    CM5如何安装网卡驱动?
    39 Posts 5 Posters 11.3k Views
      Jachyn @Jachyn
      root@coolpi:/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0# ./install.pl
      Logs dir: /tmp/OFED.127412.logs
      General log file: /tmp/OFED.127412.logs/general.log
      Below is the list of OFED packages that you have chosen
      (some may have been added by the installer due to package dependencies):
      ofed-scripts
      mlnx-tools
      mlnx-ofed-kernel-utils
      mlnx-ofed-kernel-modules
      srp-modules
      mlnx-nvme-modules
      rdma-core
      libibverbs1
      ibverbs-utils
      ibverbs-providers
      libibverbs-dev
      libibverbs1-dbg
      libibumad3
      libibumad-dev
      ibacm
      librdmacm1
      rdmacm-utils
      librdmacm-dev
      mstflint
      libibmad5
      libibmad-dev
      libibnetdisc5
      infiniband-diags
      kernel-mft-modules
      perftest
      ibsim
      ibsim-doc
      ucx
      openmpi
      mpitests
      knem-modules
      srptools
      mlnx-ethtool
      mlnx-iproute2
      rshim
      ibarr
      Checking SW Requirements...
      One or more required packages for installing OFED-internal are missing.
      Attempting to install the following missing packages:
      build-essential autotools-dev pkg-config  python3-docutils debhelper libstdc++6 pandoc bison dh-autoreconf devscripts libmnl-dev fakeroot libgfortran5 cython3 libnuma-dev libnl-route-3-dev libssl-dev python3-dev libnl-3-dev autoconf quilt libfuse-dev python3-distutils flex libsystemd-dev libselinux1-dev libudev-dev dh-python cmake libpci-dev sudo make libdb-dev libusb-1.0-0-dev libelf-dev libtool valgrind python3 gcc bzip2
      This program will install the OFED package on your machine.
      Note that all other Mellanox, OEM, OFED, RDMA or Distribution IB packages will be removed.
      Those packages are removed due to conflicts with OFED, do not reinstall them.
      Removing old packages
      get_requires: libibverbs1 is required by qemu-system-arm, but qemu-system-arm won't be removed.
      get_requires: librdmacm1 is required by qemu-system-arm, but qemu-system-arm won't be removed.
      Error: One or more packages depends on MLNX_OFED.
      Those packages should be removed before uninstalling MLNX_OFED:
      licensecheck libarray-intspan-perl
      To force uninstallation use '--force' flag.
      root@coolpi:/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0# ./install.pl --force
      Logs dir: /tmp/OFED.129276.logs
      General log file: /tmp/OFED.129276.logs/general.log
      ofed-scripts
      mlnx-tools
      srp-modules
      mlnx-nvme-modules
      rdma-core
      libibverbs1
      ibverbs-utils
      ibverbs-providers
      libibverbs-dev
      libibverbs1-dbg
      libibumad3
      libibumad-dev
      ibacm
      librdmacm1
      rdmacm-utils
      librdmacm-dev
      mstflint
      libibmad5
      libibmad-dev
      libibnetdisc5
      infiniband-diags
      kernel-mft-modules
      perftest
      ibsim
      ibsim-doc
      ucx
      openmpi
      mpitests
      knem-modules
      srptools
      mlnx-ethtool
      mlnx-iproute2
      rshim
      ibarr
      flex libelf-dev fakeroot autoconf autotools-dev dh-python libtool libfuse-dev sudo debhelper python3-docutils libnl-route-3-dev pandoc bison libselinux1-dev quilt python3 libgfortran5 build-essential valgrind libsystemd-dev libssl-dev cmake libnl-3-dev libudev-dev cython3 python3-distutils libdb-dev libpci-dev python3-dev  devscripts bzip2 libmnl-dev gcc libstdc++6 pkg-config libnuma-dev libusb-1.0-0-dev make dh-autoreconf
      Building packages
      Building DEB for ofed-scripts-23.04 (ofed-scripts)...
      Running  /usr/bin/dpkg-buildpackage -us -uc
      Installing ofed-scripts-23.04...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ofed-scripts_23.04-OFED.23.04.1.1.3_arm64.deb'
      Building DEB for mlnx-tools-23.04 (mlnx-tools)...
