    coolpi 4b support ov5647 camera module
    24 Posts 8 Posters 8.2k Views
      大法师 @bg8wj
      @bg8wj github已更新内核驱动代码。二进制执行文件明天测试好再上传
      root@coolpi:/home/coolpi# ls -l /dev/video*
      crw-rw----+ 1 root video 81,  0 Jan 27 23:26 /dev/video0
      crw-rw----+ 1 root video 81,  1 Jan 27 23:26 /dev/video1
      crw-rw----+ 1 root video 81, 10 Jan 27 23:26 /dev/video10
      crw-rw----+ 1 root video 81, 11 Jan 27 23:26 /dev/video11
      crw-rw----+ 1 root video 81, 12 Jan 27 23:26 /dev/video12
      crw-rw----+ 1 root video 81, 13 Jan 27 23:26 /dev/video13
      crw-rw----+ 1 root video 81, 14 Jan 27 23:26 /dev/video14
      crw-rw----+ 1 root video 81, 15 Jan 27 23:26 /dev/video15
      crw-rw----+ 1 root video 81, 16 Jan 27 23:26 /dev/video16
      crw-rw----+ 1 root video 81, 17 Jan 27 23:26 /dev/video17
      crw-rw----+ 1 root video 81, 18 Jan 27 23:26 /dev/video18
      crw-rw----+ 1 root video 81, 19 Jan 27 23:26 /dev/video19
      crw-rw----+ 1 root video 81,  2 Jan 27 23:26 /dev/video2
      crw-rw----+ 1 root video 81,  3 Jan 27 23:26 /dev/video3
      crw-rw----+ 1 root video 81,  4 Jan 27 23:26 /dev/video4
      crw-rw----+ 1 root video 81,  5 Jan 27 23:26 /dev/video5
      crw-rw----+ 1 root video 81,  6 Jan 27 23:26 /dev/video6
      crw-rw----+ 1 root video 81,  7 Jan 27 23:26 /dev/video7
      crw-rw----+ 1 root video 81,  8 Jan 27 23:26 /dev/video8
      crw-rw----+ 1 root video 81,  9 Jan 27 23:26 /dev/video9
      lrwxrwxrwx  1 root root       7 Jan 27 23:26 /dev/video-camera0 -> video11
      root@coolpi:/home/coolpi# dmesg | grep ov564
      [   11.285152] ov5648 8-0036: driver version: 00.01.05
      [   11.285181] ov5648 8-0036: Failed to get power-gpios, maybe no use
      [   11.285193] ov5648 8-0036: Failed to get reset-gpios, maybe no use
      [   11.285205] ov5648 8-0036: Failed to get pwdn-gpios
      [   11.285305] ov5648 8-0036: supply dovdd not found, using dummy regulator
      [   11.285372] ov5648 8-0036: supply dvdd not found, using dummy regulator
      [   11.285409] ov5648 8-0036: lane_num(2)  pixel_rate(84000000)
      [   11.285416] ov5648 8-0036: could not get default pinstate
      [   11.290827] ov5648 8-0036: could not get sleep pinstate
      [   11.299689] ov5648 8-0036: Detected OV005647 sensor
      [   11.299707] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m01_f_ov5648 8-0036:bus type 5
      N B 2 Replies Last reply Reply Quote 0
        nickliu @大法师
        @大法师 Hi, thanks for your effort!
        A suggestion, why not doc your work as a tutorial?
        So that everyone can help you debug the code.
          bg8wj @大法师
          @大法师 非常感谢。麻烦您。如可以给个安装指导。我汇总成教程。coolpi 4b 非常强大,我再学习移植一些 raspbeery 4b的项目到coolpi上。
            大法师 @bg8wj
            @bg8wj 谢谢!我们验证好了会同步发布出来。这款主板还有很多功能可以挖掘,需要更多的伙伴一起共赢!
