    CM5刷uboot找不到设备
    17 Posts 3 Posters 2.4k Views
        确认USB接口为上层的USB3.0接口?
          是USB3的上层 需要短接还是其他什么操作 我看wifi里面没有相关说明 cm4的需要短接
            @george 驱动也安装了
              @george 现在板子开机停留在coolpi的logo界面
                @jugg cm5有三个按键,中间一个持续按住,再上电,进入maskrom模式
                  loader刷好了
                  然后刷系统 按3下PWR 无法进入刷机
                    @jack_admin 连续按了很多次PWR 还是不能进入UMS
                      这种情况 还可以怎么做 才能刷系统
                        @jugg 你刷哪个loader,从哪来的,看下串口启动信息
                          loader 网盘上下的
                            一直在重启
                            DDR V1.10 75d050770f typ 23/02/28-20:47:10
                            CH0 RX Vref:26.7%, TX Vref:22.8%,20.8%
                            CH1 RX Vref:26.7%, TX Vref:22.8%,21.8%
                            CH2 RX Vref:27.9%, TX Vref:22.8%,23.8%
                            CH3 RX Vref:28.5%, TX Vref:23.8%,21.8%
                            INFO:    Preloader serial: 2
                            NOTICE:  BL31: v2.3():v2.3-557-g9609b9c19:derrick.huang
                            NOTICE:  BL31: Built : 14:29:57, Mar  8 2023
                            INFO:    spec: 0x1
                            INFO:    ext 32k is not valid
                            INFO:    ddr: stride-en 4CH
                            INFO:    SPSR = 0x3c9
                            mode:3840x2160 bus_format:0x2026
                            hdmi@fde80000:  detailed mode clock 594000 kHz, flags[5]
                                H: 3840 4016 4104 4400
                                V: 2160 2168 2178 2250
                            bus_format: 2026
                            VOP update mode to: 3840x2160p0, type: HDMI0 for VP0
                            dclk:297000,if_pixclk_div;2,if_dclk_div:4
                            VP0 set crtc_clock to 594000KHz
                            VOP VP0 enable Esmart0[356x124->356x124@1742x1018] fmt[1] addr[0xedf21000]
                            CEA mode used vic=97
                            mtmdsclock:297000000
                            bus_width:0x2d5190,bit_rate:2970000
                            hdptx_ropll_cmn_config bus_width:2d5190 rate:2970000
                            Net Initialization Skipped
                            mmc_init: -123, time 1
                            Bus usb@fc800000: USB EHCI 1.00
                            Bus usb@fc840000: USB OHCI 1.0
                            Bus usb@fc8c0000: USB OHCI 1.0
                            Bus usb@fc400000: usb maximum-speed not found
                            scanning bus usb@fc800000 for devices... WARN: interface 0 has 2 endpoint descriptor, different from the interface descriptor's value: 1
                            WARN: interface 1 has 14 endpoint descriptor, different from the interface descriptor's value: 2
                            3 USB Device(s) found
                            scanning bus usb@fc840000 for devices... 1 USB Device(s) found
                            scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found
                            scanning bus usb@fc400000 for devices... 1 USB Device(s) found
                            scanning bus for devices...
                            SATA link 0 timeout.
                            AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
                            flags: ncq stag pm led clo only pmp fbss pio slum part ccc apst
                            ** Invalid partition 1 **
                            Loading order: tf - usb - sata - emmc
                            ** Bad device mmc 1 **
                            resetting USB...
                            ** Bad device usb 0 **
                            checkconf -
                            Usage:
                            checkconf
                            ** Bad device scsi 0 **
                            CH2 RX Vref:27.5%, TX Vref:22.8%,23.8%
                            INFO:    spec: 0x1
                            INFO:    ext 32k is valid
                            INFO:    SPSR = 0x3c9
                            bus_format: 2026
                            resetting USB...
                              我这上面装了一块SSD硬盘 这个有影响?
                              系统之前是能进去的 就是用Etcher刷系统的时候 中途取消了 然后就进不去系统也不能重新刷
                              所以就刷了loader 看看能不能重新刷系统
                                @jugg 重新格式化一次emmc,还是进maskrom,用高级工具里导入loader再擦除emmc
                                  这样擦除EMMC吗?
                                  高级工具里没有导入loader?
                                  步骤能清晰一点吗
                                    @jugg 主板先进入maskrom模式,点击图片中下载左侧图标,加载loader文件,再点击下载。接着进行切换emmc存储,再擦除
                                      刷机成功
