    Firefox deb version freezed when try to play video
    31 Posts 3 Posters 5.9k Views
      sudo ln -s /usr/bin/python3.12 /usr/bin/python
        Already did. Seems it doesn't work.
        $./build-uboot.sh cm5-notebook
        ## make rk3588_coolpicm5_notebook_defconfig -j16
        # configuration written to .config
        scripts/kconfig/conf  --silentoldconfig Kconfig
          CHK     include/config.h
          CFG     u-boot.cfg
          GEN     include/autoconf.mk.dep
          CFG     spl/u-boot.cfg
          CFG     tpl/u-boot.cfg
          GEN     spl/include/autoconf.mk
          GEN     tpl/include/autoconf.mk
          CHK     include/config/uboot.release
          CHK     include/generated/timestamp_autogenerated.h
          UPD     include/generated/timestamp_autogenerated.h
          CFG     u-boot.cfg
          CHK     include/generated/version_autogenerated.h
          CHK     include/generated/generic-asm-offsets.h
          CHK     include/generated/asm-offsets.h
          HOSTCC  tools/mkenvimage.o
          HOSTCC  tools/fit_image.o
          HOSTCC  tools/image-host.o
          HOSTCC  tools/dumpimage.o
          HOSTCC  tools/mkimage.o
          HOSTCC  tools/rockchip/boot_merger.o
          HOSTCC  tools/rockchip/loaderimage.o
          HOSTLD  tools/loaderimage
        tools/rockchip/boot_merger.c: In function ‘mergeBoot’:
        tools/rockchip/boot_merger.c:700:43: warning: ‘%s’ directive output may be truncated writing up to 813 bytes into a region of size 5 [-Wformat-truncation=]
          700 |         snprintf(buffer, sizeof(buffer), "%s", chip);
          742 |                 chipType = convertChipType(chip + 2);
        In file included from /usr/include/stdio.h:980,
                         from ././include/compiler.h:25,
                         from <command-line>:
        In function ‘snprintf’,
            inlined from ‘convertChipType’ at tools/rockchip/boot_merger.c:700:2,
            inlined from ‘getChipType’ at tools/rockchip/boot_merger.c:742:14,
            inlined from ‘getBoothdr’ at tools/rockchip/boot_merger.c:761:18,
            inlined from ‘mergeBoot’ at tools/rockchip/boot_merger.c:830:2:
        /usr/include/aarch64-linux-gnu/bits/stdio2.h:54:10: note: ‘__builtin_snprintf’ output between 1 and 814 bytes into a destination of size 5
           54 |   return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,
           55 |                                    __glibc_objsize (__s), __fmt,
           56 |                                    __va_arg_pack ());
        In function ‘wide2str’,
            inlined from ‘unpackBoot’ at tools/rockchip/boot_merger.c:955:3,
            inlined from ‘main’ at tools/rockchip/boot_merger.c:1072:8:
        tools/rockchip/boot_merger.c:895:18: warning: array subscript 20 is outside array bounds of ‘char[20]’ [-Warray-bounds=]
          895 |         str[len] = 0;
        tools/rockchip/boot_merger.c: In function ‘main’:
        tools/rockchip/boot_merger.c:933:14: note: at offset 20 into object ‘name’ of size 20
          933 |         char name[MAX_NAME_LEN];
          HOSTLD  tools/boot_merger
          HOSTLD  tools/mkenvimage
          HOSTLD  tools/dumpimage
          HOSTLD  tools/mkimage
          CC      arch/arm/cpu/armv8/fwcall.o
          CC      common/main.o
          LD      arch/arm/cpu/armv8/built-in.o
          CC      cmd/version.o
          LD      common/built-in.o
          CC      lib/display_options.o
          LD      cmd/built-in.o
          LD      lib/built-in.o
          LD      u-boot
        /usr/bin/aarch64-linux-gnu-ld.bfd: warning: u-boot has a LOAD segment with RWX permissions
          OBJCOPY u-boot.srec
          OBJCOPY u-boot-nodtb.bin
          SYM     u-boot.sym
        make[2]: 'arch/arm/dts/rk3588-cp5-x8.dtb' is up to date.
