    自定义bootloader
    2 Posts 2 Posters 951 Views
    • Z
      zehui
      背景:需要自定义tee os(使用OPTEE而不是rockchip的TEE),所以想要定制bootloader。
      我之前有个rock pi 4b,然后其启动流程就如同这里所示:https://opensource.rock-chips.com/wiki_Boot_option,基于这个wiki我们构建了一个基于官方TEE的启动镜像。
      不过现在想知道在RK3588S的coolpi上是否也是一样的启动流程,如果地址或者流程不一样的话,能否告知一下coolpi 4b的启动流程呢
        george @zehui
        @zehui
        启动的流程是一样的,目前uboot的结构如下:
        FIT description: FIT Image with ATF/OP-TEE/U-Boot/MCU
        Created:         Wed Feb 28 09:32:41 2024
         Image 0 (uboot)
          Description:  U-Boot
          Type:         Standalone Program
          Compression:  uncompressed
          Data Size:    1389728 Bytes = 1357.16 KiB = 1.33 MiB
          Architecture: AArch64
          Load Address: 0x00200000
          Entry Point:  unavailable
          Hash algo:    sha256
          Hash value:   e8eeabe5b2891390396b4cb77a33c5bb8da03b1da33a64274a077cf386f2b5aa
         Image 1 (atf-1)
          Description:  ARM Trusted Firmware
          Type:         Firmware
          Data Size:    200008 Bytes = 195.32 KiB = 0.19 MiB
          Load Address: 0x00040000
          Hash algo:    sha256
          Hash value:   c902200be1343fe569e54778c286005b1c6163606664c463a24d787be4376966
         Image 2 (atf-2)
          Type:         Firmware
          Data Size:    24576 Bytes = 24.00 KiB = 0.02 MiB
          Load Address: 0xff100000
          Hash algo:    sha256
          Hash value:   225d6bf0712f850648223365ba06a73ba5f6315fb8a9580f23ab48ece795f91e
         Image 3 (atf-3)
          Type:         Firmware
          Load Address: 0x000f0000
          Hash algo:    sha256
          Hash value:   aa71013e72d7ab4be264c1093b155ef06e65d0a263d552be25b13c8ddf285586
         Image 4 (optee)
          Description:  OP-TEE
          Type:         Firmware
          Data Size:    465304 Bytes = 454.40 KiB = 0.44 MiB
          Load Address: 0x08400000
          Hash algo:    sha256
          Hash value:   66e30bf9e879405a49797aaa6c08ca1c41aa325443e910af42e3df309e65909b
         Image 5 (kern-fdt)
          Description:  cp4/uboot.dtb
          Type:         Flat Device Tree
          Data Size:    141854 Bytes = 138.53 KiB = 0.14 MiB
          Hash algo:    sha256
          Hash value:   ba43bc47ab29f0cbcba25658712ac3d3c6349a30486c76d5b720310e58f02de3
         Image 6 (fdt)
          Description:  U-Boot dtb
          Data Size:    7065 Bytes = 6.90 KiB = 0.01 MiB
          Hash algo:    sha256
          Hash value:   987a71d492c0045c4964bbed7799da0eee5276a2b60b5a1335fc2d37fdfcf944
         Default Configuration: 'conf'
         Configuration 0 (conf)
          Description:  rk3588s-cp4
          Kernel:       unavailable
          Firmware:     atf-1
          FDT:          fdt
                        kern-fdt
          Loadables:    uboot
                        atf-2
                        atf-3
                        optee
        1 Reply Last reply Reply Quote 2
