    Coolpi 4b firmware with buildroot
    Scheduled Pinned Locked Moved Buildroot
    21 Posts 6 Posters 12.0k Views
      这个buildroot是干什么用的
      刷这个进去原来的系统不是没了?
        刷一次系统,原系统就被清除了。buildroot也是一种系统构建工具
          这个系统和ubuntu这样的系统有什么区别吗?
          我看buildroot的package里面有上千个包
          顾 1 Reply Last reply Reply Quote 0
            顾真牛 @jugg
            @jugg 搜索下buildroot 就知道了。简单说是一个开源的嵌入式Linux系统自动构建框架。你用到啥了想要啥往里面加。一般来说你要做一个嵌入式的定制系统考虑用它。
              edwardzhou
              烧录了 coolpi-4b-buildroot-20230201 ,启动失败.
              channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
              channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
              channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
              channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
              CH0 RX Vref:28.7%, TX Vref:21.8%,20.8%
              CH1 RX Vref:30.7%, TX Vref:21.8%,21.8%
              CH2 RX Vref:29.7%, TX Vref:20.8%,19.8%
              CH3 RX Vref:30.7%, TX Vref:19.8%,20.8%
              INFO:    Preloader serial: 2
              NOTICE:  BL31: v2.3():v2.3-481-g17b41886e:derrick.huang
              NOTICE:  BL31: Built : 16:20:07, Dec  7 2022
              INFO:    spec: 0x13
              INFO:    ext 32k is not valid
              INFO:    ddr: stride-en 4CH
              INFO:    hdmirx_handler: dma not on, ret
              INFO:    SPSR = 0x3c9
              COOLPI LOADER BY YANYI(Mar 15 2023)
              DRAM:  16 GiB
              Skip repair gpt partition table.
              mmc1 is current device
              part_get_info_efi: *** ERROR: Invalid GPT ***
              part_get_info_efi: ***        Using Backup GPT ***
              285 bytes read in 3 ms (92.8 KiB/s)
              37706240 bytes read in 212 ms (169.6 MiB/s)
              append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n81 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:02:7c:d6:4d:f7:84
              141838 bytes read in 4 ms (33.8 MiB/s)
                 Loading Ramdisk to eb175000, end eb9d35ae ... OK
                 Loading Device Tree to 00000000eb14f000, end 00000000eb174a0d ... OK
              Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000)
              Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000)
              Adding bank: 0x4f0000000 - 0x500000000 (size: 0x10000000)
              [    8.736111] rk-pcie fe190000.pcie: IRQ msi not found
              [    8.736128] rk-pcie fe190000.pcie: Missing *config* reg space
              [    8.736222] rk-pcie fe190000.pcie: Missing *config* reg space
              [    8.736251] rk-pcie fe190000.pcie: invalid resource
              [    8.739214] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
              [    8.740373] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
              [    8.740378] rkvdec2_init:1010: No niu aclk reset resource define
              [    8.740382] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
              [    8.740384] rkvdec2_init:1013: No niu hclk reset resource define
              [    8.740922] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
              [    8.740926] rkvdec2_init:1010: No niu aclk reset resource define
              [    8.740929] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
              [    8.740932] rkvdec2_init:1013: No niu hclk reset resource define
              [    8.742685] mpp_iommu_probe:434: failed to get device node
              [    8.742690] mpp_av1dec av1d-master: failed to attach iommu
              [    8.869851] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
              [    8.877700] rockchip-drm display-subsystem: failed to show kernel logo
              [    9.053563] rk806 spi2.0: no sleep-setting state
              [    9.058182] rk806 spi2.0: no reset-setting pinctrl state
              [    9.063486] rk806 spi2.0: no dvs-setting pinctrl state
              [    9.276288] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
              [    9.283644] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
              [    9.290994] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
              [    9.298344] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
              [    9.305693] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
              [    9.312906] tinker-mcu: send_cmds: send command failed
              [    9.318035] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
              [    9.888252] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
              [    9.906965] : terminal subdev does not exist
              [    9.911238] : terminal subdev does not exist
              [    9.915502] : terminal subdev does not exist
              [    9.919766] : terminal subdev does not exist
              [    9.924031] : get_remote_sensor: video pad[0] is null
              [    9.929075] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
              [    9.936285] : get_remote_sensor: video pad[0] is null
              [    9.941327] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
              [    9.948539] : get_remote_sensor: video pad[0] is null
              [    9.953582] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
              [    9.960791] : get_remote_sensor: video pad[0] is null
              [    9.965836] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
              [    9.974213] rockchip-mipi-csi2: Async registered subdev
              [   10.043504] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
              [   10.178210] debugfs: File 'Capture' in directory 'dapm' already present!
