    Ubuntu23.04 for CoolPi
    29 Posts 5 Posters 4.5k Views
      george @super9
      @super9 镜像今天上传。
        @george img文件怎么写入emmc
          大法师 @wuming
          @wuming
          CM5主板按一次reset键复位,右侧pwr键按3~5次,进入UMS模式;接双头TYPE-A USB线连接电脑与USB OTG端口(U3 蓝色上层),电脑打开etcher烧录软件,选择img镜像进行烧录。
            wuming @大法师
            @大法师 收到
              wuming @大法师
              @大法师:好像不行,按reset键是开机的时候,还是关机的时候,是一直按住再按pwr键,还是只按一次,就释放,再按pwr键
                大法师 @wuming
                @wuming
                如果是关机状态:
                上电开机,短按3~5次pwr按键
                如果是开机状态:
                按一次reset键,使系统复位,再短按3~5次pwr按键
                  wuming @大法师
                  @大法师 好像一直进不去,估计是手气比较差,难怪mj不行
                    大法师 @wuming
                    @wuming
                    不着急,cpu加载也要时间。正常操作就好
                      wuming @大法师
                      @大法师 give up.等u盘刷机版出来吧。
                        大法师 @wuming
                        @wuming said in Ubuntu23.04 for CoolPi:
                        位置没错吧
                          wuming @大法师
                          @大法师绝对没有错
                            @wuming 确认loader有没有更新到最新,先连接USB到电脑,然后短按rst一次,然后按三次PWR按键,机器就会进入UMS模式。
                              wuming @大法师
                              @大法师 :正常启动的log,按pwr键三次毫无反应
                              [11:00:53.098] DDR V1.10 75d050770f typ 23/02/28-20:47:10
                              [11:00:53.210] LPDDR4X, 2112MHz
                              [11:00:53.279] CH0 RX Vref:31.0%, TX Vref:22.8%,21.8%
                              [11:00:53.295] CH1 RX Vref:27.5%, TX Vref:22.8%,22.8%
                              [11:00:53.311] CH2 RX Vref:26.7%, TX Vref:24.8%,24.8%
                              CH3 RX Vref:28.5%, TX Vref:22.8%,21.8%
                              [11:00:53.423] change to F3: 1560MHz
                              [11:00:53.455] change to F0: 2112MHz
                              [11:00:53.503] out
                              [11:00:53.679] INFO: Preloader serial: 2
                              NOTICE: BL31: v2.3():v2.3-481-g17b41886e:derrick.huang
                              NOTICE: BL31: Built : 16:20:07, Dec 7 2022
                              INFO: spec: 0x1
                              INFO: ext 32k is valid
                              INFO: ddr: stride-en 4CH
                              [11:00:53.788] INFO: BL31: Initialising Exception Handling Framework
                              INFO: BL31: Initializing BL32
                              INFO: hdmirx_handler: dma not on, ret
                              [11:00:53.836] I/TC:
                              I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022骞09鏈20鏃鏄熸湡浜09:41:09 CST aarch64
                              [11:00:53.900] I/TC: Primary CPU switching to normal world boot
                              INFO: SPSR = 0x3c9
                              [11:00:53.969]
                              COOLPI LOADER BY YANYI(Mar 18 2023)
                              DRAM: 8 GiB
                              [11:00:54.017] Using default environment
                              [11:00:54.049] Pre-reloc: vcc12v_dcin
                              [11:00:54.081] 0 2 1 3 6 8 7 9 Monitor has basic audio support
                              hdmi@fde80000: detailed mode clock 148500 kHz, flags[5]
                              [11:00:54.609] dw hdmi qp use tmds mode
                              eth0: ethernet@fe1b0000
                              [11:00:54.626] Autoboot in 1 seconds
                              [11:00:55.617] VOP VP0 enable Esmart0[356x124->356x124@782x478] fmt[1] addr[0xedf21000]
                              Bus usb@fc800000: USB EHCI 1.00
                              Bus usb@fc840000: USB OHCI 1.0
                              Bus usb@fc8c0000: USB OHCI 1.0
                              Bus usb@fc400000: usb maximum-speed not found
                              [11:00:56.082] Register 2000140 NbrPorts 2
                              scanning bus usb@fc800000 for devices... WARN: interface 0 has 2 endpoint descriptor, different from the interface descriptor's value: 1
                              [11:00:57.430] 2 USB Device(s) found
                              scanning bus usb@fc840000 for devices... 1 USB Device(s) found
                              scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found
                              scanning bus usb@fc400000 for devices... 1 USB Device(s) found
                              scanning bus for devices...
                              [11:01:02.145] SATA link 0 timeout.
