    coolpi 4b support ov5647 camera module
    24 Posts 8 Posters 7.7k Views
      tonyone0902
      請問是否有機會支援 VEYE 系列的模組? 像是 IMX462 之類 (http://www.veye.cc/产品/veye-mipi-imx462-2/#tab-id-2)
      畢竟 VEYE 也是國產之光,國內也比較容易買得到
        nickliu
        Hi, I tried the new kernel with two OV5647 camera.
        It looks the default configuration is not correct.
        The command I used
        sudo v4l2-ctl --verbose -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat='NV12' --stream-mmap=4 --set-selection=target=crop,flags=0,top=0,left=0,width=1920,height=1080 --stream-to=out1.yuv
        ffplay out1.yuv  -pixel_format nv12 -video_size 1920x1080
        The system message
        @Ubuntu:~$ dmesg | grep 'ov5'
        [    7.644913] ov5648 8-0036: driver version: 00.01.05
        [    7.644958] ov5648 8-0036: Failed to get power-gpios, maybe no use
        [    7.644976] ov5648 8-0036: Failed to get reset-gpios, maybe no use
        [    7.644994] ov5648 8-0036: Failed to get pwdn-gpios
        [    7.645126] ov5648 8-0036: supply dovdd not found, using dummy regulator
        [    7.645216] ov5648 8-0036: supply dvdd not found, using dummy regulator
        [    7.645268] ov5648 8-0036: lane_num(2)  pixel_rate(84000000)
        [    7.645277] ov5648 8-0036: could not get default pinstate
        [    7.650710] ov5648 8-0036: could not get sleep pinstate
        [    7.660168] ov5648 8-0036: Detected OV005647 sensor
        [    7.660205] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m01_f_ov5648 8-0036:bus type 5
        [  123.522013] ov5648 8-0036: ov5648_s_stream(997) enter!
        [  123.522018] ov5648 8-0036: stream on!!!
        [  123.574530] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1
        [  123.577105] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400
        [  141.109425] ov5648 8-0036: ov5648_s_stream(997) enter!
        [  141.109431] ov5648 8-0036: stream off!!!
        [  352.460709] ov5648 8-0036: ov5648_s_stream(997) enter!
        [  352.460714] ov5648 8-0036: stream on!!!
        [  352.506940] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1
        [  352.508804] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400
        [  359.915797] ov5648 8-0036: ov5648_s_stream(997) enter!
        [  359.915807] ov5648 8-0036: stream off!!!
        [  522.868438] ov5648 8-0036: ov5648_s_stream(997) enter!
        [  522.868438] ov5648 8-0036: stream on!!!
        [  522.907120] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1
        [  522.908828] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400
        [  527.994503] ov5648 8-0036: ov5648_s_stream(997) enter!
        [  527.994509] ov5648 8-0036: stream off!!!
        [  567.407434] ov5648 8-0036: ov5648_s_stream(997) enter!
        [  567.407435] ov5648 8-0036: stream on!!!
        [  567.448267] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1
        [  567.450267] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400
        [  572.471164] ov5648 8-0036: ov5648_s_stream(997) enter!
        [  572.471167] ov5648 8-0036: stream off!!!