              [   10.201674] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
              [   10.409766] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
              [   10.416980] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
              [   10.424280] debugfs: File 'HPCP L' in directory 'dapm' already present!
              [   10.430880] debugfs: File 'HPCP R' in directory 'dapm' already present!
              [   10.437480] debugfs: File 'HPVOL L' in directory 'dapm' already present!
              [   10.444166] debugfs: File 'HPVOL R' in directory 'dapm' already present!
              [   10.452281] ov5648 8-0036: could not get default pinstate
              [   10.457674] ov5648 8-0036: could not get sleep pinstate
              [   10.466090] ov5648 8-0036: Unexpected sensor id(000000), ret(-5)
              [   10.473190] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
              [   10.482317] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
              [   10.491431] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
              [   10.491646] rockchip_headset rk-headset: Can not read property headset_gpio
              [   10.492963] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
              [   10.492971] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
              [   10.492975] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
              [   10.496671] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
              [   10.506201] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
              [   10.523208] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
              [   10.568001] RKNPU fdab0000.npu: failed to find power_model node
              [   10.573914] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
              [   10.580515] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
              writable: recovering journal
              writable: clean, 4402/196608 files, 272411/758012 blocks
              mount: /dev: devtmpfs already mounted or mount point busy.
              Starting syslogd: OK
              Starting klogd: OK
              Running sysctl: OK
              /bin/modetest
              Populating /dev using udev: [   11.978133] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
              [   11.978143] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
              [   11.979095] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
              [   11.979097] rkcif_scale_ch2: update sensor info failed -19
              [   11.979138] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
              [   11.979140] rkcif_scale_ch1: update sensor info failed -19
              [   11.979413] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
              [   11.979414] stream_cif_mipi_id0: update sensor info failed -19
              [   11.979824] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
              [   11.979826] rkcif_scale_ch0: update sensor info failed -19
              [   11.982241] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
              [   11.982243] stream_cif_mipi_id3: update sensor info failed -19
              [   11.982583] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
              [   11.982584] rkcif_tools_id1: update sensor info failed -19
              [   11.985808] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
              [   11.985809] rkcif_tools_id2: update sensor info failed -19
              [   11.987076] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
              [   11.987079] rkcif_tools_id0: update sensor info failed -19
              [   11.987270] rkcif_scale_ch3: update sensor info failed -19
              [   12.020112] stream_cif_mipi_id1: update sensor info failed -19
              [   12.025594] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
              [   12.113820] stream_cif_mipi_id2: update sensor info failed -19
              [   12.294975] aicbsp: sdio_err:<aicwf_sdio_bus_pwrctl,1160>: bus down
              [   12.949583] ieee80211 phy0:
              [   12.949583] *******************************************************
              [   12.949583] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES **
              Initializing random number generator: OK
              Saving random seed: OK
              Will now mount all partitions in /etc/fstab
              Note: Will skip fsck, remove /.skip_fsck to enable
              Handling /dev/root / ext4 rw,noauto 1
              /bin/disk-helper: line 328: findmnt: command not found
              Handling tmpfs /tmp tmpfs mode=1777 0
              Handling tmpfs /run tmpfs mode=0755,nosuid,nodev 0
              Handling proc /proc proc defaults 0
              Handling devtmpfs /dev devtmpfs defaults 0
              Handling devpts /dev/pts devpts mode=0620,ptmxmode=0666,gid=5 0
              Handling tmpfs /dev/shm tmpfs nosuid,nodev,noexec 0
              Handling sysfs /sys sysfs defaults 0
              Handling configfs /sys/kernel/config configfs defaults 0
              Handling debugfs /sys/kernel/debug debugfs defaults 0
              Handling pstore /sys/fs/pstore pstore defaults 0
              Log saved to /tmp/mount-all.log
              Starting system message bus: done
              starting bootanim... Starting bootanim: 825...
              done.
