    Cool pi 4B & CM5 探索快速安装系统新方法
    147 Posts 11 Posters 56.4k Views
      换了个金士顿的U盘作为安装盘 加载完logo就重启 反复重启
      我已经没办法了
        到底是接U3的上面口还是下面口
        为什么我接U3上面口 没反应 接下面口才有反应
          这是换了金士顿U盘的
          还是卡在那里
          COOLPI LOADER BY YANYI(Apr 11 2023)
          DRAM:  8 GiB
          0 2 1 3 6 8 7 9 Monitor has basic audio support
          hdmi@fde80000:  detailed mode clock 148500 kHz, flags[5]
              H: 1920 2008 2052 2200
              V: 1080 1084 1089 1125
          bus_format: 100a
          VP0 set crtc_clock to 1485KHz
          VOP VP0 enable Esmart0[356x124->356x124@782x478] fmt[1] addr[0xedf21000]
          CEA mode used vic=16
          mtmdsclock:148500000
          Bus usb@fc000000: usb maximum-speed not found
          trsv ln0 mon rx cdr lock timeout
          Register 2000140 NbrPorts 2
          Bus usb@fcd00000: usb maximum-speed not found
          scanning bus usb@fc000000 for devices... cannot reset port 1!?
          2 USB Device(s) found
          scanning bus usb@fcd00000 for devices... 1 USB Device(s) found
                 scanning usb for storage devices... 1 Storage Device(s) found
          Device 0: Vendor: Kingston Rev: PMAP Prod: DataTraveler 3.0
                      Type: Removable Hard Disk
                      Capacity: 29592.0 MB = 28.8 GB (60604416 x 512)
          Scanning usb 0:1...
          284 bytes read in 33 ms (7.8 KiB/s)
          1:	Linux coolpi
          8913121 bytes read in 422 ms (20.1 MiB/s)
          37706240 bytes read in 1697 ms (21.2 MiB/s)
          append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n8 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:7a:46:da:5f:3e:bd
          Retrieving file: /rk3588s-cp4.dtb
          reading /rk3588s-cp4.dtb
          141838 bytes read in 38 ms (3.6 MiB/s)
             Loading Ramdisk to eb154000, end eb9d40e1 ... OK
             Loading Device Tree to 00000000eb12e000, end 00000000eb153a0d ... OK
          [   10.801747] rk-pcie fe190000.pcie: IRQ msi not found
          [   10.801763] rk-pcie fe190000.pcie: Missing *config* reg space
          [   10.801855] rk-pcie fe190000.pcie: Missing *config* reg space
          [   10.801883] rk-pcie fe190000.pcie: invalid resource
          [   10.804829] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
          [   10.805992] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
          [   10.805997] rkvdec2_init:1010: No niu aclk reset resource define
          [   10.806001] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
          [   10.806004] rkvdec2_init:1013: No niu hclk reset resource define
          [   10.806530] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
          [   10.806533] rkvdec2_init:1010: No niu aclk reset resource define
          [   10.806537] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
          [   10.806539] rkvdec2_init:1013: No niu hclk reset resource define
          [   10.808288] mpp_iommu_probe:434: failed to get device node
          [   10.808293] mpp_av1dec av1d-master: failed to attach iommu
          [   11.341426] rk806 spi2.0: no sleep-setting state
          [   11.346050] rk806 spi2.0: no reset-setting pinctrl state
          [   11.351356] rk806 spi2.0: no dvs-setting pinctrl state
          [   11.567895] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
          [   11.575253] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
          [   11.582602] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
          [   11.589953] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
          [   11.597302] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
          [   11.604512] tinker-mcu: send_cmds: send command failed
          [   11.609641] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
          [   12.179893] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
          [   12.198621] : terminal subdev does not exist
          [   12.202893] : terminal subdev does not exist
          [   12.207155] : terminal subdev does not exist
          [   12.211418] : terminal subdev does not exist
          [   12.215681] : get_remote_sensor: video pad[0] is null
          [   12.220725] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
          [   12.227935] : get_remote_sensor: video pad[0] is null
          [   12.232977] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
          [   12.240190] : get_remote_sensor: video pad[0] is null
          [   12.245236] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
          [   12.252446] : get_remote_sensor: video pad[0] is null
          [   12.257489] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
          [   12.265952] rockchip-mipi-csi2: Async registered subdev
          [   12.335257] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
          [   12.346141] debugfs: File 'Capture' in directory 'dapm' already present!
          [   12.368803] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
          [   12.705027] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
          [   12.712240] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
          [   12.719536] debugfs: File 'HPCP L' in directory 'dapm' already present!
          [   12.726135] debugfs: File 'HPCP R' in directory 'dapm' already present!
          [   12.732737] debugfs: File 'HPVOL L' in directory 'dapm' already present!
          [   12.739423] debugfs: File 'HPVOL R' in directory 'dapm' already present!
          [   12.747604] ov5648 8-0036: could not get default pinstate
          [   12.752995] ov5648 8-0036: could not get sleep pinstate
          [   12.761463] ov5648 8-0036: Unexpected sensor id(000000), ret(0)
          [   12.768370] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
          [   12.777492] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
          [   12.786609] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
          [   12.794481] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
          [   12.794638] rockchip_headset rk-headset: Can not read property headset_gpio
          [   12.803602] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
          [   12.819574] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
          [   12.828095] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
          [   12.836604] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
          [   12.848785] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
          [   12.877861] RKNPU fdab0000.npu: failed to find power_model node
          [   12.883771] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
          [   12.890371] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
          wait for device.
