    Cool pi 4B & CM5 探索快速安装系统新方法
    147 Posts 11 Posters 23.8k Views
      @jugg said in Cool pi 4B & CM5 探索快速安装系统新方法:
      最新的uboot在哪里?
      需要自己重新编译?
      百度网盘或Onedrive
        没有啊
          @jugg 0411那个就是了
            没法更新loader
            电脑上用RKdev工具 也识别不到设备
            我也不知道你们是怎么做的 到底需要什么样的U盘
              https://wiki.cool-pi.com/en/home/quick_start
              参考loader更新方法
              U盘你格式化一次,拷贝uboot.img到U盘
                更新了loader
                ab8cd4ce-4cfe-451f-b009-cf76a252110b-lQDPJxeIVzHuKzjNA7zNBPyw9wCLfw9939cEvtjmk0B9AA_1276_956.jpg
                卡在这里不动了 过一会儿就黑屏了
                  @jugg extlinux.conf把参数改为ttyS0,115200n8,用串口观察过程
                    DDR V1.09 a930779e06 typ 22/11/21-17:50:56
                    LPDDR4X, 2112MHz
                    channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
                    channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
                    channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
                    channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
                    Manufacturer ID:0xff
                    CH0 RX Vref:30.7%, TX Vref:21.8%,21.8%
                    CH1 RX Vref:30.7%, TX Vref:22.8%,21.8%
                    CH2 RX Vref:29.7%, TX Vref:21.8%,21.8%
                    CH3 RX Vref:29.7%, TX Vref:21.8%,21.8%
                    change to F1: 528MHz
                    change to F2: 1068MHz
                    change to F3: 1560MHz
                    change to F0: 2112MHz
                    INFO:    Preloader serial: 2
                    NOTICE:  BL31: v2.3():v2.3-557-g9609b9c19:derrick.huang
                    NOTICE:  BL31: Built : 14:29:57, Mar  8 2023
                    INFO:    spec: 0x13
                    INFO:    ext 32k is not valid
                    INFO:    ddr: stride-en 4CH
                    INFO:    GICv3 without legacy support detected.
                    INFO:    ARM GICv3 driver initialized in EL3
                    INFO:    valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
                    INFO:    system boots from cpu-hwid-0
                    INFO:    idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
                    INFO:    dfs DDR fsp_params[0].freq_mhz= 2112MHz
                    INFO:    dfs DDR fsp_params[1].freq_mhz= 528MHz
                    INFO:    dfs DDR fsp_params[2].freq_mhz= 1068MHz
                    INFO:    dfs DDR fsp_params[3].freq_mhz= 1560MHz
                    INFO:    BL31: Initialising Exception Handling Framework
                    INFO:    BL31: Initializing runtime services
                    INFO:    BL31: Initializing BL32
                    I/TC:
                    I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022年 09月 20日 星期二 09:41:09 CST aarch64
                    INFO:    BL31: Preparing for EL3 exit to normal world
                    INFO:    Entry point address = 0x200000
                    INFO:    SPSR = 0x3c9
                    COOLPI LOADER BY YANYI(Jun 06 2023)
                    DRAM:  8 GiB
                    FAT: Misaligned buffer address (00000000ebc9e610)
                    0 2 1 3 6 8 7 9 hdmi@fde80000 disconnected
                    boot mode: None
                    Bus usb@fc000000: usb maximum-speed not found
                    trsv ln0 mon rx cdr lock timeout
                    Register 2000140 NbrPorts 2
                    Bus usb@fcd00000: usb maximum-speed not found
                    scanning bus usb@fc000000 for devices... 1 USB Device(s) found
                    scanning bus usb@fc880000 for devices...
                    LPDDR4X, 2112MHz
                    CH3 RX Vref:30.7%, TX Vref:22.8%,21.8%
                    INFO:    spec: 0x13
                    I/TC:
                    INFO:    SPSR = 0x3c9
                    DRAM:  8 GiB
                    boot mode: None
                    scanning bus usb@fc880000 for devices... 2 USB Device(s) found
                    scanning bus usb@fcd00000 for devices... 1 USB Device(s) found
                           scanning usb for storage devices... 1 Storage Device(s) found
                    Device 0: Vendor: Generic  Rev: 8.07 Prod: Flash Disk
                                Type: Removable Hard Disk
                                Capacity: 30000.0 MB = 29.2 GB (61440000 x 512)
                    Scanning usb 0:1...