              Starting hook: /etc/bootanim.d/gst-bootanim.sh...
              load wifi modules: insmod: can't insert '/system/lib/modules/bcmdhd.ko': No such file or directory
              OK
              wl: wl driver adapter not found
              Starting bluetoothd: OK
              Starting network: OK
              Starting seatd: OK
              Starting dhcpcd...
              dhcpcd-9.4.1 starting
              dev: loaded udev
              DUID 00:01:00:01:c7:92:bc:8a:e0:75:26:66:33:e3
              forked to background, child pid 875
              Starting ntpd: OK
              starting weston... done.
              Starting dropbear sshd: OK
              Starting pulseaudio: OK
              Starting /usr/bin/usbdevice start, log saved to /tmp/usbdevice.log
              W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
              [   18.701164] dma-pl330 fea30000.dma-controller: fill_queue:2263 Bad Desc(2)
              Starting dnsmasq: OK
              Starting input-event-daemon: done
              root@rk3588:/# Date: 1970-01-01 UTC
              [00:00:10.476] weston 11.0.0
                             https://wayland.freedesktop.org
                             Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
                             Build: 11.0.0
              [00:00:10.476] Command line: /usr/bin/weston
              [00:00:10.476] OS: Linux, 5.10.110, #5 SMP Thu Mar 2 17:39:26 CST 2023, aarch64
              [00:00:10.476] Flight recorder: enabled
              [00:00:10.476] warning: XDG_RUNTIME_DIR "/var/run" is not configured
              correctly.  Unix access mode must be 0700 (current mode is 0755),
              and must be owned by the user UID 0 (current owner is UID 0).
              Refer to your distribution on how to get it, or
              http://www.freedesktop.org/wiki/Specifications/basedir-spec
              on how to implement it.
              [00:00:10.477] Using config file '/etc/xdg/weston/weston.ini'
              [00:00:10.478] Output repaint window is -1 ms maximum.
              [00:00:10.479] Loading module '/usr/lib/libweston-11/drm-backend.so'
              [00:00:10.486] initializing drm backend
              [00:00:10.486] Entering mirror mode.
              [00:00:10.486] Trying libseat launcher...
              [00:00:10.486] [libseat/libseat.c:73] Seat opened with backend 'seatd'
              [00:00:10.486] [libseat/backend/seatd.c:228] Enabling seat
              [00:00:10.486] libseat: session control granted
              [00:00:10.486] using /dev/dri/card0
              [00:00:10.486] DRM: does not support atomic modesetting
              [00:00:10.486] DRM: does not support GBM modifiers
              [00:00:10.486] DRM: supports picture aspect ratio
              [00:00:10.487] Loading module '/usr/lib/libweston-11/gl-renderer.so'
              arm_release_ver of this libmali is 'g6p0-01eac0', rk_so_ver is '6'.
              [00:00:10.519] EGL version: 1.4 Valhall-"g6p0-01eac0"
              [00:00:10.519] EGL vendor: ARM
              [00:00:10.519] EGL client APIs: OpenGL_ES
              [00:00:10.519] warning: Disabling render GPU timeline and explicit synchronization due to missing EGL_ANDROID_native_fence_sync extension
              [00:00:10.519] EGL features:
                             EGL Wayland extension: yes
                             context priority: yes
                             buffer age: no
                             partial update: yes
                             swap buffers with damage: no
                             configless context: yes
                             surfaceless context: yes
                             dmabuf support: modifiers
              [00:00:10.538] GL version: OpenGL ES 3.2 v1.g6p0-01eac0.ba52c908d926792b8f5fe28f383a2b03
              [00:00:10.538] GLSL version: OpenGL ES GLSL ES 3.20
              [00:00:10.538] GL vendor: ARM
              [00:00:10.538] GL renderer: Mali-LODX
              [00:00:10.775] GL ES 3.2 - renderer features:
                             read-back format: ARGB8888
                             wl_shm 10 bpc formats: yes
