    coolpi 4b python3 gpio operation compatable with raspberry pi
    30 Posts 11 Posters 5.4k Views
      download and install with root user.
      sudo pip3 install CPi.GPIO-1.0.0-cp38-cp38-linux_aarch64.whl
      for ubuntu 20.04
      for ubuntu 22.04
      CPi.GPIO-1.0.0-cp310-cp310-linux_aarch64.whl
      other
      CPi.GPIO-1.0.0-cp39-cp39-linux_aarch64.whl
      default gpio cfg with system image:
      gpio_coolpi
      test.py
      running test:
      sudo python3 test.py
      #!/usr/bin/env python3
      import CPi.GPIO as GPIO
      import time
      PIN = 40
      GPIO.setmode(GPIO.BOARD)
      GPIO.setup(PIN, GPIO.OUT)
      while True:
         GPIO.output(PIN, 0)
         time.sleep(1)
         GPIO.output(PIN, 1)
         time.sleep(1)
      其中GPIO.setmode(GPIO.BOARD)表示使用coolpi 4b板子自然编号Pin number。如果要使用Rockchip gpio编号,需要引用GPIO.setmode(GPIO.RK)。
      if you want to remove this module, exec command:
      sudo pip3 uninstall CPi.GPIO
      A W 2 Replies Last reply Reply Quote 0
      • 花
        花月
        也适用于debain等其他系统嘛
          george @花月
          @花月 注意python版本,其它都是一样的。ubuntu22.04 默认python3.10,要注意切换一下。
          花 D 2 Replies Last reply Reply Quote 0
          • 花
            花月 @george
            @george SPI 怎么开,在debain下安装完输入gpio_coolpi显示命令找不到
            是否有比较全的示例介绍SPI
              jack_admin @花月
              @花月
              系统中若无该命令,请将附件文件拷贝到/usr/sbin/,再执行chmod a+x /usr/sbin/gpio_coolpi
              gpio_coolpi
              SPI与I2C操作使用标准python或标准C调用API
              花 1 Reply Last reply Reply Quote 0
              • 花
                花月 @jack_admin
                @jack_admin 这个附件名称是什么,下载是数字的名称,有后缀嘛?
                  jack_admin @花月
                  @花月 可以拷贝重命名/usr/sbin/gpio_coolpi
                  • D
                    dreamer @george
                    @george Is there any way to use GPIOs without sudo priviledge, such as in a ros package?
                      大法师 @dreamer
                      @dreamer
                      hi, please add extra operation for coolpi user.
                      Add rules for normal user:
                      sudo echo "SUBSYSTEM==\"gpio*\", ACTION==\"add\", PROGRAM=\"/bin/bash -c 'chown root:coolpi /sys/class/gpio/export /sys/class/gpio/unexport;chmod 220 /sys/class/gpio/export /sys/class/gpio/unexport'\"" > /lib/udev/rules.d/99-gpio.rules
                      sudo echo "SUBSYSTEM==\"gpio*\", ACTION==\"add\", PROGRAM=\"/bin/bash -c 'chown root:coolpi /sys%p/direction /sys%p/value /sys%p/edge /sys%p/active_low; chmod 0660 /sys%p/direction /sys%p/value /sys%p/edge /sys%p/active_low'\"" >> /lib/udev/rules.d/99-gpio.rules
                      sudo reboot
                      Check rules:
                      coolpi@coolpi:~/Desktop$ cat /lib/udev/rules.d/99-gpio.rules
                      SUBSYSTEM=="gpio*", ACTION=="add", PROGRAM="/bin/bash -c 'chown root:coolpi /sys/class/gpio/export /sys/class/gpio/unexport;chmod 220 /sys/class/gpio/export /sys/class/gpio/unexport'"
                      SUBSYSTEM=="gpio*", ACTION=="add", PROGRAM="/bin/bash -c 'chown root:coolpi /sys%p/direction /sys%p/value /sys%p/edge /sys%p/active_low; chmod 0660 /sys%p/direction /sys%p/value /sys%p/edge /sys%p/active_low'"
                      Test case:
                      coolpi@coolpi:~/Desktop$ echo 115 > /sys/class/gpio/export
                      coolpi@coolpi:~/Desktop$ ls /sys/class/gpio/gpio115
                      active_low  device  direction  edge  power  subsystem  uevent  value
                      coolpi@coolpi:~/Desktop$ echo out > /sys/class/gpio/gpio115/direction
                      coolpi@coolpi:~/Desktop$ echo 1 > /sys/class/gpio/gpio115/value
                      coolpi@coolpi:~/Desktop$ echo 0 > /sys/class/gpio/gpio115/value
                        AugustRobot_Zou
                        请问跟RPi.GPIO的函数完全兼容吗?
                        GPIO.setwarnings(False) 之类的函数都有吗
                          大法师 @AugustRobot_Zou
                          @AugustRobot_Zou
                          还未完整测试所有接口。
                          • 大法师大 大法师 referenced this topic on
                            AugustRobot_Zou @大法师
                            请问有支持python3.6的 .whl安装包吗?
                            我的docker环境是unbuntu18.04+py2.7+py3.6.9的,CPi.GPIO-1.0.0-cp38-cp38-linux_aarch64.whl安装不了。
                            或者有没有其他方式,驱动gpio
                              @AugustRobot_Zou
                              所有的底层封装操作都是基于访问/sys/class/gpio/
                              https://www.cool-pi.com/topic/72/coolpi-4b硬件扩展四-gpio
                                请问能麻烦编译一个python3.6.9的安装包吗?
                                使用CPi.GPIO-1.0.0-cp38-cp38-linux_aarch64.whl,必须装上python3.8。
                                我的docker环境是ubuntu18.04+python3.6.9+ROS。
                                装了python3.8后,同时存在python3.8和python3.6,导致原本的代码程序很多python版本适配问题,这几天为这个问题搞得头大,很难兼顾 CPi.GPIO库和原来的程序,模块脚本的#!/usr/bin/python3 只能配置2选1(3.8 or 3.6 )。
                                大法师大 J 2 Replies Last reply Reply Quote 0
                                  @AugustRobot_Zou okay!
                                    jack_admin @AugustRobot_Zou
                                    @AugustRobot_Zou CPi.GPIO-1.0.0-cp36-cp36m-linux_aarch64.whl
                                      AugustRobot_Zou @jack_admin
                                      @jack_admin @大法师
                                      Really appreciate your help!
                                      Now our system is basically compatible with coolp4B,which used to running on raspberry-pi4B.
                                      • A AugustRobot_Zou referenced this topic on
                                      • J jack_admin referenced this topic on
                                      • X
                                        xingzhan2012
                                        有python3.9版本的吗
                                          jack_admin @xingzhan2012
                                          @xingzhan2012 有。在帖子最顶楼
                                          • X
                                            xingzhan2012 @jack_admin
                                            @jack_admin 谢谢