        @Ubuntu:~$ sudo v4l2-ctl --list-devices
        rkisp-statistics (platform: rkisp):
                /dev/video18
                /dev/video19
        rkcif-mipi-lvds2 (platform:rkcif):
                /dev/media0
        rkcif (platform:rkcif-mipi-lvds2):
                /dev/video0
                /dev/video1
                /dev/video2
                /dev/video3
                /dev/video4
                /dev/video5
                /dev/video6
                /dev/video7
                /dev/video8
                /dev/video9
                /dev/video10
        rkisp_mainpath (platform:rkisp0-vir0):
                /dev/video11
                /dev/video12
                /dev/video13
                /dev/video14
                /dev/video15
                /dev/video16
                /dev/video17
                /dev/media1
        Ubuntu:~$ sudo media-ctl -p -d /dev/media0
        Media controller API version 5.10.110
        Media device information
        driver          rkcif
        model           rkcif-mipi-lvds2
        serial
        bus info
        hw revision     0x0
        driver version  5.10.110
        Device topology
        - entity 1: stream_cif_mipi_id0 (1 pad, 11 links)
                    type Node subtype V4L flags 0
                    device node name /dev/video0
        	pad0: Sink
        		<- "rockchip-mipi-csi2":1 [ENABLED]
        		<- "rockchip-mipi-csi2":2 []
        		<- "rockchip-mipi-csi2":3 []
        		<- "rockchip-mipi-csi2":4 []
        		<- "rockchip-mipi-csi2":5 []
        		<- "rockchip-mipi-csi2":6 []
        		<- "rockchip-mipi-csi2":7 []
        		<- "rockchip-mipi-csi2":8 []
        		<- "rockchip-mipi-csi2":9 []
        		<- "rockchip-mipi-csi2":10 []
        		<- "rockchip-mipi-csi2":11 []
        - entity 5: stream_cif_mipi_id1 (1 pad, 11 links)
                    device node name /dev/video1
        	pad0: Sink
        		<- "rockchip-mipi-csi2":1 []
        		<- "rockchip-mipi-csi2":2 [ENABLED]
        - entity 9: stream_cif_mipi_id2 (1 pad, 11 links)
                    device node name /dev/video2
        	pad0: Sink
        		<- "rockchip-mipi-csi2":3 [ENABLED]
        - entity 13: stream_cif_mipi_id3 (1 pad, 11 links)
                     device node name /dev/video3
        	pad0: Sink
        		<- "rockchip-mipi-csi2":4 [ENABLED]
        - entity 17: rkcif_scale_ch0 (1 pad, 11 links)
                     device node name /dev/video4
        	pad0: Sink
        		<- "rockchip-mipi-csi2":5 [ENABLED]
        - entity 21: rkcif_scale_ch1 (1 pad, 11 links)
                     device node name /dev/video5
        	pad0: Sink
        		<- "rockchip-mipi-csi2":6 [ENABLED]
        - entity 25: rkcif_scale_ch2 (1 pad, 11 links)
                     device node name /dev/video6
        	pad0: Sink
        		<- "rockchip-mipi-csi2":7 [ENABLED]
        - entity 29: rkcif_scale_ch3 (1 pad, 11 links)
                     device node name /dev/video7
        	pad0: Sink
        		<- "rockchip-mipi-csi2":8 [ENABLED]
        - entity 33: rkcif_tools_id0 (1 pad, 11 links)
                     device node name /dev/video8
        	pad0: Sink
        		<- "rockchip-mipi-csi2":9 [ENABLED]
        - entity 37: rkcif_tools_id1 (1 pad, 11 links)
                     device node name /dev/video9
        	pad0: Sink
        		<- "rockchip-mipi-csi2":10 [ENABLED]
        - entity 41: rkcif_tools_id2 (1 pad, 11 links)
                     device node name /dev/video10
        	pad0: Sink
        		<- "rockchip-mipi-csi2":11 [ENABLED]
        - entity 45: rockchip-mipi-csi2 (12 pads, 122 links)
                     type V4L2 subdev subtype Unknown flags 0
                     device node name /dev/v4l-subdev0
        	pad0: Sink
        		[fmt:SBGGR10_1X10/2592x1944 field:none
        		 crop.bounds:(0,0)/2592x1944
