    CM5如何安装网卡驱动?
    39 Posts 5 Posters 11.6k Views
      Jake @jack_admin
        Jachyn @jack_admin
        CMD: mlxup -u --log-on-update --ssl-certificate /tmp/SGKRmQP1We/mlxfwmanager_sriov_dis_aarch64_4115-dir/ca-bundle.crt --current-dir /opt/mellanox/mlnx-fw-updater/  -L /tmp/Nr5DC9bSSF -y -d 0001:11:00.0
        Device #1:
         Device Type:      ConnectX4LX
         Part Number:      --
         Description:
         PSID:
         Base MAC:         N/A
            FW             --
         Status:           Failed to open device
        -E- Failed to query 0001:11:00.0 device, error : No such file or directory. MFE_ICMD_NOT_SUPPORTED
        EXIT_STATUS: 0
        安装网卡驱动后 显示如上的日志
          Jachyn @Jachyn
          coolpi@coolpi:~/Downloads/mlnx-en-5.8-1.0.1.1-ubuntu22.04-aarch64$ sudo ./install --force-dkms
          [sudo] password for coolpi:
          Logs dir: /tmp/mlnx-en.738979.logs
          General log file: /tmp/mlnx-en.738979.logs/general.log
          ofed-scripts
          mlnx-tools
          mlnx-en-utils
          mlnx-en-dkms
          mstflint
          Checking SW Requirements...
          Removing old packages...
          Installing new packages
          Installing ofed-scripts-5.8...
          Installing mlnx-tools-5.2.0...
          Installing mlnx-en-utils-5.8...
          Installing mlnx-en-dkms-5.8...
          Installing mstflint-4.16.1...
          (Reading database ... 199866 files and directories currently installed.)
          Preparing to unpack .../mlnx-fw-updater_5.8-1.0.1.1_arm64.deb ...
          Unpacking mlnx-fw-updater (5.8-1.0.1.1) ...
          Setting up mlnx-fw-updater (5.8-1.0.1.1) ...
          Initializing...
          Device #1:
               FW             14.32.1010     14.32.1010
               PXE            3.6.0502       3.6.0502
               UEFI           14.25.0017     14.25.0017
            Status:           Up to date
          Log File: /tmp/DR3i76jLzy
          Real log file: /tmp/mlnx-en.738979.logs/fw_update.log
          Device (0001:11:00.0):
          	PCI Link Speed: 2.5GT/s
          Device (0001:11:00.1):
          To load the new driver, run:
          /etc/init.d/mlnx-en.d restart
          coolpi@coolpi:~/Downloads/mlnx-en-5.8-1.0.1.1-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
            Jachyn @Jachyn
            coolpi@coolpi:~/Downloads/mlnx-en-5.8-2.0.3.0-ubuntu22.04-aarch64$ sudo ./install --force-dkms
            Logs dir: /tmp/mlnx-en.3438.logs
            General log file: /tmp/mlnx-en.3438.logs/general.log
            ofed-scripts
            mlnx-tools
            mlnx-en-utils
            mlnx-en-dkms
            mstflint
            Preparing to unpack .../mlnx-fw-updater_5.8-2.0.3.0_arm64.deb ...
            Unpacking mlnx-fw-updater (5.8-2.0.3.0) ...
            Setting up mlnx-fw-updater (5.8-2.0.3.0) ...
            Initializing...
            Device #1:
              Status:           Up to date
            Log File: /tmp/05iafkfb8h
            Real log file: /tmp/mlnx-en.3438.logs/fw_update.log
            	PCI Link Speed: 8GT/s
            coolpi@coolpi:~/Downloads/mlnx-en-5.8-2.0.3.0-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
              Jachyn @Jachyn
              coolpi@coolpi:~/Downloads/mlnx-en-5.6-2.0.9.0-ubuntu22.04-aarch64$ sudo ./install --force-dkms
              Logs dir: /tmp/mlnx-en.514532.logs
              General log file: /tmp/mlnx-en.514532.logs/general.log
              ofed-scripts
              mlnx-tools
              mlnx-en-utils
              mlnx-en-dkms
              mstflint
              Installing ofed-scripts-5.6...
              Installing mlnx-en-utils-5.6...
              Installing mlnx-en-dkms-5.6...
              (Reading database ... 199769 files and directories currently installed.)