      Installing mlnx-tools-23.04...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-tools_23.04-0.2304053_arm64.deb'
      Building DEB for mlnx-ofed-kernel-utils-23.04 (mlnx-ofed-kernel)...
      Running  /usr/bin/dpkg-buildpackage -us -uc  -Pmodules
      Installing mlnx-ofed-kernel-utils-23.04...
      Running /usr/bin/dpkg -i --force-confnew --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-ofed-kernel-utils_23.04-OFED.23.04.1.1.3.1.kver.5.10.110_arm64.deb'
      Installing mlnx-ofed-kernel-modules-23.04...
      Running /usr/bin/dpkg -i --force-confnew --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-ofed-kernel-modules_23.04-OFED.23.04.1.1.3.1.kver.5.10.110_arm64.deb'
      Building DEB for srp-modules-23.04 (srp)...
      Installing srp-modules-23.04...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/srp-modules_23.04-OFED.23.04.0.5.3.1.kver.5.10.110_arm64.deb'
      Building DEB for mlnx-nvme-modules-23.04 (mlnx-nvme)...
      Installing mlnx-nvme-modules-23.04...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-nvme-modules_23.04-OFED.23.04.0.5.3.1.kver.5.10.110_arm64.deb'
      Building DEB for rdma-core-2304mlnx44 (rdma-core)...
      Installing rdma-core-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/rdma-core_2304mlnx44-1.2304113_arm64.deb'
      Installing libibverbs1-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibverbs1_2304mlnx44-1.2304113_arm64.deb'
      Installing ibverbs-utils-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibverbs-utils_2304mlnx44-1.2304113_arm64.deb'
      Installing ibverbs-providers-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibverbs-providers_2304mlnx44-1.2304113_arm64.deb'
      Installing libibverbs-dev-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibverbs-dev_2304mlnx44-1.2304113_arm64.deb'
      Installing libibverbs1-dbg-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibverbs1-dbg_2304mlnx44-1.2304113_arm64.deb'
      Installing libibumad3-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibumad3_2304mlnx44-1.2304113_arm64.deb'
      Installing libibumad-dev-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibumad-dev_2304mlnx44-1.2304113_arm64.deb'
      Installing ibacm-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibacm_2304mlnx44-1.2304113_arm64.deb'
      Installing librdmacm1-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/librdmacm1_2304mlnx44-1.2304113_arm64.deb'
      Installing rdmacm-utils-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/rdmacm-utils_2304mlnx44-1.2304113_arm64.deb'
      Installing librdmacm-dev-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/librdmacm-dev_2304mlnx44-1.2304113_arm64.deb'
      Building DEB for mstflint-4.16.1 (mstflint)...
      Installing mstflint-4.16.1...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mstflint_4.16.1-2.2304053_arm64.deb'
      Installing libibmad5-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibmad5_2304mlnx44-1.2304113_arm64.deb'
      Installing libibmad-dev-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibmad-dev_2304mlnx44-1.2304113_arm64.deb'
      Installing libibnetdisc5-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/libibnetdisc5_2304mlnx44-1.2304113_arm64.deb'
      Installing infiniband-diags-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/infiniband-diags_2304mlnx44-1.2304113_arm64.deb'
      Building DEB for kernel-mft-modules-4.24.0 (kernel-mft)...
      Installing kernel-mft-modules-4.24.0...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/kernel-mft-modules_4.24.0-72.kver.5.10.110_all.deb'
      Building DEB for perftest-23.04.0 (perftest)...
      Installing perftest-23.04.0...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/perftest_23.04.0-0.23.g63e250f.2304053_arm64.deb'
      Building DEB for ibsim-0.12 (ibsim)...
      Installing ibsim-0.12...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibsim_0.12-1.2304053_arm64.deb'
      Installing ibsim-doc-0.12...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibsim-doc_0.12-1.2304053_all.deb'
      Building DEB for ucx-1.15.0 (ucx)...
      Installing ucx-1.15.0...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ucx_1.15.0-1.2304053_arm64.deb'
      Building DEB for openmpi-4.1.5rc2 (openmpi)...