        		 crop:(0,0)/2592x1944]
        		<- "rockchip-csi2-dphy0":1 [ENABLED]
        	pad1: Source
        		-> "stream_cif_mipi_id0":0 [ENABLED]
        		-> "stream_cif_mipi_id1":0 []
        		-> "stream_cif_mipi_id2":0 []
        		-> "stream_cif_mipi_id3":0 []
        		-> "rkcif_scale_ch0":0 []
        		-> "rkcif_scale_ch1":0 []
        		-> "rkcif_scale_ch2":0 []
        		-> "rkcif_scale_ch3":0 []
        		-> "rkcif_tools_id0":0 []
        		-> "rkcif_tools_id1":0 []
        		-> "rkcif_tools_id2":0 []
        	pad2: Source
        		-> "stream_cif_mipi_id0":0 []
        		-> "stream_cif_mipi_id1":0 [ENABLED]
        	pad3: Source
        		-> "stream_cif_mipi_id2":0 [ENABLED]
        	pad4: Source
        		-> "stream_cif_mipi_id3":0 [ENABLED]
        	pad5: Source
        		-> "rkcif_scale_ch0":0 [ENABLED]
        	pad6: Source
        		-> "rkcif_scale_ch1":0 [ENABLED]
        	pad7: Source
        		-> "rkcif_scale_ch2":0 [ENABLED]
        	pad8: Source
        		-> "rkcif_scale_ch3":0 [ENABLED]
        	pad9: Source
        		-> "rkcif_tools_id0":0 [ENABLED]
        	pad10: Source
        		-> "rkcif_tools_id1":0 [ENABLED]
        	pad11: Source
        		-> "rkcif_tools_id2":0 [ENABLED]
        - entity 58: rockchip-csi2-dphy0 (2 pads, 2 links)
                     device node name /dev/v4l-subdev1
        	pad0: Sink
        		[fmt:SBGGR10_1X10/2592x1944@10000/150000 field:none]
        		<- "m01_f_ov5648 8-0036":0 [ENABLED]
        	pad1: Source
        		-> "rockchip-mipi-csi2":0 [ENABLED]
        - entity 63: m01_f_ov5648 8-0036 (1 pad, 1 link)
                     type V4L2 subdev subtype Sensor flags 0
                     device node name /dev/v4l-subdev2
        	pad0: Source
        		-> "rockchip-csi2-dphy0":0 [ENABLED]
          大法师 @nickliu
          @nickliu
          ubuntu or armbian version need verify and then release.
            george @大法师
            @大法师 The latest ubuntu22.04 image can already support this camera.
            • 20230210-ubuntu-22.04-preinstalled-desktop-arm64-coolpi.rar
            • V4L2-TEST can start the camera by operating the video11 node
            175f6719-6fa9-4acb-bc1e-b9c2fbf623f5-image.png 0ef06ad8-64c6-4d7c-b1a2-4f62d01ea452-image.png
            • J jack_admin referenced this topic on
              wangyx
              摄像头亮度特别暗,202307041916-ubuntu-22.04-server-arm64-cp4b.zip
                大法师 @wangyx
                @wangyx server版本应该没有安装camera isp服务。你试下桌面是不是好的
                sudo apt install -y camera-engine-rkaiq  gstreamer1.0-rockchip gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly
                  wangyx @大法师
                  @大法师 有效,多谢
                    gongxing
                    如果遇到这个问题的话:
                    coolpi@car-c:~$ gst-launch-1.0 v4l2src device=/dev/video11 ! video/x-raw,format=NV12,width=1920,height=1080,framerate=25/1 ! videoflip method=vertical-flip !  mpph264enc ! rtspclientsink latency=0 location=rtsp://192.168.0.100:554/test
                    Setting pipeline to PAUSED ...
                    ERROR: Pipeline doesn't want to pause.
                    ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video11' for reading and writing.
                    Additional debug info:
                    v4l2_calls.c(621): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
                    system error: Permission denied
                    Setting pipeline to NULL ...
                    Freeing pipeline ...
                    执行命令前加上sudo,给上权限,摄像头就能用了
                      大法师 @gongxing
                      @gongxing 可以试下把你的用户加入到video组
                        这是我接的CSI的摄像头
                        用V4L2-TEST无法打开 选的/dev/video11
                        需要怎么样才能打开 内核是我自己编译的
                          这是用V4L2-TEST打开时demsg打印的
