    Ubuntu23.04 for CoolPi
    29 Posts 5 Posters 4.4k Views
      wuming @大法师
      @大法师绝对没有错
        @wuming 确认loader有没有更新到最新,先连接USB到电脑,然后短按rst一次,然后按三次PWR按键,机器就会进入UMS模式。
          wuming @大法师
          @大法师 :正常启动的log,按pwr键三次毫无反应
          [11:00:53.098] DDR V1.10 75d050770f typ 23/02/28-20:47:10
          [11:00:53.210] LPDDR4X, 2112MHz
          [11:00:53.279] CH0 RX Vref:31.0%, TX Vref:22.8%,21.8%
          [11:00:53.295] CH1 RX Vref:27.5%, TX Vref:22.8%,22.8%
          [11:00:53.311] CH2 RX Vref:26.7%, TX Vref:24.8%,24.8%
          CH3 RX Vref:28.5%, TX Vref:22.8%,21.8%
          [11:00:53.423] change to F3: 1560MHz
          [11:00:53.455] change to F0: 2112MHz
          [11:00:53.503] out
          [11:00:53.679] INFO: Preloader serial: 2
          NOTICE: BL31: v2.3():v2.3-481-g17b41886e:derrick.huang
          NOTICE: BL31: Built : 16:20:07, Dec 7 2022
          INFO: spec: 0x1
          INFO: ext 32k is valid
          INFO: ddr: stride-en 4CH
          [11:00:53.788] INFO: BL31: Initialising Exception Handling Framework
          INFO: BL31: Initializing BL32
          INFO: hdmirx_handler: dma not on, ret
          [11:00:53.836] I/TC:
          I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022骞09鏈20鏃鏄熸湡浜09:41:09 CST aarch64
          [11:00:53.900] I/TC: Primary CPU switching to normal world boot
          INFO: SPSR = 0x3c9
          [11:00:53.969]
          COOLPI LOADER BY YANYI(Mar 18 2023)
          DRAM: 8 GiB
          [11:00:54.017] Using default environment
          [11:00:54.049] Pre-reloc: vcc12v_dcin
          [11:00:54.081] 0 2 1 3 6 8 7 9 Monitor has basic audio support
          hdmi@fde80000: detailed mode clock 148500 kHz, flags[5]
          [11:00:54.609] dw hdmi qp use tmds mode
          eth0: ethernet@fe1b0000
          [11:00:54.626] Autoboot in 1 seconds
          [11:00:55.617] VOP VP0 enable Esmart0[356x124->356x124@782x478] fmt[1] addr[0xedf21000]
          Bus usb@fc800000: USB EHCI 1.00
          Bus usb@fc840000: USB OHCI 1.0
          Bus usb@fc8c0000: USB OHCI 1.0
          Bus usb@fc400000: usb maximum-speed not found
          [11:00:56.082] Register 2000140 NbrPorts 2
          scanning bus usb@fc800000 for devices... WARN: interface 0 has 2 endpoint descriptor, different from the interface descriptor's value: 1
          [11:00:57.430] 2 USB Device(s) found
          scanning bus usb@fc840000 for devices... 1 USB Device(s) found
          scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found
          scanning bus usb@fc400000 for devices... 1 USB Device(s) found
          scanning bus for devices...
          [11:01:02.145] SATA link 0 timeout.
          AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
          flags: ncq stag pm led clo only pmp fbss pio slum part ccc apst
          [11:01:02.252] switch to partitions #0, OK
          294 bytes read in 4 ms (71.3 KiB/s)
          1: Linux coolpi
          [11:01:02.312] 8775086 bytes read in 53 ms (157.9 MiB/s)
          [11:01:02.562] 37575168 bytes read in 209 ms (171.5 MiB/s)
          append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n81 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:ce:5d:4c:85:22:cd
          Retrieving file: /rk3588-cpcm5-evb-v11.dtb
          reading /rk3588-cpcm5-evb-v11.dtb
          162268 bytes read in 6 ms (25.8 MiB/s)
          Flattened Device Tree blob at 0x0a100000
          [11:01:02.658] 'reserved-memory' cma: addr=10000000 s[ 11.670599] tinker-ft5406: tinker_ft5406_start_polling: touch is not ready
          [11:01:05.608] [ 11.910605] tinker-ft5406: tinker_ft5406_start_polling: touch is not ready
          [11:01:05.825] [ 12.080812] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
          [ 12.089332] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
          [ 12.097843] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
          [ 12.110044] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
          [11:01:05.864] [ 12.139113] RKNPU fdab0000.npu: failed to find power_model node
          [ 12.145023] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
          [ 12.151624] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
          [11:01:06.279] writable: recovering journal
          [11:01:06.439] writable: Clearing orphaned inode 1573212 (uid=0, gid=110, mode=0100640, size=8388608)
          writable: clean, 421050/3784704 files, 5961091/15136766 blocks
          [11:01:06.467] [ 12.753972] rk-pcie fe160000.pcie: PCIe Link Fail
          [ 12.758692] rk-pcie fe160000.pcie: failed to initialize host
          [11:01:06.675] [ 12.978578] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_cancel_cpu_limit_freq freq qos nod add
          [11:01:07.626] [ 13.902436] Bluetooth: hci0: Reading Intel version information failed (-22)
          [ 13.907251] tinker-ft5406: tinker_ft5406_start_polling: touch is not ready
          [ 13.909428] Bluetooth: hci0: Intel Read version failed (-22)
          [11:01:07.723] [ 14.027265] tinker-ft5406: tinker_ft5406_start_polling: touch is not ready
          [11:01:08.091] [ 14.398123] Bluetooth: hci0: Reading Intel version information failed (-22)
          [ 14.405096] Bluetooth: hci0: Intel Read version failed (-22)
          [11:01:08.612] [ 14.918209] Bluetooth: hci0: Reading Intel version information failed (-22)
          [ 14.925204] Bluetooth: hci0: Intel Read version failed (-22)
          [11:01:09.146] [ 15.428187] Bluetooth: hci0: Reading Intel version information failed (-22)
          [ 15.435212] Bluetooth: hci0: Intel Read version failed (-22)
          [11:01:09.656] [ 15.938187] Bluetooth: hci0: Reading Intel version information failed (-22)
          [ 15.945184] Bluetooth: hci0: Intel Read version failed (-22)
          [11:01:10.167] [ 16.448217] Bluetooth: hci0: Reading Intel version information failed (-22)
          [ 16.455213] Bluetooth: hci0: Intel Read version failed (-22)
          [11:01:10.674] [ 16.955211] Bluetooth: hci0: Reading Intel version information failed (-22)
          [ 16.962344] Bluetooth: hci0: Intel Read version failed (-22)
            @wuming 确认loader是否已经升级到最新,机器和电脑通过USB线连接。重新上电,迅速多次按pwr按键。
              @george 这个log是通过串口读出来的,usb口连接了也没有什么反应,系统直接进入桌面,按loader键重启系统就卡死,完全没有反应,串口log也打不出来
                @wuming 如下图所示正常进入UMS的log信息。
                -0 2 1 3 6 8 7 9 Monitor has basic audio support
                Net Initialization Skipped
                Power Key Setting Enter UMS mode!
                UMS: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x747c000
                建议先吧loader更新到最新,老版本的不支持UMS方式烧录。参照如下文档:
                https://www.cool-pi.com/topic/162/how-to-upgrade-the-boot-loader-of-coolpi-4b
                  @george 我的主板是cm5-v11,按loader键重启是卡死状态。串口不能打印任何log信息
                    @wuming 重启是按最左边的rst按键。loader按键会进入maskrom模式用于升级loader文件。按照文档操作。
                      @george 我就是先按住rst键不放,再按住loader键,然后先放开rst键,最后放开loader键,系统然后卡死,无任何反应
                        @wuming 那是系统进入MASKROM状态了!用官方的工具就可以看到maskrom设备。
                          @wuming 如果你是CM5-V11的机器,默认的loader是可以进入UMS模式的,短按一下rst按键,然后持续多次按pwr按键。
                              @george 你能不能给个地址,我寄给你们研究一下,如果研究好了,就给我寄回来,如果不好,就扔掉。
                                jack_admin @wuming
                                @wuming 没那么复杂,电脑安装个向日葵或todesk,私信发远程
                                  wuming @jack_admin
                                  @jack_admin 下层卡在这里,是什么情况
                                    jack_admin @wuming
                                    @wuming U盘安装系统?接hdmi显示器看看,默认是输出到显示屏
                                      wuming @jack_admin
