    CSI支持
    48 Posts 3 Posters 13.6k Views
      @george 你先把这个1转2的放在淘宝买起,其它的再慢慢搞
        @george :csi线开始卖没有?
          @wuming 本周上架。
            @george 上架了在群里吼一声,再发个链接
              @george 连接线.jpg 到货了,一下干了两条。
                wuming
                使用一下代码,不能够打开mx219摄像头:a8411b3b-ccc6-4e99-9d5a-6619550a3ed7-c73827008f721de0edfd9b292ff34b1.jpg
                import cv2
                cap=cv2.VideoCapture(0)
                while True:
                ret,frame=cap.read()
                cv2.imshow('frame',frame)
                if cv2.waitKey(1)&0xFF==ord('q'):
                break
                cap.release()
                cv2.destroyAllWindows()
                  @wuming 内核同步到最新,确认系统可以生成video11节点。mipi摄像头默认的设备节点是video11
                  然后运行如下命令更新ISP库:
                  sudo apt-get update
                  sudo apt-get dist-upgrade
                        @wuming 先使用QV4L2打开video11节点,系统默认已经安装。
                        G W 2 Replies Last reply Reply Quote 0
                          george @george
                          @george 如下代码测试正常:
                          import cv2 as cv2
                          cap = cv2.VideoCapture(11)
                          while True:
                              success, img = cap.read()
                              cv2.imshow("Video", img)
                              if cv2.waitKey(1) & 0xFF == ord('q'):
                                  break
                          cap.release()
                            @george QV4L2打开摄像头命令格式是怎样的?
                              @george ec8f905d-ae13-4ed4-99a4-c6f2255e1fcd-image.png 打开了设备,但是start capturing,然后没有,然后。感觉这个板子的可靠性、兼容性不佳,有上当的感觉f8479f15-157d-4581-a7b0-70b60a11d2c8-image.png
                                @wuming dmesg打印一份传上来,这种情况是没有识别到摄像头模组。
                                  请看看这个是怎么回事情
                                    @wuming 确认DTS文件有如下配置,如果没有就更新代码:
                                      @jugg 可以提交一下如下log信息,看IMX219有没有正常识别到。
                                      coolpi@Ubuntu:~$ dmesg |grep imx219
                                      [   10.459055] imx219 4-0010: driver version: 00.01.02
                                      [   10.459070] imx219 4-0010: Failed to get reset-gpios
                                      [   10.459077] imx219 4-0010: Failed to get power-gpios
                                      [   10.459084] imx219 4-0010: Failed to get pwdn-gpios
                                      [   10.459087] imx219 4-0010: imx219_video_probe
                                      [   10.459089] imx219 4-0010: imx219 power on
                                      [   10.550251] imx219 4-0010: xvclk matched OK
                                      [   10.583962] imx219 4-0010: Model ID 0x0219, Lot ID 0x798a91, Chip ID 0x06cf
                                      [   10.583964] imx219 4-0010: imx219_ctrls_init
                                      [   10.677433] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m01_f_imx219 4-0010:bus type 5
                                      [   13.246834] imx219 4-0010: imx219 power on
                                      [   13.338229] imx219 4-0010: xvclk matched OK
                                      [   13.380673] imx219 4-0010: imx219 power off
                                      [   14.004893] imx219 4-0010: imx219 power on
                                      [   14.096951] imx219 4-0010: xvclk matched OK
                                      [   14.127786] imx219 4-0010: imx219 power off
                                      [   14.162705] imx219 4-0010: imx219 power on
                                      [   14.244563] imx219 4-0010: xvclk matched OK
                                      [   59.475452] imx219 4-0010: imx219 stream  000
                                      [   59.479866] imx219 4-0010: imx219 stream  001
                                      [   59.640823] imx219 4-0010: imx219 stream  002
                                      [   75.813070] imx219 4-0010: imx219 stream  000
                                        @george 这些信息表示imx219打开了么?
                                          @wuming 这个IMX219是有打开的。上层直接用QV4L2打开video11节点就好了。
                                            @george 可是它就是一个绿屏,线我买了两条,摄像头买了两个,都不行。我想u盘刷系统不行,连电脑刷机也不行,这个板子搞够了。
                                            G 3 Replies Last reply Reply Quote 0
                                            • 2 / 3
