    how about batocera with cool pi 4b
    41 Posts 6 Posters 20.0k Views
    • C
      cyberwisk @大法师
      @大法师 Muito obrigado pela ajuda, os meus conhecimentos em compilação e kernel e instalação de drivers no Linux é limitado voce pode ajudar ?
      onde eu baixo o AIC8800 firmware ?
      qual o procedimento de instalção no Batocera linux ?
      Se não for muito trabalho voce pode por favor aplicar o Path na iso abaixo:
      batocera-rk3588s-coolpi-4b-37-noBTnoWifi.7z
      Essa versão funiona muito bem menos o WIFI e TB, voce pode substituir pela iso que esta no seu site, já que ela não funciona corretamente.
      mais uma vez muito obrigado pelo Suporte
        大法师 @cyberwisk
        @cyberwisk
        https://github.com/yanyitech/ubuntu/tree/main/bin/wifi/aic8800
          Macs @大法师
          @大法师 it's not working even adding the AIC8800 drivers and the scripts, wifi card is not recognised.
          C 1 Reply Last reply Reply Quote 0
          • C
            carloshenrique @Macs
            @Macs I tested here by adding the files to the Driver directories and it didn't work. I decided to wait for version 38 of Batocera, as I don't know how to compile it. I'm looking forward to the possibility of using GPIO as well.
              jack_admin @jack_admin
              @jack_admin said in how about batocera with cool pi 4b:
              Test firmware link
              百度网盘 batocera36
              Onedrive coolpi4b batocera36
              @Macs have you test version 36?
                Macs @jack_admin
                @jack_admin yes , there wifi works but my 8bitdo controller is not recognised and the audio is not working. Instead in the 37 from @cyberwisk audio is ok and controller too, but it's missing the wifi.
                The majority of games freeze at start, maybe due to the issue of audio not being present, managed to make start only snes, but I did not go deeper seen so many issue present.
                • C
                  carloshenrique
                  Greetings! When will the Batocera 38 version for Cool Pi be released?
                  Saudações! Quando a versão do Batocera 38 para a Cool Pi será liberada?
                    Macs @jack_admin
                    @jack_admin I got the controller working on 46 but still no audio. On 37 the wifi still does not work even with the driver installed. I suspect because the driver was for the previous kernel on 36 and the is not compatible with 37.
                      jack_admin @Macs
                      @Macs @carloshenrique I'll verify that version 38 wireless network and audio capabilities.
                      M 大法师大 2 Replies Last reply Reply Quote 1
                        Macs @jack_admin
                        thanks a lot!
                          大法师 @jack_admin
                          Support Wifi & Audio
                          链接: https://pan.baidu.com/s/13UmH2nb6W35Gn5aL12qyiQ 提取码: qlc9
                          C 1 Reply Last reply Reply Quote 1
                          • C
                            carloshenrique @大法师
                            @大法师 said in how about batocera with cool pi 4b:
                            qlc9
                            Can anyone make this image available on another website so I can download it? I will do several tests and post them here so that we can continue to evolve this project. Thank you very much for your contribution and effort!
                              jack_admin @carloshenrique
                              @carloshenrique
                              https://github.com/yanyitech/batocera-coolpi-linux/releases/tag/V1.0
                              C 2 Replies Last reply Reply Quote 2
                              • C
                                cyberwisk @jack_admin
                                @jack_admin Parabens e muito obrigado! graças ao seu trabalho posso aposentar os adaptadores externos, o Batocera funciona perfeitamente na Placa Cool-Pi, fico feliz foi uma ótima compra, esse é meu retroconsole definitivo.
                                1 Reply Last reply Reply Quote 3
                                • C
                                  carloshenrique @cyberwisk
                                  @cyberwisk
                                  Bom dia! Quando possível testa a versão 39. Baixei o arquivo BOOT.TAR da versão Orange PI 5, substitui o arquivo boot/batocera ele mostra a imagem do Batocera e fica congelado, não chega no vídeo
                                  Peguei uma Raspberry Pi5 para testes e comparação e a Cool Pi 4 bate ela em vários aspectos:
                                  CPU, GPU, saída P2, porta para EMMC, wifi 6, NPU, vídeo 8K...
                                  A Cool Pi 4 é a placa definitiva até esse momento pra retro emulação na minha opinião.
                                  • C
                                    carloshenrique
                                    Fazendo testes aqui percebi que se mudar a resolução de "Automático" em:
                                    Ajustes de Jogos-> Modo de vídeo
                                    Sempre ao abrir um jogo o sistema congela.
                                    Doing tests here I noticed that if you change the resolution from "Automatic" to:
                                    Game Settings-> Video Mode
                                    Whenever opening a game the system freezes.
                                    • C
                                      carloshenrique
                                      Greetings! Can you please update the version? The Batocera 40 for Orange PI5 has been made available.
                                      Thank you very much!
                                      • C
                                        @jack_admin Can you please update the version? The Batocera 41 for Orange PI5 has been made available.
                                        • C
                                          cyberwisk @carloshenrique
                                          @carloshenrique
                                          https://mirrors.o2switch.fr/batocera/coolpi-4b/stable/rc/
                                          • 2 / 3