      Running  mellanox_autodetect='yes' /usr/bin/dpkg-buildpackage -us -uc
      Installing openmpi-4.1.5rc2...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/openmpi_4.1.5rc2-1.2304053_all.deb'
      Building DEB for mpitests-3.2.20 (mpitests)...
      Installing mpitests-3.2.20...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mpitests_3.2.20-de56b6b.2304053_arm64.deb'
      Building DEB for knem-modules-1.1.4.90mlnx2 (knem)...
      Installing knem-modules-1.1.4.90mlnx2...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/knem-modules_1.1.4.90mlnx2-OFED.23.04.0.5.2.1.kver.5.10.110_arm64.deb'
      Installing srptools-2304mlnx44...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/srptools_2304mlnx44-1.2304113_arm64.deb'
      Building DEB for mlnx-ethtool-6.0 (mlnx-ethtool)...
      Installing mlnx-ethtool-6.0...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-ethtool_6.0-1.2304053_arm64.deb'
      Building DEB for mlnx-iproute2-6.2.0 (mlnx-iproute2)...
      Installing mlnx-iproute2-6.2.0...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/mlnx-iproute2_6.2.0-1.2304053_arm64.deb'
      Building DEB for rshim-2.0.6 (rshim)...
      Installing rshim-2.0.6...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/rshim_2.0.6-19.g0873acd.2304113_arm64.deb'
      Building DEB for ibarr-0.1.3 (ibarr)...
      Installing ibarr-0.1.3...
      Running /usr/bin/dpkg -i --force-confmiss '/home/coolpi/Downloads/MLNX_OFED_LINUX-23.04-1.1.3.0-ubuntu22.04-aarch64/src/MLNX_OFED_SRC-23.04-1.1.3.0/DEBS/ubuntu22.04/aarch64/ibarr_0.1.3-1.2304053_arm64.deb'
      Device (0001:11:00.0):
      	0001:11:00.0 Ethernet controller: Mellanox Technologies MT27710 Family [ConnectX-4 Lx]
      	Link Width: x2 ( WARNING - device supports x8 )
      	PCI Link Speed: 2.5GT/s
      Device (0001:11:00.1):
      	0001:11:00.1 Ethernet controller: Mellanox Technologies MT27710 Family [ConnectX-4 Lx]
      Installation passed successfully
        Jachyn @jack_admin
        [11810.222046] rockchip-vop2 fdd90000.vop: pd0 on
        [11936.108867] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11936.108876] rockchip-vop2 fdd90000.vop: pd0 off
        [11936.358696] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11936.358704] rockchip-vop2 fdd90000.vop: pd0 on
        [11936.611757] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11936.611762] rockchip-vop2 fdd90000.vop: pd0 off
        [11936.743419] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11936.743427] rockchip-vop2 fdd90000.vop: pd0 on
        [11936.810102] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11936.810110] rockchip-vop2 fdd90000.vop: pd0 off
        [11936.826712] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11936.826721] rockchip-vop2 fdd90000.vop: pd0 on
        [11936.876678] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11936.876687] rockchip-vop2 fdd90000.vop: pd0 off
        [11936.909930] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11936.909938] rockchip-vop2 fdd90000.vop: pd0 on
        [11936.927166] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11936.927174] rockchip-vop2 fdd90000.vop: pd0 off
        [11936.943234] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11936.943244] rockchip-vop2 fdd90000.vop: pd0 on
        [11936.960300] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11936.960307] rockchip-vop2 fdd90000.vop: pd0 off
        [11936.974299] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11936.974307] rockchip-vop2 fdd90000.vop: pd0 on
        [11936.994271] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11936.994279] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.007777] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.007786] rockchip-vop2 fdd90000.vop: pd0 on
        [11937.026685] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11937.026694] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.041018] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.041025] rockchip-vop2 fdd90000.vop: pd0 on
        [11937.060333] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11937.060346] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.208100] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.208108] rockchip-vop2 fdd90000.vop: pd0 on
        [11937.243441] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11937.243450] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.276830] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.276838] rockchip-vop2 fdd90000.vop: pd0 on
        [11937.376144] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11937.376152] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.390939] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.390948] rockchip-vop2 fdd90000.vop: pd0 on
