    coolpi 4b support ov5647 camera module
    24 Posts 8 Posters 7.8k Views
      bg8wj @大法师
      @大法师 非常感谢。麻烦您。如可以给个安装指导。我汇总成教程。coolpi 4b 非常强大,我再学习移植一些 raspbeery 4b的项目到coolpi上。
        大法师 @bg8wj
        @bg8wj 谢谢!我们验证好了会同步发布出来。这款主板还有很多功能可以挖掘,需要更多的伙伴一起共赢!
          暂时未重新打包刷机镜像,可以先独立更新内核驱动包。
          百度网盘
          coolpi@coolpi:~$ sudo dpkg -i coolpi-kernel_1.0.0_aarch64.deb
          coolpi@coolpi:~$ sync
          coolpi@coolpi:~$ sudo reboot
          重启系统,如有连接ov5647摄像头,可以识别到video设备。
          coolpi@coolpi:~$ sudo apt install v4l-utils
          coolpi@coolpi:~$ v4l2-ctl --list-devices
          rkisp-statistics (platform: rkisp):
                  /dev/video18
                  /dev/video19
          rkcif (platform:rkcif-mipi-lvds2):
                  /dev/video0
                  /dev/video1
                  /dev/video2
                  /dev/video3
                  /dev/video4
                  /dev/video5
                  /dev/video6
                  /dev/video7
                  /dev/video8
                  /dev/video9
                  /dev/video10
          rkisp_mainpath (platform:rkisp0-vir0):
                  /dev/video11
                  /dev/video12
                  /dev/video13
                  /dev/video14
                  /dev/video15
                  /dev/video16
                  /dev/video17
          B 1 Reply Last reply Reply Quote -1
            bg8wj @大法师
            @大法师 谢谢。
              tonyone0902
              請問是否有機會支援 VEYE 系列的模組? 像是 IMX462 之類 (http://www.veye.cc/产品/veye-mipi-imx462-2/#tab-id-2)
              畢竟 VEYE 也是國產之光,國內也比較容易買得到
                nickliu
                Hi, I tried the new kernel with two OV5647 camera.
                It looks the default configuration is not correct.
                The command I used
                sudo v4l2-ctl --verbose -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat='NV12' --stream-mmap=4 --set-selection=target=crop,flags=0,top=0,left=0,width=1920,height=1080 --stream-to=out1.yuv
                ffplay out1.yuv  -pixel_format nv12 -video_size 1920x1080
                The system message
                @Ubuntu:~$ dmesg | grep 'ov5'
                [    7.644913] ov5648 8-0036: driver version: 00.01.05
                [    7.644958] ov5648 8-0036: Failed to get power-gpios, maybe no use
                [    7.644976] ov5648 8-0036: Failed to get reset-gpios, maybe no use
                [    7.644994] ov5648 8-0036: Failed to get pwdn-gpios
                [    7.645126] ov5648 8-0036: supply dovdd not found, using dummy regulator
                [    7.645216] ov5648 8-0036: supply dvdd not found, using dummy regulator
                [    7.645268] ov5648 8-0036: lane_num(2)  pixel_rate(84000000)
                [    7.645277] ov5648 8-0036: could not get default pinstate
                [    7.650710] ov5648 8-0036: could not get sleep pinstate
                [    7.660168] ov5648 8-0036: Detected OV005647 sensor
                [    7.660205] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m01_f_ov5648 8-0036:bus type 5
                [  123.522013] ov5648 8-0036: ov5648_s_stream(997) enter!
                [  123.522018] ov5648 8-0036: stream on!!!
                [  123.574530] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1
                [  123.577105] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400
                [  141.109425] ov5648 8-0036: ov5648_s_stream(997) enter!
                [  141.109431] ov5648 8-0036: stream off!!!
                [  352.460709] ov5648 8-0036: ov5648_s_stream(997) enter!
                [  352.460714] ov5648 8-0036: stream on!!!
                [  352.506940] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1
                [  352.508804] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400
                [  359.915797] ov5648 8-0036: ov5648_s_stream(997) enter!
                [  359.915807] ov5648 8-0036: stream off!!!
                [  522.868438] ov5648 8-0036: ov5648_s_stream(997) enter!
                [  522.868438] ov5648 8-0036: stream on!!!
                [  522.907120] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1
                [  522.908828] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400
                [  527.994503] ov5648 8-0036: ov5648_s_stream(997) enter!
                [  527.994509] ov5648 8-0036: stream off!!!
