    AIC8800D80 Enable AP Mode
    Scheduled Pinned Locked Moved Pi Gateway CP1B/CP2B/CP3B/CP3B-P
    1 Posts 1 Posters 1.6k Views
      • Install hostapd (requires internet connection)
      sudo apt install hostapd
      • Enable encryption mode for 2.4G hotspot
        Enter the following content, using the 11ax wireless standard, encryption method WPA-PSK, ssid as hotspot name, and wpa_passphrase as custom password, all of which can be modified
      vi /etc/hostapd.conf
      interface=wlan0
      driver=nl80211
      ctrl_interface_group=0
      ctrl_interface=/var/run/hostapd
      beacon_int=100
      ssid=aic_ax_2.4G
      country_code=CN
      channel=6
      hw_mode=g
      ieee80211n=1
      ieee80211ac=1
      ieee80211ax=1
      ht_capab=[HT20][SHORT-GI-20][HT40-][HT40+][SHORT-GI-40]
      wmm_enabled=1
      he_basic_mcs_nss_set=65534
      auth_algs=3
      wpa=3
      wpa_passphrase=1234567890
      wpa_key_mgmt=WPA-PSK
      wpa_pairwise=CCMP
      rsn_pairwise=CCMP
      • Add Address Resolution
       vi /etc/dnsmasq.conf
      # Only monitor the AP interface
      interface=wlan0
      bind-interfaces
      # DHCP configuration
      dhcp-range=192.168.11.2,192.168.11.20,255.255.255.0,24h
      dhcp-option=3,192.168.11.1
      dhcp-option=6,8.8.8.8,114.114.114.114
      resolv-file=/etc/dnsmasq/resolv.conf
      • Create /etc/dnsmasq/resol.conf
      mkdir -p /etc/dnsmasq
      vi /etc/dnsmasq/resolv.conf
      nameserver 8.8.8.8
      nameserver 8.8.4.4
      • Create script to enable AP mode
      vi /usr/bin/start_wifi_ap.sh
      #!/bin/bash
      ## Search for network interfaces starting with wlan
      WIFI_IFACE=wlan0
      # Configure IP address
      ifconfig $WIFI_IFACE 192.168.11.1 up
      # Start hostapd
      hostapd /etc/hostapd.conf -dd &
      # Start dnsmasq
      touch /var/lib/misc/udhcp.leases
      dnsmasq -i $WIFI_IFACE -C /etc/dnsmasq.conf &
      echo "AIC WiFi AP started on interface $WIFI_IFACE"
      Modify permissions
      chmod a+x /usr/bin/start_wifi_ap.sh
      • Add IP forwarding rules
      sudo sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward"
      • Edit /etc/sysctl.d/10-network-security.conf and add the following line
      net.ipv4.ip_forward=1
      • Effective operation
      sudo sysctl -p
      • Download Iptables (requires internet connection, can be skipped if installed at the top)
      sudo apt install iptables-persistent
      • Add rule
      sudo update-alternatives --set iptables /usr/sbin/iptables-legacy
      sudo update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy
      iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
      sudo iptables -A FORWARD -i wlan0 -o eth0 -j ACCEPT
      sudo iptables -A FORWARD -i eth0 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
      • Afterwards, every time the AP is turned on, it can be started through the startw_ifi_ip.sh script. If you want it to start automatically, please add a service to implement it yourself.
      admin@cp2b:~$ sudo start_wifi_ap.sh
      [sudo] password for admin:
      AIC WiFi AP started on interface wlan0
