    Coolpi 4b Ubuntu20.04 原生系统
    41 Posts 10 Posters 13.0k Views
      myhexb @george
      @george 嫊-oZp@fde50000 disconnected
      hdmi@fde80000 disconnected
      trsv ln0 mon rx cdr lock timeout
      dp@fde50000 disconnected
      scanning usb for storage devices... 0 Storage Device(s) found
      Device 0: unknown device
      mmc1 is current device
      Scanning mmc 1:1...
      287 bytes read in 8 ms (34.2 KiB/s)
      1: Ubuntu coolpi
      8775086 bytes read in 709 ms (11.8 MiB/s)
      37294592 bytes read in 2992 ms (11.9 MiB/s)
      append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n81 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:52:84:fe:01:16:93
      Retrieving file: /rk3588s-cp4.dtb
      reading /rk3588s-cp4.dtb
      141784 bytes read in 18 ms (7.5 MiB/s)
      Flattened Device Tree blob at 0x0a100000
      Loading Ramdisk to eb176000, end eb9d45ae ... OK
      Loading Device Tree to 00000000eb150000, end 00000000eb1759d7 ... OK
      [ 8.386768] rk-pcie fe190000.pcie: IRQ msi not found
      [ 8.386784] rk-pcie fe190000.pcie: Missing config reg space
      [ 8.386875] rk-pcie fe190000.pcie: Missing config reg space
      [ 8.386902] rk-pcie fe190000.pcie: invalid resource
      [ 8.389687] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
      [ 8.390791] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
      [ 8.390796] rkvdec2_init:1010: No niu aclk reset resource define
      [ 8.390799] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
      [ 8.390802] rkvdec2_init:1013: No niu hclk reset resource define
      [ 8.391320] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
      [ 8.391324] rkvdec2_init:1010: No niu aclk reset resource define
      [ 8.391327] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
      [ 8.391330] rkvdec2_init:1013: No niu hclk reset resource define
      [ 8.393004] mpp_iommu_probe:434: failed to get device node
      [ 8.393008] mpp_av1dec av1d-master: failed to attach iommu
      [ 8.517456] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
      [ 8.525303] rockchip-drm display-subsystem: failed to show kernel logo
      [ 8.704582] rk806 spi2.0: no sleep-setting state
      [ 8.709201] rk806 spi2.0: no reset-setting pinctrl state
      [ 8.714503] rk806 spi2.0: no dvs-setting pinctrl state
      [ 8.926386] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
      [ 8.933738] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
      [ 8.941087] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
      [ 8.948434] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
      [ 8.955782] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
      [ 8.962994] tinker-mcu: send_cmds: send command failed
      [ 8.968123] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
      [ 9.539506] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
      [ 9.620266] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
      [ 9.630200] debugfs: File 'Capture' in directory 'dapm' already present!
      [ 9.652203] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
      [ 9.851268] ov5647 8-0036: Unsupported clock frequency: 24000000
      [ 9.991259] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
      [ 9.998472] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
      [ 10.005768] debugfs: File 'HPCP L' in directory 'dapm' already present!
      [ 10.012367] debugfs: File 'HPCP R' in directory 'dapm' already present!
      [ 10.018969] debugfs: File 'HPVOL L' in directory 'dapm' already present!
      [ 10.025654] debugfs: File 'HPVOL R' in directory 'dapm' already present!
      [ 10.034611] rockchip_headset rk-headset: Can not read property headset_gpio
      [ 10.042867] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
      [ 10.051384] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
      [ 10.059894] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
      [ 10.072022] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
      [ 10.100903] RKNPU fdab0000.npu: failed to find power_model node
      [ 10.106814] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
      [ 10.113414] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
      Gave up waiting for root file system device. Common problems:
      • Boot args (cat /proc/cmdline)
        • Check rootdelay= (did the system wait long enough?)
      • Missing modules (cat /proc/modules; ls /dev)
        ALERT! LABEL=writable does not exist. Dropping to a shell!
      BusyBox v1.30.1 (Ubuntu 1:1.30.1-7ubuntu3) built-in shell (ash)
      Enter 'help' for a list of built-in commands.
      (initramfs)
        myhexb @george
        @george DDR V1.09 a930779e06 typ 22/11/21-17:50:56
        LPDDR4X, 2112MHz
        channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 D镈DR V1.09 a930779e06 typ 22/11/21-17:50:56
        LPDDR4X, 2112MHz
        channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
        channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
        channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
        channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
        Manufacturer ID:0xff
        CH0 RX Vref:29.7%, TX Vref:21.8%,21.8%
        CH1 RX Vref:30.7%, TX Vref:21.8%,22.8%
        CH2 RX Vref:30.7%, TX Vref:20.8%,20.8%
        CH3 RX Vref:29.7%, TX Vref:22.8%,22.8%
        change to F1: 528MHz
        change to F2: 1068MHz
        change to F3: 1560MHz
        change to F0: 2112MHz
        INFO: Preloader serial: 2
        NOTICE: BL31: v2.3():v2.3-481-g17b41886e:derrick.huang
        NOTICE: BL31: Built : 16:20:07, Dec 7 2022
        INFO: spec: 0x13
        INFO: ext 32k is not valid
        INFO: ddr: stride-en 4CH
        INFO: GICv3 without legacy support detected.
