4b会支持rkllm版本么?
有这个计划更新固件到支持rkllm么?有的话,大概什么时候可以看到
Description
RKLLM software stack can help users to quickly deploy AI models to Rockchip chips. The overall framework is as follows:
In order to use RKNPU, users need to first run the RKLLM-Toolkit tool on the computer, convert the trained model into an RKLLM format model, and then inference on the development board using the RKLLM C API.
RKLLM-Toolkit is a software development kit for users to perform model conversionand quantization on PC.
RKLLM Runtime provides C/C++ programming interfaces for Rockchip NPU platform to help users deploy RKLLM models and accelerate the implementation of LLM applications.
RKNPU kernel driver is responsible for interacting with NPU hardware. It has been open source and can be found in the Rockchip kernel code.
Support Platform
- RK3588 Series
- RK3576 Series
Download
- You can also download all packages, docker image, examples, docs and platform-tools from RKLLM_SDK, fetch code: rkllm
RKNN Toolkit2
If you want to deploy additional AI model, we have introduced a new SDK called RKNN-Toolkit2. For details, please refer to:
https://github.com/airockchip/rknn-toolkit2
Notes
Due to recent updates to the Phi2 model, the current version of the RKLLM SDK does not yet support these changes.
Please ensure to download a version of the Phi2 model that is supported.CHANGELOG
v1.0.0-beta
- Supports the conversion and deployment of LLM models on RK3588/RK3576 platforms
- Compatible with Hugging Face model architectures
- Currently supports the models LLaMA, Qwen, Qwen2, and Phi-2
- Supports quantization with w8a8 and w4a16 precision
@airobot机器人开发
目前还是beta版本,等后续的release版本再考虑移植。如果有兴趣可以自己尝试移植,里边最主要的步骤是X86上面的模型转换过程。需要更详细资料可以邮件索取:george@cool-pi.com -
@george 感谢
我自己是了一下qwen1.8b,是没问题的,但是换了4b会提示要升级npu驱动,
然后我看到官方的仓库里有放出npu driver,就是不知道如何可以在板子上,直接编译,安装的方法
@george 这个huggingface上有兄弟上传了,我下载用了没问题
@shengxia 我试了不行,请问你用的哪个版本的固件?我试了加载没问题,但是实际运行就是乱输出,有时候是乱码,有时候就是乱输出一通。
原来我自己转换的模型有问题,虽然用工具转换成功了,但是运行起来后都是乱码。不知道是否和转换时参数设置有关系
@airobot机器人开发
你手上有完整的SDK吗,我邮件发一份给你,里边有比较详细的文档。 -
@george 有的,感谢。
请问可以也发我一份资料吗? 下载链接提供的模型,输出也有乱码问题。 我又尝试了下自己转换,但是rknn-llm安装whl也有问题,提示utf8编码无法解码文件。