              暂时未重新打包刷机镜像,可以先独立更新内核驱动包。
              百度网盘
              coolpi@coolpi:~$ sudo dpkg -i coolpi-kernel_1.0.0_aarch64.deb
              coolpi@coolpi:~$ sync
              coolpi@coolpi:~$ sudo reboot
              重启系统,如有连接ov5647摄像头,可以识别到video设备。
              coolpi@coolpi:~$ sudo apt install v4l-utils
              coolpi@coolpi:~$ v4l2-ctl --list-devices
              rkisp-statistics (platform: rkisp):
                      /dev/video18
                      /dev/video19
              rkcif (platform:rkcif-mipi-lvds2):
                      /dev/video0
                      /dev/video1
                      /dev/video2
                      /dev/video3
                      /dev/video4
                      /dev/video5
                      /dev/video6
                      /dev/video7
                      /dev/video8
                      /dev/video9
                      /dev/video10
              rkisp_mainpath (platform:rkisp0-vir0):
                      /dev/video11
                      /dev/video12
                      /dev/video13
                      /dev/video14
                      /dev/video15
                      /dev/video16
                      /dev/video17
              B 1 Reply Last reply Reply Quote -1
                bg8wj @大法师
                @大法师 谢谢。
                  tonyone0902
                  請問是否有機會支援 VEYE 系列的模組? 像是 IMX462 之類 (http://www.veye.cc/产品/veye-mipi-imx462-2/#tab-id-2)
                  畢竟 VEYE 也是國產之光,國內也比較容易買得到
                    nickliu
                    Hi, I tried the new kernel with two OV5647 camera.
                    It looks the default configuration is not correct.
                    The command I used
                    sudo v4l2-ctl --verbose -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat='NV12' --stream-mmap=4 --set-selection=target=crop,flags=0,top=0,left=0,width=1920,height=1080 --stream-to=out1.yuv
                    ffplay out1.yuv  -pixel_format nv12 -video_size 1920x1080
                    The system message
                    @Ubuntu:~$ dmesg | grep 'ov5'
                    [    7.644913] ov5648 8-0036: driver version: 00.01.05
                    [    7.644958] ov5648 8-0036: Failed to get power-gpios, maybe no use
                    [    7.644976] ov5648 8-0036: Failed to get reset-gpios, maybe no use
                    [    7.644994] ov5648 8-0036: Failed to get pwdn-gpios
                    [    7.645126] ov5648 8-0036: supply dovdd not found, using dummy regulator
                    [    7.645216] ov5648 8-0036: supply dvdd not found, using dummy regulator
                    [    7.645268] ov5648 8-0036: lane_num(2)  pixel_rate(84000000)
                    [    7.645277] ov5648 8-0036: could not get default pinstate
                    [    7.650710] ov5648 8-0036: could not get sleep pinstate
                    [    7.660168] ov5648 8-0036: Detected OV005647 sensor
                    [    7.660205] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m01_f_ov5648 8-0036:bus type 5
                    [  123.522013] ov5648 8-0036: ov5648_s_stream(997) enter!
                    [  123.522018] ov5648 8-0036: stream on!!!
                    [  123.574530] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1
                    [  123.577105] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400
                    [  141.109425] ov5648 8-0036: ov5648_s_stream(997) enter!
                    [  141.109431] ov5648 8-0036: stream off!!!
                    [  352.460709] ov5648 8-0036: ov5648_s_stream(997) enter!
                    [  352.460714] ov5648 8-0036: stream on!!!
                    [  352.506940] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1
                    [  352.508804] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400
                    [  359.915797] ov5648 8-0036: ov5648_s_stream(997) enter!
                    [  359.915807] ov5648 8-0036: stream off!!!
                    [  522.868438] ov5648 8-0036: ov5648_s_stream(997) enter!
                    [  522.868438] ov5648 8-0036: stream on!!!
                    [  522.907120] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1
                    [  522.908828] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400
                    [  527.994503] ov5648 8-0036: ov5648_s_stream(997) enter!
                    [  527.994509] ov5648 8-0036: stream off!!!
                    [  567.407434] ov5648 8-0036: ov5648_s_stream(997) enter!
                    [  567.407435] ov5648 8-0036: stream on!!!
                    [  567.448267] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1
                    [  567.450267] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400
                    [  572.471164] ov5648 8-0036: ov5648_s_stream(997) enter!
                    [  572.471167] ov5648 8-0036: stream off!!!
