    Connecting a dsi display
    6 Posts 2 Posters 1.6k Views
      alfek
      how do I need to change rk3588-cpcm5-evb.dts to make dsi0 work? I plan to put i2c on C0, C1?
        george @alfek
        @alfek
        The DSI node can be enabled as follows.I didn't understand which GPIO C0 C1 corresponds to, please indicate.
        diff --git a/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb-v11.dts b/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb-v11.dts
        index 5f52819c2e9b..fa505ddfe99d 100755
        --- a/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb-v11.dts
        +++ b/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb-v11.dts
        @@ -526,7 +526,7 @@ &sdmmc {
         &dsi0 {
        -       status = "disabled";
        +       status = "okay";
                dsi0_panel: panel@0 {
                        compatible = "simple-panel-dsi";
        @@ -779,7 +779,7 @@ &dsi0_in_vp3 {
         &route_dsi0 {
        +       status = "okay";
                connect = <&vp3_out_dsi0>;
          alfek @george
          @george yes, sorry, I didn't specify
          I plan to use GPIO1_C0_1V8_U and GPIO1_C0_1V8_U
          And can you tell me how I can convert the corrected dts to dtb? It doesn't work with dtc, as far as I understand, because of include dependencies
            george @alfek
            @alfek
            • First, synchronize the code using the following command:
            https://github.com/yanyitech/coolpi-kernel.git
            • Open the corresponding DTS file and modify the DSI related configuration
            vim arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb.dts
            &dsi0 {
                    //rockchip,lane-rate = <1000>;
                            reg = <0>;
                            backlight = <&backlight>;
                            reset-delay-ms = <10>;
                            enable-delay-ms = <10>;
                            prepare-delay-ms = <10>;
                            unprepare-delay-ms = <10>;
                            disable-delay-ms = <60>;
                            dsi,flags = <(MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_VIDEO_BURST |
                                    MIPI_DSI_MODE_LPM | MIPI_DSI_MODE_EOT_PACKET)>;
                            dsi,format = <MIPI_DSI_FMT_RGB888>;
                            dsi,lanes  = <4>;
                            panel-init-sequence = [
                                    05 78 01 11
                                    05 00 01 29
                            panel-exit-sequence = [
                                    05 00 01 28
                                    05 00 01 10
            • Use the following command to recompile the kernel
             ./build-kernel.sh
            Welcome to using Coolpi Development Board!
            Please enter a number to select your machine
            1. cp4b
            2. cp4b-hdmi-in
            3. cm5-evb
            4. cm5-evb-v11
            5. cm5-minipc
            6. cm5-notebook
            7. cm5-notebook-v20
            8. cm5-8uart
            9. cpnano
            10. exit
            Enter option number: 3
            BOARD=cm5-evb
              HOSTCC  scripts/basic/fixdep
              HOSTCC  scripts/kconfig/conf.o
              HOSTCC  scripts/kconfig/confdata.o
              HOSTCC  scripts/kconfig/expr.o
              LEX     scripts/kconfig/lexer.lex.c
              YACC    scripts/kconfig/parser.tab.[ch]
              HOSTCC  scripts/kconfig/lexer.lex.o
              HOSTCC  scripts/kconfig/menu.o
              HOSTCC  scripts/kconfig/parser.tab.o
              HOSTCC  scripts/kconfig/preprocess.o
              HOSTCC  scripts/kconfig/symbol.o
              HOSTCC  scripts/kconfig/util.o
              HOSTLD  scripts/kconfig/conf
            # configuration written to .config
              SYNC    include/config/auto.conf.cmd
              HOSTCC  scripts/dtc/dtc.o
              HOSTCC  scripts/dtc/flattree.o
              HOSTCC  scripts/dtc/fstree.o
              HOSTCC  scripts/dtc/data.o
              HOSTCC  scripts/dtc/livetree.o
              HOSTCC  scripts/dtc/treesource.o
              HOSTCC  scripts/dtc/srcpos.o
              HOSTCC  scripts/dtc/checks.o
              HOSTCC  scripts/dtc/util.o
              LEX     scripts/dtc/dtc-lexer.lex.c
              YACC    scripts/dtc/dtc-parser.tab.[ch]
              HOSTCC  scripts/dtc/libfdt/fdt.o
              HOSTCC  scripts/dtc/libfdt/fdt_ro.o
              HOSTCC  scripts/dtc/libfdt/fdt_wip.o
              HOSTCC  scripts/dtc/libfdt/fdt_sw.o
              HOSTCC  scripts/dtc/libfdt/fdt_rw.o
              HOSTCC  scripts/dtc/libfdt/fdt_strerror.o
              HOSTCC  scripts/dtc/libfdt/fdt_empty_tree.o
              HOSTCC  scripts/dtc/libfdt/fdt_addresses.o
              HOSTCC  scripts/dtc/libfdt/fdt_overlay.o
              HOSTCC  scripts/dtc/fdtoverlay.o
              HOSTCC  scripts/dtc/dtc-lexer.lex.o
              HOSTCC  scripts/dtc/dtc-parser.tab.o
            • Update the dtb file to the /boot/firmware directory
            A 2 Replies Last reply Reply Quote 0
              alfek @george
              @george thank you, it worked.
              How can I customize screen resolution? 800x480. And how do I still configure i2c?
                alfek @george
                Could you help? does it give this error when connecting?
                [ 8.515533] dw-mipi-dsi2 fde20000.dsi: [drm:dw_mipi_dsi2_bind] ERROR Failed to find panel or bridge: -517