                    284 bytes read in 35 ms (7.8 KiB/s)
                    1:	Linux coolpi
                    8913121 bytes read in 886 ms (9.6 MiB/s)
                    37706240 bytes read in 3595 ms (10 MiB/s)
                    append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n8 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:96:39:8b:af:40:ae
                    Retrieving file: /rk3588s-cp4.dtb
                    reading /rk3588s-cp4.dtb
                    141838 bytes read in 47 ms (2.9 MiB/s)
                       Loading Ramdisk to eb153000, end eb9d30e1 ... OK
                       Loading Device Tree to 00000000eb12d000, end 00000000eb152a0d ... OK
                    FAT: Misaligned buffer address (00000000ebcaf6f0)
                    [   12.746995] rk-pcie fe190000.pcie: IRQ msi not found
                    [   12.747011] rk-pcie fe190000.pcie: Missing *config* reg space
                    [   12.747100] rk-pcie fe190000.pcie: Missing *config* reg space
                    [   12.747128] rk-pcie fe190000.pcie: invalid resource
                    [   12.750030] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                    [   12.751179] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                    [   12.751183] rkvdec2_init:1010: No niu aclk reset resource define
                    [   12.751187] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                    [   12.751190] rkvdec2_init:1013: No niu hclk reset resource define
                    [   12.751707] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                    [   12.751711] rkvdec2_init:1010: No niu aclk reset resource define
                    [   12.751714] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                    [   12.751717] rkvdec2_init:1013: No niu hclk reset resource define
                    [   12.753419] mpp_iommu_probe:434: failed to get device node
                    [   12.753424] mpp_av1dec av1d-master: failed to attach iommu
                    [   12.983271] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any match mode
                    [   12.991632] rockchip-drm display-subsystem: failed to show kernel logo
                    [   13.109833] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
                    [   13.110084] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
                    [   13.372226] rk806 spi2.0: no sleep-setting state
                    [   13.376844] rk806 spi2.0: no reset-setting pinctrl state
                    [   13.382148] rk806 spi2.0: no dvs-setting pinctrl state
                    [   13.595213] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                    [   13.602569] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                    [   13.609918] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                    [   13.617266] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                    [   13.624613] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                    [   13.631823] tinker-mcu: send_cmds: send command failed
                    [   13.636952] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
                    [   14.207396] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
                    [   14.226018] : terminal subdev does not exist
                    [   14.230290] : terminal subdev does not exist
                    [   14.234552] : terminal subdev does not exist
                    [   14.238815] : terminal subdev does not exist
                    [   14.243078] : get_remote_sensor: video pad[0] is null
                    [   14.248121] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                    [   14.255330] : get_remote_sensor: video pad[0] is null
                    [   14.260373] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                    [   14.267584] : get_remote_sensor: video pad[0] is null
                    [   14.272629] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                    [   14.279839] : get_remote_sensor: video pad[0] is null
                    [   14.284881] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                    [   14.293240] rockchip-mipi-csi2: Async registered subdev
                    [   14.362227] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                    [   14.373046] debugfs: File 'Capture' in directory 'dapm' already present!
                    [   14.395725] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                    [   14.729254] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                    [   14.736468] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                    [   14.743765] debugfs: File 'HPCP L' in directory 'dapm' already present!
                    [   14.750365] debugfs: File 'HPCP R' in directory 'dapm' already present!
                    [   14.756967] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                    [   14.763653] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                    [   14.771803] ov5648 8-0036: could not get default pinstate
                    [   14.777196] ov5648 8-0036: could not get sleep pinstate
                    [   14.785078] ov5648 8-0036: Unexpected sensor id(000000), ret(-5)
                    [   14.792138] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                    [   14.801266] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                    [   14.810380] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                    [   14.818204] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                    [   14.818440] rockchip_headset rk-headset: Can not read property headset_gpio
                    [   14.827318] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                    [   14.843348] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                    [   14.851869] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                    [   14.860378] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                    [   14.872438] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                    [   14.902618] RKNPU fdab0000.npu: failed to find power_model node
                    [   14.908529] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                    [   14.908530] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                    wait for device.
                    AT2Y1B
                    wait for external disk device.