              Preparing to unpack .../mlnx-fw-updater_5.6-2.0.9.0_arm64.deb ...
              Unpacking mlnx-fw-updater (5.6-2.0.9.0) ...
              Setting up mlnx-fw-updater (5.6-2.0.9.0) ...
              Initializing...
              Device #1:
                Status:           Up to date
              Log File: /tmp/07OcqgbJK0
              Real log file: /tmp/mlnx-en.514532.logs/fw_update.log
              coolpi@coolpi:~/Downloads/mlnx-en-5.6-2.0.9.0-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                Jachyn @Jachyn
                coolpi@coolpi:~/Downloads/mlnx-en-5.7-1.0.2.0-ubuntu22.04-aarch64$ sudo ./install --force-dkms
                Logs dir: /tmp/mlnx-en.759187.logs
                General log file: /tmp/mlnx-en.759187.logs/general.log
                ofed-scripts
                mlnx-tools
                mlnx-en-utils
                mlnx-en-dkms
                mstflint
                Installing ofed-scripts-5.7...
                Installing mlnx-en-utils-5.7...
                Installing mlnx-en-dkms-5.7...
                (Reading database ... 199851 files and directories currently installed.)
                Preparing to unpack .../mlnx-fw-updater_5.7-1.0.2.0_arm64.deb ...
                Unpacking mlnx-fw-updater (5.7-1.0.2.0) ...
                Setting up mlnx-fw-updater (5.7-1.0.2.0) ...
                Initializing...
                Device #1:
                  Status:           Up to date
                Log File: /tmp/FFuM6_xJPq
                Real log file: /tmp/mlnx-en.759187.logs/fw_update.log
                coolpi@coolpi:~/Downloads/mlnx-en-5.7-1.0.2.0-ubuntu22.04-aarch64$ /etc/init.d/mlnx-en.d restart
                  jack_admin @Jachyn
                  @Jachyn 需要把驱动加载过程,内核打印日志输出看看错误在哪,可以用dmesg命令
                    Jachyn @Jachyn
                    root@coolpi:/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0# ./install.pl
                    Logs dir: /tmp/OFED.127412.logs
                    General log file: /tmp/OFED.127412.logs/general.log
                    ofed-scripts
                    mlnx-tools
                    mlnx-ofed-kernel-utils
                    mlnx-ofed-kernel-modules
                    srp-modules
                    mlnx-nvme-modules
                    rdma-core
                    libibverbs1
                    ibverbs-utils
                    ibverbs-providers
                    libibverbs-dev
                    libibverbs1-dbg
                    libibumad3
                    libibumad-dev
                    ibacm
                    librdmacm1
                    rdmacm-utils
                    librdmacm-dev
                    mstflint
                    libibmad5
                    libibmad-dev
                    libibnetdisc5
                    infiniband-diags
                    kernel-mft-modules
                    perftest
                    ibsim
                    ibsim-doc
                    ucx
                    openmpi
                    mpitests
                    knem-modules
                    srptools
                    mlnx-ethtool
                    mlnx-iproute2
                    rshim
                    ibarr
                    build-essential autotools-dev pkg-config  python3-docutils debhelper libstdc++6 pandoc bison dh-autoreconf devscripts libmnl-dev fakeroot libgfortran5 cython3 libnuma-dev libnl-route-3-dev libssl-dev python3-dev libnl-3-dev autoconf quilt libfuse-dev python3-distutils flex libsystemd-dev libselinux1-dev libudev-dev dh-python cmake libpci-dev sudo make libdb-dev libusb-1.0-0-dev libelf-dev libtool valgrind python3 gcc bzip2
                    Error: One or more packages depends on MLNX_OFED.
