    CM5如何安装网卡驱动?
    39 Posts 5 Posters 11.3k Views
      Jachyn @george
        Jachyn @george
        目前的错误提示如上图所示,问一下怎么把内核的头文件编译生成deb包呢?🤔
          大法师 @Jachyn
          @Jachyn 我们提供的内核源码,你下载一份,先编译一次。
            Jachyn
            @大法师 大师 内核已经编译了 编译之后进行安装 又报如下的错
            J 大法师大 2 Replies Last reply Reply Quote 0
              jack_admin @Jachyn
              @Jachyn 你用的网卡驱动源码提供一个链接
                大法师 @jack_admin
                @jack_admin https://network.nvidia.com/products/ethernet-drivers/linux/mlnx_en/
                The NVIDIA ConnectX adapter family can run Ethernet traffic simultaneously on two ports
                Single software stack that operates across all available NVIDIA Ethernet devices and configurations such as mem-free, up to 400Gb/s, and PCI Express modes 3.0, 4.0 and 5.0
                Support for HPC applications for scientific research and AI
                Support for data center applications such as Oracle 11g/10g RAC, IBM DB2, Financial services applications such as IBM WebSphere LLM, Red Hat MRG, NYSE Data Fabric
                  大法师 @Jachyn
                  @Jachyn said in CM5如何安装网卡驱动?:
                  更新内核源码编译目录链接(假定源码目录在/home/coolpi/kernel)
                  sudo ln -sf /home/coolpi/kernel /lib/modules/5.10.110/build
                  sudo ln -sf /home/coolpi/kernel /lib/modules/5.10.110/source
                  MLNX_EN_SRC-debian-23.04-1.1.3.0.tgz
                  MLNX_EN_SRC-debian-5.8-3.0.7.0.tgz
                  解压网卡驱动源码,编译
                  coolpi@coolpi:~/MLNX_EN_SRC-23.04-1.1.3.0$ sudo ./install.pl
                  Logs dir: /tmp/OFED.80654.logs
                  General log file: /tmp/OFED.80654.logs/general.log
                  ofed-scripts
                  mlnx-tools
                  mlnx-ofed-kernel-utils
                  mlnx-ofed-kernel-modules
                  Checking SW Requirements...
                  swig  make python3 chrpath gcc quilt debhelper dh-python python3-distutils
                  Removing old packages
                  Building packages
                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/MLNX_EN_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ofed-scripts_23.04-OFED.23.04.1.1.3_arm64.deb'
                  Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/MLNX_EN_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-tools_23.04-0.2304053_arm64.deb'
                  -W- --with-mlx5-ipsec is enabled
                    Jachyn @大法师
                    @大法师 更新源码目录链接显示如下错误
                    ln: /lib/modules/5.10.110/build/kernel: cannot overwrite directory
                    ln: /lib/modules/5.10.110/source/kernel: cannot overwrite directory
                      大法师 @Jachyn
                      @大法师 更新源码目录链接显示如下错误
                      sudo unlink /lib/modules/5.10.110/build
                      sudo unlink /lib/modules/5.10.110/source
                      然后再操作。编译可能有错误,你先排查下
                        Jachyn @大法师
                        @大法师 编译内核使用命令make Image -j4,然后编译模块make modules -j4,并没有报错,内核 make modules_install 也是成功的
                        当前日志显示
                        coolpi@coolpi:~/Downloads/mlnx-en-23.04-0.5.3.3-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                        Logs dir: /tmp/mlnx-en.6425.logs
                        General log file: /tmp/mlnx-en.6425.logs/general.log
                        ofed-scripts
                        mlnx-tools
                        mlnx-en-utils
                        mlnx-en-dkms
                        mstflint
                        Removing old packages...
                        Installing new packages
                        Installing mlnx-en-utils-23.04...
                        Installing mlnx-en-dkms-23.04...
                        Installing mstflint-4.16.1...
                        (Reading database ... 196397 files and directories currently installed.)
                        Preparing to unpack .../mlnx-fw-updater_23.04-0.5.3.3_arm64.deb ...
                        Unpacking mlnx-fw-updater (23.04-0.5.3.3) ...
                        Setting up mlnx-fw-updater (23.04-0.5.3.3) ...
                        Initializing...
                        Device #1:
                          Device Type:      ConnectX4LX
                             FW             14.22.1002     14.32.1010
                             PXE            3.5.0403       3.6.0502
                             UEFI           14.15.0019     14.25.0017
                          Status:           Update required
                        Found 1 device(s) requiring firmware update...
                        Device #1: Updating FW ...
                        Done
                        Restart needed for updates to take effect.
                        Log File: /tmp/C3m3Iz3_P3
                        Real log file: /tmp/mlnx-en.6425.logs/fw_update.log
                        Device (0001:11:00.0):
                        	PCI Link Speed: 2.5GT/s
                        Device (0001:11:00.1):
                        To load the new driver, run:
                        /etc/init.d/mlnx-en.d restart
                          大法师 @Jachyn
                          @Jachyn 好
                            Jachyn @大法师
                            coolpi@coolpi:~/Desktop$ /etc/init.d/mlnx-en.d restart
                              大法师 @Jachyn
                              @Jachyn 加 sudo 执行试下
                                Jachyn @大法师
                                  Jachyn @大法师
                                  coolpi@coolpi:~/Downloads/mlnx-en-5.9-0.5.6.0-ubuntu22.04-aarch64$ sudo ./install --add-kernel-support
                                  Note: This program will create mlnx-en TGZ for ubuntu22.04 under /tmp/mlnx-en-5.9-0.5.6.0-5.10.110 directory.
                                  See log file /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs/mlnx_ofed_iso.109096.log
                                  ERROR: Failed executing "MLNX_EN_SRC-5.9-0.5.6.0/install.pl --tmpdir /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs --eth-only --kernel 5.10.110 --kernel-sources /lib/modules/5.10.110/build --builddir /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096 --without-dkms --without-debug-symbols --build-only --distro ubuntu22.04"
                                  ERROR: See /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs/mlnx_ofed_iso.109096.log
                                  Failed to build mlnx-en for 5.10.110
                                  是不是这系统就不支持这个驱动呢
                                    jack_admin @Jachyn
                                    执行这个之后,系统日志输出(dmesg)分析下错误原因。
                                      Jake @george
                                        Jake @Jake
                                        我是不是需要去内核修改一些相关的配置?
                                          jack_admin @Jake
                                          @Jake 有什么问题?网口节点出来了没
                                            Jake @jack_admin
