ofed-kernel-modules-23.04...
                                          Running /usr/bin/dpkg -i --force-confnew --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-ofed-kernel-modules_23.04-OFED.23.04.1.1.3.1.kver.5.10.110_arm64.deb'
                                          Building DEB for srp-modules-23.04 (srp)...
                                          Installing srp-modules-23.04...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/srp-modules_23.04-OFED.23.04.0.5.3.1.kver.5.10.110_arm64.deb'
                                          Building DEB for mlnx-nvme-modules-23.04 (mlnx-nvme)...
                                          Installing mlnx-nvme-modules-23.04...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-nvme-modules_23.04-OFED.23.04.0.5.3.1.kver.5.10.110_arm64.deb'
                                          Building DEB for rdma-core-2304mlnx44 (rdma-core)...
                                          Installing rdma-core-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/rdma-core_2304mlnx44-1.2304113_arm64.deb'
                                          Installing libibverbs1-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibverbs1_2304mlnx44-1.2304113_arm64.deb'
                                          Installing ibverbs-utils-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibverbs-utils_2304mlnx44-1.2304113_arm64.deb'
                                          Installing ibverbs-providers-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibverbs-providers_2304mlnx44-1.2304113_arm64.deb'
                                          Installing libibverbs-dev-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibverbs-dev_2304mlnx44-1.2304113_arm64.deb'
                                          Installing libibverbs1-dbg-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibverbs1-dbg_2304mlnx44-1.2304113_arm64.deb'
                                          Installing libibumad3-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibumad3_2304mlnx44-1.2304113_arm64.deb'
                                          Installing libibumad-dev-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibumad-dev_2304mlnx44-1.2304113_arm64.deb'
                                          Installing ibacm-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibacm_2304mlnx44-1.2304113_arm64.deb'
                                          Installing librdmacm1-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/librdmacm1_2304mlnx44-1.2304113_arm64.deb'
                                          Installing rdmacm-utils-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/rdmacm-utils_2304mlnx44-1.2304113_arm64.deb'
                                          Installing librdmacm-dev-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/librdmacm-dev_2304mlnx44-1.2304113_arm64.deb'
                                          Building DEB for mstflint-4.16.1 (mstflint)...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mstflint_4.16.1-2.2304053_arm64.deb'
                                          Installing libibmad5-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibmad5_2304mlnx44-1.2304113_arm64.deb'
                                          Installing libibmad-dev-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibmad-dev_2304mlnx44-1.2304113_arm64.deb'
                                          Installing libibnetdisc5-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibnetdisc5_2304mlnx44-1.2304113_arm64.deb'
                                          Installing infiniband-diags-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/infiniband-diags_2304mlnx44-1.2304113_arm64.deb'
                                          Building DEB for kernel-mft-modules-4.24.0 (kernel-mft)...
                                          Installing kernel-mft-modules-4.24.0...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/kernel-mft-modules_4.24.0-72.kver.5.10.110_all.deb'
                                          Building DEB for perftest-23.04.0 (perftest)...
                                          Installing perftest-23.04.0...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/perftest_23.04.0-0.23.g63e250f.2304053_arm64.deb'
                                          Building DEB for ibsim-0.12 (ibsim)...
                                          Installing ibsim-0.12...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibsim_0.12-1.2304053_arm64.deb'
                                          Installing ibsim-doc-0.12...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibsim-doc_0.12-1.2304053_all.deb'
                                          Building DEB for ucx-1.15.0 (ucx)...
                                          Installing ucx-1.15.0...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ucx_1.15.0-1.2304053_arm64.deb'
                                          Building DEB for openmpi-4.1.5rc2 (openmpi)...
                                          Running  mellanox_autodetect='yes' /usr/bin/dpkg-buildpackage -us -uc
                                          Installing openmpi-4.1.5rc2...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/openmpi_4.1.5rc2-1.2304053_all.deb'
                                          Building DEB for mpitests-3.2.20 (mpitests)...
                                          Installing mpitests-3.2.20...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mpitests_3.2.20-de56b6b.2304053_arm64.deb'
                                          Building DEB for knem-modules-1.1.4.90mlnx2 (knem)...
                                          Installing knem-modules-1.1.4.90mlnx2...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/knem-modules_1.1.4.90mlnx2-OFED.23.04.0.5.2.1.kver.5.10.110_arm64.deb'
                                          Installing srptools-2304mlnx44...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/srptools_2304mlnx44-1.2304113_arm64.deb'
                                          Building DEB for mlnx-ethtool-6.0 (mlnx-ethtool)...