          COPY    u-boot.dtb
        start=$(/usr/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ' '); end=$(/usr/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ' '); tools/relocate-rela u-boot-nodtb.bin 0x00200000 $start $end
          CAT     u-boot-dtb.bin
          MKIMAGE u-boot.img
          MKIMAGE u-boot-dtb.img
          COPY    u-boot-dtb-kern.bin
          ALIGN   u-boot-dtb-kern.bin
          CAT     u-boot.bin
          CC      spl/common/spl/spl.o
          CC      spl/arch/arm/cpu/armv8/fwcall.o
          COPY    spl/u-boot-spl.dtb
          CC      tpl/arch/arm/cpu/armv8/fwcall.o
          LD      spl/arch/arm/cpu/armv8/built-in.o
          CC      tpl/arch/arm/mach-rockchip/tpl.o
          LD      tpl/arch/arm/cpu/armv8/built-in.o
          CC      spl/lib/display_options.o
          LD      tpl/arch/arm/mach-rockchip/built-in.o
          LD      spl/common/spl/built-in.o
          LD      spl/lib/built-in.o
          LD      tpl/u-boot-tpl
        /usr/bin/aarch64-linux-gnu-ld.bfd: warning: u-boot-tpl has a LOAD segment with RWX permissions
          OBJCOPY tpl/u-boot-tpl-nodtb.bin
          COPY    tpl/u-boot-tpl.bin
          LD      spl/u-boot-spl
        /usr/bin/aarch64-linux-gnu-ld.bfd: warning: u-boot-spl has a LOAD segment with RWX permissions
          OBJCOPY spl/u-boot-spl-nodtb.bin
          CAT     spl/u-boot-spl-dtb.bin
          COPY    spl/u-boot-spl.bin
          CFGCHK  u-boot.cfg
        ERROR: No python2
        $ python
        Python 3.12.3 (main, Apr 10 2024, 05:33:47) [GCC 13.2.0] on linux
        Type "help", "copyright", "credits" or "license" for more information.
          The following is what I have compiled and can be used directly.
          RKDevTool_v3.13_for_window.rar
            @george thanks.
            The only way to upgrade uboot is following this guide?
            https://forum.cool-pi.com/topic/162/how-to-upgrade-the-boot-loader-of-coolpi-4b
            short two pins and conect to PC to upgrade loader?
                Follow the steps below to operate:
                1.USB cable for TYPEC interface and X86 computer connection
                2. Run sudo reboot loader on the shell,The machine will enter loader mode, as shown in the following figure
                3. Click on the tool to force entry into maskrom mode
                4. Check the option to force writing by address
                5. Burning, the machine will automatically restart after completion
                  @george Nice, I'll try it.
                  Btw I finally figured out why my USB Disk can't boot up.
                  The the fedora image you gave me have Boot up info in cmdline like this:
                  rootfs=LABLE=writable
                  And my EMMC also has a parttion labled writable(dafault).
                  So actually it booted up from usb disk, but set writable lable on emmc as root, So I boot back to my ubuntu. That mislanding me ths USB disk can't be boot up.
                  I changed to rootfs=UUID=(my usb disk UUID). And I can boot into fedora image now.
                    You can change the EMMC label to writable1 or another name.
                      Upgrade finished, Seems boot up speed much faster than before.
                      Will play around with fedora image.
                      BTW I compiled kernel 6.1 from github https://github.com/yanyitech/coolpi-kernel kernel 6.1 branch and It can't boot up.
                      Hope new kernel will come soon.
                      Many thanks for your help.
                        Just uncheck "Use recommended performance settings" and "Use hardware acceleration when available" in Firefox settings will fix this issue.
                        But also will have no GPU acceleration.
                          FFmpeg can be changed to a native package. Or using the Chromium browser, the decoding issue of this player has been bothering us for a long time. Take some time later to focus on solving it.
                          • 2 / 2