                    Those packages should be removed before uninstalling MLNX_OFED:
                    licensecheck libarray-intspan-perl
                    To force uninstallation use '--force' flag.
                    root@coolpi:/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0# ./install.pl --force
                    Logs dir: /tmp/OFED.129276.logs
                    General log file: /tmp/OFED.129276.logs/general.log
                    ofed-scripts
                    mlnx-tools
                    srp-modules
                    mlnx-nvme-modules
                    rdma-core
                    libibverbs1
                    ibverbs-utils
                    ibverbs-providers
                    libibverbs-dev
                    libibverbs1-dbg
                    libibumad3
                    libibumad-dev
                    ibacm
                    librdmacm1
                    rdmacm-utils
                    librdmacm-dev
                    mstflint
                    libibmad5
                    libibmad-dev
                    libibnetdisc5
                    infiniband-diags
                    kernel-mft-modules
                    perftest
                    ibsim
                    ibsim-doc
                    ucx
                    openmpi
                    mpitests
                    knem-modules
                    srptools
                    mlnx-ethtool
                    mlnx-iproute2
                    rshim
                    ibarr
                    flex libelf-dev fakeroot autoconf autotools-dev dh-python libtool libfuse-dev sudo debhelper python3-docutils libnl-route-3-dev pandoc bison libselinux1-dev quilt python3 libgfortran5 build-essential valgrind libsystemd-dev libssl-dev cmake libnl-3-dev libudev-dev cython3 python3-distutils libdb-dev libpci-dev python3-dev  devscripts bzip2 libmnl-dev gcc libstdc++6 pkg-config libnuma-dev libusb-1.0-0-dev make dh-autoreconf
                    Building packages
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ofed-scripts_23.04-OFED.23.04.1.1.3_arm64.deb'
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-tools_23.04-0.2304053_arm64.deb'
                    Installing mlnx-ofed-kernel-utils-23.04...
                    Running /usr/bin/dpkg -i --force-confnew --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-ofed-kernel-utils_23.04-OFED.23.04.1.1.3.1.kver.5.10.110_arm64.deb'
                    Installing mlnx-ofed-kernel-modules-23.04...
                    Running /usr/bin/dpkg -i --force-confnew --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-ofed-kernel-modules_23.04-OFED.23.04.1.1.3.1.kver.5.10.110_arm64.deb'
                    Building DEB for srp-modules-23.04 (srp)...
                    Installing srp-modules-23.04...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/srp-modules_23.04-OFED.23.04.0.5.3.1.kver.5.10.110_arm64.deb'
                    Building DEB for mlnx-nvme-modules-23.04 (mlnx-nvme)...
                    Installing mlnx-nvme-modules-23.04...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-nvme-modules_23.04-OFED.23.04.0.5.3.1.kver.5.10.110_arm64.deb'
                    Building DEB for rdma-core-2304mlnx44 (rdma-core)...
                    Installing rdma-core-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/rdma-core_2304mlnx44-1.2304113_arm64.deb'
                    Installing libibverbs1-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibverbs1_2304mlnx44-1.2304113_arm64.deb'
                    Installing ibverbs-utils-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibverbs-utils_2304mlnx44-1.2304113_arm64.deb'
                    Installing ibverbs-providers-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibverbs-providers_2304mlnx44-1.2304113_arm64.deb'
                    Installing libibverbs-dev-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibverbs-dev_2304mlnx44-1.2304113_arm64.deb'
                    Installing libibverbs1-dbg-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibverbs1-dbg_2304mlnx44-1.2304113_arm64.deb'
                    Installing libibumad3-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibumad3_2304mlnx44-1.2304113_arm64.deb'
                    Installing libibumad-dev-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibumad-dev_2304mlnx44-1.2304113_arm64.deb'
                    Installing ibacm-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibacm_2304mlnx44-1.2304113_arm64.deb'
                    Installing librdmacm1-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/librdmacm1_2304mlnx44-1.2304113_arm64.deb'
                    Installing rdmacm-utils-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/rdmacm-utils_2304mlnx44-1.2304113_arm64.deb'
                    Installing librdmacm-dev-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/librdmacm-dev_2304mlnx44-1.2304113_arm64.deb'
                    Building DEB for mstflint-4.16.1 (mstflint)...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mstflint_4.16.1-2.2304053_arm64.deb'
                    Installing libibmad5-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibmad5_2304mlnx44-1.2304113_arm64.deb'
                    Installing libibmad-dev-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibmad-dev_2304mlnx44-1.2304113_arm64.deb'
                    Installing libibnetdisc5-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibnetdisc5_2304mlnx44-1.2304113_arm64.deb'
                    Installing infiniband-diags-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/infiniband-diags_2304mlnx44-1.2304113_arm64.deb'
                    Building DEB for kernel-mft-modules-4.24.0 (kernel-mft)...