                              AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
                              flags: ncq stag pm led clo only pmp fbss pio slum part ccc apst
                              [11:01:02.252] switch to partitions #0, OK
                              294 bytes read in 4 ms (71.3 KiB/s)
                              1: Linux coolpi
                              [11:01:02.312] 8775086 bytes read in 53 ms (157.9 MiB/s)
                              [11:01:02.562] 37575168 bytes read in 209 ms (171.5 MiB/s)
                              append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n81 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:ce:5d:4c:85:22:cd
                              Retrieving file: /rk3588-cpcm5-evb-v11.dtb
                              reading /rk3588-cpcm5-evb-v11.dtb
                              162268 bytes read in 6 ms (25.8 MiB/s)
                              Flattened Device Tree blob at 0x0a100000
                              [11:01:02.658] 'reserved-memory' cma: addr=10000000 s[ 11.670599] tinker-ft5406: tinker_ft5406_start_polling: touch is not ready
                              [11:01:05.608] [ 11.910605] tinker-ft5406: tinker_ft5406_start_polling: touch is not ready
                              [11:01:05.825] [ 12.080812] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                              [ 12.089332] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                              [ 12.097843] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                              [ 12.110044] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                              [11:01:05.864] [ 12.139113] RKNPU fdab0000.npu: failed to find power_model node
                              [ 12.145023] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                              [ 12.151624] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                              [11:01:06.279] writable: recovering journal
                              [11:01:06.439] writable: Clearing orphaned inode 1573212 (uid=0, gid=110, mode=0100640, size=8388608)
                              writable: clean, 421050/3784704 files, 5961091/15136766 blocks
                              [11:01:06.467] [ 12.753972] rk-pcie fe160000.pcie: PCIe Link Fail
                              [ 12.758692] rk-pcie fe160000.pcie: failed to initialize host
                              [11:01:06.675] [ 12.978578] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_cancel_cpu_limit_freq freq qos nod add
                              [11:01:07.626] [ 13.902436] Bluetooth: hci0: Reading Intel version information failed (-22)
                              [ 13.907251] tinker-ft5406: tinker_ft5406_start_polling: touch is not ready
                              [ 13.909428] Bluetooth: hci0: Intel Read version failed (-22)
                              [11:01:07.723] [ 14.027265] tinker-ft5406: tinker_ft5406_start_polling: touch is not ready
                              [11:01:08.091] [ 14.398123] Bluetooth: hci0: Reading Intel version information failed (-22)
                              [ 14.405096] Bluetooth: hci0: Intel Read version failed (-22)
                              [11:01:08.612] [ 14.918209] Bluetooth: hci0: Reading Intel version information failed (-22)
                              [ 14.925204] Bluetooth: hci0: Intel Read version failed (-22)
                              [11:01:09.146] [ 15.428187] Bluetooth: hci0: Reading Intel version information failed (-22)
                              [ 15.435212] Bluetooth: hci0: Intel Read version failed (-22)
                              [11:01:09.656] [ 15.938187] Bluetooth: hci0: Reading Intel version information failed (-22)
                              [ 15.945184] Bluetooth: hci0: Intel Read version failed (-22)
                              [11:01:10.167] [ 16.448217] Bluetooth: hci0: Reading Intel version information failed (-22)
                              [ 16.455213] Bluetooth: hci0: Intel Read version failed (-22)
                              [11:01:10.674] [ 16.955211] Bluetooth: hci0: Reading Intel version information failed (-22)
                              [ 16.962344] Bluetooth: hci0: Intel Read version failed (-22)
                                @wuming 确认loader是否已经升级到最新,机器和电脑通过USB线连接。重新上电,迅速多次按pwr按键。
                                  @george 这个log是通过串口读出来的,usb口连接了也没有什么反应,系统直接进入桌面,按loader键重启系统就卡死,完全没有反应,串口log也打不出来
                                    @wuming 如下图所示正常进入UMS的log信息。
                                    -0 2 1 3 6 8 7 9 Monitor has basic audio support
                                    Net Initialization Skipped
                                    Power Key Setting Enter UMS mode!
                                    UMS: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x747c000
                                    建议先吧loader更新到最新,老版本的不支持UMS方式烧录。参照如下文档:
                                    https://www.cool-pi.com/topic/162/how-to-upgrade-the-boot-loader-of-coolpi-4b
                                      @george 我的主板是cm5-v11,按loader键重启是卡死状态。串口不能打印任何log信息
                                        @wuming 重启是按最左边的rst按键。loader按键会进入maskrom模式用于升级loader文件。按照文档操作。
                                          @george 我就是先按住rst键不放,再按住loader键,然后先放开rst键,最后放开loader键,系统然后卡死,无任何反应
                                            @wuming 那是系统进入MASKROM状态了!用官方的工具就可以看到maskrom设备。
