    AD7606 QT demo
    1 Posts 1 Posters 321 Views
      ad7606.pro
      QT       += core gui
      greaterThan(QT_MAJOR_VERSION, 4): QT += widgets charts
      CONFIG += c++11
      # You can make your code fail to compile if it uses deprecated APIs.
      # In order to do so, uncomment the following line.
      #DEFINES += QT_DISABLE_DEPRECATED_BEFORE=0x060000    # disables all the APIs deprecated before Qt 6.0.0
      SOURCES += \
          main.cpp \
          mainwindow.cpp
      HEADERS += \
          mainwindow.h
      FORMS += \
          mainwindow.ui
      TRANSLATIONS += \
          ad7606_zh_CN.ts
      CONFIG += lrelease
      CONFIG += embed_translations
      # Default rules for deployment.
      qnx: target.path = /tmp/$${TARGET}/bin
      else: unix:!android: target.path = /opt/$${TARGET}/bin
      !isEmpty(target.path): INSTALLS += target
      mainwindow.h
      #ifndef MAINWINDOW_H
      #define MAINWINDOW_H
      #include <QMainWindow>
      #include <QSplineSeries>
      using namespace QtCharts;
      QT_BEGIN_NAMESPACE
      namespace Ui { class MainWindow; }
      QT_END_NAMESPACE
      class MainWindow : public QMainWindow
          Q_OBJECT
      public:
          MainWindow(QWidget *parent = nullptr);
          ~MainWindow();
          void setChart();
          int getValue(char *channel);
      	int getScale();
      	void timerEvent(QTimerEvent *e);
      private slots:
          void on_pushButton_2_clicked();
          void on_pushButton_clicked();
      private:
          Ui::MainWindow *ui;
          QSplineSeries *serials0;
          QSplineSeries *serials1;
          QSplineSeries *serials2;
          QSplineSeries *serials3;
          QSplineSeries *serials4;
          QSplineSeries *serials5;
          QSplineSeries *serials6;
          QSplineSeries *serials7;
          QChart        *chart;
      	int scale;
      	int timerid1;
      	float value[8];
      #endif // MAINWINDOW_H
      mainwindow.cpp
      #include "mainwindow.h"
      #include "ui_mainwindow.h"
      #include <QtCharts>
      #include <QtCharts/QChartView>
      #include <QProcess>
      #include <QString>
      #include <QTimer>
      #include <fcntl.h>
      #include <unistd.h>
      MainWindow::MainWindow(QWidget *parent)
          : QMainWindow(parent)
          , ui(new Ui::MainWindow)
          ui->setupUi(this);
          setChart();
      MainWindow::~MainWindow()
          delete ui;
      void MainWindow::setChart()
        scale = getScale();
        serials0 = new QtCharts::QSplineSeries();
        serials1 = new QtCharts::QSplineSeries();
        serials2 = new QtCharts::QSplineSeries();
        serials3 = new QtCharts::QSplineSeries();
        serials4 = new QtCharts::QSplineSeries();
        serials5 = new QtCharts::QSplineSeries();
        serials6 = new QtCharts::QSplineSeries();
        serials7 = new QtCharts::QSplineSeries();
        chart = new QChart();
        chart->addSeries(serials7);
        chart->createDefaultAxes();
        chart->axisX()->setRange(0, 99);
        chart->axisY()->setRange(-10, 10);
        chart->legend()->hide();
        ui->widget->setChart(chart);
      int MainWindow::getValue(char *channel)
          int dev_fd,ret;
          char DEV_PATH[64];
          char value[5];
      	QString str_data;
          sprintf(DEV_PATH,"/sys/bus/spi/devices/spi0.0/iio:device0/in_voltage%s_raw",channel);
          dev_fd = open(DEV_PATH,O_RDONLY);
          if(dev_fd == -1)
              perror("open channel failed!\n");
              return -1;
          if(read(dev_fd,value,5)<0)
              perror("read channel failed!\n");
              return -1;
          ::close(dev_fd);
      	str_data = QString::fromLocal8Bit(value,5);
          ret = str_data.toInt();
          return ret;
      int MainWindow::getScale()
          int dev_fd;
      	int ret;
          char DEV_PATH[64];
          char value[5];
      	QString str_data;
          sprintf(DEV_PATH,"/sys/bus/spi/devices/spi0.0/iio:device0/in_voltage_scale");
          if(dev_fd == -1)
              perror("open scale failed!\n");
              return -1;
              perror("read scale failed!\n");
              return -1;
          ::close(dev_fd);
          ret = str_data.toFloat()*1000;
          return ret;
      void MainWindow::timerEvent(QTimerEvent *e)
      	int i;
          QVector<QPointF> oldData = serials7->pointsVector();
          QVector<QPointF> data;
      	if (oldData.size() < 100) {
              data = serials7->pointsVector();
      	else {
      		for (i = 1; i < oldData.size(); ++i)
      				data.append(QPointF(i - 1 , oldData.at(i).y()));
      	qint64 size = data.size();
      	for(i = 0; i < 1; ++i){
      		value[7] = getValue("7");
      		data.append(QPointF(i + size, value[7]*scale/1000000));
      	serials7->replace(data);
      void MainWindow::on_pushButton_2_clicked()
      	serials7->clear();
          timerid1 = startTimer(1);
      void MainWindow::on_pushButton_clicked()
      	killTimer(timerid1);
      source code ad7606.zip
