    coolpi 4b python3 gpio operation compatable with raspberry pi
    30 Posts 11 Posters 7.2k Views
    • 花
      花月 @jack_admin
      @jack_admin 这个附件名称是什么,下载是数字的名称,有后缀嘛?
        jack_admin @花月
        @花月 可以拷贝重命名/usr/sbin/gpio_coolpi
        • D
          dreamer @george
          @george Is there any way to use GPIOs without sudo priviledge, such as in a ros package?
            大法师 @dreamer
            @dreamer
            hi, please add extra operation for coolpi user.
            Add rules for normal user:
            sudo echo "SUBSYSTEM==\"gpio*\", ACTION==\"add\", PROGRAM=\"/bin/bash -c 'chown root:coolpi /sys/class/gpio/export /sys/class/gpio/unexport;chmod 220 /sys/class/gpio/export /sys/class/gpio/unexport'\"" > /lib/udev/rules.d/99-gpio.rules
            sudo echo "SUBSYSTEM==\"gpio*\", ACTION==\"add\", PROGRAM=\"/bin/bash -c 'chown root:coolpi /sys%p/direction /sys%p/value /sys%p/edge /sys%p/active_low; chmod 0660 /sys%p/direction /sys%p/value /sys%p/edge /sys%p/active_low'\"" >> /lib/udev/rules.d/99-gpio.rules
            sudo reboot
            Check rules:
            coolpi@coolpi:~/Desktop$ cat /lib/udev/rules.d/99-gpio.rules
            SUBSYSTEM=="gpio*", ACTION=="add", PROGRAM="/bin/bash -c 'chown root:coolpi /sys/class/gpio/export /sys/class/gpio/unexport;chmod 220 /sys/class/gpio/export /sys/class/gpio/unexport'"
            SUBSYSTEM=="gpio*", ACTION=="add", PROGRAM="/bin/bash -c 'chown root:coolpi /sys%p/direction /sys%p/value /sys%p/edge /sys%p/active_low; chmod 0660 /sys%p/direction /sys%p/value /sys%p/edge /sys%p/active_low'"
            Test case:
            coolpi@coolpi:~/Desktop$ echo 115 > /sys/class/gpio/export
            coolpi@coolpi:~/Desktop$ ls /sys/class/gpio/gpio115
            active_low  device  direction  edge  power  subsystem  uevent  value
            coolpi@coolpi:~/Desktop$ echo out > /sys/class/gpio/gpio115/direction
            coolpi@coolpi:~/Desktop$ echo 1 > /sys/class/gpio/gpio115/value
            coolpi@coolpi:~/Desktop$ echo 0 > /sys/class/gpio/gpio115/value
              AugustRobot_Zou
              请问跟RPi.GPIO的函数完全兼容吗?
              GPIO.setwarnings(False) 之类的函数都有吗
                大法师 @AugustRobot_Zou
                @AugustRobot_Zou
                还未完整测试所有接口。
                • 大法师大 大法师 referenced this topic on
                  AugustRobot_Zou @大法师
                  请问有支持python3.6的 .whl安装包吗?
                  我的docker环境是unbuntu18.04+py2.7+py3.6.9的,CPi.GPIO-1.0.0-cp38-cp38-linux_aarch64.whl安装不了。
                  或者有没有其他方式,驱动gpio
                    @AugustRobot_Zou
                    所有的底层封装操作都是基于访问/sys/class/gpio/
                    https://www.cool-pi.com/topic/72/coolpi-4b硬件扩展四-gpio
                      请问能麻烦编译一个python3.6.9的安装包吗?
                      使用CPi.GPIO-1.0.0-cp38-cp38-linux_aarch64.whl,必须装上python3.8。
                      我的docker环境是ubuntu18.04+python3.6.9+ROS。
                      装了python3.8后,同时存在python3.8和python3.6,导致原本的代码程序很多python版本适配问题,这几天为这个问题搞得头大,很难兼顾 CPi.GPIO库和原来的程序,模块脚本的#!/usr/bin/python3 只能配置2选1(3.8 or 3.6 )。
                      大法师大 J 2 Replies Last reply Reply Quote 0
                        @AugustRobot_Zou okay!
                          jack_admin @AugustRobot_Zou
                          @AugustRobot_Zou CPi.GPIO-1.0.0-cp36-cp36m-linux_aarch64.whl
                            AugustRobot_Zou @jack_admin
                            @jack_admin @大法师
                            Really appreciate your help!
                            Now our system is basically compatible with coolp4B,which used to running on raspberry-pi4B.
                            • A AugustRobot_Zou referenced this topic on
                            • J jack_admin referenced this topic on
                            • X
                              xingzhan2012
                              有python3.9版本的吗
                                jack_admin @xingzhan2012
                                @xingzhan2012 有。在帖子最顶楼
                                • X
                                  xingzhan2012 @jack_admin
                                  @jack_admin 谢谢
                                    Macs
                                    Does the coolpi have a DPI mode for the gpio like the RPI4?
                                      jack_admin @Macs
                                      @Macs said in coolpi 4b python3 gpio operation compatable with raspberry pi:
                                      WiringPi ?
                                        Macs @jack_admin
                                        @jack_admin I mean can output video signal on the gpio using with custom timings, like you can on the RPI4?
                                        • O
                                          Orion
                                          请问支持C++语言吗
                                            jack_admin @Orion
                                            @Orion C++可以代码文件操作gpio,不需要调用python库
                                            O 1 Reply Last reply Reply Quote 0