                [  567.407434] ov5648 8-0036: ov5648_s_stream(997) enter!
                [  567.407435] ov5648 8-0036: stream on!!!
                [  567.448267] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1
                [  567.450267] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400
                [  572.471164] ov5648 8-0036: ov5648_s_stream(997) enter!
                [  572.471167] ov5648 8-0036: stream off!!!
                @Ubuntu:~$ sudo v4l2-ctl --list-devices
                        /dev/video18
                        /dev/video19
                rkcif-mipi-lvds2 (platform:rkcif):
                        /dev/media0
                        /dev/video0
                        /dev/video1
                        /dev/video2
                        /dev/video3
                        /dev/video4
                        /dev/video5
                        /dev/video6
                        /dev/video7
                        /dev/video8
                        /dev/video9
                        /dev/video10
                        /dev/video11
                        /dev/video12
                        /dev/video13
                        /dev/video14
                        /dev/video15
                        /dev/video16
                        /dev/video17
                        /dev/media1
                Ubuntu:~$ sudo media-ctl -p -d /dev/media0
                Media controller API version 5.10.110
                Media device information
                driver          rkcif
                model           rkcif-mipi-lvds2
                serial
                bus info
                hw revision     0x0
                driver version  5.10.110
                Device topology
                - entity 1: stream_cif_mipi_id0 (1 pad, 11 links)
                            type Node subtype V4L flags 0
                            device node name /dev/video0
                	pad0: Sink
                		<- "rockchip-mipi-csi2":1 [ENABLED]
                		<- "rockchip-mipi-csi2":2 []
                		<- "rockchip-mipi-csi2":3 []
                		<- "rockchip-mipi-csi2":4 []
                		<- "rockchip-mipi-csi2":5 []
                		<- "rockchip-mipi-csi2":6 []
                		<- "rockchip-mipi-csi2":7 []
                		<- "rockchip-mipi-csi2":8 []
                		<- "rockchip-mipi-csi2":9 []
                		<- "rockchip-mipi-csi2":10 []
                		<- "rockchip-mipi-csi2":11 []
                - entity 5: stream_cif_mipi_id1 (1 pad, 11 links)
                            device node name /dev/video1
                	pad0: Sink
                		<- "rockchip-mipi-csi2":1 []
                		<- "rockchip-mipi-csi2":2 [ENABLED]
                - entity 9: stream_cif_mipi_id2 (1 pad, 11 links)
                            device node name /dev/video2
                	pad0: Sink
                		<- "rockchip-mipi-csi2":3 [ENABLED]
                - entity 13: stream_cif_mipi_id3 (1 pad, 11 links)
                             device node name /dev/video3
                	pad0: Sink
                		<- "rockchip-mipi-csi2":4 [ENABLED]
                - entity 17: rkcif_scale_ch0 (1 pad, 11 links)
                             device node name /dev/video4
                	pad0: Sink
                		<- "rockchip-mipi-csi2":5 [ENABLED]
                - entity 21: rkcif_scale_ch1 (1 pad, 11 links)
                             device node name /dev/video5
                	pad0: Sink
                		<- "rockchip-mipi-csi2":6 [ENABLED]
                - entity 25: rkcif_scale_ch2 (1 pad, 11 links)
                             device node name /dev/video6
                	pad0: Sink
                		<- "rockchip-mipi-csi2":7 [ENABLED]
                - entity 29: rkcif_scale_ch3 (1 pad, 11 links)
                             device node name /dev/video7
                	pad0: Sink
                		<- "rockchip-mipi-csi2":8 [ENABLED]
                - entity 33: rkcif_tools_id0 (1 pad, 11 links)
                             device node name /dev/video8
                	pad0: Sink
                		<- "rockchip-mipi-csi2":9 [ENABLED]
                - entity 37: rkcif_tools_id1 (1 pad, 11 links)
                             device node name /dev/video9
                	pad0: Sink
                		<- "rockchip-mipi-csi2":10 [ENABLED]
                - entity 41: rkcif_tools_id2 (1 pad, 11 links)
                             device node name /dev/video10
                	pad0: Sink
                		<- "rockchip-mipi-csi2":11 [ENABLED]
                - entity 45: rockchip-mipi-csi2 (12 pads, 122 links)
                             type V4L2 subdev subtype Unknown flags 0
