    Laptop install Ubuntu on nvme
    22 Posts 3 Posters 4.6k Views
      Is firmware stored in EMMC or NVME?
        @george currently i have the home folders on an nvme, the rest is on the emmc
        Also sometimes it wont boot and be stuck at a blinking underscore, from reeding it seems that both my issues could be videodriver issues
        Edit: So the boot issue was a problem with my disk setup, and i did fix it, but i still can't get the laptop to suspend.
          Momo 0 @Momo 0
          @george So with the suspend issue, any idea? It would be really useful for the laptop to be able to suspend. Otherwise i currently have to set it to turn off on closing the Lid.
            Configure according to the factory's configuration (both the file system and kernel are placed in EMMC, while nvme only serves as a data disk). Is there a problem with suspend?
              @george i tried both armbian and Ubuntu images flashed to emmc only and have the problem, if i suspend from menu and closing the lid. The power light stays on and the Laptop doesn't respond to keys. anything else i should try?
                After booting up, print a dmesg message and send it out. I think this should be a single machine issue. Normally, our machine does not have this problem.
                  @george dmesg.txt
                    There is no abnormal log information found in the dmesg information. Do you have any USB to serial port tools in your hand, and do you have some hands-on skills, such as welding and debugging serial ports. If further debugging information needs to be obtained, it is necessary to capture the logs of the serial port sleep wake up section to confirm the direction of the problem.
                      For anyone who has a similar issue like me, it turned out the nvme ssd i was using didn't agree with the notebook when it came to sleep states. I swapped it with an WD Blue SN570 and now everything works as expected.
                      G plumlisP 2 Replies Last reply Reply Quote 1
                        Thank you for sharing. If you have any questions during use, I hope you can raise them. Thank you very much for your support.
                          plumlis @Momo 0
                          @Momo-0 Hi Which brand SSD are you using which effected this suspend sleeping issue?
                          I know SN570 works fine but this quite hard to get one now. There is only SN580 on sale.
                            Momo 0 @plumlis
                            @plumlis it was an oem model I took from a damaged laptop, I also had issues with other oem nvmes I scavenged and used them in external enclosures on macOS, so I suspect ssds delivered to Laptop manufacturers have some kinda special firmwares, both times a new ssd worked without issues. my guess is any WD ssd can buy as a consumer will work.
                              plumlis @Momo 0
                              @Momo-0 Thank for your reply.
                              I think the point is pcie 3.0 /4.0
                              maybe pcie 3.0 version nvme ssd should be okay.