                             wl_shm 16 bpc formats: no
                             wl_shm half-float formats: yes
                             internal R and RG formats: yes
                             OES_EGL_image_external: yes
                             wl_shm sub-image to texture: yes
              [00:00:10.793] event8  - adc-keys: is tagged by udev as: Keyboard
              [00:00:10.793] event8  - adc-keys: device is a keyboard
              [00:00:10.793] event6  - rockchip,dp0 rockchip,dp0: is tagged by udev as: Switch
              [00:00:10.816] event6  - not using input device '/dev/input/event6'
              [00:00:10.817] event1  - CX 2.4G Receiver: is tagged by udev as: Keyboard
              [00:00:10.817] event1  - CX 2.4G Receiver: device is a keyboard
              [00:00:10.817] event2  - CX 2.4G Receiver Mouse: is tagged by udev as: Mouse
              [00:00:10.817] event2  - CX 2.4G Receiver Mouse: device is a pointer
              [00:00:10.818] event3  - CX 2.4G Receiver: not tagged as supported input device
              [00:00:10.830] event3  - not using input device '/dev/input/event3'
              [00:00:10.830] event4  - CX 2.4G Receiver Consumer Control: is tagged by udev as: Keyboard
              [00:00:10.830] event4  - CX 2.4G Receiver Consumer Control: device is a keyboard
              [00:00:10.831] event5  - CX 2.4G Receiver System Control: is tagged by udev as: Keyboard
              [00:00:10.831] event5  - CX 2.4G Receiver System Control: device is a keyboard
              [00:00:10.831] event0  - rk805 pwrkey: is tagged by udev as: Keyboard
              [00:00:10.831] event0  - rk805 pwrkey: device is a keyboard
              [00:00:10.831] event7  - rockchip-hdmi0 rockchip-hdmi0: is tagged by udev as: Switch
              [00:00:10.850] event7  - not using input device '/dev/input/event7'
              [00:00:10.877] libinput: configuring device "adc-keys".
              [00:00:10.877] libinput: configuring device "CX 2.4G Receiver".
              [00:00:10.877] libinput: configuring device "CX 2.4G Receiver Mouse".
              [00:00:10.877] libinput: configuring device "CX 2.4G Receiver Consumer Control".
              [00:00:10.877] libinput: configuring device "CX 2.4G Receiver System Control".
              [00:00:10.877] libinput: configuring device "rk805 pwrkey".
              [00:00:10.877] DRM: head 'HDMI-A-1' updated, connector 197 is disconnected.
              [00:00:10.877] DRM: head 'HDMI-A-1' found, connector 197 is disconnected.
              [00:00:10.877] DRM: head 'DP-1' updated, connector 211 is disconnected.
              [00:00:10.877] DRM: head 'DP-1' found, connector 211 is disconnected.
              [00:00:10.877] Output 'DUMMY' attempts EOTF mode: SDR
              [00:00:10.877] Registered plugin API 'weston_drm_output_api_v1' of size 32
              [00:00:10.878] Color manager: no-op
              [00:00:10.878] Compositor capabilities:
                             arbitrary surface rotation: yes
                             screen capture uses y-flip: yes
                             cursor planes: yes
                             arbitrary resolutions: no
                             view mask clipping: yes
                             explicit sync: no
                             color operations: yes
                             presentation clock: CLOCK_MONOTONIC, id 1
                             presentation clock resolution: 0.000000001 s
              [00:00:10.878] Loading module '/usr/lib/weston/desktop-shell.so'
              [00:00:10.880] launching '/usr/libexec/weston-keyboard'
              [00:00:10.880] launching '/usr/libexec/weston-desktop-shell'
              could not load cursor 'dnd-move'
              could not load cursor 'dnd-copy'
              could not load cursor 'dnd-none'
              xkbcommon: ERROR: couldn't find a Compose file for locale "C" (mapped to "C")
              could not create XKB compose table for locale 'C'.  Disabiling compose
              E: [pulseaudio] module-rescue-streams.c: module-rescue-stream is obsolete and should no longer be loaded. Please remove it from your configuration.