                                          Installing mlnx-ethtool-6.0...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-ethtool_6.0-1.2304053_arm64.deb'
                                          Building DEB for mlnx-iproute2-6.2.0 (mlnx-iproute2)...
                                          Installing mlnx-iproute2-6.2.0...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-iproute2_6.2.0-1.2304053_arm64.deb'
                                          Building DEB for rshim-2.0.6 (rshim)...
                                          Installing rshim-2.0.6...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/rshim_2.0.6-19.g0873acd.2304113_arm64.deb'
                                          Building DEB for ibarr-0.1.3 (ibarr)...
                                          Installing ibarr-0.1.3...
                                          Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibarr_0.1.3-1.2304053_arm64.deb'
                                            Jachyn @jack_admin
                                            [11810.222046] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11936.108867] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11936.108876] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11936.358696] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11936.358704] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11936.611757] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11936.611762] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11936.743419] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11936.743427] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11936.810102] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11936.810110] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11936.826712] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11936.826721] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11936.876678] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11936.876687] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11936.909930] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11936.909938] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11936.927166] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11936.927174] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11936.943234] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11936.943244] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11936.960300] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11936.960307] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11936.974299] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11936.974307] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11936.994271] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11936.994279] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.007777] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.007786] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11937.026685] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11937.026694] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.041018] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.041025] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11937.060333] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11937.060346] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.208100] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.208108] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11937.243441] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11937.243450] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.276830] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.276838] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11937.376144] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11937.376152] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.390939] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.390948] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11937.408707] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11937.408715] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.424696] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.424703] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11937.441800] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11937.441809] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.457559] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.457567] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11937.476665] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11937.476673] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.494117] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.494125] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11937.527350] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11937.527358] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.543463] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.543472] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11937.677395] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11937.677402] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.693754] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.693778] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11937.827447] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11937.827455] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.843330] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.843338] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11937.859775] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11937.859783] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.876886] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.876894] rockchip-vop2 fdd90000.vop: pd0 on
                                            [11937.977322] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [11937.977330] rockchip-vop2 fdd90000.vop: pd0 off
                                            [11937.993229] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [11937.993237] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12026.742752] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [12026.742761] rockchip-vop2 fdd90000.vop: pd0 off
                                            [12028.675768] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [12028.675777] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12038.110980] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [12038.110991] rockchip-vop2 fdd90000.vop: pd0 off
                                            [12042.042122] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [12042.042131] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12059.577168] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [12059.577176] rockchip-vop2 fdd90000.vop: pd0 off
                                            [12097.108956] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [12097.108964] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12112.377853] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [12112.377862] rockchip-vop2 fdd90000.vop: pd0 off
                                            [12113.609157] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [12113.609166] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12113.743643] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [12113.743651] rockchip-vop2 fdd90000.vop: pd0 off
                                            [12115.227092] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [12115.227099] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12115.243558] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [12115.243567] rockchip-vop2 fdd90000.vop: pd0 off
                                            [12123.609235] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [12123.609244] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12138.310541] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [12138.310549] rockchip-vop2 fdd90000.vop: pd0 off
                                            [12138.461714] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [12138.461723] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12177.442599] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [12177.442612] rockchip-vop2 fdd90000.vop: pd0 off
                                            [12177.459270] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [12177.459282] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12214.938648] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [12214.938655] rockchip-vop2 fdd90000.vop: pd0 off
                                            [12214.955385] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [12214.955393] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12307.991337] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [12307.991341] rockchip-vop2 fdd90000.vop: pd0 off
                                            [12310.607684] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [12310.607688] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12430.810610] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [12430.810618] rockchip-vop2 fdd90000.vop: pd0 off
                                            [12449.474330] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [12449.474333] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12827.407348] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 512 (unused: 4608)
                                            [12830.044346] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 512 (unused: 2560)
                                            [12832.345678] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 1024 (unused: 5120)
                                            [12834.277161] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 1024 (unused: 3072)
                                            [12839.567026] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 2048 (unused: 4608)
                                            [12946.121325] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 1536 (unused: 3584)
                                            [12973.576452] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [12973.576460] rockchip-vop2 fdd90000.vop: pd0 off
                                            [12979.624709] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                                            [12979.624713] rockchip-vop2 fdd90000.vop: pd0 on
                                            [12991.331086] mlx5_core: version magic '5.10.110 SMP preempt mod_unload aarch64' should be '5.10.110 SMP mod_unload aarch64'
                                            [13019.261815] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                                            [13019.261823] rockchip-vop2 fdd90000.vop: pd0 off
                                            dmseg的结果如上
