    Firefox deb version freezed when try to play video
    31 Posts 3 Posters 9.6k Views
      Will this issue being fixed in Kernel 6.1 and new version mesa?
        Provide a basic image, the system can start normally, WIFI is working properly, and support for GPU and VPU has not been added yet.
        plumlisP 2 Replies Last reply Reply Quote 0
          @george nice, I'll gave it a try.
          thank you.
            https://gitlab.collabora.com/hardware-enablement/rockchip-3588/notes-for-rockchip-3588/-/blob/main/mainline-status.md
            Someday we will be able to use mainline kernel.
              Coolpi4b and cm5 evb currently support mainline kernels above 6.8, but laptops do not support mainline kernels due to eDP display drivers. So it will be a little later. Currently undergoing debugging. Looking forward to the next main version being released. Thank you for your support.
                May be you can add build recipe here, it will be a good advertise 🙂
                https://github.com/manjaro-arm
                  Actully not only video playing decode issue.
                  But also some display area shutter issue while scrolling.
                  Disable GPU accelaration. everthing looks fine now.
                  Will this be solved in kernel 6.1 BSP?
                  How is the status of kernel 6.1 now? When will we see it?
                  I tried to compile kernel by myself ftom cool pi github 6.1 stan rkr1 branch but failed.
                    plumlis @plumlis
                    Is it safe to install newer version mesa?
                    I saw that new version mesa have many panfrost related fixes.
                      The kernel version 6.1 will support it and is currently being adapted.
                      plumlisP 1 Reply Last reply Reply Quote 1
                        @george okay. hope kernel 6.1 will release soon.
                        And thanks for your hard work.
                          Hey George. Could you have some USB Disk brands recomand to use as Boot drive?
                          I tried many Sandisk 3.0 and all of them don't work. Only one 16GB USB(No brand) disk can boot up. But it can't be use as fedora image( It's 17GB )
                            Let me briefly introduce the current situation of the NAND flash industry. The best A-class die is used as a high-capacity and high-value storage device for first tier brands such as SSDs and EMMCs. The worse one is used for second tier brands such as EMMCs and NAND FLASH, and the worse one is used for a large number of bad fast devices. The 8GB capacity can be reduced to 4G or 2G for USB drives or T cards. There is even worse junk die, which will appear on the T card that costs a few yuan on Mouduoduo. So if doing system mirroring, it is recommended to use SSD or SATA portable hard drives, as both performance and reliability are the best.
                              @george I knew that.
                              But the point is I can't find a usb stick to make this fedora image boot up.
                              Wiki said only usb 2.0 disk can be boot up.
                              I tested all my usb 3.0/2.0 devices. Only one usb 2.0 stick can be booted. But it's 16GB, fedora image is 17GB and can't write to it.
                              I just asked you to recommand a usb device can be boot up.
                                Suggest updating uboot to the latest version and then trying USB BOOT. The latest development branch has been optimized for some USB drives. Of course, you can also write images to EMMC through UMS.
                                  @george It seems I have to compile boot loader first?
                                  https://cool-pi.com/topic/380/cool-pi-4b-cm5-linux-system-support-compile-u-boot
                                  Following this guide.
                                  Ubuntu 24.04 don't have python2, can't compile directly, annoying
                                    sudo ln -s /usr/bin/python3.12 /usr/bin/python
                                      Already did. Seems it doesn't work.
                                      $./build-uboot.sh cm5-notebook
                                      ## make rk3588_coolpicm5_notebook_defconfig -j16
                                      # configuration written to .config
                                      scripts/kconfig/conf  --silentoldconfig Kconfig
                                        CHK     include/config.h
                                        CFG     u-boot.cfg
                                        GEN     include/autoconf.mk.dep
                                        CFG     spl/u-boot.cfg
                                        CFG     tpl/u-boot.cfg
                                        GEN     spl/include/autoconf.mk
                                        GEN     tpl/include/autoconf.mk
                                        CHK     include/config/uboot.release
                                        CHK     include/generated/timestamp_autogenerated.h
                                        UPD     include/generated/timestamp_autogenerated.h
                                        CFG     u-boot.cfg
                                        CHK     include/generated/version_autogenerated.h
                                        CHK     include/generated/generic-asm-offsets.h
                                        CHK     include/generated/asm-offsets.h
                                        HOSTCC  tools/mkenvimage.o
                                        HOSTCC  tools/fit_image.o
                                        HOSTCC  tools/image-host.o
                                        HOSTCC  tools/dumpimage.o
                                        HOSTCC  tools/mkimage.o
                                        HOSTCC  tools/rockchip/boot_merger.o
                                        HOSTCC  tools/rockchip/loaderimage.o
                                        HOSTLD  tools/loaderimage
                                      tools/rockchip/boot_merger.c: In function ‘mergeBoot’:
                                      tools/rockchip/boot_merger.c:700:43: warning: ‘%s’ directive output may be truncated writing up to 813 bytes into a region of size 5 [-Wformat-truncation=]
                                        700 |         snprintf(buffer, sizeof(buffer), "%s", chip);
                                        742 |                 chipType = convertChipType(chip + 2);