              W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Using X11 for dbus-daemon autolaunch was disabled at compile time, set your DBUS_SESSION_BUS_ADDRESS instead
              W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Using X11 for dbus-daemon autolaunch was disabled at compile time, set your DBUS_SESSION_BUS_ADDRESS instead
                edwardzhou @edwardzhou
                启动是成功的,只是ttl终端没能操作,hdmi上有桌面,能正常操作。
                  edwardzhou
                  仓库更新的版本编译起来很丝滑
                  make coolpi4_defconfig
                  make -j12
                  把 rootfs.tar.gz 拷贝到 U盘的install 目录下,插上即可完成系统刷新。
                  期待继续完善支持:
                  1. 构建可以直接启动引导的可烧卡镜像,就不用通过U盘install工具。
                  2. 启用蓝牙驱动模块
                  3. 启用WiFi驱动模块
                  4. rknpu toolket 1.4
                  5. BuildRoot upgrade 到 2022.11 或 最新 2023.02
                    更好的做法,把 coolpi4 的相关部分抽离出来成为一个patch
                    这就容易进行 buildroot的升级,甚至用户可以自己去尝试升级buildroot
                    大法师 @edwardzhou
                    @edwardzhou
                    已更新仓库,支持编译生成卡刷镜像文件
                    buildroot百度网盘测试镜像
                    用户名root 密码coolpi
                    也可以使用rufus工具制作启动TF卡或EMMC(推荐)
                    E J 2 Replies Last reply Reply Quote 0
                      edwardzhou @大法师
                      @大法师 Nice Job. 烧录启动成功. 能自动启动进入桌面,串口也能操作 👍
                        我刷了这个镜像
                        第一次能进去系统 然后执行了auto_reboot.sh
                        之后重启了 然后就一直重启
                        断电重启后 还是一直在重启 完全停不下来
                        1:	linux coolpi
                        8775086 bytes read in 53 ms (157.9 MiB/s)
                        37573120 bytes read in 212 ms (169 MiB/s)
                        141830 bytes read in 6 ms (22.5 MiB/s)
                           Loading Device Tree to 00000000eb150000, end 00000000eb175a05 ... OK
                        [    4.925266] rk-pcie fe190000.pcie: IRQ msi not found
                        [    4.925284] rk-pcie fe190000.pcie: Missing *config* reg space
                        [    4.925383] rk-pcie fe190000.pcie: Missing *config* reg space
                        [    4.925412] rk-pcie fe190000.pcie: invalid resource
                        [    4.928306] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                        [    4.929439] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                        [    4.929444] rkvdec2_init:1010: No niu aclk reset resource define
                        [    4.929447] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                        [    4.929450] rkvdec2_init:1013: No niu hclk reset resource define
                        [    4.929974] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                        [    4.929978] rkvdec2_init:1010: No niu aclk reset resource define
                        [    4.929981] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                        [    4.929984] rkvdec2_init:1013: No niu hclk reset resource define
                        [    4.931699] mpp_iommu_probe:434: failed to get device node
                        [    4.931703] mpp_av1dec av1d-master: failed to attach iommu
                        [    5.058250] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
                        [    5.066098] rockchip-drm display-subsystem: failed to show kernel logo
                        [    5.229169] rk806 spi2.0: no sleep-setting state
                        [    5.233789] rk806 spi2.0: no reset-setting pinctrl state
                        [    5.239092] rk806 spi2.0: no dvs-setting pinctrl state
                        [    5.451611] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                        [    5.458966] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                        [    5.466316] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                        [    5.473664] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                        [    5.481013] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
                        [    5.488224] tinker-mcu: send_cmds: send command failed
                        [    5.493354] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
                        [    6.063741] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
                        [    6.080841] : terminal subdev does not exist
                        [    6.085110] : terminal subdev does not exist
                        [    6.089372] : terminal subdev does not exist
                        [    6.093635] : terminal subdev does not exist
                        [    6.097900] : get_remote_sensor: video pad[0] is null
                        [    6.102944] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                        [    6.110153] : get_remote_sensor: video pad[0] is null
                        [    6.115197] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                        [    6.122406] : get_remote_sensor: video pad[0] is null
                        [    6.127449] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                        [    6.134658] : get_remote_sensor: video pad[0] is null
                        [    6.139701] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
                        [    6.148020] rockchip-mipi-csi2: Async registered subdev
                        [    6.217221] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                        [    6.228022] debugfs: File 'Capture' in directory 'dapm' already present!
                        [    6.251003] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                        [    6.582117] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                        [    6.589378] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                        [    6.596678] debugfs: File 'HPCP L' in directory 'dapm' already present!
                        [    6.603287] debugfs: File 'HPCP R' in directory 'dapm' already present!