        [11937.408707] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11937.408715] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.424696] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.424703] rockchip-vop2 fdd90000.vop: pd0 on
        [11937.441800] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11937.441809] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.457559] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.457567] rockchip-vop2 fdd90000.vop: pd0 on
        [11937.476665] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11937.476673] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.494117] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.494125] rockchip-vop2 fdd90000.vop: pd0 on
        [11937.527350] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11937.527358] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.543463] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.543472] rockchip-vop2 fdd90000.vop: pd0 on
        [11937.677395] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11937.677402] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.693754] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.693778] rockchip-vop2 fdd90000.vop: pd0 on
        [11937.827447] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11937.827455] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.843330] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.843338] rockchip-vop2 fdd90000.vop: pd0 on
        [11937.859775] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11937.859783] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.876886] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.876894] rockchip-vop2 fdd90000.vop: pd0 on
        [11937.977322] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [11937.977330] rockchip-vop2 fdd90000.vop: pd0 off
        [11937.993229] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [11937.993237] rockchip-vop2 fdd90000.vop: pd0 on
        [12026.742752] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [12026.742761] rockchip-vop2 fdd90000.vop: pd0 off
        [12028.675768] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [12028.675777] rockchip-vop2 fdd90000.vop: pd0 on
        [12038.110980] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [12038.110991] rockchip-vop2 fdd90000.vop: pd0 off
        [12042.042122] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [12042.042131] rockchip-vop2 fdd90000.vop: pd0 on
        [12059.577168] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [12059.577176] rockchip-vop2 fdd90000.vop: pd0 off
        [12097.108956] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [12097.108964] rockchip-vop2 fdd90000.vop: pd0 on
        [12112.377853] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [12112.377862] rockchip-vop2 fdd90000.vop: pd0 off
        [12113.609157] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [12113.609166] rockchip-vop2 fdd90000.vop: pd0 on
        [12113.743643] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [12113.743651] rockchip-vop2 fdd90000.vop: pd0 off
        [12115.227092] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [12115.227099] rockchip-vop2 fdd90000.vop: pd0 on
        [12115.243558] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [12115.243567] rockchip-vop2 fdd90000.vop: pd0 off
        [12123.609235] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [12123.609244] rockchip-vop2 fdd90000.vop: pd0 on
        [12138.310541] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [12138.310549] rockchip-vop2 fdd90000.vop: pd0 off
        [12138.461714] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [12138.461723] rockchip-vop2 fdd90000.vop: pd0 on
        [12177.442599] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [12177.442612] rockchip-vop2 fdd90000.vop: pd0 off
        [12177.459270] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [12177.459282] rockchip-vop2 fdd90000.vop: pd0 on
        [12214.938648] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [12214.938655] rockchip-vop2 fdd90000.vop: pd0 off
        [12214.955385] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [12214.955393] rockchip-vop2 fdd90000.vop: pd0 on
        [12307.991337] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [12307.991341] rockchip-vop2 fdd90000.vop: pd0 off
        [12310.607684] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [12310.607688] rockchip-vop2 fdd90000.vop: pd0 on
        [12430.810610] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [12430.810618] rockchip-vop2 fdd90000.vop: pd0 off
        [12449.474330] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [12449.474333] rockchip-vop2 fdd90000.vop: pd0 on
