    29 Posts 8 Posters 5.6k Views
      还是不得不感慨,这个机器的键盘实在是太烂了。
      经常有吞键,还有误触的情况。虽然感觉不太可能有机会改善了,但还是要吐槽一下。
        当然要和Thinkpad的键盘没法比较,但是确实从来没有收到过键盘会误触 吞键的问题,这套模具我们工厂X86一年几十万台出货量的。如果确实是单体有问题,直接申请售后就好了。这个没关系的。
          测试一阵后再来分享一下改造方式。
            mez62
            coolpi有没有可能支持一下archlinnux?
              george @mez62
              @mez62
              好的,抽空弄一个。其实教给大家方法可能会更好,回头写个帖子,就以archlinux作为对象一步一步制作镜像。
                mez62 @george
                  jack_admin @mez62
                  @mez62 需要更多的参与者一起完善
                    期待能放出做其他发行版的教程和手册,我可以做个 fedora 的。
                    也可以考虑开个讨论频道,IRC 也行,这样速度快一点。
                      这个项目现在进度如何了?我已经等不及大容量电池了。
                        目前的大容量电池厂家给的最小起订量是3K,交期要2个月,认证还要45天。众筹的这个来不及上大容量电池了。只能后续作为配件再升级了。
                          @george 这太可惜了,不知道有没有什么小批量内部测试的,或者可以兼容哪些chuwi的电池模块。
                          总之还是工作辛苦。
                          • reukiodoR
                            reukiodo
                            Can this be charged by USB C? I don't care for barrel chargers anymore when USB C is everywhere.
                              george @reukiodo
                              @reukiodo
                              Hardware versions after V20 can support TYPEC PD charging, but it can only be used when turned on, and only supports adapter charging when turned off.
                              reukiodoR 1 Reply Last reply Reply Quote 1
                              • reukiodoR
                                reukiodo @george
                                @george The only place I can find to buy this is https://www.aliexpress.us/item/3256805802818420.html but it doesn't state what HW version it is. There seems to be more than enough internal space for a larger battery as well as an additional USB C port only for charging.
                                Ideally, what is the best way to get this laptop and the internal WAN expansion board?
                                • U
                                  ukoda
                                  Hi, I was a Crowdsupply backer but since that didn't go through I was looking at getting one from AliExpress's "Chip Board" store, https://www.aliexpress.com/item/1005005989133182.html, as this looks to be the same as the crowd funding version. Can anyone verify if this is a credible seller?