                        [    6.609893] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                        [    6.616580] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                        [    6.624805] ov5648 8-0036: could not get default pinstate
                        [    6.630197] ov5648 8-0036: could not get sleep pinstate
                        [    6.638705] ov5648 8-0036: Unexpected sensor id(000000), ret(0)
                        [    6.645632] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                        [    6.654766] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                        [    6.663882] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                        [    6.671706] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                        [    6.671984] rockchip_headset rk-headset: Can not read property headset_gpio
                        [    6.680820] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
                        [    6.696800] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                        [    6.705317] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                        [    6.713827] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                        [    6.725998] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                        [    6.755046] RKNPU fdab0000.npu: failed to find power_model node
                        [    6.760957] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                        [    6.767557] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                        writable: clean, 4880/196608 files, 277546/758012 blocks
                        Starting klogd: OK
                        Running sysctl: OK
                        /bin/modetest
                        Populating /dev using udev: [    8.333985] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
                        [    8.334831] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
                        [    8.334833] rkcif_tools_id2: update sensor info failed -19
                        [    8.334851] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
                        [    8.334853] stream_cif_mipi_id2: update sensor info failed -19
                        [    8.334950] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
                        [    8.334952] rkcif_scale_ch1: update sensor info failed -19
                        [    8.335530] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                        [    8.335532] rkcif_scale_ch0: update sensor info failed -19
                        [    8.337272] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                        [    8.337275] stream_cif_mipi_id0: update sensor info failed -19
                        [    8.338137] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
                        [    8.338139] rkcif_tools_id1: update sensor info failed -19
                        [    8.339352] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
                        [    8.339354] stream_cif_mipi_id3: update sensor info failed -19
                        [    8.341478] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
                        [    8.341479] rkcif_tools_id0: update sensor info failed -19
                        [    8.343174] stream_cif_mipi_id1: update sensor info failed -19
                        [    8.352585] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
                        [    8.355026] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
                        [    8.355029] rkcif_scale_ch2: update sensor info failed -19
                        [    8.387294] rkcif_scale_ch3: update sensor info failed -19
                        [    8.673816] aicbsp: sdio_err:<aicwf_sdio_bus_pwrctl,1160>: bus down
                        [    9.129111] ieee80211 phy0:
                        [    9.129111] *******************************************************
                        [    9.129111] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES **
                        starting bootanim... Starting bootanim: 753...
                        done.
                        OK
                        Starting seatd: OK
                        Starting dhcpcd...
                        dev: loaded udev
                        DUID 00:01:00:01:c7:92:bc:84:e0:75:26:66:36:53
                        forked to background, child pid 803
                        Starting ntpd: OK
                        [   10.532514] dma-pl330 fea30000.dma-controller: fill_queue:2263 Bad Desc(2)
                        [00:00:06.098] weston 11.0.0
                                       Build: 11.0.0
                        [00:00:06.098] Command line: /usr/bin/weston
                        [00:00:06.098] OS: Linux, 5.10.110, #5 SMP Wed Feb 1 16:58:12 CST 2023, aarch64
                        [00:00:06.098] Flight recorder: enabled
                        [00:00:06.098] warning: XDG_RUNTIME_DIR "/var/run" is not configured
                        [00:00:06.099] Using config file '/etc/xdg/weston/weston.ini'
                        [00:00:06.099] Output repaint window is -1 ms maximum.
                        [00:00:06.100] Loading module '/usr/lib/libweston-11/drm-backend.so'
                        [00:00:06.104] initializing drm backend
                        [00:00:06.105] Entering mirror mode.
                        [00:00:06.105] Trying libseat launcher...
                        [00:00:06.105] [libseat/libseat.c:73] Seat opened with backend 'seatd'
                        [00:00:06.105] [libseat/backend/seatd.c:228] Enabling seat
                        [00:00:06.105] libseat: session control granted
                        [00:00:06.105] using /dev/dri/card0
                        [00:00:06.105] DRM: does not support atomic modesetting
                        [00:00:06.105] DRM: does not support GBM modifiers
                        [00:00:06.105] DRM: supports picture aspect ratio
                        [00:00:06.106] Loading module '/usr/lib/libweston-11/gl-renderer.so'
                        Starting dnsmasq: [00:00:06.132] EGL version: 1.4 Valhall-"g6p0-01eac0"
                        [00:00:06.132] EGL vendor: ARM
                        [00:00:06.132] EGL client APIs: OpenGL_ES
                        [00:00:06.132] warning: Disabling render GPU timeline and explicit synchronization due to missing EGL_ANDROID_native_fence_sync extension
                        [00:00:06.132] EGL features:
                                       buffer age: no
                                       partial update: yes
                        OK
                        start auto-reboot
                        Starting input-event-daemon: [00:00:06.148] GL version: OpenGL ES 3.2 v1.g6p0-01eac0.ba52c908d926792b8f5fe28f383a2b03
                        [00:00:06.148] GLSL version: OpenGL ES GLSL ES 3.20
                        [00:00:06.148] GL vendor: ARM
                        [00:00:06.148] GL renderer: Mali-LODX
                        Reboot after 8 seconds.