                    Installing kernel-mft-modules-4.24.0...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/kernel-mft-modules_4.24.0-72.kver.5.10.110_all.deb'
                    Building DEB for perftest-23.04.0 (perftest)...
                    Installing perftest-23.04.0...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/perftest_23.04.0-0.23.g63e250f.2304053_arm64.deb'
                    Building DEB for ibsim-0.12 (ibsim)...
                    Installing ibsim-0.12...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibsim_0.12-1.2304053_arm64.deb'
                    Installing ibsim-doc-0.12...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibsim-doc_0.12-1.2304053_all.deb'
                    Building DEB for ucx-1.15.0 (ucx)...
                    Installing ucx-1.15.0...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ucx_1.15.0-1.2304053_arm64.deb'
                    Building DEB for openmpi-4.1.5rc2 (openmpi)...
                    Running  mellanox_autodetect='yes' /usr/bin/dpkg-buildpackage -us -uc
                    Installing openmpi-4.1.5rc2...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/openmpi_4.1.5rc2-1.2304053_all.deb'
                    Building DEB for mpitests-3.2.20 (mpitests)...
                    Installing mpitests-3.2.20...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mpitests_3.2.20-de56b6b.2304053_arm64.deb'
                    Building DEB for knem-modules-1.1.4.90mlnx2 (knem)...
                    Installing knem-modules-1.1.4.90mlnx2...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/knem-modules_1.1.4.90mlnx2-OFED.23.04.0.5.2.1.kver.5.10.110_arm64.deb'
                    Installing srptools-2304mlnx44...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/srptools_2304mlnx44-1.2304113_arm64.deb'
                    Building DEB for mlnx-ethtool-6.0 (mlnx-ethtool)...
                    Installing mlnx-ethtool-6.0...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-ethtool_6.0-1.2304053_arm64.deb'
                    Building DEB for mlnx-iproute2-6.2.0 (mlnx-iproute2)...
                    Installing mlnx-iproute2-6.2.0...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-iproute2_6.2.0-1.2304053_arm64.deb'
                    Building DEB for rshim-2.0.6 (rshim)...
                    Installing rshim-2.0.6...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/rshim_2.0.6-19.g0873acd.2304113_arm64.deb'
                    Building DEB for ibarr-0.1.3 (ibarr)...
                    Installing ibarr-0.1.3...
                    Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibarr_0.1.3-1.2304053_arm64.deb'
                      Jachyn @jack_admin
                      [11810.222046] rockchip-vop2 fdd90000.vop: pd0 on
                      [11936.108867] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11936.108876] rockchip-vop2 fdd90000.vop: pd0 off
                      [11936.358696] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11936.358704] rockchip-vop2 fdd90000.vop: pd0 on
                      [11936.611757] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11936.611762] rockchip-vop2 fdd90000.vop: pd0 off
                      [11936.743419] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11936.743427] rockchip-vop2 fdd90000.vop: pd0 on
                      [11936.810102] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11936.810110] rockchip-vop2 fdd90000.vop: pd0 off
                      [11936.826712] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11936.826721] rockchip-vop2 fdd90000.vop: pd0 on
                      [11936.876678] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11936.876687] rockchip-vop2 fdd90000.vop: pd0 off
                      [11936.909930] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11936.909938] rockchip-vop2 fdd90000.vop: pd0 on
                      [11936.927166] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11936.927174] rockchip-vop2 fdd90000.vop: pd0 off
                      [11936.943234] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11936.943244] rockchip-vop2 fdd90000.vop: pd0 on
                      [11936.960300] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11936.960307] rockchip-vop2 fdd90000.vop: pd0 off
                      [11936.974299] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11936.974307] rockchip-vop2 fdd90000.vop: pd0 on
                      [11936.994271] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11936.994279] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.007777] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.007786] rockchip-vop2 fdd90000.vop: pd0 on
                      [11937.026685] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11937.026694] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.041018] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.041025] rockchip-vop2 fdd90000.vop: pd0 on
                      [11937.060333] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11937.060346] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.208100] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.208108] rockchip-vop2 fdd90000.vop: pd0 on
                      [11937.243441] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11937.243450] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.276830] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.276838] rockchip-vop2 fdd90000.vop: pd0 on
