    Ubuntu docker使用
    1 Posts 1 Posters 237 Views
      root@ubuntu:~# snap install docker
      root@ubuntu:~# snap start docker
      Started.
      root@ubuntu:~# snap services
      Service Startup Current Notes
      docker.dockerd enabled active -
      lxd.activate enabled inactive -
      lxd.daemon enabled inactive socket-activated
      root@ubuntu:~#
      root@ubuntu:~# docker info
      Client:
      Context: default
      Debug Mode: false
      Server:
      Containers: 0
      Running: 0
      Paused: 0
      Stopped: 0
      Images: 0
      Server Version: 20.10.14
      Storage Driver: overlay2
      Backing Filesystem: extfs
      Supports d_type: true
      Native Overlay Diff: true
      userxattr: false
      Logging Driver: json-file
      Cgroup Driver: cgroupfs
      Cgroup Version: 1
      Plugins:
      Volume: local
      Network: bridge host ipvlan macvlan null overlay
      Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
      Swarm: inactive
      Runtimes: io.containerd.runc.v2 io.containerd.runtime.v1.linux runc
      Default Runtime: runc
      Init Binary: docker-init
      containerd version: 3df54a852345ae127d1fa3092b95168e4a88e2f8
      runc version:
      init version: de40ad0
      Security Options:
      seccomp
      Profile: default
      Kernel Version: 5.10.66
      Operating System: Ubuntu Core 18
      OSType: linux
      Architecture: aarch64
      CPUs: 8
      Total Memory: 3.634GiB
      Docker Root Dir: /var/snap/docker/common/var-lib-docker
      Debug Mode: false
      Registry: https://index.docker.io/v1/
      Labels:
      Experimental: false
      Insecure Registries:
      127.0.0.0/8
      Live Restore Enabled: false
      root@ubuntu:~#
      root@ubuntu:~# docker pull hello-world
      Using default tag: latest
      latest: Pulling from library/hello-world
      7050e35b49f5: Pull complete
      Digest: sha256:7d246653d0511db2a6b2e0436cfd0e52ac8c066000264b3ce63331ac66dca625
      Status: Downloaded newer image for hello-world:latest
      docker.io/library/hello-world:latest
      root@ubuntu:~#
      root@ubuntu:~# docker run hello-world
      Hello from Docker!
      This message shows that your installation appears to be working correctly.
      To generate this message, Docker took the following steps:
      1. The Docker client contacted the Docker daemon.
      2. The Docker daemon pulled the "hello-world" image from the Docker Hub.
        (arm64v8)
      3. The Docker daemon created a new container from that image which runs the
        executable that produces the output you are currently reading.
      4. The Docker daemon streamed that output to the Docker client, which sent it
        to your terminal.
      To try something more ambitious, you can run an Ubuntu container with:
      $ docker run -it ubuntu bash
      Share images, automate workflows, and more with a free Docker ID:
      https://hub.docker.com/
      For more examples and ideas, visit:
      https://docs.docker.com/get-started/
      root@ubuntu:~#
      • J jack_admin moved this topic from Linux Server Operating System on
