    CM5如何安装网卡驱动?
    39 Posts 5 Posters 7.5k Views
      Jake
      我在装mellanox的时候遇到无法识别linux内核头文件的问题,这个该怎么解决呢?希望可以解答。
        george @Jake
        @Jake 这个需要把内核的头文件编译生成DEB包,然后系统上安装。
        J J 4 Replies Last reply Reply Quote 0
          Jake @george
          @george 好的,感谢,我去试试
            Jachyn @george
              Jachyn @george
              目前的错误提示如上图所示,问一下怎么把内核的头文件编译生成deb包呢?🤔
                大法师 @Jachyn
                @Jachyn 我们提供的内核源码,你下载一份,先编译一次。
                  Jachyn
                  @大法师 大师 内核已经编译了 编译之后进行安装 又报如下的错
                  J 大法师大 2 Replies Last reply Reply Quote 0
                    jack_admin @Jachyn
                    @Jachyn 你用的网卡驱动源码提供一个链接
                      大法师 @jack_admin
                      @jack_admin https://network.nvidia.com/products/ethernet-drivers/linux/mlnx_en/
                      The NVIDIA ConnectX adapter family can run Ethernet traffic simultaneously on two ports
                      Single software stack that operates across all available NVIDIA Ethernet devices and configurations such as mem-free, up to 400Gb/s, and PCI Express modes 3.0, 4.0 and 5.0
                      Support for HPC applications for scientific research and AI
                      Support for data center applications such as Oracle 11g/10g RAC, IBM DB2, Financial services applications such as IBM WebSphere LLM, Red Hat MRG, NYSE Data Fabric
                        大法师 @Jachyn
                        @Jachyn said in CM5如何安装网卡驱动?:
                        更新内核源码编译目录链接(假定源码目录在/home/coolpi/kernel)
                        sudo ln -sf /home/coolpi/kernel /lib/modules/5.10.110/build
                        sudo ln -sf /home/coolpi/kernel /lib/modules/5.10.110/source
                        MLNX_EN_SRC-debian-23.04-1.1.3.0.tgz
                        MLNX_EN_SRC-debian-5.8-3.0.7.0.tgz
                        解压网卡驱动源码,编译
                        coolpi@coolpi:~/MLNX_EN_SRC-23.04-1.1.3.0$ sudo ./install.pl
                        Logs dir: /tmp/OFED.80654.logs
                        General log file: /tmp/OFED.80654.logs/general.log
                        ofed-scripts
                        mlnx-tools
                        mlnx-ofed-kernel-utils
                        mlnx-ofed-kernel-modules
                        Checking SW Requirements...
                        swig  make python3 chrpath gcc quilt debhelper dh-python python3-distutils
                        Removing old packages
                        Building packages
                        Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/MLNX_EN_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ofed-scripts_23.04-OFED.23.04.1.1.3_arm64.deb'
                        Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/MLNX_EN_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-tools_23.04-0.2304053_arm64.deb'
                        -W- --with-mlx5-ipsec is enabled
                          Jachyn @大法师
                          @大法师 更新源码目录链接显示如下错误
                          ln: /lib/modules/5.10.110/build/kernel: cannot overwrite directory
                          ln: /lib/modules/5.10.110/source/kernel: cannot overwrite directory
                            大法师 @Jachyn
                            @大法师 更新源码目录链接显示如下错误
                            sudo unlink /lib/modules/5.10.110/build
                            sudo unlink /lib/modules/5.10.110/source
                            然后再操作。编译可能有错误,你先排查下
                              Jachyn @大法师
                              @大法师 编译内核使用命令make Image -j4,然后编译模块make modules -j4,并没有报错,内核 make modules_install 也是成功的
                              当前日志显示
                              coolpi@coolpi:~/Downloads/mlnx-en-23.04-0.5.3.3-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                              Logs dir: /tmp/mlnx-en.6425.logs
                              General log file: /tmp/mlnx-en.6425.logs/general.log
                              ofed-scripts
                              mlnx-tools
                              mlnx-en-utils
                              mlnx-en-dkms
                              mstflint
                              Removing old packages...
                              Installing new packages
                              Installing mlnx-en-utils-23.04...
                              Installing mlnx-en-dkms-23.04...
                              Installing mstflint-4.16.1...
                              (Reading database ... 196397 files and directories currently installed.)
                              Preparing to unpack .../mlnx-fw-updater_23.04-0.5.3.3_arm64.deb ...
                              Unpacking mlnx-fw-updater (23.04-0.5.3.3) ...
                              Setting up mlnx-fw-updater (23.04-0.5.3.3) ...
                              Initializing...
                              Device #1:
                                Device Type:      ConnectX4LX
                                   FW             14.22.1002     14.32.1010
                                   PXE            3.5.0403       3.6.0502
                                   UEFI           14.15.0019     14.25.0017
                                Status:           Update required
                              Found 1 device(s) requiring firmware update...
                              Device #1: Updating FW ...
                              Done
                              Restart needed for updates to take effect.
                              Log File: /tmp/C3m3Iz3_P3
                              Real log file: /tmp/mlnx-en.6425.logs/fw_update.log
                              Device (0001:11:00.0):
                              	PCI Link Speed: 2.5GT/s
                              Device (0001:11:00.1):
                              To load the new driver, run:
                              /etc/init.d/mlnx-en.d restart
                                大法师 @Jachyn
                                @Jachyn 好
                                  Jachyn @大法师
                                  coolpi@coolpi:~/Desktop$ /etc/init.d/mlnx-en.d restart
                                    大法师 @Jachyn
                                    @Jachyn 加 sudo 执行试下
                                      Jachyn @大法师
                                        Jachyn @大法师
                                        coolpi@coolpi:~/Downloads/mlnx-en-5.9-0.5.6.0-ubuntu22.04-aarch64$ sudo ./install --add-kernel-support
                                        Note: This program will create mlnx-en TGZ for ubuntu22.04 under /tmp/mlnx-en-5.9-0.5.6.0-5.10.110 directory.
                                        See log file /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs/mlnx_ofed_iso.109096.log
                                        ERROR: Failed executing "MLNX_EN_SRC-5.9-0.5.6.0/install.pl --tmpdir /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs --eth-only --kernel 5.10.110 --kernel-sources /lib/modules/5.10.110/build --builddir /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096 --without-dkms --without-debug-symbols --build-only --distro ubuntu22.04"
                                        ERROR: See /tmp/mlnx-en-5.9-0.5.6.0-5.10.110/mlnx_iso.109096_logs/mlnx_ofed_iso.109096.log
                                        Failed to build mlnx-en for 5.10.110
                                        是不是这系统就不支持这个驱动呢
                                          jack_admin @Jachyn
                                          执行这个之后,系统日志输出(dmesg)分析下错误原因。
                                            Jake @george