        INFO: ARM GICv3 driver initialized in EL3
        INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
        INFO: system boots from cpu-hwid-0
        INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
        INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
        INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
        INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
        INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
        INFO: BL31: Initialising Exception Handling Framework
        INFO: BL31: Initializing runtime services
        INFO: BL31: Initializing BL32
        INFO: hdmirx_handler: dma not on, ret
        I/TC:
        I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022骞?09鏈?20鏃?鏄熸湡浜?09:41:09 CST aarch64
        INFO: BL31: Preparing for EL3 exit to normal world
        INFO: Entry point address = 0x200000
        INFO: SPSR = 0x3c9
        COOLPI LOADER BY YANYI(Jan 04 2023)
        DRAM: 8 GiB
        0 2 1 3 6 8 7 9 trsv ln0 mon rx cdr lock timeout
        Failed to mount ext2 filesystem...
        ** Unrecognized filesystem type **
        Card did not respond to voltage select!
        mmc_init: -95, time 17
        Loading order: usb - tf - emmc
        bank id invalid
        request for 141 failed:-22
        bank id invalid
        resetting USB...
        ** Bad device usb 0 **
        mmc_init: -95, time 16
        ** Bad device mmc 0 **
        LPDDR4X, 2112MHz
        CH0 RX Vref:30.7%, TX Vref:21.8%,21.8%
        CH1 RX Vref:30.7%, TX Vref:22.8%,21.8%
        CH3 RX Vref:30.7%, TX Vref:22.8%,22.8%
        INFO: spec: 0x13
        INFO: ext 32k is valid
        I/TC:
        INFO: SPSR = 0x3c9
        DRAM: 8 GiB
        bank id invalid
        bank id invalid
        resetting USB...
        这个是完全启动 不起来的日志
          george @myhexb
          @myhexb 这个是镜像没有制作成功。如果有读卡器可以先格式化一次卡,然后再制作,闪迪的卡我一直在用,没有什么问题。
            myhexb @george
            @george 第一张闪迪卡各种方式格式化 试了4 5次了 ,第二张也试了一次 还是不行
              george @myhexb
              @myhexb 可以换个镜像再测试。从log看的情况就是卡没有识别到或者rootfs没有成功挂载。
                myhexb @george
                @george 换22.04 也还是一样的情况
                  大法师 @myhexb
                  @myhexb 用读卡器连接,插在USB3下层端口,启动试试
                  M 2 Replies Last reply Reply Quote 0
                    myhexb @大法师
                    @大法师 试了 usb插 硬盘盒子和 读卡器 还是只有京东卡可以启动,闪迪卡可以找到卡 但不能启动 ,重做和换镜像文件都没成功,0 2 1 3 6 8 7 9 trsv ln0 mon rx cdr lock timeout
                    scanning bus usb@fc880000 for devices... 2 USB Device(s) found
                    scanning usb for storage devices... 1 Storage Device(s) found
                    Device 0: Vendor: Generic Rev: 1532 Prod: STORAGE DEVICE
                    Type: Removable Hard Disk
                    Capacity: 60906.0 MB = 59.4 GB (124735488 x 512)
                      myhexb @大法师
                      @大法师 硬盘盒子干脆就找不到usb设备 ,
                        大法师 @myhexb
                        @myhexb said in Coolpi 4b Ubuntu20.04 原生系统:
                        硬盘盒需要更新loader,且需要注意适配器供电功率
                        https://www.cool-pi.com/topic/170/coolpi-4b-loading-from-usb-ssd
                          大法师 @myhexb
                          能找到卡,不能启动,可能与分区表有关,请参考
                          https://www.cool-pi.com/topic/168/如果制作的启动盘无法加载/3
                            myhexb @大法师
                            找不到设备,数据线也换了两根了 就是读不到,设备管理器也看不到有设备
                              jack_admin @myhexb
                              @myhexb usb线插上面那个蓝色USB端口。另外驱动安装后,重启系统试试
                                myhexb @jack_admin
                                @jack_admin 都试了 , 重启 换线 换口 短接MASKROM和地 重装驱动
                                  jack_admin @myhexb
                                  @myhexb
                                  有些usb数据线是只供电的,不带数据信号。请确认一下
                                    myhexb @jack_admin
                                    @jack_admin 试了两根 万用表测4个触点通断也没问题,
                                      george @myhexb
                                      @myhexb 联系一下代理商,申请售后。
                                        bg8wj
                                        新的系统映像能跟新以下 树莓派摄像头和AP+sta的内核码,测试安装了ap+sta 的驱动后摄像头 ov56XX 不工作了。测试Create_ap无法运行,定位到摄像头和wifi 不能同时工作。
                                          jack_admin @bg8wj
                                          @bg8wj 哪个版本镜像
                                            bg8wj @jack_admin
                                            @jack_admin ubuntu20.04 20230116的
                                            • 2 / 3