                        current cnt = 15, total cnt = 10000
                        You can stop reboot by: echo off > /userdata/rockchip-test/reboot_cnt
                        [00:00:06.319] GL ES 3.2 - renderer features:
                        [00:00:06.332] event3  - adc-keys: is tagged by udev as: Keyboard
                        [00:00:06.332] event3  - adc-keys: device is a keyboard
                        [00:00:06.333] event1  - rockchip,dp0 rockchip,dp0: is tagged by udev as: Switch
                        [00:00:06.366] event1  - not using input device '/dev/input/event1'
                        [00:00:06.367] event4  - USB OPTICAL MOUSE : is tagged by udev as: Mouse
                        [00:00:06.367] event4  - USB OPTICAL MOUSE : device is a pointer
                        [00:00:06.368] event5  - USB OPTICAL MOUSE  Keyboard: is tagged by udev as: Keyboard
                        [00:00:06.368] event5  - USB OPTICAL MOUSE  Keyboard: device is a keyboard
                        [00:00:06.368] event6  - USB OPTICAL MOUSE  Consumer Control: is tagged by udev as: Keyboard
                        [00:00:06.368] event6  - USB OPTICAL MOUSE  Consumer Control: device is a keyboard
                        [00:00:06.369] event9  - Telink Wireless Receiver System Control: is tagged by udev as: Keyboard
                        [00:00:06.369] event9  - Telink Wireless Receiver System Control: device is a keyboard
                        [00:00:06.370] event7  - Telink Wireless Receiver Mouse: is tagged by udev as: Mouse
                        root@rk3588:/# [00:00:06.370] event7  - Telink Wireless Receiver Mouse: device is a pointer
                        [00:00:06.370] event8  - Telink Wireless Receiver Consumer Control: is tagged by udev as: Keyboard
                        [00:00:06.370] event8  - Telink Wireless Receiver Consumer Control: device is a keyboard
                        [00:00:06.371] event10 - Telink Wireless Receiver: is tagged by udev as: Keyboard
                        [00:00:06.371] event10 - Telink Wireless Receiver: device is a keyboard
                        [00:00:06.371] event0  - rk805 pwrkey: is tagged by udev as: Keyboard
                        [00:00:06.371] event0  - rk805 pwrkey: device is a keyboard
                        [00:00:06.372] event2  - rockchip-hdmi0 rockchip-hdmi0: is tagged by udev as: Switch
                        [00:00:06.393] event2  - not using input device '/dev/input/event2'
                        [00:00:06.411] libinput: configuring device "adc-keys".
                        [00:00:06.411] libinput: configuring device "USB OPTICAL MOUSE ".
                        [00:00:06.411] libinput: configuring device "USB OPTICAL MOUSE  Keyboard".
                        [00:00:06.411] libinput: configuring device "USB OPTICAL MOUSE  Consumer Control".
                        [00:00:06.411] libinput: configuring device "Telink Wireless Receiver System Control".
                        [00:00:06.411] libinput: configuring device "Telink Wireless Receiver Mouse".
                        [00:00:06.412] libinput: configuring device "Telink Wireless Receiver Consumer Control".
                        [00:00:06.412] libinput: configuring device "Telink Wireless Receiver".
                        [00:00:06.412] libinput: configuring device "rk805 pwrkey".
                        [00:00:06.412] DRM: head 'HDMI-A-1' updated, connector 197 is disconnected.
                        [00:00:06.412] DRM: head 'HDMI-A-1' found, connector 197 is disconnected.
                        [00:00:06.412] DRM: head 'DP-1' updated, connector 211 is disconnected.
                        [00:00:06.412] DRM: head 'DP-1' found, connector 211 is disconnected.
