    Coolpi 4b Ubuntu22.04 原生系统
    24 Posts 8 Posters 3.8k Views
      george @zensation
      @zensation If this is the case, it means that the image you are using is incorrect, or it is not successfully created.
        zensation @george
        @george its exactly correct based on other screenshots of the ubuntu 22.0.4 builds seen on here that also show a username of ubuntu and somewhere someone shared their password as coolpi. i was able to figure it out when i plugged in an hdmi cable. before that was just trying to access terminal through UART.
        • C
          cbratschi
            george @allen
            @allen 更新内核代码,已经解决了概率鼠标消失问题。
            @cbratschi Add onedrive download link.
              Twsuts
              我在系统中使用想开机自启动一个QT程序,我沿用了树莓派的方法,在~/.profile文件中添加了我的启动路径,但是程序并没有像树莓派一样启动,传统的自启动程序会进入桌面再启动程序,效果会差很多时间也长很多,还有就是开机的动画能不能有个教程,如果太忙了就算了,希望能回答我第一个问题
                大法师 @Twsuts
                @Twsuts
                提供个demo与配置,我们测试下
                  Twsuts @大法师
                  @大法师 配置就是在~/profile文件末尾加上 echo “coolpi” | sudo -S /home/coolpi/qt5/demo ,这是启动程序的命令,树莓派跟我以前用的ROCKPI正常是能启动程序的,在界面出来以前,你看到的效果就是黑屏然后直接进入了我们的程序,demo可以随便写一个QT demo,然后开机重启的时候看能不能在进入界面之前启动
                    大法师 @Twsuts
                    @Twsuts
                    这是阻塞系统运行?还是后台运行作为开机动画?
                    我试了分别在/etc/profile、/home/coolpi/.profile文件尾增加qt demo是可以的
                    sudo apt install qtbase5-examples
                    coolpi@coolpi:~$ cat /etc/profile
                    # /etc/profile: system-wide .profile file for the Bourne shell (sh(1))
                    # and Bourne compatible shells (bash(1), ksh(1), ash(1), ...).
                    if [ "${PS1-}" ]; then
                      if [ "${BASH-}" ] && [ "$BASH" != "/bin/sh" ]; then
                        # The file bash.bashrc already sets the default PS1.
                        # PS1='\h:\w\$ '
                        if [ -f /etc/bash.bashrc ]; then
                          . /etc/bash.bashrc
                        fi
                      else
                        if [ "`id -u`" -eq 0 ]; then
                          PS1='# '
                        else
                          PS1='$ '
                        fi
                      fi
                    fi
                    if [ -d /etc/profile.d ]; then
                      for i in /etc/profile.d/*.sh; do
                        if [ -r $i ]; then
                          . $i
                        fi
                      unset i
                    fi
                    #echo "coolpi" | sudo -S /usr/lib/aarch64-linux-gnu/qt5/examples/gui/analogclock/analogclock
                    coolpi@coolpi:~$
                    coolpi@coolpi:~$ cat ~/.profile
                    # ~/.profile: executed by the command interpreter for login shells.
                    # This file is not read by bash(1), if ~/.bash_profile or ~/.bash_login
                    # exists.
                    # see /usr/share/doc/bash/examples/startup-files for examples.
                    # the files are located in the bash-doc package.
                    # the default umask is set in /etc/profile; for setting the umask
                    # for ssh logins, install and configure the libpam-umask package.
                    #umask 022
                    # if running bash
                    if [ -n "$BASH_VERSION" ]; then
                        # include .bashrc if it exists
                        if [ -f "$HOME/.bashrc" ]; then
                            . "$HOME/.bashrc"
                        fi
                    fi
                    # set PATH so it includes user's private bin if it exists
                    if [ -d "$HOME/bin" ] ; then
                        PATH="$HOME/bin:$PATH"
                    fi
                    if [ -d "$HOME/.local/bin" ] ; then
                        PATH="$HOME/.local/bin:$PATH"
                    fi
                    coolpi@coolpi:~$
                    因为不是后台运行,重启后会阻塞桌面系统显示窗口。此时可以通过键盘ctrl+alt+f6切换到终端命令行进行恢复修改操作。
                    也可以后台运行测试
                    vim ~/.profile
                    echo "coolpi" | sudo -S /usr/lib/aarch64-linux-gnu/qt5/examples/gui/analogclock/analogclock &
                      Twsuts @大法师
                      @大法师 感谢您的回答,您的操作看起来很正常,这样看来确实很奇怪,但我这边不论是ubuntu22还是ubuntu20我在.profile文件下启动我的qt程序都没反应,它会直接进入桌面,而在/etc/xdg/autostart/下可以自动启动我的应用程序,但是后者显示屏会出现几秒钟的ubuntu图形界面,这看起来很糟糕!
                        大法师 @Twsuts
                        @Twsuts
                        百度网盘或onedrive有最新镜像,是否镜像不一致?
                          Twsuts @大法师
                          @大法师 前天刚刷的最新镜像,甚至于我在使用ssh登陆时都能启动程序,终端登陆就会启动程序,但是显示屏上就是直接进入了桌面。
                          大法师大 顾 2 Replies Last reply Reply Quote 0
                            大法师 @Twsuts
                            @Twsuts
                            是不是自动登陆设置打开了?
                              Twsuts @大法师
                              @大法师 还真是的
                                Twsuts @大法师
                                @大法师 关了也没用,换了一个最简单的demo也没用,我只能通过我原来的方法启动程序,然后把整个桌面服务关了试试看了,不过这样启动会慢很多
                                顾 1 Reply Last reply Reply Quote 0
                                  顾真牛 @Twsuts
                                  @Twsuts 看看登录服务用的是什么gdm还是LightDM,改那个的配置文件。不启动桌面启动你的QT程序
                                    顾真牛 @Twsuts
                                    @Twsuts SSH能启动 开机不启动,你看看是不是用户不一致
                                      Twsuts @顾真牛
                                      @顾真牛 用户都是一样的coolpi,我现在解决了这个问题,在那之前加入export DISPLAY=:0 这样就可以启动了
                                        Twsuts @顾真牛
                                        @顾真牛 @大法师 感谢你们的帮助🤓
                                        • 大法师大 大法师 moved this topic from Pi 4B on