                      [11937.376144] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11937.376152] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.390939] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.390948] rockchip-vop2 fdd90000.vop: pd0 on
                      [11937.408707] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11937.408715] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.424696] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.424703] rockchip-vop2 fdd90000.vop: pd0 on
                      [11937.441800] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11937.441809] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.457559] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.457567] rockchip-vop2 fdd90000.vop: pd0 on
                      [11937.476665] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11937.476673] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.494117] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.494125] rockchip-vop2 fdd90000.vop: pd0 on
                      [11937.527350] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11937.527358] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.543463] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.543472] rockchip-vop2 fdd90000.vop: pd0 on
                      [11937.677395] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11937.677402] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.693754] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.693778] rockchip-vop2 fdd90000.vop: pd0 on
                      [11937.827447] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11937.827455] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.843330] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.843338] rockchip-vop2 fdd90000.vop: pd0 on
                      [11937.859775] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11937.859783] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.876886] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.876894] rockchip-vop2 fdd90000.vop: pd0 on
                      [11937.977322] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [11937.977330] rockchip-vop2 fdd90000.vop: pd0 off
                      [11937.993229] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [11937.993237] rockchip-vop2 fdd90000.vop: pd0 on
                      [12026.742752] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [12026.742761] rockchip-vop2 fdd90000.vop: pd0 off
                      [12028.675768] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [12028.675777] rockchip-vop2 fdd90000.vop: pd0 on
                      [12038.110980] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [12038.110991] rockchip-vop2 fdd90000.vop: pd0 off
                      [12042.042122] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [12042.042131] rockchip-vop2 fdd90000.vop: pd0 on
                      [12059.577168] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [12059.577176] rockchip-vop2 fdd90000.vop: pd0 off
                      [12097.108956] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [12097.108964] rockchip-vop2 fdd90000.vop: pd0 on
                      [12112.377853] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [12112.377862] rockchip-vop2 fdd90000.vop: pd0 off
                      [12113.609157] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [12113.609166] rockchip-vop2 fdd90000.vop: pd0 on
                      [12113.743643] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [12113.743651] rockchip-vop2 fdd90000.vop: pd0 off
                      [12115.227092] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [12115.227099] rockchip-vop2 fdd90000.vop: pd0 on
                      [12115.243558] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [12115.243567] rockchip-vop2 fdd90000.vop: pd0 off
                      [12123.609235] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [12123.609244] rockchip-vop2 fdd90000.vop: pd0 on
                      [12138.310541] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [12138.310549] rockchip-vop2 fdd90000.vop: pd0 off
                      [12138.461714] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [12138.461723] rockchip-vop2 fdd90000.vop: pd0 on
                      [12177.442599] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [12177.442612] rockchip-vop2 fdd90000.vop: pd0 off
                      [12177.459270] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [12177.459282] rockchip-vop2 fdd90000.vop: pd0 on
                      [12214.938648] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [12214.938655] rockchip-vop2 fdd90000.vop: pd0 off
                      [12214.955385] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [12214.955393] rockchip-vop2 fdd90000.vop: pd0 on
                      [12307.991337] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [12307.991341] rockchip-vop2 fdd90000.vop: pd0 off
                      [12310.607684] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [12310.607688] rockchip-vop2 fdd90000.vop: pd0 on
                      [12430.810610] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [12430.810618] rockchip-vop2 fdd90000.vop: pd0 off
                      [12449.474330] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [12449.474333] rockchip-vop2 fdd90000.vop: pd0 on
                      [12827.407348] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 512 (unused: 4608)