                        [00:00:06.412] Output 'DUMMY' attempts EOTF mode: SDR
                        [00:00:06.412] Registered plugin API 'weston_drm_output_api_v1' of size 32
                        [00:00:06.412] Color manager: no-op
                        [00:00:06.412] Compositor capabilities:
                                       cursor planes: yes
                                       explicit sync: no
                        [00:00:06.412] Loading module '/usr/lib/weston/desktop-shell.so'
                        [00:00:06.413] launching '/usr/libexec/weston-keyboard'
                        [00:00:06.414] launching '/usr/libexec/weston-desktop-shell'
                        [00:00:10.717] Output 'DUMMY' attempts EOTF mode: SDR
                        [00:00:10.717] Output 'DUMMY' using color profile: built-in default sRGB SDR profile
                        [00:00:10.717] Chosen EGL config details: id:   9 rgba: 8 8 8 0 buf: 24 dep:  0 stcl: 0 int: 0-1 type: win|pbf|swap_preserved vis_id: XRGB8888 (0x34325258)
                        [00:00:10.717] Output 'DUMMY' enabled with head(s) DUMMY
                        check console-ramoops-o message
                        Stopping input-event-daemon: done
                        stop auto-reboot finished
                        Stopping dnsmasq: OK
                        Starting /usr/bin/usbdevice stop, log saved to /tmp/usbdevice.log
                        Stopping pulseaudio: E: [pulseaudio] main.c: Failed to kill daemon: No such process
                        OK
                        Stopping dropbear sshd: OK
                        stoping weston... [00:00:14.419] caught signal 15
                        done.
                        [00:00:14.420] event3  - adc-keys: device removed
                        Stopping ntpd: OK
                        Stopping dhcpcd...
                        no /sbin/dhcpcd found; none killed
                        Stopping seatd: stopped /usr/bin/seatd (pid 799)
                        OK
                        killall: rkaiq_3A_server: no process killed
                        Stopping network: OK
                        Stopping bluetoothd: [00:00:14.480] event4  - USB OPTICAL MOUSE : device removed
                        [00:00:14.480] [libseat/backend/seatd.c:138] Could not flush connection: Broken pipe
                        [00:00:14.480] libseat: Could not close device 3OK
                        stoping bootanim... done.
                        Stopping system message bus: done
                        [00:00:14.526] event5  - USB OPTICAL MOUSE  Keyboard: device removed
                        [00:00:14.526] libseat: Could not close device 4killall: can't kill pid 513: No such process
                        killall: can't kill pid 514: No such process
                        killall: can't kill pid 515: No such process
                        killall: can't kill pid 516: No such process
                        killall: can't kill pid 517: No such process
                        killall: can't kill pid 518: No such process
                        killall: can't kill pid 519: No such process
                        killall: can't kill pid 520: No such process
                        killall: can't kill pid 521: No such process
                        killall: can't kill pid 523: No such process
                        killall: can't kill pid 524: No such process
                        killall: can't kill pid 525: No such process
                        killall: can't kill pid 526: No such process
                        killall: can't kill pid 527: No such process
                        killall: can't kill pid 528: No such process
                        killall: can't kill pid 529: No such process
                        killall: can't kill pid 530: No such process
                        killall: can't kill pid 531: No such process
                        killall: can't kill pid 532: No such process
                        killall: can't kill pid 533: No such process
                        killall: can't kill pid 534: No such process
                        killall: can't kill pid 535: No such process
                        killall: can't kill pid 536: No such process
                        killall: can't kill pid 537: No such process
                        /bin/modetest
                        Stopping klogd: OK
                        Stopping syslogd: OK
                        umount: /tmp: target is busy.
                        umount: /run: target is busy.
                        The system is going down NOW!
                          @jugg 可以看下脚本内容,是不是有重启次数
                            我重新刷了系统
                            我在虚拟机里重新编译了buildroot (添加了一些模块)
                            怎么才能做成这样的镜像
                              @jugg coolpi-sdcard.img就是自动生成的
                                这个是sd卡的
                                我想做成刷到emmc的那种镜像
                                  @jugg 通用的
                                    coolpi-sdcard.img 也能通过balenaEtcher 烧录进emmc里面?
                                    烧录的时候选这个镜像就行了是吧
                                      @jugg said in Coolpi 4b firmware with buildroot:
                                      烧录的时候选这个镜像就行了是吧
                                      对的
                                        gst没有mpph264enc吗?
                                        而且添加的ffmpeg也没有mpp相关的支持
                                          gst没有mpph264enc吗?
                                          buildroot 是不是还没有适配gst的mpp相关部分?
                                            @jugg 这个版本还没有增加。