                    @Ubuntu:~$ sudo v4l2-ctl --list-devices
                            /dev/video18
                            /dev/video19
                    rkcif-mipi-lvds2 (platform:rkcif):
                            /dev/media0
                            /dev/video0
                            /dev/video1
                            /dev/video2
                            /dev/video3
                            /dev/video4
                            /dev/video5
                            /dev/video6
                            /dev/video7
                            /dev/video8
                            /dev/video9
                            /dev/video10
                            /dev/video11
                            /dev/video12
                            /dev/video13
                            /dev/video14
                            /dev/video15
                            /dev/video16
                            /dev/video17
                            /dev/media1
                    Ubuntu:~$ sudo media-ctl -p -d /dev/media0
                    Media controller API version 5.10.110
                    Media device information
                    driver          rkcif
                    model           rkcif-mipi-lvds2
                    serial
                    bus info
                    hw revision     0x0
                    driver version  5.10.110
                    Device topology
                    - entity 1: stream_cif_mipi_id0 (1 pad, 11 links)
                                type Node subtype V4L flags 0
                                device node name /dev/video0
                    	pad0: Sink
                    		<- "rockchip-mipi-csi2":1 [ENABLED]
                    		<- "rockchip-mipi-csi2":2 []
                    		<- "rockchip-mipi-csi2":3 []
                    		<- "rockchip-mipi-csi2":4 []
                    		<- "rockchip-mipi-csi2":5 []
                    		<- "rockchip-mipi-csi2":6 []
                    		<- "rockchip-mipi-csi2":7 []
                    		<- "rockchip-mipi-csi2":8 []
                    		<- "rockchip-mipi-csi2":9 []
                    		<- "rockchip-mipi-csi2":10 []
                    		<- "rockchip-mipi-csi2":11 []
                    - entity 5: stream_cif_mipi_id1 (1 pad, 11 links)
                                device node name /dev/video1
                    	pad0: Sink
                    		<- "rockchip-mipi-csi2":1 []
                    		<- "rockchip-mipi-csi2":2 [ENABLED]
                    - entity 9: stream_cif_mipi_id2 (1 pad, 11 links)
                                device node name /dev/video2
                    	pad0: Sink
                    		<- "rockchip-mipi-csi2":3 [ENABLED]
                    - entity 13: stream_cif_mipi_id3 (1 pad, 11 links)
                                 device node name /dev/video3
                    	pad0: Sink
                    		<- "rockchip-mipi-csi2":4 [ENABLED]
                    - entity 17: rkcif_scale_ch0 (1 pad, 11 links)
                                 device node name /dev/video4
                    	pad0: Sink
                    		<- "rockchip-mipi-csi2":5 [ENABLED]
                    - entity 21: rkcif_scale_ch1 (1 pad, 11 links)
                                 device node name /dev/video5
                    	pad0: Sink
                    		<- "rockchip-mipi-csi2":6 [ENABLED]
                    - entity 25: rkcif_scale_ch2 (1 pad, 11 links)
                                 device node name /dev/video6
                    	pad0: Sink
                    		<- "rockchip-mipi-csi2":7 [ENABLED]
                    - entity 29: rkcif_scale_ch3 (1 pad, 11 links)
                                 device node name /dev/video7
                    	pad0: Sink
                    		<- "rockchip-mipi-csi2":8 [ENABLED]
                    - entity 33: rkcif_tools_id0 (1 pad, 11 links)
                                 device node name /dev/video8
                    	pad0: Sink
                    		<- "rockchip-mipi-csi2":9 [ENABLED]
                    - entity 37: rkcif_tools_id1 (1 pad, 11 links)
                                 device node name /dev/video9
                    	pad0: Sink
                    		<- "rockchip-mipi-csi2":10 [ENABLED]
                    - entity 41: rkcif_tools_id2 (1 pad, 11 links)
                                 device node name /dev/video10
                    	pad0: Sink
                    		<- "rockchip-mipi-csi2":11 [ENABLED]
                    - entity 45: rockchip-mipi-csi2 (12 pads, 122 links)
                                 type V4L2 subdev subtype Unknown flags 0
                                 device node name /dev/v4l-subdev0
                    	pad0: Sink
                    		[fmt:SBGGR10_1X10/2592x1944 field:none