                    Generic
                    20+0 records in
                    20+0 records out
                    20971520 bytes (21 MB, 20 MiB) copied, 0.188153 s, 111 MB/s
                    Device contains neither a valid DOS partition table, nor Sun, SGI, OSF or GPT disklabel
                    Building a new DOS disklabel. Changes will remain in memory only,
                    until you decide to write them. After that the previous content
                    won't be recoverable.
                    The number of cylinders for this disk is set to 946944.
                    There is nothing wrong with that, but this is larger than 1024,
                    and could in certain setups cause problems with:
                    1) software that runs at boot time (e.g., old versions of LILO)
                    2) booting and partitioning software from other OSs
                       (e.g., DOS FDISK, OS/2 FDISK)
                    Command (m for help): Partition type
                       p   primary partition (1-4)
                       e   extended
                    Partition number (1-4): First sector (16-60604415, default 16): Using default value 16
                    Last sector or +size{,K,M,G,T} (16-60604415, default 60604415):
                    Command (m for help): Selected partition 1
                    Hex code (type L to list codes): Changed system type of partition 1 to b (Win95 FAT32)
                       e   extended
                    Partition number (1-4): First sector (1048592-60604415, default 1048592): Using default value 1048592
                    Last sector or +size{,K,M,G,T} (1048592-60604415, default 60604415): Using default value 60604415
                    Command (m for help): The partition table has been altered.
                    Calling ioctl() to re-read partition table
                    mkfs.fat 4.2 (2021-01-31)
                    fatlabel: warning - lowercase labels might not work properly on some systems
                    total 205M
                    -rwxr-xr-x 1 0 0  37M Jul 31  2023 Image
                    -rwxr-xr-x 1 0 0  176 Jun 13  2023 cmdline.txt
                    -rwxr-xr-x 1 0 0   68 Jul 31  2023 config.txt
                    drwxr-xr-x 2 0 0 4.0K Jun 19  2023 extlinux
                    -rwxr-xr-x 1 0 0 8.4M Jun 13  2023 initrd.img
                    -rwxr-xr-x 1 0 0 136M Jun 13  2023 modules.tar.gz
                    -rwxr-xr-x 1 0 0 140K Jul 31  2023 rk3588s-cp4-dsi.dtb
                    -rwxr-xr-x 1 0 0 140K Jul 31  2023 rk3588s-cp4-sfc.dtb
                    -rwxr-xr-x 1 0 0 140K Jul 31  2023 rk3588s-cp4.dtb
                    -rwxr-xr-x 1 0 0  13M Jul 31  2023 vmlinuz
                    mke2fs 1.46.5 (30-Dec-2021)
                    Discarding device blocks: [   41.269135] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
                    [   41.276429] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
                    [   42.604779] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
                    [   42.612045] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
                    done
                    Creating filesystem with 7444478 4k blocks and 1864128 inodes
                    Filesystem UUID: eb878b89-7651-4f9c-8eb8-e6e819f2f447
                    Superblock backups stored on blocks:
                    	32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
                    	4096000
                    Allocating group tables: done
                    Writing inode tables: done
                    Creating journal (32768 blocks): done
                    Writing superblocks and filesystem accounting information: done
                    e2fsck 1.46.5 (30-Dec-2021)
                    Pass 1: Checking inodes, blocks, and sizes
                    Pass 2: Checking directory structure
                    Pass 3: Checking directory connectivity
                    Pass 4: Checking reference counts
                    Pass 5: Checking group summary information
                    writable: 11/1864128 files (0.0% non-contiguous), 161057/7444478 blocks
                    resize2fs 1.46.5 (30-Dec-2021)
                    The filesystem is already 7444478 (4k) blocks long.  Nothing to do!
                      @jugg 把备份的镜像文件压缩包发给我试试
                        是不是跟要刷机的板子的原来的系统有关 而不是备份的镜像
                        这是安装盘的压缩包 install里面就是备份盘备份出来的镜像 还原不了到另外一块板子里面
                        链接:https://pan.baidu.com/s/1qw-WQMRiGHzMaGcCRLAtMA?pwd=6qap
                        提取码:6qap
                          怎么样?