                                      In file included from /usr/include/stdio.h:980,
                                                       from ././include/compiler.h:25,
                                                       from <command-line>:
                                      In function ‘snprintf’,
                                          inlined from ‘convertChipType’ at tools/rockchip/boot_merger.c:700:2,
                                          inlined from ‘getChipType’ at tools/rockchip/boot_merger.c:742:14,
                                          inlined from ‘getBoothdr’ at tools/rockchip/boot_merger.c:761:18,
                                          inlined from ‘mergeBoot’ at tools/rockchip/boot_merger.c:830:2:
                                      /usr/include/aarch64-linux-gnu/bits/stdio2.h:54:10: note: ‘__builtin_snprintf’ output between 1 and 814 bytes into a destination of size 5
                                         54 |   return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,
                                         55 |                                    __glibc_objsize (__s), __fmt,
                                         56 |                                    __va_arg_pack ());
                                      In function ‘wide2str’,
                                          inlined from ‘unpackBoot’ at tools/rockchip/boot_merger.c:955:3,
                                          inlined from ‘main’ at tools/rockchip/boot_merger.c:1072:8:
                                      tools/rockchip/boot_merger.c:895:18: warning: array subscript 20 is outside array bounds of ‘char[20]’ [-Warray-bounds=]
                                        895 |         str[len] = 0;
                                      tools/rockchip/boot_merger.c: In function ‘main’:
                                      tools/rockchip/boot_merger.c:933:14: note: at offset 20 into object ‘name’ of size 20
                                        933 |         char name[MAX_NAME_LEN];
                                        HOSTLD  tools/boot_merger
                                        HOSTLD  tools/mkenvimage
                                        HOSTLD  tools/dumpimage
                                        HOSTLD  tools/mkimage
                                        CC      arch/arm/cpu/armv8/fwcall.o
                                        CC      common/main.o
                                        LD      arch/arm/cpu/armv8/built-in.o
                                        CC      cmd/version.o
                                        LD      common/built-in.o
                                        CC      lib/display_options.o
                                        LD      cmd/built-in.o
                                        LD      lib/built-in.o
                                        LD      u-boot
                                      /usr/bin/aarch64-linux-gnu-ld.bfd: warning: u-boot has a LOAD segment with RWX permissions
                                        OBJCOPY u-boot.srec
                                        OBJCOPY u-boot-nodtb.bin
                                        SYM     u-boot.sym
                                      make[2]: 'arch/arm/dts/rk3588-cp5-x8.dtb' is up to date.
                                        COPY    u-boot.dtb
                                      start=$(/usr/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ' '); end=$(/usr/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ' '); tools/relocate-rela u-boot-nodtb.bin 0x00200000 $start $end
                                        CAT     u-boot-dtb.bin
                                        MKIMAGE u-boot.img
                                        MKIMAGE u-boot-dtb.img
                                        COPY    u-boot-dtb-kern.bin
                                        ALIGN   u-boot-dtb-kern.bin
                                        CAT     u-boot.bin
                                        CC      spl/common/spl/spl.o
                                        CC      spl/arch/arm/cpu/armv8/fwcall.o
                                        COPY    spl/u-boot-spl.dtb
                                        CC      tpl/arch/arm/cpu/armv8/fwcall.o
                                        LD      spl/arch/arm/cpu/armv8/built-in.o
                                        CC      tpl/arch/arm/mach-rockchip/tpl.o
                                        LD      tpl/arch/arm/cpu/armv8/built-in.o
                                        CC      spl/lib/display_options.o
                                        LD      tpl/arch/arm/mach-rockchip/built-in.o
                                        LD      spl/common/spl/built-in.o
                                        LD      spl/lib/built-in.o
                                        LD      tpl/u-boot-tpl
                                      /usr/bin/aarch64-linux-gnu-ld.bfd: warning: u-boot-tpl has a LOAD segment with RWX permissions
                                        OBJCOPY tpl/u-boot-tpl-nodtb.bin
                                        COPY    tpl/u-boot-tpl.bin
                                        LD      spl/u-boot-spl
                                      /usr/bin/aarch64-linux-gnu-ld.bfd: warning: u-boot-spl has a LOAD segment with RWX permissions
                                        OBJCOPY spl/u-boot-spl-nodtb.bin
                                        CAT     spl/u-boot-spl-dtb.bin
                                        COPY    spl/u-boot-spl.bin
                                        CFGCHK  u-boot.cfg
                                      ERROR: No python2
                                      $ python
                                      Python 3.12.3 (main, Apr 10 2024, 05:33:47) [GCC 13.2.0] on linux
                                      Type "help", "copyright", "credits" or "license" for more information.
                                        The following is what I have compiled and can be used directly.
                                        RKDevTool_v3.13_for_window.rar
                                          @george thanks.
                                          The only way to upgrade uboot is following this guide?
                                          https://forum.cool-pi.com/topic/162/how-to-upgrade-the-boot-loader-of-coolpi-4b
                                          short two pins and conect to PC to upgrade loader?
