    HDMI接口新增特殊分辨率时序
    7 Posts 2 Posters 1.1k Views
      DRM 框架目前代码已经支持了绝大部分分辨率时序,但是部分 HDMI 屏幕旋转的场景下,可能还有一些特殊分辨率不支持。需要在 kernel\drivers\gpu\drm\drm_edid.c 中的drm_dmt_modes 的末尾新增项目:
      /* 0x58 - 4096x2160@59.94Hz RB */
      { DRM_MODE("4096x2160", DRM_MODE_TYPE_DRIVER, 556188, 4096, 4104,
      4136, 4176, 0, 2160, 2208, 2216, 2222, 0,
      DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_NVSYNC) },
      顾 3 Replies Last reply Reply Quote 0
      • 顾
        顾真牛 @george
        @george 像素时钟 Pixel Clock 去查是三位数。。。是不是后面直接加三个零?
        • 顾
          顾真牛 @george
          添加了下面 几行,然并卵
          	/* 0x59 - 3840x1080@120Hz RB */
          	{ DRM_MODE("3840x1080", DRM_MODE_TYPE_DRIVER, 540000, 3840, 3848,
          		   3880, 3920, 0, 1080, 1130, 1138, 1144, 0,
          	/* 0x60 - 3840x1100@60Hz RB */
          	{ DRM_MODE("3840x1100", DRM_MODE_TYPE_DRIVER, 282890, 3840, 3848,
          		   3880, 3920, 0, 1100, 1118, 1126, 1132, 0,
          edid信息如下
          Detailed Timing Descriptors:
          DTD 1: 3840x1100 59.998 Hz 192:55 68.998 kHz 282.890 MHz (1196 mm x 336 mm)
          Hfront 48 Hsync 32 Hback 180 Hpol P
          Vfront 3 Vsync 5 Vback 42 Vpol N
          Display Range Limits:
          Monitor ranges (GTF): 48-120 Hz V, 30-180 kHz H, max dotclock 600 MHz
          DTD 2: 3840x1080 120.000 Hz 32:9 135.000 kHz 540.000 MHz (1196 mm x 336 mm)
          Hfront 48 Hsync 64 Hback 48 Hpol P
          Vfront 3 Vsync 10 Vback 32 Vpol N
          Display Product Name: 'HDMI'
          Extension blocks: 1
          Checksum: 0x24
          我这应该怎么填?
          • 顾
            顾真牛 @george
            https://www.cool-pi.com/topic/131/coolpi-4b-linux-kernel开发在线更新说明?_=1680497887440
            用这个更新内核没错吧?? 似乎没啥效果啊
            根据
            最终添加了一个
            	/* 0x59 - 3840x1100@60Hz RB */
            	{ DRM_MODE("3840x1100", DRM_MODE_TYPE_DRIVER, 282890, 3840, 3888,
            		   4068, 4224, 0, 1100, 1103, 1108, 1108, 0,
              george @顾真牛
              @顾真牛 插拔HDMI然后打印dmesg发上来。
              顾 1 Reply Last reply Reply Quote 0
              • 顾
                顾真牛 @george
                @george dmesg.txt
                  george @顾真牛
                  @顾真牛 改为动态分频测试一下
                  diff --git a/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb.dts b/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb.dts
                  index da170f0b2086..3f01ba675516 100644
                  --- a/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb.dts
                  +++ b/arch/arm64/boot/dts/rockchip/rk3588-cpcm5-evb.dts
                  @@ -1015,6 +1015,10 @@ &hdptxphy_hdmi0 {
                  +&hdptxphy_hdmi_clk0 {
                  +status = "okay";
                   #if 1
                   &hdmi1 {
                          enable-gpios = <&gpio4 RK_PB2 GPIO_ACTIVE_HIGH>;
                  @@ -1044,6 +1048,10 @@ &route_hdmi1 {
                   &hdptxphy_hdmi1 {
                  +&hdptxphy_hdmi_clk1 {
                  +status = "okay";
                   #endif
                   &dp0 {
                  @@ -1304,6 +1312,8 @@ &uart2 {
                   &display_subsystem {
                  +       clocks = <&hdptxphy_hdmi_clk0>, <&hdptxphy_hdmi_clk1>;
                  +       clock-names = "hdmi0_phy_pll", "hdmi1_phy_pll";
                          memory-region = <&drm_logo>;
                          memory-region-names = "drm-logo";