                    		 crop.bounds:(0,0)/2592x1944
                    		 crop:(0,0)/2592x1944]
                    		<- "rockchip-csi2-dphy0":1 [ENABLED]
                    	pad1: Source
                    		-> "stream_cif_mipi_id0":0 [ENABLED]
                    		-> "stream_cif_mipi_id1":0 []
                    		-> "stream_cif_mipi_id2":0 []
                    		-> "stream_cif_mipi_id3":0 []
                    		-> "rkcif_scale_ch0":0 []
                    		-> "rkcif_scale_ch1":0 []
                    		-> "rkcif_scale_ch2":0 []
                    		-> "rkcif_scale_ch3":0 []
                    		-> "rkcif_tools_id0":0 []
                    		-> "rkcif_tools_id1":0 []
                    		-> "rkcif_tools_id2":0 []
                    	pad2: Source
                    		-> "stream_cif_mipi_id0":0 []
                    		-> "stream_cif_mipi_id1":0 [ENABLED]
                    	pad3: Source
                    		-> "stream_cif_mipi_id2":0 [ENABLED]
                    	pad4: Source
                    		-> "stream_cif_mipi_id3":0 [ENABLED]
                    	pad5: Source
                    		-> "rkcif_scale_ch0":0 [ENABLED]
                    	pad6: Source
                    		-> "rkcif_scale_ch1":0 [ENABLED]
                    	pad7: Source
                    		-> "rkcif_scale_ch2":0 [ENABLED]
                    	pad8: Source
                    		-> "rkcif_scale_ch3":0 [ENABLED]
                    	pad9: Source
                    		-> "rkcif_tools_id0":0 [ENABLED]
                    	pad10: Source
                    		-> "rkcif_tools_id1":0 [ENABLED]
                    	pad11: Source
                    		-> "rkcif_tools_id2":0 [ENABLED]
                    - entity 58: rockchip-csi2-dphy0 (2 pads, 2 links)
                                 device node name /dev/v4l-subdev1
                    	pad0: Sink
                    		[fmt:SBGGR10_1X10/2592x1944@10000/150000 field:none]
                    		<- "m01_f_ov5648 8-0036":0 [ENABLED]
                    	pad1: Source
                    		-> "rockchip-mipi-csi2":0 [ENABLED]
                    - entity 63: m01_f_ov5648 8-0036 (1 pad, 1 link)
                                 type V4L2 subdev subtype Sensor flags 0
                                 device node name /dev/v4l-subdev2
                    	pad0: Source
                    		-> "rockchip-csi2-dphy0":0 [ENABLED]
                      大法师 @nickliu
                      @nickliu
                      ubuntu or armbian version need verify and then release.
                        george @大法师
                        @大法师 The latest ubuntu22.04 image can already support this camera.
                        • 20230210-ubuntu-22.04-preinstalled-desktop-arm64-coolpi.rar
                        • V4L2-TEST can start the camera by operating the video11 node
                        175f6719-6fa9-4acb-bc1e-b9c2fbf623f5-image.png 0ef06ad8-64c6-4d7c-b1a2-4f62d01ea452-image.png
                        • J jack_admin referenced this topic on
                          wangyx
                          摄像头亮度特别暗,202307041916-ubuntu-22.04-server-arm64-cp4b.zip
                            大法师 @wangyx
                            @wangyx server版本应该没有安装camera isp服务。你试下桌面是不是好的
                            sudo apt install -y camera-engine-rkaiq  gstreamer1.0-rockchip gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly
                              wangyx @大法师
                              @大法师 有效,多谢
                                gongxing
                                如果遇到这个问题的话:
                                coolpi@car-c:~$ gst-launch-1.0 v4l2src device=/dev/video11 ! video/x-raw,format=NV12,width=1920,height=1080,framerate=25/1 ! videoflip method=vertical-flip !  mpph264enc ! rtspclientsink latency=0 location=rtsp://192.168.0.100:554/test
                                Setting pipeline to PAUSED ...
                                ERROR: Pipeline doesn't want to pause.
                                ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video11' for reading and writing.
                                Additional debug info:
                                v4l2_calls.c(621): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
                                system error: Permission denied
                                Setting pipeline to NULL ...
                                Freeing pipeline ...
                                执行命令前加上sudo,给上权限,摄像头就能用了
                                  大法师 @gongxing
                                  @gongxing 可以试下把你的用户加入到video组
                                    这是我接的CSI的摄像头
                                    用V4L2-TEST无法打开 选的/dev/video11
                                    需要怎么样才能打开 内核是我自己编译的
                                      这是用V4L2-TEST打开时demsg打印的
