    Can the Raspberry Display using MIPI DSI work with COOL PI?
    8 Posts 5 Posters 1.6k Views
    • F
      farukbak
      I have just came on board cool pi knowing all the advantages. Can someone please assist if coolpi's MIPI DSI can work with Raspberry LCD which is using MIPI DSI..?
      • J jack_admin moved this topic from Ubuntu on
        jack_admin @farukbak
        @farukbak which one LCD model you have? please send a reference link. The model mipi dsi is okay. https://www.waveshare.net/wiki/5inch_DSI_LCD_(B)
        F 1 Reply Last reply Reply Quote 0
        • F
          farukbak @jack_admin
          @jack_admin Hi there. Im using LCD from this place. https://www.raspberrypi.com/documentation/accessories/display.html#:~:text=The Raspberry Pi Touch Display,(this requires software support).
          Previously i was using raspberry pi 4B, but Im changing to coolpi 4. So, need some advice, if I use the same interface cable MIPI DSI on coolpi 4, it does not work. But it works on a raspberry pi 4B board. Can please advice? Thank you.
            大法师 @farukbak
            @farukbak take a try with the latest kernel image from source code. and log out the message "dmesg | grep ft5406"
            • F
              farukbak @大法师
              @大法师 Hi, sure. I will follow your advice and give it a try. Thank you.
                zensation
                dsi does not work with this unit. caution before you buy.
                  jack_admin @zensation
                  @zensation
                  DSI driver with 'https://www.waveshare.net/wiki/5inch_DSI_LCD_(B)' worked fine. The other LCD model kernel driver need to be ported.
                    retroman
                    Does Cool Pi 4B support parallel RGB like the Raspberry Pi 4b? I would love to put Cool Pi 4B board in the PiBoy DMG instead of the Raspberry Pi 4B.
                    https://experimentalpi.com/PiBoy-DMG--Kit_p_18.html