                            正常安装
                            [   11.122038] rk-pcie fe190000.pcie: IRQ msi not found
                            [   11.122053] rk-pcie fe190000.pcie: Missing *config* reg space
                            [   11.122142] rk-pcie fe190000.pcie: Missing *config* reg space
                            [   11.122169] rk-pcie fe190000.pcie: invalid resource
                            [   11.125068] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                            [   11.126208] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                            [   11.126214] rkvdec2_init:1010: No niu aclk reset resource define
                            [   11.126218] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                            [   11.126220] rkvdec2_init:1013: No niu hclk reset resource define
                            [   11.126737] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                            [   11.126740] rkvdec2_init:1010: No niu aclk reset resource define
                            [   11.126744] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                            [   11.126747] rkvdec2_init:1013: No niu hclk reset resource define
                            [   11.128444] mpp_iommu_probe:434: failed to get device node
                            [   11.128448] mpp_av1dec av1d-master: failed to attach iommu
                            [   11.666758] rk806 spi2.0: no sleep-setting state
                            [   11.671377] rk806 spi2.0: no reset-setting pinctrl state
                            [   11.676680] rk806 spi2.0: no dvs-setting pinctrl state
                            [   11.889706] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                            [   11.897062] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                            [   11.904409] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                            [   11.911758] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                            [   11.919105] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                            [   11.926316] tinker-mcu: send_cmds: send command failed
                            [   11.931446] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
                            [   12.501950] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
                            [   12.520585] : terminal subdev does not exist
                            [   12.524858] : terminal subdev does not exist
                            [   12.529120] : terminal subdev does not exist
                            [   12.533383] : terminal subdev does not exist
                            [   12.537647] : get_remote_sensor: video pad[0] is null
                            [   12.542691] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                            [   12.549901] : get_remote_sensor: video pad[0] is null
                            [   12.554943] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                            [   12.562160] : get_remote_sensor: video pad[0] is null
                            [   12.567204] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                            [   12.574416] : get_remote_sensor: video pad[0] is null
                            [   12.579458] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                            [   12.587879] rockchip-mipi-csi2: Async registered subdev
                            [   12.657092] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                            [   12.667892] debugfs: File 'Capture' in directory 'dapm' already present!
                            [   12.690795] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                            [   13.023688] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                            [   13.030902] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                            [   13.038198] debugfs: File 'HPCP L' in directory 'dapm' already present!
                            [   13.044797] debugfs: File 'HPCP R' in directory 'dapm' already present!
                            [   13.051402] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                            [   13.058088] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                            [   13.066273] ov5648 8-0036: could not get default pinstate
                            [   13.071667] ov5648 8-0036: could not get sleep pinstate
                            [   13.079716] ov5648 8-0036: Unexpected sensor id(000000), ret(-5)
                            [   13.086769] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                            [   13.095900] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                            [   13.105015] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                            [   13.112896] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                            [   13.113084] rockchip_headset rk-headset: Can not read property headset_gpio
                            [   13.122014] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                            [   13.137989] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                            [   13.146511] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                            [   13.155020] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                            [   13.167187] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                            [   13.198264] RKNPU fdab0000.npu: failed to find power_model node
                            [   13.204174] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                            [   13.210775] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                            wait for device.
                            AT2Y1B
                            wait for external disk device..
                            Kingston
                            20+0 records in
                            20+0 records out
                            20971520 bytes (21 MB, 20 MiB) copied, 0.186213 s, 113 MB/s
                               e   extended
                               e   extended
                            total 205M
                            Discarding device blocks: done
                            Filesystem UUID: e42c8656-d1a3-40b1-85a8-2ddce3913d78
                                    4096000
                             1.6GiB 0:00:54 [29.8MiB/s] [================================> ] 99%
                            Complete install... please remove udisk for next booting
                            auto poweroff system later when you plugout udisk...
                            udisk have been removed.Now poweroff system...
                            [  136.856307] reboot: Power down
                              要换U盘?
                                我也是这样刷的
                                安装盘里面就只有压缩包里面的内容
                                怎么就不行呢
                                u盘也识别到了啊
                                  @jugg 你的u盘感觉质量如何
                                  J 3 Replies Last reply Reply Quote 0
                                    我觉得质量没问题
                                      你可以多刷几次 是不是每次都能刷成功
                                        系统刷不了 就没法批量了
                                          @jugg 有没有试过品牌U盘。这个方法我一直在用
                                            你可以多刷几次 是不是每次都能刷成功
                                            刷机方法没有问题,试了多次都能刷成功。
                                            • 4
                                            • 5
                                            • 6
                                            • 7
                                            • 8
                                            • 5 / 8
