    系统备份异常
    6 Posts 3 Posters 815 Views
      新刷的0613的系统
      然后用U盘备份
      开机后就出现内核崩溃
      不接备份U盘 能正常进系统
      Connecting to COM4...
      Connected.
      ¿ÿ񁀿ÿÿDDR V1.09 a930779e06 typ 22/11/21-17:50:56
      LPDDR4X, 2112MHz
      channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
      channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
      channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
      channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
      Manufacturer ID:0xff
      CH0 RX Vref:30.7%, TX Vref:21.8%,21.8%
      CH1 RX Vref:30.7%, TX Vref:21.8%,21.8%
      CH2 RX Vref:28.7%, TX Vref:21.8%,21.8%
      CH3 RX Vref:29.7%, TX Vref:22.8%,20.8%
      change to F1: 528MHz
      change to F2: 1068MHz
      change to F3: 1560MHz
      change to F0: 2112MHz
      INFO:    Preloader serial: 2
      NOTICE:  BL31: v2.3():v2.3-557-g9609b9c19:derrick.huang
      NOTICE:  BL31: Built : 14:29:57, Mar  8 2023
      INFO:    spec: 0x13
      INFO:    ext 32k is not valid
      INFO:    ddr: stride-en 4CH
      INFO:    GICv3 without legacy support detected.
      INFO:    ARM GICv3 driver initialized in EL3
      INFO:    valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
      INFO:    system boots from cpu-hwid-0
      INFO:    idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
      INFO:    dfs DDR fsp_params[0].freq_mhz= 2112MHz
      INFO:    dfs DDR fsp_params[1].freq_mhz= 528MHz
      INFO:    dfs DDR fsp_params[2].freq_mhz= 1068MHz
      INFO:    dfs DDR fsp_params[3].freq_mhz= 1560MHz
      INFO:    BL31: Initialising Exception Handling Framework
      INFO:    BL31: Initializing runtime services
      INFO:    BL31: Initializing BL32
      I/TC:
      I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022年 09月 20日 星期二 09:41:09 CST aarch64
      INFO:    BL31: Preparing for EL3 exit to normal world
      INFO:    Entry point address = 0x200000
      INFO:    SPSR = 0x3c9
      COOLPI LOADER BY YANYI(Jun 06 2023)
      DRAM:  8 GiB
      FAT: Misaligned buffer address (00000000ebc9e610)
      0 2 1 3 6 8 7 9 Monitor has basic audio support
      hdmi@fde80000:  detailed mode clock 148500 kHz, flags[5]
          H: 1920 2008 2052 2200
          V: 1080 1084 1089 1125
      bus_format: 100a
      VP0 set crtc_clock to 1485KHz
      VOP VP0 enable Esmart0[1920x1080->1920x1080@0x0] fmt[1] addr[0xee4ef000]
      CEA mode used vic=16
      mtmdsclock:148500000
      dw hdmi qp use tmds mode
      boot mode: None
      Bus usb@fc000000: usb maximum-speed not found
      trsv ln0 mon rx cdr lock timeout
      Register 2000140 NbrPorts 2
      Bus usb@fcd00000: usb maximum-speed not found
      scanning bus usb@fc000000 for devices... 1 USB Device(s) found
      scanning bus usb@fc880000 for devices... 2 USB Device(s) found
      scanning bus usb@fcd00000 for devices... 1 USB Device(s) found
             scanning usb for storage devices... 1 Storage Device(s) found
      Device 0: Vendor: Generic  Rev: 8.07 Prod: Flash Disk
                  Type: Removable Hard Disk
                  Capacity: 30000.0 MB = 29.2 GB (61440000 x 512)
      Scanning usb 0:1...
      274 bytes read in 35 ms (6.8 KiB/s)
      1:	Linux coolpi
      8202961 bytes read in 796 ms (9.8 MiB/s)
      37706240 bytes read in 3647 ms (9.9 MiB/s)
      append: root=LABEL=writable rw rootfstype=ext4 console=tty0 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:96:39:8b:af:40:ae
      Retrieving file: /rk3588s-cp4.dtb
      reading /rk3588s-cp4.dtb
      141838 bytes read in 46 ms (2.9 MiB/s)
         Loading Ramdisk to eb201000, end eb9d3ad1 ... OK
         Loading Device Tree to 00000000eb1db000, end 00000000eb200a0d ... OK
      FAT: Misaligned buffer address (00000000ebcb6950)
      I/TC: Secondary CPU 3 switching to normal world boo
      就卡在这里不动了
      显示器上面是内核崩溃一样的信息打印
        这个备份U盘之前备份过之前旧的系统 可以备份 可以还原 就这个不行
          @jugg 哪个板子?看log是4b u盘
            是4B 用U盘备份
            U盘的内容我没动过 备份几次之后就这样了
            把U盘重新刷了 又能备份了
              这里最近的就是0306的
              现在0613的备份 能不能用这个来还原
                @jugg 看iso名称,install是安装系统用的。备份使用backup iso