                      [12830.044346] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 512 (unused: 2560)
                      [12832.345678] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 1024 (unused: 5120)
                      [12834.277161] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 1024 (unused: 3072)
                      [12839.567026] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 2048 (unused: 4608)
                      [12946.121325] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 1536 (unused: 3584)
                      [12973.576452] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [12973.576460] rockchip-vop2 fdd90000.vop: pd0 off
                      [12979.624709] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
                      [12979.624713] rockchip-vop2 fdd90000.vop: pd0 on
                      [12991.331086] mlx5_core: version magic '5.10.110 SMP preempt mod_unload aarch64' should be '5.10.110 SMP mod_unload aarch64'
                      [13019.261815] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
                      [13019.261823] rockchip-vop2 fdd90000.vop: pd0 off
                      dmseg的结果如上
                        jack_admin @Jachyn
                        @Jachyn
                        1. modinfo mlx5相关的ko驱动文件
                        2. 内核更改配置为抢占模式,编译替换
                          Jachyn @jack_admin
                          [ 8935.079458] mlx5_core: Unknown symbol pci_num_vf (err -2)
                          [ 8935.079472] mlx5_core: Unknown symbol pci_sriov_get_totalvfs (err -2)
                          [ 8935.079526] mlx5_core: Unknown symbol net_dim (err -2)
                          [ 8935.079536] mlx5_core: Unknown symbol numa_node (err -2)
                          [ 8935.079650] mlx5_core: Unknown symbol net_dim_get_rx_moderation (err -2)
                          [ 8935.079667] mlx5_core: Unknown symbol net_dim_get_def_tx_moderation (err -2)
                          [ 8935.079679] mlx5_core: Unknown symbol pci_disable_sriov (err -2)
                          [ 8935.079686] mlx5_core: Unknown symbol net_dim_get_def_rx_moderation (err -2)
                          [ 8935.079687] mlx5_core: Unknown symbol net_dim_get_tx_moderation (err -2)
                          [ 8935.079711] mlx5_core: Unknown symbol pci_enable_sriov (err -2)
                          [ 8935.079715] mlx5_core: Unknown symbol elfcorehdr_addr (err -2)
                          [ 8935.079725] mlx5_core: Unknown symbol alloc_pages_current (err -2)
                          这次不报抢占的错误了 但是有这些
                            Jachyn @Jachyn
                            @Jachyn
                            root@coolpi:/home/coolpi/Downloads/mlnx-en-5.9-0.5.6.0-ubuntu22.04-aarch64/mlnx-en-5.9-0.5.6.0-ubuntu22.04-aarch64# ./mlnx_add_kernel_support.sh -m ./
                            Note: This program will create mlnx-en TGZ for ubuntu22.04 under /tmp directory.
                            See log file /tmp/mlnx_iso.834968_logs/mlnx_ofed_iso.834968.log
                            ERROR: Failed executing "MLNX_EN_SRC-5.9-0.5.6.0/install.pl --tmpdir /tmp/mlnx_iso.834968_logs --eth-only --kernel 5.10.110 --kernel-sources /lib/modules/5.10.110/build/ --builddir /tmp/mlnx_iso.834968 --without-dkms --build-only"
                            ERROR: See /tmp/mlnx_iso.834968_logs/mlnx_ofed_iso.834968.log
                              jack_admin @Jachyn
                              @Jachyn 内核配置增加CONFIG_PCI_IOV,还有其他的根据相应的symbol查找。
                              另外发现内核带有一个版本的驱动,你可以试下配置编译试试
                              drivers/net/ethernet/mellanox/
                              ├── Kconfig
                              ├── Makefile
                              ├── mlx4
                              ├── mlx5
                              ├── mlxfw
                              └── mlxsw
                              4 directories, 2 files
                                Jachyn @jack_admin
                                @jack_admin 这个内核我是从其他网站下的 站内的内核编译不通过
                                  jack_admin @Jachyn
                                  @Jachyn 需要用我们提供的内核,编译不过,找方法解决
                                    Jachyn @jack_admin
                                    CC      drivers/mtd/spi-nor/issi.o
                                    CC      drivers/mtd/spi-nor/macronix.o
                                    CC      drivers/scsi/scsi_sysfs.o
                                    CC      drivers/mtd/spi-nor/micron-st.o
                                    CC      drivers/mtd/spi-nor/puya.o
                                    CC      drivers/mtd/spi-nor/spansion.o
                                    CC      drivers/mtd/spi-nor/sst.o
                                    CC      drivers/mtd/spi-nor/winbond.o
                                    CC      drivers/mtd/spi-nor/xilinx.o
                                    CC      drivers/mtd/spi-nor/xmc.o
                                    CC      drivers/mtd/spi-nor/xtx.o
                                    AR      drivers/mtd/spi-nor/built-in.a
                                    AR      drivers/mtd/built-in.a
                                    AR      drivers/scsi/built-in.a
                                    make: *** [Makefile:1917: drivers] Error 2
                                      jack_admin @Jachyn
                                      @Jachyn 完整log,不要猜哈
