    每个开发者都需要的私有化git服务器
    2 Posts 1 Posters 1.3k Views
      基于Coolpi 4B搭建流行的gitlab服务器,一步到位。
      gitlab_install.sh
      ubuntu@coolpi:~$ ./gitlab_install.sh
      libcurl4 was already not on hold.
      Reading package lists... Done
      Building dependency tree... Done
      Reading state information... Done
      curl is already the newest version (7.81.0-1ubuntu1.6).
      0 upgraded, 0 newly installed, 0 to remove and 230 not upgraded.
      Detected operating system as Ubuntu/jammy.
      Checking for curl...
      Detected curl...
      Checking for gpg...
      Detected gpg...
      Running apt-get update... done.
      Installing apt-transport-https... done.
      Installing /etc/apt/sources.list.d/gitlab_gitlab-ce.list...done.
      Importing packagecloud gpg key... done.
      The repository is setup! You can now install packages.
      ubuntu@coolpi:~$
      选择你需要的版本,安装它
      ubuntu@coolpi:~$ sudo apt install gitlab-ce=15.6.0-ce.0
      The following NEW packages will be installed:
        gitlab-ce
      0 upgraded, 1 newly installed, 0 to remove and 230 not upgraded.
      Need to get 1,148 MB of archives.
      After this operation, 3,869 MB of additional disk space will be used.
      Get:1 https://packages.gitlab.com/gitlab/gitlab-ce/ubuntu jammy/main arm64 gitlab-ce arm64 15.6.0-ce.0 [1,148 MB]
      Fetched 1,148 MB in 1min 10s (16.3 MB/s)
      Selecting previously unselected package gitlab-ce.
      (Reading database ... 148928 files and directories currently installed.)
      Preparing to unpack .../gitlab-ce_15.6.0-ce.0_arm64.deb ...
      Unpacking gitlab-ce (15.6.0-ce.0) ...
      Setting up gitlab-ce (15.6.0-ce.0) ...
      It looks like GitLab has not been configured yet; skipping the upgrade script.
           _______ __  __          __
          / ____(_) /_/ /   ____ _/ /_
         / / __/ / __/ /   / __ `/ __ \
        / /_/ / / /_/ /___/ /_/ / /_/ /
        \____/_/\__/_____/\__,_/_.___/
      Thank you for installing GitLab!
      GitLab was unable to detect a valid hostname for your instance.
      Please configure a URL for your GitLab instance by setting `external_url`
      configuration in /etc/gitlab/gitlab.rb file.
      Then, you can start your GitLab instance by running the following command:
        sudo gitlab-ctl reconfigure
      For a comprehensive list of configuration options please see the Omnibus GitLab
      readme
      https://gitlab.com/gitlab-org/omnibus-gitlab/blob/master/README.md
      Help us improve the installation experience, let us know how we did with a 1 min
      ute survey:
      https://gitlab.fra1.qualtrics.com/jfe/form/SV_6kVqZANThUQ1bZb?installation=omnib
      us&release=15-6
      ubuntu@coolpi:~$
      修改默认配置文件,重新部署初始化配置
      ubuntu@coolpi:~$ sudo vim /etc/gitlab/gitlab.rb
      #external_url 'http://gitlab.example.com'
      external_url 'http://192.168.1.172'
      ubuntu@coolpi:~$ sudo gitlab-ctl reconfigure
      Notes:
      Default admin account has been configured with following details:
      Username: root
      Password: You didn't opt-in to print initial root password to STDOUT.
      Password stored to /etc/gitlab/initial_root_password. This file will be cleaned up in first reconfigure run after 24 hours.
      NOTE: Because these credentials might be present in your log files in plain text, it is highly recommended to reset the password following https://docs.gitlab.com/ee/security/reset_user_password.html#reset-your-root-password.
      gitlab Reconfigured!
      初始root用户密码请查看文件
      ubuntu@coolpi:~$ sudo cat /etc/gitlab/initial_root_password
      [sudo] password for ubuntu:
      # WARNING: This value is valid only in the following conditions
      #          1. If provided manually (either via `GITLAB_ROOT_PASSWORD` environment variable or via `gitlab_rails['initial_root_password']` setting in `gitlab.rb`, it was provided before database was seeded for the first time (usually, the first reconfigure run).
      #          2. Password hasn't been changed manually, either via UI or via command line.
      #          If the password shown here doesn't work, you must reset the admin password following https://docs.gitlab.com/ee/security/reset_user_password.html#reset-your-root-password.
      Password: HQQY3tBsOGOW2jd2gmiLDROf3fEnKH8CW3ZFnikPlHg=
      # NOTE: This file will be automatically deleted in the first reconfigure run after 24 hours.
      浏览器访问http://localhost 或者 http://192.168.1.172
      大法师大 1 Reply Last reply Reply Quote 1
        大法师 @大法师
        nice board for server!