        [12827.407348] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 512 (unused: 4608)
        [12830.044346] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 512 (unused: 2560)
        [12832.345678] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 1024 (unused: 5120)
        [12834.277161] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 1024 (unused: 3072)
        [12839.567026] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 2048 (unused: 4608)
        [12946.121325] mali fb000000.gpu: Tiler heap reclaim scan freed pages: 1536 (unused: 3584)
        [12973.576452] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [12973.576460] rockchip-vop2 fdd90000.vop: pd0 off
        [12979.624709] rockchip-vop2 fdd90000.vop: pd0 get ref_count:0
        [12979.624713] rockchip-vop2 fdd90000.vop: pd0 on
        [12991.331086] mlx5_core: version magic '5.10.110 SMP preempt mod_unload aarch64' should be '5.10.110 SMP mod_unload aarch64'
        [13019.261815] rockchip-vop2 fdd90000.vop: pd0 put ref_count:1
        [13019.261823] rockchip-vop2 fdd90000.vop: pd0 off
        dmseg的结果如上
          jack_admin @Jachyn
          @Jachyn
          1. modinfo mlx5相关的ko驱动文件
          2. 内核更改配置为抢占模式,编译替换
            Jachyn @jack_admin
            [ 8935.079458] mlx5_core: Unknown symbol pci_num_vf (err -2)
            [ 8935.079472] mlx5_core: Unknown symbol pci_sriov_get_totalvfs (err -2)
            [ 8935.079526] mlx5_core: Unknown symbol net_dim (err -2)
            [ 8935.079536] mlx5_core: Unknown symbol numa_node (err -2)
            [ 8935.079650] mlx5_core: Unknown symbol net_dim_get_rx_moderation (err -2)
            [ 8935.079667] mlx5_core: Unknown symbol net_dim_get_def_tx_moderation (err -2)
            [ 8935.079679] mlx5_core: Unknown symbol pci_disable_sriov (err -2)
            [ 8935.079686] mlx5_core: Unknown symbol net_dim_get_def_rx_moderation (err -2)
            [ 8935.079687] mlx5_core: Unknown symbol net_dim_get_tx_moderation (err -2)
            [ 8935.079711] mlx5_core: Unknown symbol pci_enable_sriov (err -2)
            [ 8935.079715] mlx5_core: Unknown symbol elfcorehdr_addr (err -2)
            [ 8935.079725] mlx5_core: Unknown symbol alloc_pages_current (err -2)
            这次不报抢占的错误了 但是有这些
            J J 2 Replies Last reply Reply Quote 0
              Jachyn @Jachyn
              @Jachyn
              root@coolpi:/home/coolpi/Downloads/mlnx-en-5.9-0.5.6.0-ubuntu22.04-aarch64/mlnx-en-5.9-0.5.6.0-ubuntu22.04-aarch64# ./mlnx_add_kernel_support.sh -m ./
              Note: This program will create mlnx-en TGZ for ubuntu22.04 under /tmp directory.
              Do you want to continue?[y/N]:y
              See log file /tmp/mlnx_iso.834968_logs/mlnx_ofed_iso.834968.log
              Checking if all needed packages are installed...
              Building mlnx-en DEBS . Please wait...
              ERROR: Failed executing "MLNX_EN_SRC-5.9-0.5.6.0/install.pl --tmpdir /tmp/mlnx_iso.834968_logs --eth-only --kernel 5.10.110 --kernel-sources /lib/modules/5.10.110/build/ --builddir /tmp/mlnx_iso.834968 --without-dkms --build-only"
              ERROR: See /tmp/mlnx_iso.834968_logs/mlnx_ofed_iso.834968.log
                jack_admin @Jachyn
                @Jachyn 内核配置增加CONFIG_PCI_IOV,还有其他的根据相应的symbol查找。
                另外发现内核带有一个版本的驱动,你可以试下配置编译试试
                drivers/net/ethernet/mellanox/
                ├── Kconfig
                ├── Makefile
                ├── mlx4
                ├── mlx5
                ├── mlxfw
                └── mlxsw
                4 directories, 2 files
                  Jachyn @jack_admin
                  @jack_admin 这个内核我是从其他网站下的 站内的内核编译不通过
                    jack_admin @Jachyn
                    @Jachyn 需要用我们提供的内核,编译不过,找方法解决
                      Jachyn @jack_admin
                      CC      drivers/mtd/spi-nor/issi.o
                      CC      drivers/mtd/spi-nor/macronix.o
                      CC      drivers/scsi/scsi_sysfs.o
                      CC      drivers/mtd/spi-nor/micron-st.o
                      CC      drivers/mtd/spi-nor/puya.o
                      CC      drivers/mtd/spi-nor/spansion.o
                      CC      drivers/mtd/spi-nor/sst.o
                      CC      drivers/mtd/spi-nor/winbond.o
                      CC      drivers/mtd/spi-nor/xilinx.o
                      CC      drivers/mtd/spi-nor/xmc.o
                      CC      drivers/mtd/spi-nor/xtx.o
                      AR      drivers/mtd/spi-nor/built-in.a
                      AR      drivers/mtd/built-in.a
                      AR      drivers/scsi/built-in.a
                      make: *** [Makefile:1917: drivers] Error 2
                        jack_admin @Jachyn
                        @Jachyn 完整log,不要猜哈
                        • 2 / 2
