    cool pi 4b 3D 打印外壳 base
    6 Posts 3 Posters 985 Views
      bg8wj
      cool pi 4b 3D 打印外壳 安装基板 STL
      安装螺丝2.5mm 基板接耳开孔为2.8mm 可以使用M3螺丝固定。
      解决 cool pi 外壳 DP输出 与raspberry Pi 4b mini HDMI尺寸问题。
      J B 2 Replies Last reply Reply Quote 1
        jack_admin @bg8wj
        @bg8wj
        在线查看了模型,长这样的
          bg8wj @jack_admin
          @jack_admin 还有待完善 pwr key 留空没有处理好。
            bg8wj @bg8wj
            coolpi 基板带接耳.stl
            装机效果
              retroman
              Why not use all the cases for raspberry pi 4 out there with a little modification for the minidp port? That's what I did and it is much better quality than 3D printing this one. Isn't that one of the points of making the Cool Pi 4B in the form of Raspberry Pi 4 is to use as much Raspberry Pi 4 assesscories as possible? But OK. Question for Cool Pi: What's the point of the miniDp port? Why not make 2 micro-hdmi ports like Raspberry Pi 4?
              B 1 Reply Last reply Reply Quote -1
                bg8wj @retroman
                @retroman Because the pi 4b box has no power key location, direct use will cause pwr key is stuck. In addition, the size of the DP output port is larger than Pi 4b, and the size of the metal radiator of PI4b is too far from the DP interface. 3D printing is the only option before the surrounding accessories of the cool pi come out.
                • 大法师大 大法师 moved this topic from Hardware on