          AT2Y1B
          wait for external disk device..
          Kingston
          20+0 records in
          20+0 records out
          20971520 bytes (21 MB, 20 MiB) copied, 0.187014 s, 112 MB/s
          Device contains neither a valid DOS partition table, nor Sun, SGI, OSF or GPT disklabel
          Building a new DOS disklabel. Changes will remain in memory only,
          until you decide to write them. After that the previous content
          won't be recoverable.
          The number of cylinders for this disk is set to 946944.
          There is nothing wrong with that, but this is larger than 1024,
          and could in certain setups cause problems with:
          1) software that runs at boot time (e.g., old versions of LILO)
          2) booting and partitioning software from other OSs
             (e.g., DOS FDISK, OS/2 FDISK)
          Command (m for help): Partition type
             p   primary partition (1-4)
             e   extended
          Partition number (1-4): First sector (16-60604415, default 16): Using default value 16
          Last sector or +size{,K,M,G,T} (16-60604415, default 60604415):
          Command (m for help): Selected partition 1
          Hex code (type L to list codes): Changed system type of partition 1 to b (Win95 FAT32)
             e   extended
          Partition number (1-4): First sector (1048592-60604415, default 1048592): Using default value 1048592
          Last sector or +size{,K,M,G,T} (1048592-60604415, default 60604415): Using default value 60604415
          Command (m for help): The partition table has been altered.
          Calling ioctl() to re-read partition table
          mkfs.fat 4.2 (2021-01-31)
          fatlabel: warning - lowercase labels might not work properly on some systems
          total 205M
          -rwxr-xr-x 1 0 0  37M Jul 31  2023 Image
          -rwxr-xr-x 1 0 0  176 Jun 13  2023 cmdline.txt
          -rwxr-xr-x 1 0 0   68 Jul 31  2023 config.txt
          drwxr-xr-x 2 0 0 4.0K Jun 19  2023 extlinux
          -rwxr-xr-x 1 0 0 8.4M Jun 13  2023 initrd.img
          -rwxr-xr-x 1 0 0 136M Jun 13  2023 modules.tar.gz
          -rwxr-xr-x 1 0 0 140K Jul 31  2023 rk3588s-cp4-dsi.dtb
          -rwxr-xr-x 1 0 0 140K Jul 31  2023 rk3588s-cp4-sfc.dtb
          -rwxr-xr-x 1 0 0 140K Jul 31  2023 rk3588s-cp4.dtb
          -rwxr-xr-x 1 0 0  13M Jul 31  2023 vmlinuz
          mke2fs 1.46.5 (30-Dec-2021)
          /dev/mmcblk0p2 contains a ext4 file system labelled 'writable'
          	last mounted on /root on Thu Jan  1 00:00:03 1970
          Discarding device blocks: done
          Creating filesystem with 7444478 4k blocks and 1864128 inodes
          Filesystem UUID: d1493481-5088-470c-87b2-3cc6db991a0c
          Superblock backups stored on blocks:
          	32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
          	4096000
          Allocating group tables: done
          Writing inode tables: done
          Creating journal (32768 blocks): done
          Writing superblocks and filesystem accounting information: done
          e2fsck 1.46.5 (30-Dec-2021)
          Pass 1: Checking inodes, blocks, and sizes
          Pass 2: Checking directory structure
          Pass 3: Checking directory connectivity
          Pass 4: Checking reference counts
          Pass 5: Checking group summary information
          writable: 11/1864128 files (0.0% non-contiguous), 161057/7444478 blocks
          resize2fs 1.46.5 (30-Dec-2021)
          The filesystem is already 7444478 (4k) blocks long.  Nothing to do!
            这个角度看,U3下面一个口。
            确认你的电源适配器
              电源适配器是买的时候里面配的12V2A的
                jugg @jugg
                @jugg said in Cool pi 4B & CM5 探索快速安装系统新方法:
                  你这接的不是U3上面那个口?
                  我接的不是对的?
                    @jugg 你手上有几块板,换个试下。emmc模组看下有没有扣好
                      不接U盘 系统能正常进去 说明emmc没问题
                        你这接的不是U3上面那个口?
                        我接的不是对的?
                        看文字描述。图片是角度示意
                          接下面口 直接进系统
                            @jugg loader重新刷一个,用Windows rkdevtools工具刷
                              loader刷了 接U3下面口 还是直接进系统
                                jugg @jugg
                                  确认是这个接口,附带串口启动信息
                                    是下面这个口
                                    是不是跟备份的系统有什么关系 导致还原不了?
                                      @jugg 安装引导盘,不管安装包内容。只要压缩包没有损坏,通常都能解压缩
                                        备份出来的文件 没法解压 解压失败
                                          @jugg 合并再解压。你的U盘install目录存放这些文件?把rootfs.tar.gz删了先,不可共存
                                            原来的文件肯定删了的
                                            • 4
                                            • 5
                                            • 6
                                            • 7
                                            • 8
                                            • 6 / 8