                             device node name /dev/v4l-subdev0
                	pad0: Sink
                		[fmt:SBGGR10_1X10/2592x1944 field:none
                		 crop.bounds:(0,0)/2592x1944
                		 crop:(0,0)/2592x1944]
                		<- "rockchip-csi2-dphy0":1 [ENABLED]
                	pad1: Source
                		-> "stream_cif_mipi_id0":0 [ENABLED]
                		-> "stream_cif_mipi_id1":0 []
                		-> "stream_cif_mipi_id2":0 []
                		-> "stream_cif_mipi_id3":0 []
                		-> "rkcif_scale_ch0":0 []
                		-> "rkcif_scale_ch1":0 []
                		-> "rkcif_scale_ch2":0 []
                		-> "rkcif_scale_ch3":0 []
                		-> "rkcif_tools_id0":0 []
                		-> "rkcif_tools_id1":0 []
                		-> "rkcif_tools_id2":0 []
                	pad2: Source
                		-> "stream_cif_mipi_id0":0 []
                		-> "stream_cif_mipi_id1":0 [ENABLED]
                	pad3: Source
                		-> "stream_cif_mipi_id2":0 [ENABLED]
                	pad4: Source
                		-> "stream_cif_mipi_id3":0 [ENABLED]
                	pad5: Source
                		-> "rkcif_scale_ch0":0 [ENABLED]
                	pad6: Source
                		-> "rkcif_scale_ch1":0 [ENABLED]
                	pad7: Source
                		-> "rkcif_scale_ch2":0 [ENABLED]
                	pad8: Source
                		-> "rkcif_scale_ch3":0 [ENABLED]
                	pad9: Source
                		-> "rkcif_tools_id0":0 [ENABLED]
                	pad10: Source
                		-> "rkcif_tools_id1":0 [ENABLED]
                	pad11: Source
                		-> "rkcif_tools_id2":0 [ENABLED]
                - entity 58: rockchip-csi2-dphy0 (2 pads, 2 links)
                             device node name /dev/v4l-subdev1
                	pad0: Sink
                		[fmt:SBGGR10_1X10/2592x1944@10000/150000 field:none]
                		<- "m01_f_ov5648 8-0036":0 [ENABLED]
                	pad1: Source
                		-> "rockchip-mipi-csi2":0 [ENABLED]
                - entity 63: m01_f_ov5648 8-0036 (1 pad, 1 link)
                             type V4L2 subdev subtype Sensor flags 0
                             device node name /dev/v4l-subdev2
                	pad0: Source
                		-> "rockchip-csi2-dphy0":0 [ENABLED]
                  大法师 @nickliu
                  @nickliu
                  ubuntu or armbian version need verify and then release.
                    george @大法师
                    @大法师 The latest ubuntu22.04 image can already support this camera.
                    • 20230210-ubuntu-22.04-preinstalled-desktop-arm64-coolpi.rar
                    • V4L2-TEST can start the camera by operating the video11 node
                    175f6719-6fa9-4acb-bc1e-b9c2fbf623f5-image.png 0ef06ad8-64c6-4d7c-b1a2-4f62d01ea452-image.png
                    • J jack_admin referenced this topic on
                      wangyx
                      摄像头亮度特别暗,202307041916-ubuntu-22.04-server-arm64-cp4b.zip
                        大法师 @wangyx
                        @wangyx server版本应该没有安装camera isp服务。你试下桌面是不是好的
                        sudo apt install -y camera-engine-rkaiq  gstreamer1.0-rockchip gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly
                          wangyx @大法师
                          @大法师 有效,多谢
                            gongxing
                            如果遇到这个问题的话:
                            coolpi@car-c:~$ gst-launch-1.0 v4l2src device=/dev/video11 ! video/x-raw,format=NV12,width=1920,height=1080,framerate=25/1 ! videoflip method=vertical-flip !  mpph264enc ! rtspclientsink latency=0 location=rtsp://192.168.0.100:554/test
                            Setting pipeline to PAUSED ...
                            ERROR: Pipeline doesn't want to pause.
                            ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video11' for reading and writing.
                            Additional debug info:
                            v4l2_calls.c(621): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
                            system error: Permission denied
                            Setting pipeline to NULL ...
                            Freeing pipeline ...
                            执行命令前加上sudo,给上权限,摄像头就能用了
                              大法师 @gongxing
                              @gongxing 可以试下把你的用户加入到video组
                                这是我接的CSI的摄像头
                                用V4L2-TEST无法打开 选的/dev/video11
                                需要怎么样才能打开 内核是我自己编译的
                                  这是用V4L2-TEST打开时demsg打印的
